Текущее время: Вт окт 06, 2026 22:13
 Заголовок сообщения: DES 3528 баг с qinq в 1.03.B009
СообщениеДобавлено: Чт фев 26, 2009 12:25
Стенд: DES 3528, в 1 порту маршрутизатор cisco 1841, в 23 компьютер. Настройки коммутатора
Command: show switch
Device Type : DES-3528 Fast Ethernet Switch
MAC Address : 00-21-91-25-F1-C0
IP Address : 10.100.100.8 (Manual)
VLAN Name : mgmt
Subnet Mask : 255.255.255.224
Default Gateway : 10.100.100.30
Boot PROM Version : Build 1.00.B007
Firmware Version : Build 1.03.B009
Hardware Version : A1
Serial Number : P1UM187000192
System Name : --test--
System Location :
System Contact :
Spanning Tree : Disabled
GVRP : Disabled
IGMP Snooping : Disabled
MLD Snooping : Disabled
TELNET : Enabled (TCP 23)
WEB : Disabled
SNMP : Enabled
SSL Status : Disabled
SSH Status : Disabled
802.1x : Disabled
Jumbo Frame : On
Clipaging : Enabled
MAC Notification : Disabled
Port Mirror : Enabled
SNTP : Enabled
HOL Prevention State : Enabled
Syslog Global State : Disabled
Single IP Management : Disabled
Dual Image : Supported
Password Encryption Status : Disabled
--test--:3#sh vlan
Command: show vlan
VID : 1 VLAN Name : default
VLAN Type : Static Advertisement : Enabled
Member Ports :
Static Ports :
Current Tagged Ports :
Current Untagged Ports:
Static Tagged Ports :
Static Untagged Ports :
Forbidden Ports :
VID : 20 VLAN Name : green
VLAN Type : Static Advertisement : Disabled
Member Ports : 1,23
Static Ports : 1,23
Current Tagged Ports : 1
Current Untagged Ports: 23
Static Tagged Ports : 1
Static Untagged Ports : 23
Forbidden Ports :
VID : 100 VLAN Name : mgmt
Member Ports : 28
Static Ports : 28
Current Untagged Ports: 28
Static Untagged Ports : 28
Forbidden Ports :
Total Entries: 3
настройки маршрутизатора
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.0.1 255.255.255.0
no cdp enable
настройки хоста
eth1 Link encap:Ethernet HWaddr 00:10:EE:89:24:07
inet addr:192.168.0.10 Bcast:192.168.0.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:58894 errors:0 dropped:0 overruns:0 frame:0
TX packets:52761 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:5498020 (5.2 MiB) TX bytes:26471975 (25.2 MiB)
Interrupt:217 Base address:0xa000
Суть проблемы в том, что после применения команды
enable qinq даже без создания каких либо правил трансляций связь между маршрутизатором и хостом обрывается.
Такое впечатление, что коммутатор изымает untaged порт 23 из влана.
 Заголовок сообщения: Re: DES 3528 баг с qinq в 1.03.B009
СообщениеДобавлено: Чт фев 26, 2009 14:07
А для чего Вы используете Double VLAN? Судя по настройкам оконечного оборудования Вам нужно использовать стандартный VLAN 802.1Q.
Бигаров Руслан.
СообщениеДобавлено: Чт фев 26, 2009 14:10
Настройки конечного оборудования сделаны из расчета прозрачно показать суть проблемы.
СообщениеДобавлено: Чт фев 26, 2009 14:17
А я не вижу проблемы. Вам стоит почитать информацию по технолигии Double VLAN, хотя бы в наших презентациях.
Бигаров Руслан.
СообщениеДобавлено: Чт фев 26, 2009 16:19
Позволю себе заметить, что имел честь работы с qinq на оборудование других вендоров (cisco, huawei, qtech). Если я в предыдущих постах не смог донести суть проблемы то прошу прошения, попробую сделать это еще раз. Итак фича qinq включена на свиче, на для тестового влана в ней нет необходимости, в нем все просто: есть untagged порт (23 в конфигурации) и есть tagged порт 1. По идее вашей реализации qinq(который включается глобально сразу на всех портах) в случае если оба порта являются NNI схема должна работать без добавления/изъятия какого либо SP-VLAN. Однако что-то происходит и пакеты в untagged порт не ходят.
