Текущее время: Чт окт 01, 2026 00:50
 Заголовок сообщения: DIR-655 и pptp
СообщениеДобавлено: Ср фев 18, 2009 21:57
DIR-655 не хочет соединяться с интернет сервером провайдера через соединение Russia PPTP (и просто PPTP тоже).
Соединение с сервером провайдера через локальную сеть со статическим IP-адресом (192.168.9.2). Между сервером и d-link есть роутер 192.168.9.254
Настройки d-link:
My Internet Connection is :   Russia PPTP (Dual access)
Address Mode : Static IP
PPTP IP Address : 192.168.9.2
PPTP Subnet Mask :255.255.255.0
PPTP Gateway IP Address :192.168.9.254
PPTP Server IP or Name  :192.168.100.201
Username : username
Password : my_password
Verify Password : my_password
Reconnect Mode : On demand
Maximum Idle Time : 0
Primary DNS Server : 212.3.133.6
Secondary DNS Server : 217.150.34.129
MTU : 1400
Логи на d-link:
[INFO]   Wed Feb 18 20:01:36 2009   PPP network down
[INFO]   Wed Feb 18 20:01:36 2009   PPTP tunnel ID 0x90D3 has been closed
[INFO]   Wed Feb 18 20:01:36 2009   MSCHAP authentication successful.
[INFO]   Wed Feb 18 20:01:36 2009   Blocked incoming UDP packet from 192.168.10.42:27005 to
192.168.9.2:27015
[INFO]   Wed Feb 18 20:01:36 2009   MSCHAP authentication details were sent to authenticator.
[INFO]   Wed Feb 18 20:01:36 2009   MSCHAP authentication challenge received from peer.
[INFO]   Wed Feb 18 20:01:36 2009   LCP sets local options: ACCM: 00000000, ACFC: 1, PFC: 0, MRU:
1462
[INFO]   Wed Feb 18 20:01:36 2009   LCP sets remote auth: C223
[INFO]   Wed Feb 18 20:01:36 2009   LCP sets remote options: ACCM: 00000000, ACFC: 1, PFC: 1, MRU:
1460
[INFO]   Wed Feb 18 20:01:36 2009   PPTP connected to server "local" with ID 0x90D3
[INFO]   Wed Feb 18 20:01:36 2009   The PPTP transmit window is 200
[INFO]   Wed Feb 18 20:01:36 2009   Attempting to establish a PPTP connection.
Логи у провайдера:
Feb 18 19:55:43 dlsinet-ru pppd[13651]: User login <user>.
Feb 18 19:55:43 dlsinet-ru pppd[13651]: MPPE required but peer negotiation failed
Feb 18 19:55:43 dlsinet-ru pppd[13651]: Connection terminated.
Feb 18 19:55:43 dlsinet-ru pppd[13651]: Connect time 0.1 minutes.
Feb 18 19:55:43 dlsinet-ru pppd[13651]: Sent 14 bytes, received 34 bytes.
Feb 18 19:55:43 dlsinet-ru pppd[13651]: Exit.
Для информации пример работоспособного на моем провайдере конфига для pptp в линукс.
-pap
+chap
noauth
nobsdcomp
nodeflate
require-mppe-128
persist
usepeerdns
Вопрос DIR-655 поддерживает mppe или нет и планируется ли его поддержка???
СообщениеДобавлено: Чт фев 19, 2009 11:59
Точно не поддерживается.
DI-524 (2.06Patch08RU) - Divo PPPoE
DIR-300 (1.05_b09) - OnLime IPoE
DIR-655 (1.37WW) (в запасе)
DIR-825 - OnLime IPoE
DIR-140L (1.02b02WW) + DIR-806A (2.5.22) + DES-1008A - OnLime IPoE
СообщениеДобавлено: Чт фев 19, 2009 18:46
MPPE на нем не поддерживается.
СообщениеДобавлено: Ср май 13, 2009 22:14
возможно ли активировать поддержку прошивкой???
Сейчас этот форум просматривают: Google [Bot] и гости: 135
