Текущее время: Сб июл 04, 2026 00:59
 Заголовок сообщения: WDS with AP на Dlink DWL-2100AP
СообщениеДобавлено: Вт фев 17, 2009 21:29
Послушав добрых людей взял 2 ТД DWL-2100AP для настройки в WDS+AP
и подружить их немогу...
1 ТД:
Firmware Version: v2.50eu
MAC Address: 00:19:5b:66:9b:d7
Ethernet
Get IP From:    Manual
IP Address:    192.168.1.50
Subnet Mask:    255.255.255.0
Gateway:   192.168.1.1
Wireless (802.11g)
SSID:   ross104
Channel:    6
Super G Mode:    Enabled
Rate:    Auto
Security Level:    WPA-PSK / Encryption Enabled
AP Status
CPU Utilization:   7
Memory Utilization:    64
Лог:
TUE FEB 17 20:09:27 2009 System --AP warm start with f/w version: v2.50e
u
TUE FEB 17 20:09:35 2009 Wireless --WLAN1 WDS with AP (P2MP) ready
TUE FEB 17 20:09:38 2009 System --Web login success from 192.168.1.2
TUE FEB 17 20:09:43 2009 Wireless --WDS AP connected: wlan 1 11G AP 00:21:
91:80:a0:89
TUE FEB 17 20:10:10 2009 Wireless --Association:11G STA 00:21:91:80:a0:89
associated with WLAN1 SSID = ross104
TUE FEB 17 20:10:14 2009 Wireless --Deauth: WLAN1 11G WDS port 00:21:91:80
:a0:89 reason code=1
TUE FEB 17 20:10:15 2009 Wireless --Association:11G STA 00:21:91:80:a0:89
2 ТД:
MAC Address: 00:21:91:80:a0:89
Ethernet
Get IP From:    Manual
IP Address:    192.168.1.51
Wireless (802.11g)
SSID:   ross104
Channel:    6
Rate:    Auto
AP Status
CPU Utilization:   4
Memory Utilization:    65
Лог:
TUE FEB 17 20:10:06 2009 System --AP warm start with f/w version: v2.50e
u
TUE FEB 17 20:10:09 2009 Wireless --WLAN1 WDS with AP (P2MP) ready
TUE FEB 17 20:10:09 2009 Wireless --WDS AP connected: wlan 1 11G AP 00:19:
5b:66:9b:d7
TUE FEB 17 20:10:16 2009 Wireless --Received Disassoc: WLAN 1 11G STA 00:1
9:5b:66:9b:d7
TUE FEB 17 20:10:16 2009 Wireless --Received Deauth: WLAN 1 11G STA 00:19:
5b:66:9b:d7 reason code=1
TUE FEB 17 20:12:33 2009 Notice --Ethernet AE1 LINK DOWN
TUE FEB 17 20:12:35 2009 Notice --Ethernet AE1 LINK UP
TUE FEB 17 20:12:37 2009 System --Web login success from 192.168.1.2
Что значат ошибки в логах: --Received Deauth: ..... reason code=1 и т.д.
Точки доступа стоят на столе рядом друг с другом :)
Скрины настроек:
СообщениеДобавлено: Вт фев 17, 2009 22:59
А зачем режим WDS with AP на обоих точках?
СообщениеДобавлено: Ср фев 18, 2009 00:04
Точки будут установлены на 1 и 2 этаже жилого дома.
Соответственно режим на обоих так чтоб покрытие было на 2 этажа и клиенты могли конектится с любой точки дома.
Если одну из них включить на WDS без AP то к ней клиент конектится не сможет - тобиш покрытие будет все равно 1 этаж чего можна добится 1-й ТД.
Хотя в WiFi сетях не силен и могу немного заблуждаться...
СообщениеДобавлено: Ср фев 18, 2009 08:30
Прошывка версии 2.30 патч02. У меня работает на УРА! 8)
СообщениеДобавлено: Ср фев 18, 2009 10:23
Помогите пожалуйста, может быть не в тему, но вроде то же вопрос по режиму WDS with AP.
Вопрос такой, сейчас имеются к примеру 5 точек DWL2100, все в режиме WDS with AP, я так понимаю это не правильно. Хочу настроить чтоб главная точка, которая имеет прямое Ethernet подключение в сетку имела режим AP, а остальные AP Client. Правильно ли я планирую???? Но вот почему то пробовал так сделать на двух точках, так и не соединились они =(
SSID - одинаковый
Канал передачи 6
Прошивка 2.50
Подскажите пожалуйста, что делаю не так?
СообщениеДобавлено: Ср фев 18, 2009 11:16
Перешил ТД на 2.30 Патч 02 и получил то же
ТД 1
Firmware Version: v2.30eu_patch02
Ethernet
Get IP From:    Manual
IP address:    192.168.0.50
Gateway:   192.168.0.1
Wireless (802.11g)
SSID:   ross104
Channel:    5
Super G Mode:    Disabled
Rate:    Auto
ТД 2
Ethernet
Get IP From:    Manual
IP address:    192.168.0.51
Wireless (802.11g)
SSID:   ross104
Channel:    5
Rate:    Auto
WiFi Settings
ТД 1
ТД 2
Логи:
ТД 1
WED FEB 18 09:59:56 2009   System   --AP cold start with f/w version: v2.30e
u_patch02
WED FEB 18 09:59:56 2009   Wireless   --WLAN1 WDS with AP (P2MP) ready
WED FEB 18 10:00:01 2009   Wireless   --WDS AP connected: wlan 1 11G AP 00:21:
91:80:a0:89
WED FEB 18 10:00:03 2009   System   --Web login success from 192.168.0.11
WED FEB 18 10:00:06 2009   Wireless   --Association:11G STA 00:21:91:80:a0:89
ТД 2
WED FEB 18 09:59:58 2009   System   --AP cold start with f/w version: v2.30e
u_patch02
WED FEB 18 09:59:58 2009   Wireless   --WLAN1 WDS with AP (P2MP) ready
WED FEB 18 09:59:58 2009   Wireless   --WDS AP connected: wlan 1 11G AP 00:19:
5b:66:9b:d7
WED FEB 18 09:59:58 2009   Wireless   --Received Disassoc: WLAN 1 11G STA 00:1
9:5b:66:9b:d7
WED FEB 18 09:59:58 2009   Wireless   --Received Deauth: WLAN 1 11G STA 00:19:
5b:66:9b:d7 reason code=7
WED FEB 18 10:07:49 2009      Last message repeated 78 times
WED FEB 18 10:07:49 2009   System   --Web login success from 192.168.0.11
Что значат:
reason code=7
-Received Disassoc:
--Received Deauth:
Как с ними боротся?
Опять же точки стоят на столе рядом друг с другом...
СообщениеДобавлено: Ср фев 18, 2009 11:32
2 Hunta
Можно как в WDS так и Точка-Клиент.
Если ВДС - то на центральной пропишите МАСи остальных ТД,а на крайних только центральную.
Если как Точка-клиент,то на основной настриваете имя сети шиврование,а на клиентах перед тем как сканировать список сетей укажите тот тип шифрования.который выставлен на основной и потом уже подключайтесь.
2 ross104
Точки после перепрошивки ресетили и перенастраивали?Такое ощущение что у одной из пары прошивка некорректно стоит....
СообщениеДобавлено: Ср фев 18, 2009 12:04
Сейчас попробую ресетнуть на заводские обе точки и настроить их заново...
СообщениеДобавлено: Ср фев 18, 2009 12:47
reason code = 7 - проверьте еще раз PassPhrase, где-то ошиблись с вводом (или языком),
и еще задайте CipherType не AUTO, а явно TKIP или AES.
СообщениеДобавлено: Ср фев 18, 2009 12:56
Ошибится немог так как вводил посредством Ctrl+C - Ctrl+V :)
Щас поколдую со сбросом на заводские и настройкой заново и отпишусь
СообщениеДобавлено: Ср фев 18, 2009 13:24
Sergey Filonenko писал(а):
2 Hunta
Если на основной и на клиенте стоит Open System, то они по идее должны подключаться, без шифрования?
И ещё вопрос, если на главной стоит режим WDS with AP, а на клиенте AP Client, клиент же должен соединиться с главной точкой?
СообщениеДобавлено: Ср фев 18, 2009 13:44
Да,должен без паролей,если open system,encryption - disable.
СообщениеДобавлено: Ср фев 18, 2009 14:10
1. Перешил
2. Ресетнул
3. Естроил Lan (адреса - одна на 50 другая 51)
4. Настроил Wireles На WDS+AP и все....
Не пингуются. к веб интерфейсу не достучатся...
СообщениеДобавлено: Ср фев 18, 2009 16:32
Одним словом перешил, ресетнул. Настроил
и на одной из точек опять:
WED FEB 18 15:25:16 2009   System   --AP cold start with f/w version: v2.30e
u_patch02
WED FEB 18 15:25:16 2009   Wireless   --WLAN1 WDS with AP (P2MP) ready
WED FEB 18 15:25:35 2009   System   --Web login success from 192.168.0.2
WED FEB 18 15:25:36 2009   Wireless   --WDS AP connected: wlan 1 11G AP 00:19:
5b:66:9b:d7
[b]WED FEB 18 15:25:40 2009   Wireless   --Received Disassoc: WLAN 1 11G STA 00:1
9:5b:66:9b:d7
WED FEB 18 15:25:40 2009   Wireless   --Received Deauth: WLAN 1 11G STA 00:19:
5b:66:9b:d7 reason code=1[/b]
Либо код 7 либо код 1
СообщениеДобавлено: Ср фев 18, 2009 16:33
u_patch02
5b:66:9b:d7
9:5b:66:9b:d7
Хотя самое интересное что вытянув из одной лан кабель она пингуется по WiFi...
Ответ от 192.168.0.51: число байт=32 время=112мс TTL=64
Ответ от 192.168.0.51: число байт=32 время=18мс TTL=64
Ответ от 192.168.0.51: число байт=32 время=44мс TTL=64
Ответ от 192.168.0.51: число байт=32 время=2мс TTL=64
