Текущее время: Вс окт 04, 2026 10:07
СообщениеДобавлено: Вт фев 10, 2009 10:24
есть такого типа конфиг:
config ipif System ipaddress 192.168.0.1/24
create vlan vlan1 tag 11
create vlan vlan2 tag 12
create vlan vlan3 tag 13
create vlan vlan4 tag 14
create vlan vlan5 tag 15
create vlan vlan6 tag 16
create vlan vlan7 tag 17
create vlan vlan8 tag 18
create vlan vlan9 tag 19
create vlan vlan10 tag 20
create vlan vlan11 tag 21
create vlan vlan12 tag 22
create vlan vlan13 tag 23
create vlan vlan14 tag 24
create vlan vlan15 tag 25
create vlan vlan16 tag 26
config vlan default delete 1-16
config vlan vlan1 add untagged 1
config vlan vlan2 add untagged 2
config vlan vlan3 add untagged 3
config vlan vlan4 add untagged 4
config vlan vlan5 add untagged 5
config vlan vlan6 add untagged 6
config vlan vlan7 add untagged 7
config vlan vlan8 add untagged 8
config vlan vlan9 add untagged 9
config vlan vlan10 add untagged 10
config vlan vlan11 add untagged 11
config vlan vlan12 add untagged 12
config vlan vlan13 add untagged 13
config vlan vlan14 add untagged 14
config vlan vlan15 add untagged 15
config vlan vlan16 add untagged 16
create ipif iface1 192.168.1.1/24 vlan1 state enable
create ipif iface2 192.168.2.1/24 vlan2 state enable
create ipif iface3 192.168.3.1/24 vlan3 state enable
create ipif iface4 192.168.4.1/24 vlan4 state enable
create ipif iface5 192.168.5.1/24 vlan5 state enable
create ipif iface6 192.168.6.1/24 vlan6 state enable
create ipif iface7 192.168.7.1/24 vlan7 state enable
create ipif iface8 192.168.8.1/24 vlan8 state enable
create ipif iface9 192.168.9.1/24 vlan9 state enable
create ipif iface10 192.168.10.1/24 vlan10 state enable
create ipif iface11 192.168.11.1/24 vlan11 state enable
create ipif iface12 192.168.12.1/24 vlan12 state enable
create ipif iface13 192.168.13.1/24 vlan13 state enable
create ipif iface14 192.168.14.1/24 vlan14 state enable
create ipif iface15 192.168.15.1/24 vlan15 state enable
create ipif iface16 192.168.16.1/24 vlan16 state enable
create iproute default 192.168.1.1
config dhcp_relay add ipif System 192.168.1.1
config dhcp_relay add ipif iface1 192.168.1.1
config dhcp_relay add ipif iface2 192.168.1.1
config dhcp_relay add ipif iface3 192.168.1.1
config dhcp_relay add ipif iface4 192.168.1.1
config dhcp_relay add ipif iface5 192.168.1.1
config dhcp_relay add ipif iface6 192.168.1.1
config dhcp_relay add ipif iface7 192.168.1.1
config dhcp_relay add ipif iface8 192.168.1.1
config dhcp_relay add ipif iface9 192.168.1.1
config dhcp_relay add ipif iface10 192.168.1.1
config dhcp_relay add ipif iface11 192.168.1.1
config dhcp_relay add ipif iface12 192.168.1.1
config dhcp_relay add ipif iface13 192.168.1.1
config dhcp_relay add ipif iface14 192.168.1.1
config dhcp_relay add ipif iface15 192.168.1.1
config dhcp_relay add ipif iface16 192.168.1.1
enable dhcp_relay
config dnsr primary nameserver 192.168.1.1
enable dnsr
save
Необходимо получить 6 вланов, допустим 1-6 подсети
при забросе этого конфига ничего не происходит....не могу понять в чем проблема ...помогите советом плиз...=(
СообщениеДобавлено: Вт фев 10, 2009 12:40
А что конкретно не так то?
LiveComm
СообщениеДобавлено: Вт фев 10, 2009 12:57
когда подключаю к любому порту
выдает только первую подсеть а остальные не видит ...
вот и у меня такой же вопрос - в чем проблема=)
СообщениеДобавлено: Вт фев 10, 2009 13:11
выдаёт кто? DHCP ?
тогда надо смотреть конфиг DHCP-сервера. Неправильно настроили. Свитч тут не причем.
LiveComm
СообщениеДобавлено: Вт фев 10, 2009 13:19
хмм... а как сделать раздачу вланов по портам?
СообщениеДобавлено: Вт фев 10, 2009 16:24
С помощью скрипта, так как смена VLAN-а на порту после авторизации реализована только в функционале 802.1x
Бигаров Руслан.
СообщениеДобавлено: Вт фев 10, 2009 16:39
просто на 3828 - это элементарно настроилось и никаких проблем
дхцп будет раздавать циска (автомат.)
а здесь нужно просто разделить поток на 5-7 виланов...
конфиг вроде как правильный...
а что за скрипт ?
СообщениеДобавлено: Вт фев 10, 2009 23:20
Перезвоните пожалуйста завтра в офис по телефону 744-00-99 или укажите Ваш телефон.
СообщениеДобавлено: Ср фев 11, 2009 11:03
8(4732)205-546 добавочный 777 Алексей
СообщениеДобавлено: Чт фев 12, 2009 15:38
Огромное спасибо Демину Ивану и Бигарову Руслану за техподдрежку...
к сожалению сегодня нет возможности опробовать конфиг, буду запускать роутер завтра с утра..
отпишусь по результатам
СообщениеДобавлено: Чт фев 12, 2009 20:02
Рад слышать! Ждём результатов!
СообщениеДобавлено: Пт фев 13, 2009 09:49
к сожалению проблема та же и осталась...дело не в прошивке =(
все таки с конефигом что-то не так,
поясню также - в кабелях проблемы тоже нет - на другом роутере они превосходно работают ....а вот на этом что то не хотят
СообщениеДобавлено: Пт фев 13, 2009 10:15
Попробуйте выставить режим 100 FD на этих портах.
СообщениеДобавлено: Пт фев 13, 2009 10:37
к сожалению пробовать только на выходных удастся
если не получится - тогда сброшу настройки и проверю по умолчанию..
СообщениеДобавлено: Пт фев 13, 2009 22:19
ОК. Ждём результатов!
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 132
