Текущее время: Вс июн 28, 2026 23:28
 Заголовок сообщения: DIR-300 Отваливается WLan
СообщениеДобавлено: Ср янв 14, 2009 11:33
Пропадает связь с роутером, подхожу выдергиваю WAN-кабель связь по wifi восстанавливается.
Лог с роутера:
Jan 14 10:21:56    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:5927, dst:212.2.136.246:80.
Jan 14 10:21:56    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:5909, dst:212.2.136.228:80.
Jan 14 10:21:56    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:5890, dst:212.2.136.210:80.
Jan 14 10:21:56    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:5915, dst:212.2.136.234:80.
Jan 14 10:21:39    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:5931, dst:212.2.136.250:80.
Jan 14 10:21:39    DROP: 001. Drop TCP Packet from WAN, src:212.79.80.89:5877, dst:212.2.136.197:80.
Jan 14 10:21:39    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:5484, dst:212.2.136.66:80.
Jan 14 10:21:39    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:5378, dst:212.2.135.214:80.
Jan 14 10:21:38    DROP: 001. Drop TCP Packet from WAN, src:212.79.80.89:5513, dst:212.2.136.95:80.
Jan 14 10:20:36    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:3865, dst:212.2.132.246:80.
Jan 14 10:20:19    DROP: 001. Drop TCP Packet from WAN, src:212.79.80.89:3848, dst:212.2.132.229:80.
Jan 14 10:20:18    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:3348, dst:212.2.131.251:80.
Jan 14 10:20:18    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:3296, dst:212.2.131.201:80.
Jan 14 10:20:13    DROP: 001. Drop TCP Packet from WAN, src:212.79.80.89:3285, dst:212.2.131.190:80.
Jan 14 10:20:13    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:3270, dst:212.2.131.175:80.
Jan 14 10:20:07    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:2997, dst:212.2.131.162:80.
Jan 14 10:20:07    DROP: 001. Drop TCP Packet from WAN, src:212.79.80.89:2842, dst:212.2.131.7:80.
Jan 14 10:20:07    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:2825, dst:212.2.130.244:80.
Jan 14 10:19:38    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:2256, dst:212.2.129.226:80.
Jan 14 10:19:38    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:2238, dst:212.2.129.208:80.
Jan 14 10:19:38    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:2220, dst:212.2.129.190:80.
Jan 14 10:19:31    DROP: 001. Drop TCP Packet from WAN, src:212.79.80.89:2201, dst:212.2.129.171:80.
Jan 14 10:19:20    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:1743, dst:212.2.128.225:80.
Jan 14 10:19:20    DROP: 001. Drop TCP Packet from WAN, src:212.79.80.89:1724, dst:212.2.128.206:80.
Jan 14 10:19:20    DROP: 001. Drop TCP Packet from WAN, src:212.79.80.89:1706, dst:212.2.128.188:80.
Jan 14 10:19:20    DROP: 001. Drop TCP Packet from WAN, src:212.79.80.89:1688, dst:212.2.128.170:80.
Jan 14 10:19:03    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:1391, dst:212.2.128.143:80.
Jan 14 10:19:03    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:1381, dst:212.2.128.133:80.
Jan 14 10:18:56    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:1363, dst:212.2.128.115:80.
Jan 14 10:18:56    DROP: 001. Drop TCP Packet from WAN, src:81.82.199.96:1343, dst:212.2.128.95:80.
Jan 14 10:18:47    DROP: 001. Drop TCP Packet from WAN, src:212.79.80.89:1296, dst:212.2.128.48:80.
ip роутера здесь вообще не присутствует. (212.2.29.159)
Что и зачем он блокирует и почему при этом отваливается WLan? и вообще как это исправить.
Версия текущего программного обеспечения : 1.05
Дата программного обеспечения : Fri 05 Dec 2008
+ русский интерфейс
СообщениеДобавлено: Ср янв 14, 2009 12:09
Выяснил при каких условиях это все происходит.
На втором ноутбуке (по вифи) брат играет в в игру, garena.com. Насколько я знаю это клиент для игры по интернету в варкрафт.
Порт клиента (1513 udp) я в настройках открыл, хотя он и не блокировался.
И еще. До DIR-300 (буквально 5 дней как купил) у меня был DI-524 и никаких блокировок не было и брат играл нормально.
Помогите решить проблему...
СообщениеДобавлено: Ср янв 14, 2009 12:58
Вот такой пинг когда подключен WAN
Ответ от 192.168.0.1: число байт=32 время=1337мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=1мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=567мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=67мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=504мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=127мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=166мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=253мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=1181мс TTL=64
Превышен интервал ожидания для запроса.
Ответ от 192.168.0.1: число байт=32 время=449мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=503мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=3892мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=599мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=321мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=630мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=1681мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=6мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=1766мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=8мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=1105мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=3мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=1372мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=337мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=2011мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=1742мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=2175мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=3522мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=1775мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=2819мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=2427мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=2625мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=1797мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=1997мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=3538мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=3059мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=3852мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=2062мс TTL=64
СообщениеДобавлено: Чт янв 15, 2009 23:11
У кого нибудь мысль по этому поводу есть?
СообщениеДобавлено: Пт янв 16, 2009 22:32
Было бы интересно услышать ответ
СообщениеДобавлено: Сб янв 24, 2009 11:46
Кто нибудь из тех поддержки может ответить на этот вопрос?
СообщениеДобавлено: Вс янв 25, 2009 13:49
Протянул через всю квартиру кабель - И ТА ЖЕ ИСТОРИЯ!!
Точно так же периодически пропадает связь с роутером!
Вы можете указать решение проблемы?
СообщениеДобавлено: Чт янв 29, 2009 11:34
UP
СообщениеДобавлено: Чт янв 29, 2009 11:56
Мы протестируем
СообщениеДобавлено: Чт янв 29, 2009 14:29
Отваливается не wlan. Проблема в другом но она действительно существует. Проблема будет устранена в следющей прошивке.
СообщениеДобавлено: Чт янв 29, 2009 23:29
Ответили :D
Пойду свечку поставлю, и буду ждать прошивку.
Спасибо!
Сейчас этот форум просматривают: Google [Bot] и гости: 51
