Текущее время: Пн июн 22, 2026 17:51
Начать новую тему Эта тема закрыта, Вы не можете редактировать и оставлять сообщения в ней.  [ Сообщений: 6 ]
 Заголовок сообщения: [SOLVED] DES-3526 Dhcp option 82
СообщениеДобавлено: Пн янв 26, 2009 06:44
Device Type       : DES-3526 Fast-Ethernet Switch
Combo Port Type   : 1000Base-T + 1000Base-T
MAC Address       : 00-1E-58-A9-14-81
IP Address        : 192.168.0.103 (Manual)
VLAN Name         : default
Subnet Mask       : 255.255.255.0
Default Gateway   : 0.0.0.0
Boot PROM Version : Build 5.00.009
Firmware Version  : Build 5.01.B52
Hardware Version  : A4G
# DHCP_RELAY
enable dhcp_relay
config dhcp_relay hops 4 time 0
config dhcp_relay option_82 state enable
config dhcp_relay option_82 check disable
config dhcp_relay option_82 policy replace
config dhcp_relay option_82 remote_id default
config dhcp_relay option_60 state disable
config dhcp_relay option_60 default mode drop
config dhcp_relay option_61 state disable
config dhcp_relay option_61 default drop
config dhcp_relay add ipif System 192.168.0.254
# DHCP_LOCAL_RELAY
disable dhcp_local_relay
Пытаюсь с 1-го порта (DHCP-сервер настроен на получение option 82) отправить dhcp-запрос. Вот так он выглядит:
No.     Time           Source                Destination           Protocol Info
      1 0.000000000    0.0.0.0               255.255.255.255       DHCP     DHCP Discover - Transaction ID 0xcdabd857
Frame 1 (342 bytes on wire, 342 bytes captured)
    Arrival Time: Jan  1, 2000 16:01:45.671269000
    [Time delta from previous captured frame: 0.000000000 seconds]
    [Time delta from previous displayed frame: 0.000000000 seconds]
    [Time since reference or first frame: 0.000000000 seconds]
    Frame Number: 1
    Frame Length: 342 bytes
    Capture Length: 342 bytes
    [Frame is marked: False]
    [Protocols in frame: eth:ip:udp:bootp]
    [Coloring Rule Name: UDP]
    [Coloring Rule String: udp]
Ethernet II, Src: Dell_5c:d9:2f (00:11:43:5c:d9:2f), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
    Destination: Broadcast (ff:ff:ff:ff:ff:ff)
        Address: Broadcast (ff:ff:ff:ff:ff:ff)
        .... ...1 .... .... .... .... = IG bit: Group address (multicast/broadcast)
        .... ..1. .... .... .... .... = LG bit: Locally administered address (this is NOT the factory default)
    Source: Dell_5c:d9:2f (00:11:43:5c:d9:2f)
        Address: Dell_5c:d9:2f (00:11:43:5c:d9:2f)
        .... ...0 .... .... .... .... = IG bit: Individual address (unicast)
        .... ..0. .... .... .... .... = LG bit: Globally unique address (factory default)
    Type: IP (0x0800)
Internet Protocol, Src: 0.0.0.0 (0.0.0.0), Dst: 255.255.255.255 (255.255.255.255)
    Version: 4
    Header length: 20 bytes
    Differentiated Services Field: 0x00 (DSCP 0x00: Default; ECN: 0x00)
        0000 00.. = Differentiated Services Codepoint: Default (0x00)
        .... ..0. = ECN-Capable Transport (ECT): 0
        .... ...0 = ECN-CE: 0
    Total Length: 328
    Identification: 0x033e (830)
    Flags: 0x00
        0... = Reserved bit: Not set
        .0.. = Don't fragment: Not set
        ..0. = More fragments: Not set
    Fragment offset: 0
    Time to live: 128
    Protocol: UDP (0x11)
    Header checksum: 0x3668 [correct]
        [Good: True]
        [Bad : False]
    Source: 0.0.0.0 (0.0.0.0)
    Destination: 255.255.255.255 (255.255.255.255)
User Datagram Protocol, Src Port: bootpc (68), Dst Port: bootps (67)
    Source port: bootpc (68)
    Destination port: bootps (67)
    Length: 308
    Checksum: 0xbd18 [correct]
        [Good Checksum: True]
        [Bad Checksum: False]
Bootstrap Protocol
    Message type: Boot Request (1)
    Hardware type: Ethernet
    Hardware address length: 6
    Hops: 0
    Transaction ID: 0xcdabd857
    Seconds elapsed: 3 (little endian bug?)
    Bootp flags: 0x8000 (Broadcast)
        1... .... .... .... = Broadcast flag: Broadcast
        .000 0000 0000 0000 = Reserved flags: 0x0000
    Client IP address: 0.0.0.0 (0.0.0.0)
    Your (client) IP address: 0.0.0.0 (0.0.0.0)
    Next server IP address: 0.0.0.0 (0.0.0.0)
    Relay agent IP address: 0.0.0.0 (0.0.0.0)
    Client MAC address: Dell_5c:d9:2f (00:11:43:5c:d9:2f)
    Server host name not given
    Boot file name not given
    Magic cookie: (OK)
    Option: (t=53,l=1) DHCP Message Type = DHCP Discover
        Option: (53) DHCP Message Type
        Length: 1
        Value: 01
    Option: (t=116,l=1) DHCP Auto-Configuration
        Option: (116) DHCP Auto-Configuration
        Length: 1
        Value: 01
    Option: (t=61,l=7) Client identifier
        Option: (61) Client identifier
        Length: 7
        Value: 010011435CD92F
    Option: (t=50,l=4) Requested IP Address = 169.254.23.80
        Option: (50) Requested IP Address
        Length: 4
        Value: A9FE1750
    Option: (t=12,l=5) Host Name = "paaa"
        Option: (12) Host Name
        Length: 5
        Value: 6C6573696B
    Option: (t=60,l=8) Vendor class identifier = "MSFT 5.0"
        Option: (60) Vendor class identifier
        Length: 8
        Value: 4D53465420352E30
    Option: (t=55,l=11) Parameter Request List
        Option: (55) Parameter Request List
        Length: 11
        Value: 010F03062C2E2F1F21F92B
        1 = Subnet Mask
        15 = Domain Name
        3 = Router
        6 = Domain Name Server
        44 = NetBIOS over TCP/IP Name Server
        46 = NetBIOS over TCP/IP Node Type
        47 = NetBIOS over TCP/IP Scope
        31 = Perform Router Discover
        33 = Static Route
        249 = Classless Static Route (Microsoft)
        43 = Vendor-Specific Information
    End Option
    Padding
Включал напрямую коммутатор и DHCP-сервер, такая же петрушка.
Соответственно IP-адрес не выдаёт DHCP. Где ошибка?
Последний раз редактировалось Inri Вт янв 27, 2009 07:16, всего редактировалось 1 раз.
СообщениеДобавлено: Пн янв 26, 2009 14:24
UP
СообщениеДобавлено: Пн янв 26, 2009 14:30
Запрос доходит до сервера?
СообщениеДобавлено: Пн янв 26, 2009 14:35
Да. Дамп сделан с помощью tcpdump. Relay agent подставляется 0.0.0.0, а должен быть ip коммутатора.
СообщениеДобавлено: Пн янв 26, 2009 17:55
Это же оригинальный Discover от клиента. Он и должен быть с source IP = 0.0.0.0. Ищите и другой пакет с нужными параметрами.
СообщениеДобавлено: Вт янв 27, 2009 07:15
Нашел причину. Проблему закрываю. Спасибо за ответ.
