Текущее время: Сб окт 03, 2026 18:22
 Заголовок сообщения: DFL-210 нужна помощь
СообщениеДобавлено: Сб дек 13, 2008 00:46
1. DFL-210, русский интерфейс.
Все предыдущие настройки скинул до заводских.
Обновил firmware до 2.20.03.08-8260
2. VPN-клиент
Interfaces > PPTP/L2TP Clients > Add PPTP/L2TP Client >
Name = Beeline
Tunnel Protocol = PPTP
Remote Endpoint = 10.0.0.1
Remote Network = all-nets
Username = dxxxxxxx@internet.beeline.ua
Password = *******
Confirm Password = *******
> Security >
None [V]
RC4 40 bit [ ]
RC4 56 bit [ ]
RC4 128 bit [ ]
OK
System > DNS >
Primary Server = wan_dns1
Secondary Server = None
Tertiary Server = None
OK
3.Адресная книжка
Objects > Address Book >
Add IP address >
Name = PPTP_CLI
IP Address = 10.0.0.1
OK
Add IP address >
Name = ISP_nets
IP Address = 10.0.0.0/8
OK
Add IP address >
Name = DHCP_netmask
IP Address = 255.255.255.0
OK
Add IP address >
Name = DHCP_pool
IP Address = 192.168.1.2-192.168.1.5
OK
Add IP address >
Name = user_1_ip
OK
Add IP address >
Name = user_2_ip
IP Address = 192.168.1.3
OK
Add IP address >
Name = user_3_ip
IP Address = 192.168.1.4
OK
Add IP address >
Name = dreambox_ip
IP Address = 192.168.1.5
OK
Add Ethernet dddress >
Name = user_1_mac
MAC Address = 04-4B-80-80-80-03
OK
Name = user_2_mac
MAC Address = 00-02-44-6E-A7-EЕ
OK
Name = user_3_mac
MAC Address = 00-13-8F-A6-AD-5А
OK
Name = dreambox_mac
MAC Address = 00-12-25-2E-7A-0Н
OK
4. DHCP
System > DHCP > DHCP Servers >
Add DHCP server >
Name = DHCP
Interface Filter = lan
IP Address Pool = DHCP_pool
Netmask = DHCP_netmask
> Options >
Default GW = lan_ip
DNS Primary = Beeline_dns1
DNS Secondary = Beeline_dns2
OK
5. Cтатичные адреса в LAN
System > DHCP > DHCP Servers > Static Hosts >
Add Static Host Entry >
Host = user_1_ip
Mac = user_1_mac
OK
Host = user_2_ip
Mac = user_2_mac
OK
Host = user_3_ip
Mac = user_3_mac
OK
Host = dreambox_ip
Mac = dreambox_mac
OK
6. IP-фильтры
Rules > IP Rules > IP Rule folder >
Name = lan_to_internet
OK
Rules > IP Rules > lan_to_internet > Add IP rule >
Name = drop_smb-all
Action = Drop
Service = smb-all
Source Interface = lan
Source Network = lannet
Destination Interface = Beeline
Destination Network = all-nets
OK
Name = allow_ping-outbound
Action = NAT
Service = ping-outbound
OK
Name = allow_standard
Action = NAT
Service = all_tcpudp
OK
Name = allow-dns
Action = NAT
Service = dns-all
OK
Rules > IP Rules > lan_to_wan >
Удалил все старые правила.
Записал новые:
Rules > IP Rules > lan_to_wan > Add IP rule >
Name = drop_smb-all
Action = Drop
Service = smb-all
Destination Interface = wan
Destination Network = ISP_nets
OK
Action = NAT
OK
Action = NAT
OK
7. Маршруты
Routing >Routing Tables > main > Add Route >
Interface = wan
Network = ISP_nets
Gateway = wan_gw
Metric = 100
OK
8. Пинг и трасы
http://dlink.ru/technical/faq_firewall_49.php
9. Порты (для торентов)
Objects > Services > Add TCP/UDP service >
Name = torrent_40000
Type = TCP/UDP
Source = 0-65535
Destination = 40000
SYN flood protection (SYN Relay) [V]
OK
Name = port_mapping
OK
Rules > IP Rules > port_mapping > Add IP rule >
Name = torrent_4000_forward
Action = SAT
Service = torrent_40000
Source Interface = any
Source Network = all-nets
Destination Interface = core
Destination Network = Beeline_ip
> SAT >
Translate the [V] Destination IP Address To: New IP Address = user_1_ip
OK
Name = torrent_40000_allow
Action = Allow
OK
торенты созданы для всех ip с разными портами, кроме дримбокса
10. Configuration > Save and Activate
Что не правильно? и почему получается так:
При подключении на прямую к компьютеру по ВПН без DFL-210
а при подключении через DFL
или что-то с DFL-210?
СообщениеДобавлено: Сб дек 13, 2008 20:29
Ну что есть специалисты или нет?
подскажите пожалуйста, что не так.
почему при подключении без DFL-210 скорость upload намного выше, чем при поключении через DFL-210. (при тестировании никакие программы не включены)
СообщениеДобавлено: Вс дек 14, 2008 06:22
А по какому принципу Вы измеряли скорость? Неужели этот идиотский спидтест.нет, который показывает цифры от балды, являлся основанием?? Мой Вам совет - тестируйте только на торрентах с большим кол-вом сидов, либо на гарантированном канале. Забудьте про бред под названием спидтест.нет Это головная боль всех провайдеров и производителей оборудования, потому что юзеры ориентируются на него, думая, что это правда. А там дохлый сервер генерит картинки.
СообщениеДобавлено: Вс дек 14, 2008 11:43
Может и так, но он сгенерил на даунлод практически одинаково, а на
аплод очень большая разница, и так постоянно.
СообщениеДобавлено: Вс дек 14, 2008 16:06
А у меня он показывает то 145 Мбит, то 35. Притом, что канал 100Мбит. Потестите в разное время суток и обедитесь сами.
Сейчас этот форум просматривают: Google [Bot] и гости: 218
