Текущее время: Сб окт 03, 2026 13:14
 Заголовок сообщения: Постоянные обрывы VPN на DI-824VUP+
СообщениеДобавлено: Пт дек 12, 2008 15:25
Кабель провайдера воткнут в Linksys, из которого работает телефон и DI-824VUP+. Интернет подключается через PPTP. Проблема в следующем - соединение успешно создается, инет работает замечательно, но минут через 5-10 инет пропадает на минуту, а потом появляется снова. Логи прилагаются
Tue Dec 09 14:58:53 2008 PPTP start to dial-up
Tue Dec 09 14:58:53 2008 PPTP server=83.167.72.1
Tue Dec 09 14:58:53 2008 PPTP:error=-112
Tue Dec 09 14:58:54 2008 DOD:prot 1 trigger from 192.168.0.143 to 194.67.57.26
Tue Dec 09 14:58:54 2008 PPTP start to dial-up
Tue Dec 09 14:58:54 2008 PPTP server=83.167.72.1
Tue Dec 09 14:58:54 2008 CHAP1: OK
Tue Dec 09 14:58:54 2008 IPCP1: IP is 83.167.75.37
Tue Dec 09 14:59:07 2008  Disassociated: Blocked access attempt from 60.63.184.220:30175 to UDP port 55108
Tue Dec 09 14:59:35 2008  Disassociated: Blocked access attempt from 122.111.87.114:60724 to UDP port 48091
Tue Dec 09 14:59:42 2008  Disassociated: Blocked access attempt from 85.28.24.6:4415 to TCP port 27286
Tue Dec 09 14:59:45 2008  Disassociated: Blocked access attempt from 85.28.24.6:4415 to TCP port 27286
Tue Dec 09 14:59:51 2008  Disassociated: Blocked access attempt from 85.28.24.6:4415 to TCP port 27286
Tue Dec 09 15:02:52 2008  Associated: 00-80-C8-12-00-AA st=0
Tue Dec 09 15:04:25 2008 Connection is broken
Tue Dec 09 15:04:25 2008 PPTP start to dial-down
Tue Dec 09 15:04:40 2008 DOD:prot 1 trigger from 192.168.0.143 to 194.67.57.26
Tue Dec 09 15:04:40 2008 PPTP start to dial-up
Tue Dec 09 15:04:40 2008 PPTP server=83.167.72.1
Tue Dec 09 15:04:40 2008 PPTP:error=-112
Tue Dec 09 15:04:41 2008 DOD:prot 1 trigger from 192.168.0.100 to 89.249.225.170
Tue Dec 09 15:04:41 2008 PPTP start to dial-up
Tue Dec 09 15:04:41 2008 PPTP server=83.167.72.1
Tue Dec 09 15:04:42 2008 CHAP1: OK
Tue Dec 09 15:04:42 2008 IPCP1: IP is 83.167.75.37
Tue Dec 09 15:06:23 2008  Disassociated: Blocked access attempt from 195.5.116.137:56615 to TCP port 55108
Tue Dec 09 15:08:01 2008  Disassociated: Blocked access attempt from 60.221.169.154:25265 to UDP port 48091
Tue Dec 09 15:08:07 2008  Disassociated: Blocked access attempt from 60.221.169.154:25265 to UDP port 48091
Tue Dec 09 15:08:26 2008  Disassociated: Blocked access attempt from 122.50.38.196:34540 to UDP port 55108
Tue Dec 09 15:08:28 2008  Disassociated: Blocked access attempt from 195.5.116.137:33941 to TCP port 55108
Tue Dec 09 15:08:37 2008  Disassociated: Blocked access attempt from 195.5.116.137:33941 to TCP port 55108
Tue Dec 09 15:10:12 2008 Connection is broken
Tue Dec 09 15:10:12 2008 PPTP start to dial-down
Tue Dec 09 15:10:27 2008 DOD:prot 1 trigger from 192.168.0.143 to 194.67.57.26
Tue Dec 09 15:10:27 2008 PPTP start to dial-up
Tue Dec 09 15:10:27 2008 PPTP server=83.167.72.1
Tue Dec 09 15:10:27 2008 PPTP:error=-112
Tue Dec 09 15:10:28 2008 DOD:prot 1 trigger from 192.168.0.143 to 194.67.57.26
Tue Dec 09 15:10:28 2008 PPTP start to dial-up
Tue Dec 09 15:10:28 2008 PPTP server=83.167.72.1
Tue Dec 09 15:10:28 2008 CHAP1: OK
Tue Dec 09 15:10:28 2008 IPCP1: IP is 83.167.75.37
СообщениеДобавлено: Пт дек 12, 2008 16:24
Какая прошивка на роутере? Соединение обрывается только при простое или даже есть что-то качать?
СообщениеДобавлено: Сб дек 13, 2008 12:03
ооо у меня такая же хрень... но рвётся при простое.
СообщениеДобавлено: Вс дек 14, 2008 17:35
Прошивка D-Link_824VUP_v200(v200b14) от 20-Jun-2008, соединение рвется в любом случае.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 187
