Текущее время: Ср сен 23, 2026 07:39
 Заголовок сообщения: DGE-560T
СообщениеДобавлено: Вс ноя 30, 2008 17:16
Привет Всем
Debian etch.
Отваливается сеть(DGE-560T) с сообщением в консоль:
Nov 30 09:36:16 debian kernel: NETDEV WATCHDOG: eth1: transmit timed out
Nov 30 09:36:16 debian kernel: sky2 status report lost?
Nov 30 09:45:30 debian kernel: NETDEV WATCHDOG: eth1: transmit timed out
Nov 30 09:45:30 debian kernel: sky2 hardware hung? flushing
Если перевоткнуть линк - кернел паник
Настройки сети:
iface eth1 inet static
address 169.0.0.1
netmask 255.255.255.252
iface vlan51 inet static
address 10.1.5.3
netmask 255.255.248.0
gateway 10.1.5.1
vlan_raw_device eth1
dmesg:
Nov 30 18:57:17 debian syslogd 1.4.1#18: restart.
Nov 30 18:57:17 debian kernel: klogd 1.4.1#18, log source = /proc/kmsg started.
Nov 30 18:57:17 debian kernel: Linux version 2.6.18-028stab053-13 (root@debian) (gcc version 4.1.2 20061115 (prerelease) (Debi
an 4.1.1-21)) #1 Sat Nov 22 03:06:30 EET 2008
Nov 30 18:57:17 debian kernel: BIOS-provided physical RAM map:
Nov 30 18:57:17 debian kernel: BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
Nov 30 18:57:17 debian kernel: BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
Nov 30 18:57:17 debian kernel: BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
Nov 30 18:57:17 debian kernel: BIOS-e820: 0000000000100000 - 000000003f790000 (usable)
Nov 30 18:57:17 debian kernel: BIOS-e820: 000000003f790000 - 000000003f79e000 (ACPI data)
Nov 30 18:57:17 debian kernel: BIOS-e820: 000000003f79e000 - 000000003f7e0000 (ACPI NVS)
Nov 30 18:57:17 debian kernel: BIOS-e820: 000000003f7e0000 - 000000003f800000 (reserved)
Nov 30 18:57:17 debian kernel: BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
Nov 30 18:57:17 debian kernel: BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
Nov 30 18:57:17 debian kernel: 119MB HIGHMEM available.
Nov 30 18:57:17 debian kernel: 896MB LOWMEM available.
Nov 30 18:57:17 debian kernel: DMI present.
Nov 30 18:57:17 debian kernel: ACPI: PM-Timer IO Port: 0x808
Nov 30 18:57:17 debian kernel: Allocating PCI resources starting at 40000000 (gap: 3f800000:bf600000)
Nov 30 18:57:17 debian kernel: Detected 1600.006 MHz processor.
Nov 30 18:57:17 debian kernel: Built 1 zonelists. Total pages: 259984
Nov 30 18:57:17 debian kernel: Kernel command line: root=/dev/hde1 ro
Nov 30 18:57:17 debian kernel: Enabling fast FPU save and restore... done.
Nov 30 18:57:17 debian kernel: Enabling unmasked SIMD FPU exception support... done.
Nov 30 18:57:17 debian kernel: Initializing CPU#0
Nov 30 18:57:17 debian kernel: CPU 0 irqstacks, hard=c0603000 soft=c0602000
Nov 30 18:57:17 debian kernel: PID hash table entries: 4096 (order: 12, 16384 bytes)
Nov 30 18:57:17 debian kernel: Console: colour VGA+ 80x25
Nov 30 18:57:17 debian kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Nov 30 18:57:17 debian kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Nov 30 18:57:17 debian kernel: Memory: 1021172k/1039936k available (3686k kernel code, 18056k reserved, 1083k data, 332k init,
122432k highmem)
Nov 30 18:57:17 debian kernel: Checking if this processor honours the WP bit even in supervisor mode... Ok.
Nov 30 18:57:17 debian kernel: Calibrating delay using timer specific routine.. 3201.33 BogoMIPS (lpj=1600665)
Nov 30 18:57:17 debian kernel: Mount-cache hash table entries: 512
Nov 30 18:57:17 debian kernel: monitor/mwait feature present.
Nov 30 18:57:17 debian kernel: using mwait in idle threads.
Nov 30 18:57:17 debian kernel: CPU: L1 I cache: 32K, L1 D cache: 32K
Nov 30 18:57:17 debian kernel: CPU: L2 cache: 1024K
Nov 30 18:57:17 debian kernel: Intel machine check architecture supported.
Nov 30 18:57:17 debian kernel: Intel machine check reporting enabled on CPU#0.
Nov 30 18:57:17 debian kernel: Compat vDSO mapped to ffffe000.
Nov 30 18:57:17 debian kernel: CPU: Intel Genuine Intel(R) CPU 2140 @ 1.60GHz stepping 02
Nov 30 18:57:17 debian kernel: Checking 'hlt' instruction... OK.
Nov 30 18:57:17 debian kernel: ACPI: Core revision 20060707
Nov 30 18:57:17 debian kernel: ACPI: setting ELCR to 0200 (from 0c28)
Nov 30 18:57:17 debian kernel: Page beancounter hash is 65536 entries.
Nov 30 18:57:17 debian kernel: checking if image is initramfs... it is
Nov 30 18:57:17 debian kernel: Freeing initrd memory: 2538k freed
Nov 30 18:57:17 debian kernel: NET: Registered protocol family 16
Nov 30 18:57:17 debian kernel: EISA bus registered
Nov 30 18:57:17 debian kernel: ACPI: bus type pci registered
Nov 30 18:57:17 debian kernel: PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=4
Nov 30 18:57:17 debian kernel: PCI: Using configuration type 1
Nov 30 18:57:17 debian kernel: Setting up standard PCI resources
Nov 30 18:57:17 debian kernel: ACPI: Interpreter enabled
Nov 30 18:57:17 debian kernel: ACPI: Using PIC for interrupt routing
Nov 30 18:57:17 debian kernel: ACPI: PCI Root Bridge [PCI0] (0000:00)
Nov 30 18:57:17 debian kernel: PCI: Ignoring BAR0-3 of IDE controller 0000:00:1f.2
Nov 30 18:57:17 debian kernel: PCI: Transparent bridge - 0000:00:1e.0
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *10 11 12 14 15)
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 *11 12 14 15)
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 7 10 11 12 14 15)
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs *3 4 5 6 7 10 11 12 14 15)
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 *11 12 14 15)
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 *10 11 12 14 15)
Nov 30 18:57:17 debian kernel: SCSI subsystem initialized
Nov 30 18:57:17 debian kernel: PCI: Using ACPI for IRQ routing
Nov 30 18:57:17 debian kernel: PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
Nov 30 18:57:17 debian kernel: PCI: Ignore bogus resource 6 [0:0] of 0000:00:02.0
Nov 30 18:57:17 debian kernel: PCI: Bridge: 0000:00:1c.0
Nov 30 18:57:17 debian kernel: IO window: disabled.
Nov 30 18:57:17 debian kernel: MEM window: disabled.
Nov 30 18:57:17 debian kernel: PREFETCH window: def00000-deffffff
Nov 30 18:57:17 debian kernel: PCI: Bridge: 0000:00:1c.1
Nov 30 18:57:17 debian kernel: IO window: d000-dfff
Nov 30 18:57:17 debian kernel: MEM window: dfe00000-dfefffff
Nov 30 18:57:17 debian kernel: PREFETCH window: disabled.
Nov 30 18:57:17 debian kernel: PCI: Bridge: 0000:00:1c.4
Nov 30 18:57:17 debian kernel: IO window: c000-cfff
Nov 30 18:57:17 debian kernel: MEM window: dfd00000-dfdfffff
Nov 30 18:57:17 debian kernel: PCI: Bridge: 0000:00:1e.0
Nov 30 18:57:17 debian kernel: IO window: e000-efff
Nov 30 18:57:17 debian kernel: MEM window: dff00000-dfffffff
Nov 30 18:57:17 debian kernel: PREFETCH window: 40000000-400fffff
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 11
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt 0000:00:1c.0[A] -> Link [LNKB] -> GSI 11 (level, low) -> IRQ 11
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 10
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt 0000:00:1c.1[B] -> Link [LNKA] -> GSI 10 (level, low) -> IRQ 10
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt 0000:00:1c.4[A] -> Link [LNKB] -> GSI 11 (level, low) -> IRQ 11
Nov 30 18:57:17 debian kernel: NET: Registered protocol family 2
Nov 30 18:57:17 debian kernel: IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
Nov 30 18:57:17 debian kernel: TCP established hash table entries: 131072 (order: 7, 524288 bytes)
Nov 30 18:57:17 debian kernel: TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
Nov 30 18:57:17 debian kernel: TCP: Hash tables configured (established 131072 bind 65536)
Nov 30 18:57:17 debian kernel: TCP reno registered
Nov 30 18:57:17 debian kernel: highmem bounce pool size: 64 pages
Nov 30 18:57:17 debian kernel: VFS: Disk quotas dquot_6.5.1
Nov 30 18:57:17 debian kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Nov 30 18:57:17 debian kernel: SGI XFS with ACLs, security attributes, realtime, large block numbers, no debug enabled
Nov 30 18:57:17 debian kernel: SGI XFS Quota Management subsystem
Nov 30 18:57:17 debian kernel: Initializing Cryptographic API
Nov 30 18:57:17 debian kernel: io scheduler noop registered
Nov 30 18:57:17 debian kernel: io scheduler anticipatory registered
Nov 30 18:57:17 debian kernel: io scheduler deadline registered
Nov 30 18:57:17 debian kernel: io scheduler cfq registered (default)
Nov 30 18:57:17 debian kernel: Real Time Clock Driver v1.12ac
Nov 30 18:57:17 debian kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing disabled
Nov 30 18:57:17 debian kernel: serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Nov 30 18:57:17 debian kernel: RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize
Nov 30 18:57:17 debian kernel: Compaq SMART2 Driver (v 2.6.0)
Nov 30 18:57:17 debian kernel: HP CISS Driver (v 3.6.10)
Nov 30 18:57:17 debian kernel: Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
Nov 30 18:57:17 debian kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Nov 30 18:57:17 debian kernel: JMB368: IDE controller at PCI slot 0000:02:00.0
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt 0000:02:00.0[A] -> Link [LNKB] -> GSI 11 (level, low) -> IRQ 11
Nov 30 18:57:17 debian kernel: JMB368: chipset revision 0
Nov 30 18:57:17 debian kernel: JMB368: 100%% native mode on irq 11
Nov 30 18:57:17 debian kernel: ide2: BM-DMA at 0xd400-0xd407, BIOS settings: hde:DMA, hdf:DMA
Nov 30 18:57:17 debian kernel: ide3: BM-DMA at 0xd408-0xd40f, BIOS settings: hdg:pio, hdh:pio
Nov 30 18:57:17 debian kernel: hde: WDC WD1600AAJB-00PVA0, ATA DISK drive
Nov 30 18:57:17 debian kernel: ide2 at 0xdc00-0xdc07,0xd882 on irq 11
Nov 30 18:57:17 debian kernel: hde: max request size: 512KiB
Nov 30 18:57:17 debian kernel: hde: 312581808 sectors (160041 MB) w/8192KiB Cache, CHS=19457/255/63
Nov 30 18:57:17 debian kernel: hde: cache flushes supported
Nov 30 18:57:17 debian kernel: hde: hde1 hde2 hde3
Nov 30 18:57:17 debian kernel: Loading iSCSI transport class v1.1-646.<6>Adaptec aacraid driver (1.1-5[2409]-mh2)
Nov 30 18:57:17 debian kernel: QLogic Fibre Channel HBA Driver
Nov 30 18:57:17 debian kernel: Emulex LightPulse Fibre Channel SCSI driver 8.1.9
Nov 30 18:57:17 debian kernel: Copyright(c) 2004-2006 Emulex. All rights reserved.
Nov 30 18:57:17 debian kernel: megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:01:03 EST 2006)
Nov 30 18:57:17 debian kernel: megaraid: 2.20.4.9 (Release Date: Sun Jul 16 12:27:22 EST 2006)
Nov 30 18:57:17 debian kernel: megasas: 00.00.03.01 Sun May 14 22:49:52 PDT 2006
Nov 30 18:57:17 debian kernel: GDT-HA: Storage RAID Controller Driver. Version: 3.05
Nov 30 18:57:17 debian kernel: GDT-HA: Found 0 PCI Storage RAID Controllers
Nov 30 18:57:17 debian kernel: 3ware Storage Controller device driver for Linux v1.26.02.001.
Nov 30 18:57:17 debian kernel: 3ware 9000 Storage Controller device driver for Linux v2.26.02.007.
Nov 30 18:57:17 debian kernel: ata_piix 0000:00:1f.2: MAP [ P0 -- P1 -- ]
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 5
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt 0000:00:1f.2[A] -> Link [LNKC] -> GSI 5 (level, low) -> IRQ 5
Nov 30 18:57:17 debian kernel: ata1: SATA max UDMA/133 cmd 0x1F0 ctl 0x3F6 bmdma 0xFF90 irq 14
Nov 30 18:57:17 debian kernel: scsi0 : ata_piix
Nov 30 18:57:17 debian kernel: ATA: abnormal status 0x7F on port 0x1F7
Nov 30 18:57:17 debian kernel: ata2: SATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xFF98 irq 15
Nov 30 18:57:17 debian kernel: scsi1 : ata_piix
Nov 30 18:57:17 debian kernel: ATA: abnormal status 0x7F on port 0x177
Nov 30 18:57:17 debian kernel: ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt 0000:00:1f.5[A] -> Link [LNKC] -> GSI 5 (level, low) -> IRQ 5
Nov 30 18:57:17 debian kernel: ata3: SATA max UDMA/133 cmd 0xB000 ctl 0xAC02 bmdma 0xA480 irq 5
Nov 30 18:57:17 debian kernel: ata4: SATA max UDMA/133 cmd 0xA880 ctl 0xA802 bmdma 0xA488 irq 5
Nov 30 18:57:17 debian kernel: scsi2 : ata_piix
Nov 30 18:57:17 debian kernel: ata3.00: ATA-7, max UDMA7, 1465149168 sectors: LBA48 NCQ (depth 0/32)
Nov 30 18:57:17 debian kernel: ata3.00: ata3: dev 0 multi count 16
Nov 30 18:57:17 debian kernel: ata3.00: configured for UDMA/133
Nov 30 18:57:17 debian kernel: scsi3 : ata_piix
Nov 30 18:57:17 debian kernel: ata4.00: ATA-8, max UDMA7, 976773168 sectors: LBA48 NCQ (depth 0/32)
Nov 30 18:57:17 debian kernel: ata4.00: ata4: dev 0 multi count 16
Nov 30 18:57:17 debian kernel: ata4.00: configured for UDMA/133
Nov 30 18:57:17 debian kernel: Vendor: ATA Model: SAMSUNG HD753LJ Rev: 1AA0
Nov 30 18:57:17 debian kernel: Type: Direct-Access ANSI SCSI revision: 05
Nov 30 18:57:17 debian kernel: Vendor: ATA Model: SAMSUNG HD501LJ Rev: CR10
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt Link [LNKE] enabled at IRQ 5
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt 0000:04:00.0[A] -> Link [LNKE] -> GSI 5 (level, low) -> IRQ 5
Nov 30 18:57:17 debian kernel: ata5: SATA max UDMA/100 cmd 0xF885CC80 ctl 0xF885CC8A bmdma 0xF885CC00 irq 5
Nov 30 18:57:17 debian kernel: ata6: SATA max UDMA/100 cmd 0xF885CCC0 ctl 0xF885CCCA bmdma 0xF885CC08 irq 5
Nov 30 18:57:17 debian kernel: scsi4 : sata_sil
Nov 30 18:57:17 debian kernel: ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
Nov 30 18:57:17 debian kernel: ata5.00: ATA-8, max UDMA7, 781422768 sectors: LBA48 NCQ (depth 0/32)
Nov 30 18:57:17 debian kernel: ata5.00: ata5: dev 0 multi count 16
Nov 30 18:57:17 debian kernel: ata5.00: configured for UDMA/100
Nov 30 18:57:17 debian kernel: scsi5 : sata_sil
Nov 30 18:57:17 debian kernel: ata6: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
Nov 30 18:57:17 debian kernel: ata6.00: ATA-8, max UDMA7, 976773168 sectors: LBA48 NCQ (depth 0/32)
Nov 30 18:57:17 debian kernel: ata6.00: ata6: dev 0 multi count 16
Nov 30 18:57:17 debian kernel: ata6.00: configured for UDMA/100
Nov 30 18:57:17 debian kernel: Vendor: ATA Model: SAMSUNG HD403LJ Rev: CT10
Nov 30 18:57:17 debian kernel: SCSI device sda: 1465149168 512-byte hdwr sectors (750156 MB)
Nov 30 18:57:17 debian kernel: sda: Write Protect is off
Nov 30 18:57:17 debian kernel: SCSI device sda: drive cache: write back
Nov 30 18:57:17 debian kernel: sda: sda1
Nov 30 18:57:17 debian kernel: sd 2:0:0:0: Attached scsi disk sda
Nov 30 18:57:17 debian kernel: SCSI device sdb: 976773168 512-byte hdwr sectors (500108 MB)
Nov 30 18:57:17 debian kernel: sdb: Write Protect is off
Nov 30 18:57:17 debian kernel: SCSI device sdb: drive cache: write back
Nov 30 18:57:17 debian kernel: sdb: sdb1
Nov 30 18:57:17 debian kernel: sd 3:0:0:0: Attached scsi disk sdb
Nov 30 18:57:17 debian kernel: SCSI device sdc: 781422768 512-byte hdwr sectors (400088 MB)
Nov 30 18:57:17 debian kernel: sdc: Write Protect is off
Nov 30 18:57:17 debian kernel: SCSI device sdc: drive cache: write back
Nov 30 18:57:17 debian kernel: sdc: sdc1
Nov 30 18:57:17 debian kernel: sd 4:0:0:0: Attached scsi disk sdc
Nov 30 18:57:17 debian kernel: SCSI device sdd: 976773168 512-byte hdwr sectors (500108 MB)
Nov 30 18:57:17 debian kernel: sdd: Write Protect is off
Nov 30 18:57:17 debian kernel: SCSI device sdd: drive cache: write back
Nov 30 18:57:17 debian kernel: sdd: sdd1
Nov 30 18:57:17 debian kernel: sd 5:0:0:0: Attached scsi disk sdd
Nov 30 18:57:17 debian kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Nov 30 18:57:17 debian kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Nov 30 18:57:17 debian kernel: mice: PS/2 mouse device common for all mice
Nov 30 18:57:17 debian kernel: md: linear personality registered for level -1
Nov 30 18:57:17 debian kernel: md: raid0 personality registered for level 0
Nov 30 18:57:17 debian kernel: md: raid1 personality registered for level 1
Nov 30 18:57:17 debian kernel: md: raid10 personality registered for level 10
Nov 30 18:57:17 debian kernel: raid6: int32x1 632 MB/s
Nov 30 18:57:17 debian kernel: raid6: int32x2 609 MB/s
Nov 30 18:57:17 debian kernel: raid6: int32x4 488 MB/s
Nov 30 18:57:17 debian kernel: raid6: int32x8 402 MB/s
Nov 30 18:57:17 debian kernel: raid6: mmxx1 2011 MB/s
Nov 30 18:57:17 debian kernel: raid6: mmxx2 2328 MB/s
Nov 30 18:57:17 debian kernel: raid6: sse1x1 1417 MB/s
Nov 30 18:57:17 debian kernel: raid6: sse1x2 1808 MB/s
Nov 30 18:57:17 debian kernel: raid6: sse2x1 2660 MB/s
Nov 30 18:57:17 debian kernel: raid6: sse2x2 3082 MB/s
Nov 30 18:57:17 debian kernel: raid6: using algorithm sse2x2 (3082 MB/s)
Nov 30 18:57:17 debian kernel: md: raid6 personality registered for level 6
Nov 30 18:57:17 debian kernel: md: raid5 personality registered for level 5
Nov 30 18:57:17 debian kernel: md: raid4 personality registered for level 4
Nov 30 18:57:17 debian kernel: raid5: automatically using best checksumming function: pIII_sse
Nov 30 18:57:17 debian kernel: pIII_sse : 5904.000 MB/sec
Nov 30 18:57:17 debian kernel: raid5: using function: pIII_sse (5904.000 MB/sec)
Nov 30 18:57:17 debian kernel: md: multipath personality registered for level -4
Nov 30 18:57:17 debian kernel: md: md driver 0.90.3 MAX_MD_DEVS=256, MD_SB_DISKS=27
Nov 30 18:57:17 debian kernel: md: bitmap version 4.39
Nov 30 18:57:17 debian kernel: device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
Nov 30 18:57:17 debian kernel: device-mapper: multipath: version 1.0.4 loaded
Nov 30 18:57:17 debian kernel: device-mapper: multipath round-robin: version 1.0.0 loaded
Nov 30 18:57:17 debian kernel: device-mapper: multipath emc: version 0.0.3 loaded
Nov 30 18:57:17 debian kernel: EISA: Probing bus 0 at eisa.0
Nov 30 18:57:17 debian kernel: TCP bic registered
Nov 30 18:57:17 debian kernel: NET: Registered protocol family 10
Nov 30 18:57:17 debian kernel: IPv6 over IPv4 tunneling driver
Nov 30 18:57:17 debian kernel: Using IPI Shortcut mode
Nov 30 18:57:17 debian kernel: ACPI: (supports S0 S1 S3 S4 S5)
Nov 30 18:57:17 debian kernel: Freeing unused kernel memory: 332k freed
Nov 30 18:57:17 debian kernel: Time: tsc clocksource has been installed.
Nov 30 18:57:17 debian kernel: input: AT Translated Set 2 keyboard as /class/input/input0
Nov 30 18:57:17 debian kernel: ACPI (exconfig-0455): Dynamic SSDT Load - OemId [ AMI] OemTableId [ CPU1PM] [20060707]
Nov 30 18:57:17 debian kernel: usbcore: registered new driver usbfs
Nov 30 18:57:17 debian kernel: usbcore: registered new driver hub
Nov 30 18:57:17 debian kernel: USB Universal Host Controller Interface driver v3.0
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt Link [LNKG] enabled at IRQ 11
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt 0000:00:1a.0[A] -> Link [LNKG] -> GSI 11 (level, low) -> IRQ 11
Nov 30 18:57:17 debian kernel: uhci_hcd 0000:00:1a.0: UHCI Host Controller
Nov 30 18:57:17 debian kernel: uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
Nov 30 18:57:17 debian kernel: uhci_hcd 0000:00:1a.0: irq 11, io base 0x0000b800
Nov 30 18:57:17 debian kernel: usb usb1: configuration #1 chosen from 1 choice
Nov 30 18:57:17 debian kernel: hub 1-0:1.0: USB hub found
Nov 30 18:57:17 debian kernel: hub 1-0:1.0: 2 ports detected
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt Link [LNKF] enabled at IRQ 3
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt 0000:00:1a.1[B] -> Link [LNKF] -> GSI 3 (level, low) -> IRQ 3
Nov 30 18:57:17 debian kernel: uhci_hcd 0000:00:1a.1: UHCI Host Controller
Nov 30 18:57:17 debian kernel: uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 2
Nov 30 18:57:17 debian kernel: uhci_hcd 0000:00:1a.1: irq 3, io base 0x0000b880
Nov 30 18:57:17 debian kernel: usb usb2: configuration #1 chosen from 1 choice
Nov 30 18:57:17 debian kernel: hub 2-0:1.0: USB hub found
Nov 30 18:57:17 debian kernel: hub 2-0:1.0: 2 ports detected
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 10
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt 0000:00:1d.0[A] -> Link [LNKH] -> GSI 10 (level, low) -> IRQ 10
Nov 30 18:57:17 debian kernel: uhci_hcd 0000:00:1d.0: UHCI Host Controller
Nov 30 18:57:17 debian kernel: uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 3
Nov 30 18:57:17 debian kernel: uhci_hcd 0000:00:1d.0: irq 10, io base 0x0000b080
Nov 30 18:57:17 debian kernel: usb usb3: configuration #1 chosen from 1 choice
Nov 30 18:57:17 debian kernel: hub 3-0:1.0: USB hub found
Nov 30 18:57:17 debian kernel: hub 3-0:1.0: 2 ports detected
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt 0000:00:1d.1[B] -> Link [LNKE] -> GSI 5 (level, low) -> IRQ 5
Nov 30 18:57:17 debian kernel: uhci_hcd 0000:00:1d.1: UHCI Host Controller
Nov 30 18:57:17 debian kernel: uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 4
Nov 30 18:57:17 debian kernel: uhci_hcd 0000:00:1d.1: irq 5, io base 0x0000b400
Nov 30 18:57:17 debian kernel: usb usb4: configuration #1 chosen from 1 choice
Nov 30 18:57:17 debian kernel: hub 4-0:1.0: USB hub found
Nov 30 18:57:17 debian kernel: hub 4-0:1.0: 2 ports detected
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt 0000:00:1d.2[C] -> Link [LNKF] -> GSI 3 (level, low) -> IRQ 3
Nov 30 18:57:17 debian kernel: uhci_hcd 0000:00:1d.2: UHCI Host Controller
Nov 30 18:57:17 debian kernel: uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 5
Nov 30 18:57:17 debian kernel: uhci_hcd 0000:00:1d.2: irq 3, io base 0x0000b480
Nov 30 18:57:17 debian kernel: usb usb5: configuration #1 chosen from 1 choice
Nov 30 18:57:17 debian kernel: hub 5-0:1.0: USB hub found
Nov 30 18:57:17 debian kernel: hub 5-0:1.0: 2 ports detected
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt 0000:00:1a.7[C] -> Link [LNKC] -> GSI 5 (level, low) -> IRQ 5
Nov 30 18:57:17 debian kernel: ehci_hcd 0000:00:1a.7: EHCI Host Controller
Nov 30 18:57:17 debian kernel: ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 6
Nov 30 18:57:17 debian kernel: ehci_hcd 0000:00:1a.7: debug port 1
Nov 30 18:57:17 debian kernel: ehci_hcd 0000:00:1a.7: irq 5, io mem 0xdfbfbc00
Nov 30 18:57:17 debian kernel: ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Nov 30 18:57:17 debian kernel: usb usb6: configuration #1 chosen from 1 choice
Nov 30 18:57:17 debian kernel: hub 6-0:1.0: USB hub found
Nov 30 18:57:17 debian kernel: hub 6-0:1.0: 4 ports detected
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt 0000:00:1d.7[A] -> Link [LNKH] -> GSI 10 (level, low) -> IRQ 10
Nov 30 18:57:17 debian kernel: ehci_hcd 0000:00:1d.7: EHCI Host Controller
Nov 30 18:57:17 debian kernel: ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 7
Nov 30 18:57:17 debian kernel: ehci_hcd 0000:00:1d.7: debug port 1
Nov 30 18:57:17 debian kernel: ehci_hcd 0000:00:1d.7: irq 10, io mem 0xdfbfb800
Nov 30 18:57:17 debian kernel: ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Nov 30 18:57:17 debian kernel: usb usb7: configuration #1 chosen from 1 choice
Nov 30 18:57:17 debian kernel: hub 7-0:1.0: USB hub found
Nov 30 18:57:17 debian kernel: hub 7-0:1.0: 6 ports detected
Nov 30 18:57:17 debian kernel: EXT3-fs: INFO: recovery required on readonly filesystem.
Nov 30 18:57:17 debian kernel: EXT3-fs: write access will be enabled during recovery.
Nov 30 18:57:17 debian kernel: kjournald starting. Commit interval 5 seconds
Nov 30 18:57:17 debian kernel: EXT3-fs: recovery complete.
Nov 30 18:57:17 debian kernel: EXT3-fs: mounted filesystem with ordered data mode.
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt 0000:01:00.0[A] -> Link [LNKA] -> GSI 10 (level, low) -> IRQ 10
Nov 30 18:57:17 debian kernel: sky2 v1.5 addr 0xdfdfc000 irq 10 Yukon-EC (0xb6) rev 2
Nov 30 18:57:17 debian kernel: sky2 eth0: addr 00:1e:58:94:cf:12
Nov 30 18:57:17 debian kernel: ACPI: PCI Interrupt 0000:00:1f.3[C] -> Link [LNKC] -> GSI 5 (level, low) -> IRQ 5
Nov 30 18:57:17 debian kernel: Adding 9775544k swap on /dev/hde3. Priority:-1 extents:1 across:9775544k
Nov 30 18:57:17 debian kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Nov 30 18:57:17 debian kernel: EXT3 FS on hde1, internal journal
Nov 30 18:57:17 debian kernel: loop: loaded (max 8 devices)
Nov 30 18:57:17 debian kernel: EXT3 FS on hde2, internal journal
Nov 30 18:57:17 debian kernel: EXT3 FS on sdb1, internal journal
Nov 30 18:57:17 debian kernel: EXT3-fs: mounted filesystem with writeback data mode.
Nov 30 18:57:17 debian kernel: XFS mounting filesystem sda1
Nov 30 18:57:17 debian kernel: EXT3 FS on sdc1, internal journal
Nov 30 18:57:17 debian kernel: EXT3 FS on sdd1, internal journal
Nov 30 18:57:17 debian kernel: sky2 eth1: enabling interface
Nov 30 18:57:17 debian kernel: ADDRCONF(NETDEV_UP): eth1: link is not ready
Nov 30 18:57:17 debian kernel: 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
Nov 30 18:57:17 debian kernel: All bugs added by David S. Miller <davem@redhat.com>
Nov 30 18:57:17 debian kernel: ADDRCONF(NETDEV_UP): vlan51: link is not ready
Nov 30 18:57:17 debian kernel: ACPI: Power Button (FF) [PWRF]
Nov 30 18:57:17 debian kernel: ACPI: Power Button (CM) [PWRB]
Nov 30 18:57:17 debian kernel: sky2 eth1: Link is up at 1000 Mbps, full duplex, flow control none
Nov 30 18:57:17 debian kernel: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Nov 30 18:57:18 debian kernel: ADDRCONF(NETDEV_CHANGE): vlan51: link becomes ready
Nov 30 19:17:17 debian -- MARK --
СообщениеДобавлено: Вс ноя 30, 2008 17:43
# lspci -v
00:00.0 Host bridge: Intel Corporation P965/G965 Memory Controller Hub (rev 02)
Subsystem: ASUSTeK Computer Inc. Unknown device 823b
Flags: bus master, fast devsel, latency 0
Capabilities: [e0] Vendor Specific Information
00:02.0 VGA compatible controller: Intel Corporation G965 Integrated Graphics Controller (rev 02) (prog-if 00 [VGA])
Flags: bus master, fast devsel, latency 0, IRQ 10
Memory at dfc00000 (32-bit, non-prefetchable) [size=1M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
I/O ports at bc00 [size=8]
Capabilities: [90] Message Signalled Interrupts: Mask- 64bit- Queue=0/0 Enable-
Capabilities: [d0] Power Management version 2
00:1c.0 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 1 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Prefetchable memory behind bridge: 00000000def00000-00000000deffffff
Capabilities: [40] Express Root Port (Slot+) IRQ 0
Capabilities: [80] Message Signalled Interrupts: Mask- 64bit- Queue=0/0 Enable-
Capabilities: [90] Subsystem: ASUSTeK Computer Inc. Unknown device 81eb
Capabilities: [a0] Power Management version 2
00:1c.1 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 2 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: dfe00000-dfefffff
00:1c.4 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 5 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000c000-0000cfff
Memory behind bridge: dfd00000-dfdfffff
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev f2) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=32
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: dff00000-dfffffff
Prefetchable memory behind bridge: 0000000040000000-00000000400fffff
Capabilities: [50] Subsystem: ASUSTeK Computer Inc. Unknown device 81eb
00:1f.0 ISA bridge: Intel Corporation 82801HB/HR (ICH8/R) LPC Interface Controller (rev 02)
Flags: bus master, medium devsel, latency 0
00:1f.2 IDE interface: Intel Corporation 82801H (ICH8 Family) 4 port SATA IDE Controller (rev 02) (prog-if 8a [Master SecP PriP])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 5
I/O ports at <unassigned>
I/O ports at ff90 [size=16]
I/O ports at ffa0 [size=16]
Capabilities: [70] Power Management version 3
00:1f.3 SMBus: Intel Corporation 82801H (ICH8 Family) SMBus Controller (rev 02)
Flags: medium devsel, IRQ 5
Memory at dfbfb400 (32-bit, non-prefetchable) [size=256]
I/O ports at 0400 [size=32]
00:1f.5 IDE interface: Intel Corporation 82801H (ICH8 Family) 2 port SATA IDE Controller (rev 02) (prog-if 85 [Master SecO PriO])
I/O ports at b000 [size=8]
I/O ports at ac00 [size=4]
I/O ports at a880 [size=8]
I/O ports at a800 [size=4]
I/O ports at a480 [size=16]
I/O ports at a400 [size=16]
00:1f.6 Signal processing controller: Intel Corporation 82801H (ICH8 Family) Thermal Reporting Device
Flags: fast devsel, IRQ 5
Memory at dfbfa000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [50] Power Management version 2
01:00.0 Ethernet controller: D-Link System Inc Unknown device 4b00 (rev 13)
Subsystem: D-Link System Inc Unknown device 4b00
Memory at dfdfc000 (64-bit, non-prefetchable) [size=16K]
I/O ports at c800 [size=256]
Expansion ROM at dfdc0000 [disabled] [size=128K]
Capabilities: [48] Power Management version 2
Capabilities: [50] Vital Product Data
Capabilities: [5c] Message Signalled Interrupts: Mask- 64bit+ Queue=0/1 Enable-
Capabilities: [e0] Express Legacy Endpoint IRQ 0
02:00.0 IDE interface: JMicron Technologies, Inc. Unknown device 2368 (prog-if 85 [Master SecO PriO])
Subsystem: ASUSTeK Computer Inc. Unknown device 827e
Flags: bus master, fast devsel, latency 0, IRQ 11
I/O ports at dc00 [size=8]
I/O ports at d880 [size=4]
I/O ports at d800 [size=8]
I/O ports at d480 [size=4]
I/O ports at d400 [size=16]
Expansion ROM at dfef0000 [disabled] [size=64K]
Capabilities: [68] Power Management version 2
Capabilities: [50] Express Legacy Endpoint IRQ 1
Capabilities: [70] Message Signalled Interrupts: Mask- 64bit- Queue=0/0 Enable-
04:00.0 Mass storage controller: Silicon Image, Inc. SiI 3112 [SATALink/SATARaid] Serial ATA Controller (rev 02)
Subsystem: Silicon Image, Inc. SiI 3112 SATALink Controller
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 5
I/O ports at ec00 [size=8]
I/O ports at e880 [size=4]
I/O ports at e800 [size=8]
I/O ports at e480 [size=4]
I/O ports at e400 [size=16]
Memory at dffffc00 (32-bit, non-prefetchable) [size=512]
Expansion ROM at 40000000 [disabled] [size=512K]
Capabilities: [60] Power Management version 2
