Текущее время: Вс сен 06, 2026 19:14
 Заголовок сообщения: DIR-615 (постоянные дисконекты)
СообщениеДобавлено: Пн сен 22, 2008 10:57
Собственно:
Роутер постоянно теряет связь с провайдером. (Всю сеть)
ОС WinXP SP2
Подключение по VPN
Каких ли бо временных рамок нет, то каждый час, то каждые пол часа, то каждые пять минут. В общем рандомно.
[INFO] Mon Sep 22 13:52:18 2008 Blocked incoming TCP packet from 61.139.8.100:80 to 89.189.152.27:20879 as SYN:ACK received but there is no active connection
[INFO] Mon Sep 22 13:52:15 2008 Blocked incoming ICMP packet (ICMP type 8 ) from 124.144.100.78 to 89.189.152.27
[INFO] Mon Sep 22 13:52:12 2008 Above message repeated 1 times
[INFO] Mon Sep 22 13:52:10 2008 Log viewed by IP address 192.168.0.199
[INFO] Mon Sep 22 13:52:01 2008 Stored configuration to non-volatile memory
[INFO] Mon Sep 22 03:26:55 2008 Log viewed by IP address 192.168.0.199
[INFO] Mon Sep 22 03:26:28 2008 Blocked incoming TCP packet from 61.139.8.100:80 to 89.189.152.27:20879 as SYN:ACK received but there is no active connection
[INFO] Mon Sep 22 03:25:50 2008 Above message repeated 1 times
[INFO] Mon Sep 22 03:25:07 2008 Blocked incoming TCP connection request from 118.168.136.4:4136 to 89.189.152.27:3128
[INFO] Mon Sep 22 03:24:58 2008 Above message repeated 2 times
[INFO] Mon Sep 22 03:24:27 2008 Allowed configuration authentication by IP address 192.168.0.199
[WARN] Mon Sep 22 03:24:18 2008 A network computer (SHIMA) was assigned the IP address of 192.168.0.199.
[INFO] Mon Sep 22 03:24:11 2008 Wireless system with MAC address 001CF0DA5981 associated
[INFO] Mon Sep 22 03:22:57 2008 Blocked incoming TCP connection request from 92.62.101.22:59502 to 89.189.152.27:1080
[INFO] Mon Sep 22 03:22:53 2008 Starting DHCP server
[INFO] Mon Sep 22 03:22:47 2008 Starting WAN Services
[INFO] Mon Sep 22 03:22:47 2008 WAN interface is up. Connection to Internet established with IP Address 89.189.152.27 and default gateway 10.8.0.8
[INFO] Mon Sep 22 03:22:47 2008 PPP network up with IP Address 89.189.152.27
[INFO] Mon Sep 22 03:22:46 2008 WAN interface is down
[INFO] Mon Sep 22 03:22:46 2008 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Sep 22 03:22:46 2008 LCP sets remote auth: C223
[INFO] Mon Sep 22 03:22:46 2008 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1460
[INFO] Mon Sep 22 03:22:46 2008 PPTP connected to server "drs25.ufanet.ru" with ID 0x8C31
[INFO] Mon Sep 22 03:22:46 2008 The PPTP transmit window is 16
[INFO] Mon Sep 22 03:22:46 2008 Attempting to establish a PPTP connection.
[INFO] Mon Sep 22 03:22:46 2008 Attempting to start always-on WAN connection
[INFO] Mon Sep 22 03:22:46 2008 Obtained IP Address using DHCP. IP address is 10.68.45.174
[WARN] Mon Sep 22 03:22:46 2008 Blocked packet from 0.0.0.0 to 0.0.0.0 (LAND Attack)
[INFO] Mon Sep 22 03:22:45 2008 Bringing up WAN using PPTP
[INFO] Mon Sep 22 03:22:45 2008 WAN interface cable has been connected
[INFO] Mon Sep 22 03:22:45 2008 LAN interface is up
[INFO] Mon Sep 22 03:22:45 2008 LAN Ethernet Carrier Detected
[INFO] Mon Sep 22 03:22:44 2008 Device initialized
[WARN] Mon Sep 22 03:22:44 2008 gw_wireless_schedule init
[INFO] Mon Sep 22 03:22:44 2008 Wireless Link is up
[INFO] Mon Sep 22 03:22:43 2008 Unlock AP setup
[INFO] Mon Sep 22 03:22:43 2008 No Internet access policy is in effect. Unrestricted Internet access allowed to everyone
[INFO] Wed Dec 31 16:00:00 1969 Loaded configuration from non-volatile memory
СообщениеДобавлено: Пн сен 22, 2008 11:54
Вот ещё один дисконект в промежутке за 10-ть минут.
[INFO] Mon Sep 22 13:58:01 2008 Log viewed by IP address 192.168.0.199
[INFO] Mon Sep 22 13:57:59 2008 Blocked incoming TCP connection request from 118.168.136.221:1491 to 81.30.177.111:3128
[INFO] Mon Sep 22 13:57:50 2008 Above message repeated 2 times
[INFO] Mon Sep 22 13:57:15 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3819 and 192.168.1.10:26994
[INFO] Mon Sep 22 13:57:01 2008 Dropped packet from 192.168.0.199 to 255.255.255.255 (IP protocol 6) as unable to create new session
[INFO] Mon Sep 22 13:57:01 2008 UPnP added entry 255.255.255.255 <-> 81.30.177.111:6667 <-> 192.168.0.199:6666 TCP timeout:-1 'uTorrent (TCP)'
[INFO] Mon Sep 22 13:56:59 2008 UPnP added entry 255.255.255.255 <-> 81.30.177.111:6666 <-> 192.168.0.199:6666 UDP timeout:-1 'uTorrent (UDP)'
[INFO] Mon Sep 22 13:56:59 2008 Dropped packet from 192.168.0.199 to 255.255.255.255 (IP protocol 6) as unable to create new session
[INFO] Mon Sep 22 13:56:59 2008 UPnP added entry 255.255.255.255 <-> 81.30.177.111:6667 <-> 192.168.0.199:6666 TCP timeout:-1 'uTorrent (TCP)'
[INFO] Mon Sep 22 13:56:52 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3732 and 192.168.1.10:26994
[INFO] Mon Sep 22 13:56:40 2008 Blocked incoming TCP packet from 81.109.84.129:60045 to 81.30.177.111:3690 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 13:56:37 2008 Above message repeated 1 times
[INFO] Mon Sep 22 13:56:31 2008 Blocked incoming UDP packet from 88.10.228.158:24153 to 81.30.177.111:45816
[INFO] Mon Sep 22 13:56:25 2008 Blocked incoming UDP packet from 172.27.21.171:1815 to 81.30.177.111:27015
[INFO] Mon Sep 22 13:56:20 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3613 and 192.168.1.10:26994
[INFO] Mon Sep 22 13:56:12 2008 Allowed configuration authentication by IP address 192.168.0.199
[INFO] Mon Sep 22 13:56:03 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3550 and 192.168.1.10:26994
[INFO] Mon Sep 22 13:55:30 2008 Blocked incoming TCP packet from 75.157.158.161:64078 to 81.30.177.111:3415 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 13:55:14 2008 Blocked incoming UDP packet from 24.83.119.247:6881 to 81.30.177.111:45816
[INFO] Mon Sep 22 13:55:13 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3334 and 192.168.1.10:26994
[INFO] Mon Sep 22 13:55:09 2008 Blocked incoming TCP packet from 75.157.158.161:63838 to 81.30.177.111:3329 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 13:54:55 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3273 and 192.168.1.10:26994
[INFO] Mon Sep 22 13:54:52 2008 Above message repeated 1 times
[INFO] Mon Sep 22 13:54:49 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3253 and 192.168.1.10:26994
[INFO] Mon Sep 22 13:54:49 2008 Blocked incoming UDP packet from 78.59.146.133:30238 to 81.30.177.111:45816
[INFO] Mon Sep 22 13:54:31 2008 Blocked incoming TCP packet from 71.60.15.29:60774 to 81.30.177.111:3188 as SYN:ACK received but there is no active connection
[INFO] Mon Sep 22 13:54:28 2008 Above message repeated 1 times
[INFO] Mon Sep 22 13:54:04 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3087 and 192.168.1.10:26994
[INFO] Mon Sep 22 13:54:00 2008 Above message repeated 1 times
[INFO] Mon Sep 22 13:53:50 2008 Blocked incoming TCP packet from 67.167.237.170:61768 to 81.30.177.111:3041 as SYN:ACK received but there is no active connection
[INFO] Mon Sep 22 13:53:47 2008 Blocked incoming TCP packet from 67.167.237.170:61768 to 81.30.177.111:3041 as RST:ACK received but there is no active connection
[WARN] Mon Sep 22 13:53:34 2008 A network computer (SHIMA) was assigned the IP address of 192.168.0.199.
[INFO] Mon Sep 22 13:53:29 2008 Blocked incoming UDP packet from 172.27.25.192:2104 to 81.30.177.111:27015
[INFO] Mon Sep 22 13:53:26 2008 Wireless system with MAC address 001CF0DA5981 associated
[INFO] Mon Sep 22 13:52:40 2008 Starting WAN Services
[INFO] Mon Sep 22 13:52:40 2008 WAN interface is up. Connection to Internet established with IP Address 81.30.177.111 and default gateway 10.8.0.8
[INFO] Mon Sep 22 13:52:40 2008 PPP network up with IP Address 81.30.177.111
[INFO] Mon Sep 22 13:52:39 2008 WAN interface is down
[INFO] Mon Sep 22 13:52:39 2008 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Sep 22 13:52:39 2008 LCP sets remote auth: C223
[INFO] Mon Sep 22 13:52:39 2008 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1460
[INFO] Mon Sep 22 13:52:39 2008 PPTP connected to server "drs25.ufanet.ru" with ID 0xF27A
[INFO] Mon Sep 22 13:52:39 2008 The PPTP transmit window is 16
[INFO] Mon Sep 22 13:52:39 2008 Attempting to establish a PPTP connection.
[INFO] Mon Sep 22 13:52:16 2008 Starting DHCP server
[INFO] Mon Sep 22 13:52:09 2008 PPP network down
[INFO] Mon Sep 22 13:52:09 2008 WAN interface is down
[INFO] Mon Sep 22 13:52:09 2008 PPTP tunnel ID 0x45CB has been closed
[INFO] Mon Sep 22 13:52:09 2008 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Sep 22 13:52:09 2008 LCP sets remote auth: C223
[INFO] Mon Sep 22 13:52:09 2008 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1460
[INFO] Mon Sep 22 13:52:09 2008 PPTP connected to server "drs25.ufanet.ru" with ID 0x45CB
[INFO] Mon Sep 22 13:52:09 2008 The PPTP transmit window is 16
[INFO] Mon Sep 22 13:52:09 2008 Attempting to establish a PPTP connection.
[INFO] Mon Sep 22 13:52:09 2008 Attempting to start always-on WAN connection
[INFO] Mon Sep 22 13:52:09 2008 Obtained IP Address using DHCP. IP address is 10.68.45.174
[INFO] Mon Sep 22 13:52:08 2008 Bringing up WAN using PPTP
[INFO] Mon Sep 22 13:52:08 2008 WAN interface cable has been connected
[INFO] Mon Sep 22 13:52:08 2008 LAN interface is up
[INFO] Mon Sep 22 13:52:08 2008 LAN Ethernet Carrier Detected
[INFO] Mon Sep 22 13:52:07 2008 Device initialized
[WARN] Mon Sep 22 13:52:07 2008 gw_wireless_schedule init
[INFO] Mon Sep 22 13:52:07 2008 Wireless Link is up
[INFO] Mon Sep 22 13:52:06 2008 Unlock AP setup
[INFO] Mon Sep 22 13:52:06 2008 No Internet access policy is in effect. Unrestricted Internet access allowed to everyone
СообщениеДобавлено: Пн сен 22, 2008 13:32
И ещё один:
[INFO] Mon Sep 22 15:30:29 2008 Log viewed by IP address 192.168.0.199
[INFO] Mon Sep 22 15:30:24 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 84.48.124.175:55862 with unexpected sequence 1735745661 (expected 1728510309 to 1730005351)
[INFO] Mon Sep 22 15:30:21 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:30:12 2008 Allowed configuration authentication by IP address 192.168.0.199
[INFO] Mon Sep 22 15:29:11 2008 Blocked incoming TCP connection request from 118.168.136.4:1122 to 81.30.177.111:3128
[INFO] Mon Sep 22 15:29:02 2008 Above message repeated 2 times
[WARN] Mon Sep 22 15:27:48 2008 The remote PPTP access concentrator is slow to respond. There may be connectivity problems.
[INFO] Mon Sep 22 15:27:45 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1500 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:27:28 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1464 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:26:04 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1285 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:25:12 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1130 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:25:09 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:25:03 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1101 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:24:59 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:24:59 2008 Blocked incoming TCP packet from 75.157.158.161:60985 to 81.30.177.111:1091 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 15:24:25 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4949 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:24:10 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4926 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:24:07 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:23:35 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4828 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:23:32 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:23:32 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4820 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:23:26 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:22:48 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4735 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:22:05 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4631 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:22:02 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:21:09 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4522 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:21:05 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:21:01 2008 Blocked incoming UDP packet from 202.111.175.48:34079 to 81.30.177.111:1027
[INFO] Mon Sep 22 15:19:41 2008 Blocked incoming UDP packet from 77.51.57.180:28467 to 81.30.177.111:45816
[INFO] Mon Sep 22 15:19:40 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4369 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:19:11 2008 Blocked incoming UDP packet from 123.218.22.203:16001 to 81.30.177.111:45816
[INFO] Mon Sep 22 15:19:10 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:18:23 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4270 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:18:12 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4255 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:18:09 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:17:33 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4196 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:17:29 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:17:05 2008 UPnP added entry 255.255.255.255 <-> 81.30.177.111:6667 <-> 192.168.0.199:6666 TCP timeout:-1 'uTorrent (TCP)'
[INFO] Mon Sep 22 15:17:05 2008 UPnP deleted entry 255.255.255.255 <-> 81.30.177.111:6667 TCP
[INFO] Mon Sep 22 15:16:55 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4117 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:16:45 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4103 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:16:42 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:16:17 2008 Blocked incoming UDP packet from 219.90.153.204:50505 to 81.30.177.111:50505
[INFO] Mon Sep 22 15:16:16 2008 Blocked incoming TCP packet from 75.157.158.161:60088 to 81.30.177.111:4067 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 15:15:59 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4041 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:15:54 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:15:42 2008 Blocked incoming UDP packet from 219.90.153.204:50505 to 81.30.177.111:50505
[INFO] Mon Sep 22 15:15:19 2008 Blocked incoming TCP packet from 75.157.158.161:63677 to 81.30.177.111:3985 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 15:15:17 2008 Blocked incoming UDP packet from 219.90.153.204:50505 to 81.30.177.111:50505
[INFO] Mon Sep 22 15:15:13 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3933 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:15:12 2008 Blocked incoming UDP packet from 219.90.153.204:50505 to 81.30.177.111:50505
[INFO] Mon Sep 22 15:15:10 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3933 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:15:01 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3912 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:15:01 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:14:42 2008 Blocked incoming UDP packet from 219.90.153.204:50505 to 81.30.177.111:50505
[INFO] Mon Sep 22 15:14:42 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3880 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:14:39 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:14:34 2008 Blocked incoming TCP packet from 75.157.158.161:63139 to 81.30.177.111:3864 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 15:14:32 2008 Blocked incoming UDP packet from 219.90.153.204:50505 to 81.30.177.111:50505
[INFO] Mon Sep 22 15:14:30 2008 Blocked incoming UDP packet from 24.83.119.247:6881 to 81.30.177.111:45816
[INFO] Mon Sep 22 15:14:14 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3828 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:13:57 2008 Blocked incoming UDP packet from 219.90.153.204:50505 to 81.30.177.111:50505
[INFO] Mon Sep 22 15:13:40 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3781 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:13:36 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3778 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:13:36 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3781 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:13:32 2008 Blocked incoming UDP packet from 219.90.153.204:50505 to 81.30.177.111:50505
[INFO] Mon Sep 22 15:13:30 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3765 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:13:16 2008 Dropped TCP packet from 76.172.108.116:64429 to 81.30.177.111:6667 as unable to modify header options
[INFO] Mon Sep 22 15:13:16 2008 Blocked incoming UDP packet from 219.90.153.204:50505 to 81.30.177.111:50505
[INFO] Mon Sep 22 15:12:27 2008 Blocked incoming UDP packet from 210.229.215.59:27591 to 81.30.177.111:45816
[INFO] Mon Sep 22 15:12:17 2008 Blocked incoming UDP packet from 93.134.131.21:31708 to 81.30.177.111:45816
[INFO] Mon Sep 22 15:12:03 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3567 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:11:59 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:11:59 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3556 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:11:55 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:11:55 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3554 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:11:25 2008 Blocked incoming UDP packet from 172.27.22.149:3011 to 81.30.177.111:27015
[INFO] Mon Sep 22 15:11:06 2008 Blocked incoming UDP packet from 172.27.19.238:3976 to 81.30.177.111:27015
[INFO] Mon Sep 22 15:10:47 2008 Blocked incoming TCP packet from 75.157.158.161:60453 to 81.30.177.111:3398 as SYN:ACK received but there is no active connection
[INFO] Mon Sep 22 15:10:43 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3384 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:10:40 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:10:35 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3370 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:10:08 2008 Blocked outgoing TCP packet from 192.168.0.199:3296 to 76.28.23.59:55677 with unexpected sequence 1314092141 (expected 256443954 to 256575093)
[INFO] Mon Sep 22 15:10:05 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:09:29 2008 Blocked incoming TCP packet from 75.157.158.161:63836 to 81.30.177.111:3234 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 15:09:20 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3210 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:08:53 2008 Blocked incoming TCP packet from 75.157.158.161:63505 to 81.30.177.111:3151 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 15:08:05 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3033 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:07:02 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2876 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:06:03 2008 Blocked incoming UDP packet from 172.27.20.136:1701 to 81.30.177.111:27015
[INFO] Mon Sep 22 15:06:00 2008 Blocked incoming TCP connection request from 208.115.32.227:1657 to 81.30.177.111:2852
[INFO] Mon Sep 22 15:05:51 2008 Above message repeated 2 times
[INFO] Mon Sep 22 15:05:33 2008 Blocked incoming UDP packet from 78.84.230.173:62655 to 81.30.177.111:45816
[INFO] Mon Sep 22 15:05:23 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2620 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:05:18 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:04:37 2008 Blocked outgoing TCP packet from 83.167.112.163:35530 to 81.30.177.111:6667 with unexpected acknowledgement 3154442313 (expected 3154444539 to 3154575722)
[INFO] Mon Sep 22 15:04:32 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2494 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:04:27 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2464 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:04:23 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:04:19 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2454 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:04:19 2008 Blocked incoming TCP packet from 75.157.158.161:60991 to 81.30.177.111:2457 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 15:03:21 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2301 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:03:17 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:03:03 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2250 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:02:00 2008 Wireless system with MAC address 001DD98313A7 disconnected for reason: Timeout, station left.
[INFO] Mon Sep 22 15:01:56 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2072 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:01:53 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2071 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:01:14 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1996 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:01:10 2008 Above message repeated 1 times
[INFO] Mon Sep 22 15:00:50 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1946 and 192.168.1.10:26994
[INFO] Mon Sep 22 15:00:50 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:57:55 2008 Blocked incoming TCP packet from 75.157.158.161:61369 to 81.30.177.111:1626 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:57:24 2008 Blocked incoming TCP connection request from 67.80.10.154:48700 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:57:23 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1588 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:57:20 2008 Blocked incoming TCP connection request from 67.80.10.154:48700 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:57:13 2008 Above message repeated 6 times
[INFO] Mon Sep 22 14:57:10 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1572 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:57:09 2008 Blocked incoming TCP connection request from 67.80.10.154:36134 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:57:08 2008 Blocked incoming TCP connection request from 118.168.136.221:2149 to 81.30.177.111:3128
[INFO] Mon Sep 22 14:57:08 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 91.122.222.120:2162 as PSH:ACK received but there is no active connection
[INFO] Mon Sep 22 14:57:07 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1572 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:57:05 2008 Blocked incoming TCP connection request from 67.80.10.154:36134 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:57:04 2008 UPnP added entry 255.255.255.255 <-> 81.30.177.111:6667 <-> 192.168.0.199:6666 TCP timeout:-1 'uTorrent (TCP)'
[INFO] Mon Sep 22 14:57:04 2008 UPnP deleted entry 255.255.255.255 <-> 81.30.177.111:6667 TCP
[INFO] Mon Sep 22 14:57:03 2008 Blocked incoming TCP connection request from 67.80.10.154:36134 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:57:02 2008 Blocked incoming TCP connection request from 118.168.136.221:2149 to 81.30.177.111:3128
[INFO] Mon Sep 22 14:57:02 2008 Blocked incoming TCP connection request from 67.80.10.154:36134 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:57:00 2008 Above message repeated 2 times
[INFO] Mon Sep 22 14:56:59 2008 Blocked incoming TCP connection request from 118.168.136.221:2149 to 81.30.177.111:3128
[INFO] Mon Sep 22 14:56:59 2008 Blocked incoming TCP connection request from 67.80.10.154:36134 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:56:58 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:56:39 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1513 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:56:33 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:56:15 2008 Blocked incoming TCP connection request from 92.62.101.20:40644 to 81.30.177.111:1080
[INFO] Mon Sep 22 14:56:14 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1471 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:56:09 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:55:58 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1440 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:55:55 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:55:27 2008 Blocked incoming TCP packet from 75.157.158.161:60144 to 81.30.177.111:1390 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:55:24 2008 Blocked incoming UDP packet from 24.83.119.247:6881 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:55:24 2008 Blocked incoming TCP packet from 75.157.158.161:60093 to 81.30.177.111:1377 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:55:21 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1370 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:55:20 2008 Blocked incoming TCP packet from 75.157.158.161:60093 to 81.30.177.111:1377 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:54:59 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1309 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:54:55 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:54:55 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1297 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:54:43 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1247 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:54:43 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:54:22 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1172 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:54:18 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:54:18 2008 Blocked incoming TCP connection request from 89.163.96.86:27121 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:54:13 2008 Above message repeated 4 times
[INFO] Mon Sep 22 14:54:09 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1139 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:54:09 2008 Blocked incoming TCP connection request from 89.163.96.86:26998 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:54:08 2008 Blocked outgoing TCP packet from 83.167.112.163:21700 to 81.30.177.111:6666 with unexpected acknowledgement 3546168283 (expected 3546170509 to 3546301692)
[INFO] Mon Sep 22 14:54:06 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1139 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:54:02 2008 Blocked incoming TCP connection request from 89.163.96.86:26998 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:54:02 2008 Blocked outgoing TCP packet from 83.167.112.163:21700 to 81.30.177.111:6666 with unexpected acknowledgement 3544839510 (expected 3544841736 to 3544972919)
[INFO] Mon Sep 22 14:54:01 2008 Blocked incoming TCP connection request from 89.163.96.86:26998 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:53:58 2008 Above message repeated 3 times
[INFO] Mon Sep 22 14:53:55 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1108 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:52:38 2008 Blocked incoming UDP packet from 210.229.215.59:27591 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:52:21 2008 Blocked outgoing TCP packet from 83.167.112.163:21700 to 81.30.177.111:6666 with unexpected acknowledgement 3525058852 (expected 3525065158 to 3525196341)
[INFO] Mon Sep 22 14:52:19 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4866 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:52:11 2008 Blocked incoming UDP packet from 172.27.6.224:3393 to 81.30.177.111:27015
[INFO] Mon Sep 22 14:52:01 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4806 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:52:00 2008 Blocked outgoing TCP packet from 83.167.112.163:21700 to 81.30.177.111:6666 with unexpected acknowledgement 3520545340 (expected 3520604686 to 3520735869)
[INFO] Mon Sep 22 14:51:59 2008 Blocked outgoing TCP packet from 83.167.112.163:21700 to 81.30.177.111:6666 with unexpected acknowledgement 3520524940 (expected 3520555726 to 3520686909)
[INFO] Mon Sep 22 14:51:58 2008 Blocked outgoing TCP packet from 83.167.112.163:21700 to 81.30.177.111:6666 with unexpected acknowledgement 3520293740 (expected 3520301406 to 3520432589)
[INFO] Mon Sep 22 14:51:58 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4806 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:51:50 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4781 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:51:46 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:51:29 2008 Blocked outgoing TCP packet from 83.167.112.163:21700 to 81.30.177.111:6666 with unexpected acknowledgement 3513013857 (expected 3513017443 to 3513148626)
[INFO] Mon Sep 22 14:51:27 2008 Blocked incoming UDP packet from 91.64.41.26:59549 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:51:11 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4709 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:51:11 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:50:34 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4628 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:50:34 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:50:27 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4621 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:50:11 2008 Blocked outgoing TCP packet from 83.167.112.163:21700 to 81.30.177.111:6666 with unexpected acknowledgement 3500765375 (expected 3500827441 to 3500958624)
[INFO] Mon Sep 22 14:50:09 2008 Blocked outgoing TCP packet from 83.167.112.163:21700 to 81.30.177.111:6666 with unexpected acknowledgement 3500542463 (expected 3500558289 to 3500689472)
[INFO] Mon Sep 22 14:50:08 2008 Blocked incoming UDP packet from 172.27.21.53:1724 to 81.30.177.111:27015
[INFO] Mon Sep 22 14:50:05 2008 Blocked outgoing TCP packet from 83.167.112.20:15877 to 81.30.177.111:6666 with unexpected acknowledgement 3359682202 (expected 2862201247 to 2862332430)
[INFO] Mon Sep 22 14:49:53 2008 Above message repeated 2 times
[INFO] Mon Sep 22 14:49:33 2008 Blocked outgoing TCP packet from 83.167.112.163:21700 to 81.30.177.111:6666 with unexpected acknowledgement 3494796790 (expected 3494845256 to 3494976439)
[INFO] Mon Sep 22 14:49:29 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4505 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:49:26 2008 Blocked outgoing TCP packet from 83.167.112.163:21700 to 81.30.177.111:6666 with unexpected acknowledgement 3493578870 (expected 3493654536 to 3493785719)
[INFO] Mon Sep 22 14:49:25 2008 Blocked outgoing TCP packet from 83.167.112.163:21700 to 81.30.177.111:6666 with unexpected acknowledgement 3493451081 (expected 3493464136 to 3493595319)
[INFO] Mon Sep 22 14:49:24 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4505 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:49:16 2008 Blocked outgoing TCP packet from 83.167.112.163:21700 to 81.30.177.111:6666 with unexpected acknowledgement 3492324769 (expected 3492339235 to 3492470418)
[INFO] Mon Sep 22 14:48:46 2008 Blocked incoming TCP packet from 75.157.158.161:60776 to 81.30.177.111:4402 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:48:25 2008 Blocked incoming TCP packet from 75.157.158.161:60553 to 81.30.177.111:4357 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:48:14 2008 Blocked outgoing TCP packet from 83.167.112.20:65157 to 81.30.177.111:6666 with unexpected acknowledgement 2716950924 (expected 4042076806 to 4042207989)
[INFO] Mon Sep 22 14:48:14 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4315 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:48:10 2008 Blocked outgoing TCP packet from 83.167.112.20:65157 to 81.30.177.111:6666 with unexpected acknowledgement 2716950924 (expected 4042076806 to 4042207989)
[INFO] Mon Sep 22 14:48:02 2008 Above message repeated 2 times
[INFO] Mon Sep 22 14:47:41 2008 Blocked incoming TCP packet from 75.157.158.161:60168 to 81.30.177.111:4255 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:47:37 2008 Blocked outgoing TCP packet from 83.167.112.20:60783 to 81.30.177.111:6666 with unexpected acknowledgement 3177169132 (expected 4153607397 to 4153738580)
[INFO] Mon Sep 22 14:47:25 2008 Above message repeated 3 times
[INFO] Mon Sep 22 14:47:24 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4209 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:44:51 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3732 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:44:51 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3717 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:44:48 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:44:23 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3616 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:44:19 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:44:18 2008 Blocked incoming UDP packet from 172.27.25.192:4116 to 81.30.177.111:27015
[INFO] Mon Sep 22 14:44:10 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3585 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:43:26 2008 Blocked incoming UDP packet from 94.178.64.94:14070 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:38:40 2008 Blocked outgoing TCP packet from 192.168.0.199:2782 to 70.47.114.223:34000 with unexpected sequence 1724167491 (expected 1183123596 to 1183135618)
[INFO] Mon Sep 22 14:38:31 2008 Above message repeated 2 times
[INFO] Mon Sep 22 14:38:05 2008 Blocked incoming UDP packet from 202.111.175.48:42258 to 81.30.177.111:1026
[INFO] Mon Sep 22 14:38:05 2008 Blocked incoming UDP packet from 202.111.175.48:42261 to 81.30.177.111:1027
[INFO] Mon Sep 22 14:37:35 2008 Blocked incoming TCP connection request from 79.41.54.177:52425 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:37:29 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:37:17 2008 Blocked incoming TCP packet from 67.167.237.170:60119 to 81.30.177.111:2537 as SYN:ACK received but there is no active connection
[INFO] Mon Sep 22 14:37:14 2008 Blocked incoming TCP packet from 67.167.237.170:60119 to 81.30.177.111:2537 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:37:01 2008 UPnP added entry 255.255.255.255 <-> 81.30.177.111:6667 <-> 192.168.0.199:6666 TCP timeout:-1 'uTorrent (TCP)'
[INFO] Mon Sep 22 14:37:01 2008 UPnP deleted entry 255.255.255.255 <-> 81.30.177.111:6667 TCP
[INFO] Mon Sep 22 14:37:00 2008 Blocked incoming UDP packet from 202.97.238.201:55218 to 81.30.177.111:1026
[INFO] Mon Sep 22 14:36:13 2008 Blocked incoming TCP connection request from 89.178.191.74:2149 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:36:04 2008 Above message repeated 2 times
[INFO] Mon Sep 22 14:35:43 2008 Blocked incoming UDP packet from 86.125.69.144:9054 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:35:37 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2275 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:35:34 2008 Blocked incoming UDP packet from 172.27.26.199:1830 to 81.30.177.111:27015
[INFO] Mon Sep 22 14:35:33 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2275 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:35:20 2008 Blocked incoming UDP packet from 24.83.119.247:6881 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:35:12 2008 Blocked incoming TCP packet from 67.167.237.170:63417 to 81.30.177.111:2219 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:35:09 2008 Blocked incoming TCP packet from 67.167.237.170:63417 to 81.30.177.111:2219 as SYN:ACK received but there is no active connection
[INFO] Mon Sep 22 14:33:56 2008 Blocked incoming TCP connection request from 80.234.127.15:2226 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:33:47 2008 Above message repeated 2 times
[INFO] Mon Sep 22 14:33:46 2008 Blocked incoming TCP connection request from 58.213.117.66:64236 to 81.30.177.111:22
[INFO] Mon Sep 22 14:33:07 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2041 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:33:03 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:32:43 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2005 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:32:38 2008 Blocked incoming TCP packet from 67.167.237.170:62404 to 81.30.177.111:2002 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:32:35 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:32:12 2008 Blocked incoming UDP packet from 210.229.215.59:27591 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:32:00 2008 Blocked incoming TCP packet from 75.157.158.161:63714 to 81.30.177.111:1956 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:31:53 2008 Blocked incoming TCP connection request from 89.178.191.74:1759 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:31:44 2008 Above message repeated 2 times
[INFO] Mon Sep 22 14:31:31 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1910 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:31:27 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:31:23 2008 Blocked incoming TCP packet from 67.167.237.170:61939 to 81.30.177.111:1903 as SYN:ACK received but there is no active connection
[INFO] Mon Sep 22 14:31:23 2008 Blocked incoming TCP packet from 67.167.237.170:61939 to 81.30.177.111:1903 as ACK received but there is no active connection
[INFO] Mon Sep 22 14:30:46 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1836 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:30:42 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:30:21 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1779 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:30:10 2008 Blocked incoming TCP connection request from 89.178.191.74:1612 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:30:07 2008 Blocked incoming TCP connection request from 118.168.136.4:2632 to 81.30.177.111:3128
[INFO] Mon Sep 22 14:30:04 2008 Blocked incoming TCP connection request from 89.178.191.74:1612 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:30:01 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:30:01 2008 Blocked incoming TCP connection request from 118.168.136.4:2632 to 81.30.177.111:3128
[INFO] Mon Sep 22 14:29:58 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:29:51 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1710 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:29:24 2008 Blocked incoming TCP packet from 75.157.158.161:62242 to 81.30.177.111:1651 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:29:19 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1630 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:29:11 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1615 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:29:11 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:28:48 2008 Blocked incoming TCP packet from 72.86.95.24:61442 to 81.30.177.111:1551 as SYN:ACK received but there is no active connection
[INFO] Mon Sep 22 14:28:25 2008 Blocked incoming ICMP packet (ICMP type 8) from 81.30.173.155 to 81.30.177.111
[INFO] Mon Sep 22 14:28:17 2008 Blocked incoming TCP packet from 75.157.158.161:61405 to 81.30.177.111:1454 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:28:07 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1421 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:28:04 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:25:36 2008 Blocked incoming ICMP packet (ICMP type 8) from 81.30.168.90 to 81.30.177.111
[INFO] Mon Sep 22 14:25:14 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4967 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:25:11 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:24:58 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4923 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:24:55 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:24:50 2008 UPnP added entry 255.255.255.255 <-> 81.30.177.111:3658 <-> 192.168.0.198:3658 UDP timeout:14400 'EA Tunnel'
[INFO] Mon Sep 22 14:24:50 2008 UPnP deleted entry 255.255.255.255 <-> 81.30.177.111:3658 UDP
[INFO] Mon Sep 22 14:24:41 2008 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.198 to 159.153.250.74
[INFO] Mon Sep 22 14:24:41 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:24:26 2008 Blocked incoming UDP packet from 221.8.126.133:56046 to 81.30.177.111:1027
[INFO] Mon Sep 22 14:24:26 2008 Blocked incoming UDP packet from 221.8.126.133:56045 to 81.30.177.111:1026
[INFO] Mon Sep 22 14:23:44 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4768 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:23:40 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:23:26 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4723 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:23:26 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4725 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:22:36 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4557 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:22:35 2008 Blocked incoming UDP packet from 172.27.25.192:2797 to 81.30.177.111:27015
[INFO] Mon Sep 22 14:22:33 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4557 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:22:21 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4516 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:22:10 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4462 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:22:08 2008 Blocked incoming TCP packet from 75.157.158.161:61856 to 81.30.177.111:4454 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:22:04 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:21:43 2008 Blocked incoming UDP packet from 78.31.182.17:59171 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:21:18 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4302 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:21:03 2008 Blocked incoming TCP connection request from 82.131.5.252:1709 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:21:00 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:20:04 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4026 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:20:01 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:19:53 2008 Blocked incoming TCP packet from 75.157.158.161:60669 to 81.30.177.111:3995 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:19:38 2008 Blocked incoming UDP packet from 202.97.238.235:49548 to 81.30.177.111:1026
[INFO] Mon Sep 22 14:19:07 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3838 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:18:44 2008 Blocked incoming TCP connection request from 118.168.139.210:1202 to 81.30.177.111:8080
[INFO] Mon Sep 22 14:18:35 2008 Above message repeated 2 times
[INFO] Mon Sep 22 14:18:32 2008 Blocked incoming TCP connection request from 118.168.139.210:4165 to 81.30.177.111:80
[INFO] Mon Sep 22 14:18:27 2008 Administrator logout
[INFO] Mon Sep 22 14:18:26 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3705 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:18:26 2008 Blocked incoming TCP connection request from 118.168.139.210:4165 to 81.30.177.111:80
[INFO] Mon Sep 22 14:18:23 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3705 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:18:23 2008 Blocked incoming TCP connection request from 118.168.139.210:4165 to 81.30.177.111:80
[INFO] Mon Sep 22 14:18:20 2008 Blocked incoming TCP packet from 67.167.237.170:63417 to 81.30.177.111:3679 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:18:17 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:18:12 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3652 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:18:09 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:17:51 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3592 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:17:40 2008 Blocked incoming UDP packet from 202.97.238.206:34008 to 81.30.177.111:1027
[INFO] Mon Sep 22 14:17:20 2008 Blocked incoming TCP packet from 24.189.41.71:61574 to 81.30.177.111:3531 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:17:17 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:17:00 2008 UPnP added entry 255.255.255.255 <-> 81.30.177.111:6667 <-> 192.168.0.199:6666 TCP timeout:-1 'uTorrent (TCP)'
[INFO] Mon Sep 22 14:16:19 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:51126 with unexpected sequence 1272325973 (expected 1264055436 to 1267045518)
[INFO] Mon Sep 22 14:16:10 2008 Above message repeated 2 times
[INFO] Mon Sep 22 14:15:45 2008 Blocked incoming UDP packet from 86.125.69.144:9054 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:15:10 2008 Blocked incoming ICMP error message (ICMP type 3) from 71.233.44.56 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3233 and 192.168.1.100:51946
[INFO] Mon Sep 22 14:15:07 2008 Blocked incoming TCP packet from 24.189.41.71:61049 to 81.30.177.111:3228 as SYN:ACK received but there is no active connection
[INFO] Mon Sep 22 14:15:04 2008 Blocked incoming TCP packet from 24.189.41.71:61049 to 81.30.177.111:3228 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:14:50 2008 UPnP added entry 255.255.255.255 <-> 81.30.177.111:21101 <-> 192.168.0.198:21101 UDP timeout:14400 'EA Tunnel'
[INFO] Mon Sep 22 14:14:49 2008 Blocked incoming UDP packet from 159.153.250.74:21101 to 81.30.177.111:21101
[INFO] Mon Sep 22 14:14:49 2008 Above message repeated 7 times
[INFO] Mon Sep 22 14:14:48 2008 UPnP deleted entry 255.255.255.255 <-> 81.30.177.111:21101 UDP
[INFO] Mon Sep 22 14:14:41 2008 Blocked incoming TCP packet from 75.157.158.161:61901 to 81.30.177.111:3183 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:14:30 2008 UPnP added entry 255.255.255.255 <-> 81.30.177.111:3658 <-> 192.168.0.198:3658 UDP timeout:14400 'EA Tunnel'
[INFO] Mon Sep 22 14:14:30 2008 UPnP deleted entry 255.255.255.255 <-> 81.30.177.111:3658 UDP
[INFO] Mon Sep 22 14:14:21 2008 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.198 to 159.153.250.74
[INFO] Mon Sep 22 14:14:21 2008 Above message repeated 2 times
[INFO] Mon Sep 22 14:14:13 2008 Blocked incoming TCP packet from 24.189.41.71:60831 to 81.30.177.111:3129 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:14:10 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:13:50 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:59778 with unexpected sequence 3564164077 (expected 3556741221 to 3559731303)
[INFO] Mon Sep 22 14:13:41 2008 Above message repeated 2 times
[INFO] Mon Sep 22 14:13:00 2008 Blocked incoming UDP packet from 77.181.245.35:28111 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:12:10 2008 Blocked incoming UDP packet from 210.229.215.59:27591 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:12:09 2008 Blocked incoming UDP packet from 172.27.25.192:1501 to 81.30.177.111:27015
[INFO] Mon Sep 22 14:11:50 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2928 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:11:32 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2909 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:11:28 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2898 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:11:25 2008 Blocked incoming UDP packet from 172.27.14.39:1736 to 81.30.177.111:27015
[INFO] Mon Sep 22 14:10:43 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:36959 with unexpected sequence 2905054475 (expected 2896787205 to 2899777287)
[INFO] Mon Sep 22 14:10:43 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:36958 with unexpected sequence 3186899617 (expected 3178621078 to 3181611160)
[INFO] Mon Sep 22 14:10:38 2008 Blocked incoming TCP connection request from 92.62.101.21:48758 to 81.30.177.111:1080
[INFO] Mon Sep 22 14:10:37 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:36959 with unexpected sequence 2905054475 (expected 2896787205 to 2899777287)
[INFO] Mon Sep 22 14:10:37 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:36958 with unexpected sequence 3186899617 (expected 3178621078 to 3181611160)
[INFO] Mon Sep 22 14:10:35 2008 Blocked incoming ICMP packet (ICMP type 8) from 81.30.168.90 to 81.30.177.111
[INFO] Mon Sep 22 14:10:34 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:36959 with unexpected sequence 2905054475 (expected 2896787205 to 2899777287)
[INFO] Mon Sep 22 14:10:34 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:36958 with unexpected sequence 3186899617 (expected 3178621078 to 3181611160)
[INFO] Mon Sep 22 14:10:32 2008 Blocked incoming UDP packet from 77.181.245.35:28111 to 81.30.177.111:45816
[INFO] Mon Sep 22 14:10:08 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:60101 with unexpected sequence 4176513310 (expected 4166701826 to 4169691908)
[INFO] Mon Sep 22 14:10:08 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:60100 with unexpected sequence 2193889740 (expected 2184077400 to 2187067482)
[INFO] Mon Sep 22 14:10:02 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:60101 with unexpected sequence 4176513310 (expected 4166701826 to 4169691908)
[INFO] Mon Sep 22 14:10:02 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:60100 with unexpected sequence 2193889740 (expected 2184077400 to 2187067482)
[INFO] Mon Sep 22 14:09:59 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:60101 with unexpected sequence 4176513310 (expected 4166701826 to 4169691908)
[INFO] Mon Sep 22 14:09:59 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:60100 with unexpected sequence 2193889740 (expected 2184077400 to 2187067482)
[INFO] Mon Sep 22 14:09:49 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:57351 with unexpected sequence 2942125720 (expected 2932078950 to 2935069032)
[INFO] Mon Sep 22 14:09:49 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:57350 with unexpected sequence 3112519967 (expected 3102473199 to 3105463281)
[INFO] Mon Sep 22 14:09:48 2008 UPnP added entry 255.255.255.255 <-> 81.30.177.111:21101 <-> 192.168.0.198:21101 UDP timeout:14400 'EA Tunnel'
[INFO] Mon Sep 22 14:09:43 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:57351 with unexpected sequence 2942125720 (expected 2932078950 to 2935069032)
[INFO] Mon Sep 22 14:09:43 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:57350 with unexpected sequence 3112519967 (expected 3102473199 to 3105463281)
[INFO] Mon Sep 22 14:09:40 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:57351 with unexpected sequence 2942125720 (expected 2932078950 to 2935069032)
[INFO] Mon Sep 22 14:09:40 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:57350 with unexpected sequence 3112519967 (expected 3102473199 to 3105463281)
[INFO] Mon Sep 22 14:09:39 2008 Blocked incoming UDP packet from 159.153.250.74:21101 to 81.30.177.111:21101
[INFO] Mon Sep 22 14:09:34 2008 Blocked incoming TCP packet from 24.189.41.71:60095 to 81.30.177.111:2605 as SYN:ACK received but there is no active connection
[INFO] Mon Sep 22 14:09:31 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:09:30 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2581 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:09:26 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:09:15 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:52325 with unexpected sequence 1217948758 (expected 1207945753 to 1210935835)
[INFO] Mon Sep 22 14:09:15 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:52323 with unexpected sequence 1629767571 (expected 1619757014 to 1622747096)
[INFO] Mon Sep 22 14:09:09 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:52325 with unexpected sequence 1217948758 (expected 1207945753 to 1210935835)
[INFO] Mon Sep 22 14:09:09 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:52323 with unexpected sequence 1629767571 (expected 1619757014 to 1622747096)
[INFO] Mon Sep 22 14:09:08 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2472 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:09:06 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:52325 with unexpected sequence 1217948758 (expected 1207945753 to 1210935835)
[INFO] Mon Sep 22 14:09:06 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:52323 with unexpected sequence 1629767571 (expected 1619757014 to 1622747096)
[INFO] Mon Sep 22 14:08:47 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2391 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:08:44 2008 UPnP added entry 255.255.255.255 <-> 81.30.177.111:3658 <-> 192.168.0.198:3658 UDP timeout:14400 'EA Tunnel'
[INFO] Mon Sep 22 14:08:44 2008 UPnP deleted entry 255.255.255.255 <-> 81.30.177.111:3658 UDP
[INFO] Mon Sep 22 14:08:42 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:47696 with unexpected sequence 3651668895 (expected 3641408164 to 3644398246)
[INFO] Mon Sep 22 14:08:41 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:47551 with unexpected sequence 313308361 (expected 303083056 to 306073138)
[INFO] Mon Sep 22 14:08:36 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:47696 with unexpected sequence 3651668895 (expected 3641408164 to 3644398246)
[INFO] Mon Sep 22 14:08:35 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:47551 with unexpected sequence 313308361 (expected 303083056 to 306073138)
[INFO] Mon Sep 22 14:08:35 2008 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.198 to 159.153.194.203
[INFO] Mon Sep 22 14:08:35 2008 Above message repeated 3 times
[INFO] Mon Sep 22 14:08:33 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:47696 with unexpected sequence 3651668895 (expected 3641408164 to 3644398246)
[INFO] Mon Sep 22 14:08:32 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:47551 with unexpected sequence 313308361 (expected 303083056 to 306073138)
[INFO] Mon Sep 22 14:08:23 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:44720 with unexpected sequence 4228511003 (expected 4217935533 to 4220925615)
[INFO] Mon Sep 22 14:08:22 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:44543 with unexpected sequence 1953447037 (expected 1942673164 to 1945663246)
[INFO] Mon Sep 22 14:08:22 2008 Blocked incoming TCP packet from 67.167.237.170:63376 to 81.30.177.111:2253 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:08:21 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:44426 with unexpected sequence 2148635116 (expected 2137785688 to 2140775770)
[INFO] Mon Sep 22 14:08:21 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:44425 with unexpected sequence 3629286029 (expected 3618448228 to 3621438310)
[INFO] Mon Sep 22 14:08:19 2008 Blocked incoming TCP packet from 67.167.237.170:63376 to 81.30.177.111:2253 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:08:17 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:44720 with unexpected sequence 4228511003 (expected 4217935533 to 4220925615)
[INFO] Mon Sep 22 14:08:16 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:44543 with unexpected sequence 1953447037 (expected 1942673164 to 1945663246)
[INFO] Mon Sep 22 14:08:15 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:44426 with unexpected sequence 2148635116 (expected 2137785688 to 2140775770)
[INFO] Mon Sep 22 14:08:15 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:44425 with unexpected sequence 3629286029 (expected 3618448228 to 3621438310)
[INFO] Mon Sep 22 14:08:14 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:44720 with unexpected sequence 4228511003 (expected 4217935533 to 4220925615)
[INFO] Mon Sep 22 14:08:13 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:44543 with unexpected sequence 1953447037 (expected 1942673164 to 1945663246)
[INFO] Mon Sep 22 14:08:12 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:44426 with unexpected sequence 2148635116 (expected 2137785688 to 2140775770)
[INFO] Mon Sep 22 14:08:12 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:44425 with unexpected sequence 3629286029 (expected 3618448228 to 3621438310)
[INFO] Mon Sep 22 14:08:12 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2202 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:07:56 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2089 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:07:54 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:46495 with unexpected sequence 2660116615 (expected 2650340285 to 2653330367)
[INFO] Mon Sep 22 14:07:52 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:2089 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:07:48 2008 Blocked outgoing TCP packet from 192.168.0.199:6666 to 70.47.114.223:46495 with unexpected sequence 2660116615 (expected 2650340285 to 2653330367)
[INFO] Mon Sep 22 14:07:45 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:07:31 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1973 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:07:26 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:07:21 2008 UPnP added entry 255.255.255.255 <-> 81.30.177.111:21106 <-> 192.168.0.198:21106 UDP timeout:14400 'EA Tunnel'
[INFO] Mon Sep 22 14:07:13 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1901 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:07:02 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1833 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:06:58 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:06:53 2008 Blocked incoming TCP packet from 75.157.158.161:62195 to 81.30.177.111:1807 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:06:41 2008 UPnP added entry 255.255.255.255 <-> 81.30.177.111:3658 <-> 192.168.0.198:3658 UDP timeout:14400 'EA Tunnel'
[INFO] Mon Sep 22 14:06:41 2008 Blocked incoming TCP packet from 72.86.95.24:62047 to 81.30.177.111:1784 as SYN:ACK received but there is no active connection
[WARN] Mon Sep 22 14:06:32 2008 A network computer (001DD98313A7) was assigned the IP address of 192.168.0.198.
[INFO] Mon Sep 22 14:06:29 2008 Wireless system with MAC address 001DD98313A7 associated
[INFO] Mon Sep 22 14:06:24 2008 Blocked incoming UDP packet from 172.27.20.136:1717 to 81.30.177.111:27015
[INFO] Mon Sep 22 14:05:43 2008 Blocked incoming TCP packet from 67.167.237.170:62284 to 81.30.177.111:1576 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:05:40 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:05:35 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1539 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:05:32 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:04:22 2008 Blocked incoming UDP packet from 202.97.238.231:46702 to 81.30.177.111:1026
[INFO] Mon Sep 22 14:03:44 2008 Blocked incoming TCP connection request from 118.168.141.52:1167 to 81.30.177.111:8000
[INFO] Mon Sep 22 14:03:35 2008 Above message repeated 2 times
[INFO] Mon Sep 22 14:03:32 2008 Blocked incoming TCP connection request from 118.168.141.52:2645 to 81.30.177.111:80
[INFO] Mon Sep 22 14:03:23 2008 Above message repeated 2 times
[INFO] Mon Sep 22 14:03:20 2008 Blocked incoming TCP connection request from 118.168.141.52:4713 to 81.30.177.111:1080
[INFO] Mon Sep 22 14:03:11 2008 Above message repeated 2 times
[INFO] Mon Sep 22 14:02:29 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1148 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:02:26 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:01:42 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1037 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:01:42 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:1025 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:01:39 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:01:36 2008 Blocked incoming TCP packet from 67.167.237.170:60694 to 81.30.177.111:4994 as SYN:ACK received but there is no active connection
[INFO] Mon Sep 22 14:01:35 2008 Blocked incoming ICMP packet (ICMP type 8) from 81.30.168.90 to 81.30.177.111
[INFO] Mon Sep 22 14:01:33 2008 Blocked incoming TCP packet from 67.167.237.170:60694 to 81.30.177.111:4994 as SYN:ACK received but there is no active connection
[INFO] Mon Sep 22 14:01:06 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4851 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:00:54 2008 Blocked incoming TCP packet from 81.109.84.129:61457 to 81.30.177.111:4811 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 14:00:51 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:00:50 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4796 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:00:24 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4644 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:00:20 2008 Above message repeated 1 times
[INFO] Mon Sep 22 14:00:05 2008 Blocked incoming TCP packet from 67.167.237.170:60142 to 81.30.177.111:4549 as SYN:ACK received but there is no active connection
[INFO] Mon Sep 22 14:00:04 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4548 and 192.168.1.10:26994
[INFO] Mon Sep 22 14:00:02 2008 Blocked incoming TCP packet from 67.167.237.170:60142 to 81.30.177.111:4549 as SYN:ACK received but there is no active connection
[INFO] Mon Sep 22 13:59:43 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4429 and 192.168.1.10:26994
[INFO] Mon Sep 22 13:59:40 2008 Above message repeated 1 times
[INFO] Mon Sep 22 13:59:20 2008 Blocked incoming TCP packet from 75.157.158.161:62247 to 81.30.177.111:4320 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 13:58:55 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:4209 and 192.168.1.10:26994
[INFO] Mon Sep 22 13:58:28 2008 Blocked incoming TCP packet from 88.66.61.15:61639 to 81.30.177.111:4070 as SYN:ACK received but there is no active connection
[INFO] Mon Sep 22 13:58:25 2008 Above message repeated 1 times
[INFO] Mon Sep 22 13:58:17 2008 Blocked incoming TCP packet from 75.157.158.161:61663 to 81.30.177.111:4020 as SYN:ACK received but there is no active connection
[INFO] Mon Sep 22 13:58:14 2008 Blocked incoming TCP packet from 75.157.158.161:61663 to 81.30.177.111:4020 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 13:58:14 2008 Blocked incoming TCP packet from 81.109.84.129:60580 to 81.30.177.111:4007 as SYN:ACK received but there is no active connection
[INFO] Mon Sep 22 13:58:11 2008 Blocked incoming TCP packet from 81.109.84.129:60580 to 81.30.177.111:4007 as RST:ACK received but there is no active connection
[INFO] Mon Sep 22 13:58:01 2008 Log viewed by IP address 192.168.0.199
[INFO] Mon Sep 22 13:57:59 2008 Blocked incoming TCP connection request from 118.168.136.221:1491 to 81.30.177.111:3128
[INFO] Mon Sep 22 13:57:50 2008 Above message repeated 2 times
[INFO] Mon Sep 22 13:57:15 2008 Blocked incoming ICMP error message (ICMP type 3) from 85.140.199.155 to 81.30.177.111 as there is no TCP connection active between 81.30.177.111:3819 and 192.168.1.10:26994
[INFO] Mon Sep 22 13:57:01 2008 Dropped packet from 192.168.0.199 to 255.255.255.255 (IP protocol 6) as unable to create new session
[INFO] Mon Sep 22 13:57:01 2008 UPnP added entry 255.255.255.255 <-> 81.30.177.111:6667 <-> 192.168.0.199:6666 TCP timeout:-1 'uTorrent (TCP)'
СообщениеДобавлено: Пн сен 22, 2008 15:51
Ищем на странице слово:
WAN interface is down
И почему-то информация автора не подтверждается.
Автору:
1) вас хакеры/вирусня долбит
2) убейте IPv6 на компах
СообщениеДобавлено: Пн сен 22, 2008 17:00
Автору:
Не понял, что значит:
1. Хакеры меня не могут долбить, роутер в инвизе. Вирусня хм... NOD32 с последними обновлениями молчит.
2. Как отключить IPv6 в Линуксе, знаю. А вот как в Виндах...!
К тому же, какая может быть связь компьютера с разрывами связи между роутером и провом, если в данном случае, компьютер ни как не задействуется в этом процессе?!
СообщениеДобавлено: Пн сен 22, 2008 21:16
Аллё, Тех.поддержка? От чего происходят разрывы?
Достало уже. Каждые пол часа разрыв, разрыв...
СообщениеДобавлено: Вт сен 23, 2008 12:01
Если бы у вас реально отваливался бы линк, ну или падал бы PPTP клиент, это бы отображалось в логах. Я такого не нашел, чтобы каждые полчаса в даун уходил интерфейс. Вижу только что роутер с нуля запущен, и работает.
Не ваш компьютер, а роутер, опять же в логах:
INFO] Mon Sep 22 13:54:31 2008 Blocked incoming TCP packet from 71.60.15.29:60774 to 81.30.177.111:3188 as SYN:ACK received but there is no active connection
Галочку снять с протокола IPv6 в подключении по локальной сети (Vista), или если получится вообще его удалить (XP).
Вот с этим вопросом можно ещё обратиться к прову, может быть они логи свои поднимут и скажу, из-за чего связь может обрываться.
Вот например:
[WARN] Mon Sep 22 15:27:48 2008 The remote PPTP access concentrator is slow to respond. There may be connectivity problems.
Сейчас этот форум просматривают: Baidu [Spider] и гости: 56
