Текущее время: Чт окт 01, 2026 00:12
СообщениеДобавлено: Пт авг 15, 2008 10:47
Здравствуйте!
Далее приведены выдержки LOG файла DI-808HV (Firmware Version: V1.50b08, Wed, Jun 18 2008) IP = 194.67.57.226
Подскажите, почему не устанавливается соединение TUNNEL_2?
На другом конце DI-824VUP (TUNNEL_1) и DI-804HV (TUNNEL_2) настройки идентичные в соответствии с FAQ, антивирусы и файерволы отключены...
============ TUNNEL_1 ===============
Friday August 15, 2008 10:15:31 Send IKE M1(INIT) : 194.67.57.226 --> 194.186.36.229
Friday August 15, 2008 10:15:32 Receive IKE M2(RESP) : 194.186.36.229 --> 194.67.57.226
Friday August 15, 2008 10:15:32 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group2
Friday August 15, 2008 10:15:32 Send IKE M3(KEYINIT) : 194.67.57.226 --> 194.186.36.229
Friday August 15, 2008 10:15:32 Receive IKE M4(KEYRESP) : 194.186.36.229 --> 194.67.57.226
Friday August 15, 2008 10:15:33 Send IKE M5(IDINIT) : 194.67.57.226 --> 194.186.36.229
Friday August 15, 2008 10:15:33 Receive IKE M6(IDRESP) : 194.186.36.229 --> 194.67.57.226
Friday August 15, 2008 10:15:33 IKE Phase1 (ISAKMP SA) established : 194.186.36.229 <-> 194.67.57.226
Friday August 15, 2008 10:15:33 Send IKE Q1(QINIT) : 192.168.0.0 --> 192.168.1.0
Friday August 15, 2008 10:15:34 Receive IKE Q2(QRESP) : [192.168.1.0|194.186.36.229]-->[194.67.57.226|192.168.0.0]
Friday August 15, 2008 10:15:34 Try to match ESP with MODE:Tunnel PROTOCAL:ESP-3DES AUTH:MD5 HASH:Others PFS(Group):NONE
Friday August 15, 2008 10:15:34 Send IKE Q3(QHASH) : 192.168.0.0 --> 192.168.1.0
Friday August 15, 2008 10:15:34 IKE Phase2 (IPSEC SA) established : [192.168.1.0|194.186.36.229]<->[194.67.57.226|192.168.0.0]
Friday August 15, 2008 10:15:34 inbound SPI = 0x3b005a10, outbound SPI = 0x14000010
============ TUNNEL_2 ===============
Friday August 15, 2008 10:23:50 Send IKE M1(INIT) : 194.67.57.226 --> 207.46.232.182
Friday August 15, 2008 10:23:55 IKED re-TX : INIT to 207.46.232.182
Friday August 15, 2008 10:24:00 IKED re-TX : INIT to 207.46.232.182
Friday August 15, 2008 10:24:10 IKED re-TX : INIT to 207.46.232.182
Friday August 15, 2008 10:24:20 IKED re-TX : INIT to 207.46.232.182
Friday August 15, 2008 10:24:40 IKED re-TX : INIT to 207.46.232.182
Friday August 15, 2008 10:24:41 Send IKE (INFO) : delete 194.67.57.226 -> 207.46.232.182 phase 1
Friday August 15, 2008 10:24:41 IKE phase1 (ISAKMP SA) remove : 194.67.57.226 <-> 207.46.232.182
СообщениеДобавлено: Пт авг 15, 2008 13:56
А на маршруте 2 провайдер не блокирует протокол, используемый для первой фазы IKE (IP 50 или 51)?
СообщениеДобавлено: Пт авг 15, 2008 15:16
Клянется что нет. Существует-ли метод, как это можно установить?
СообщениеДобавлено: Пт авг 15, 2008 15:44
Самому интересно. В принципе, устанавливаемые роутеры и являются такой утилитой :)
В спорных случаях можно проверить, что на стенде соединение происходит. Если да, то проблема явно провайдера. Если нет, то настраиваешь, пока не заработает.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 151
