Текущее время: Пт окт 30, 2026 22:46
Начать новую тему Эта тема закрыта, Вы не можете редактировать и оставлять сообщения в ней.  [ Сообщений: 386 ]  На страницу Пред.  1, 2, 3, 4, 5, 6, 7, 8 ... 26  След.
СообщениеДобавлено: Вт июл 22, 2008 17:36
спасибо. хоть ответили.
СообщениеДобавлено: Вт июл 22, 2008 20:12
тех поддержка что скажите на эти логи ужасный дисконект подряд раз 10,(((((((((((((((((((((((
[INFO] Mon Jul 21 00:42:34 2008 Log viewed by IP address 192.168.10.199
[INFO] Mon Jul 21 00:42:21 2008 Blocked incoming UDP packet from 172.27.16.1:3102 to 81.30.223.94:27015
[WARN] Mon Jul 21 00:41:29 2008 The remote PPTP access concentrator is slow to respond. There may be connectivity problems.
[INFO] Mon Jul 21 00:41:03 2008 Starting WAN Services
[INFO] Mon Jul 21 00:41:03 2008 WAN interface is up. Connection to Internet established with IP Address 81.30.223.94 and default gateway 10.8.0.8
[INFO] Mon Jul 21 00:41:03 2008 PPP network up with IP Address 81.30.223.94
[INFO] Mon Jul 21 00:41:02 2008 WAN interface is down
[INFO] Mon Jul 21 00:41:01 2008 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Jul 21 00:41:01 2008 LCP sets remote auth: C223
[INFO] Mon Jul 21 00:41:01 2008 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1460
[INFO] Mon Jul 21 00:41:01 2008 PPTP connected to server "drs20.ufanet.ru" with ID 0xA444
[INFO] Mon Jul 21 00:41:01 2008 The PPTP transmit window is 16
[INFO] Mon Jul 21 00:41:01 2008 Attempting to establish a PPTP connection.
[INFO] Mon Jul 21 00:40:31 2008 WAN interface is down
[INFO] Mon Jul 21 00:40:31 2008 PPTP tunnel ID 0x36E4 has been closed
[INFO] Mon Jul 21 00:40:31 2008 PPTP received a tunnel clear down request from the application, the tunnel will now be closed.
[INFO] Mon Jul 21 00:40:31 2008 PPP network down
[INFO] Mon Jul 21 00:40:31 2008 LCP sets remote auth: 00000000
[INFO] Mon Jul 21 00:40:31 2008 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Jul 21 00:40:31 2008 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Jul 21 00:40:30 2008 Stopping WAN Services
[INFO] Mon Jul 21 00:40:30 2008 WAN interface is down
[INFO] Mon Jul 21 00:40:30 2008 PPP network down
[INFO] Mon Jul 21 00:39:51 2008 Log viewed by IP address 192.168.10.199
[INFO] Mon Jul 21 00:38:59 2008 Above message repeated 1 times
[INFO] Mon Jul 21 00:38:18 2008 Blocked incoming UDP packet from 125.211.198.10:54004 to 92.50.167.117:1026
[WARN] Mon Jul 21 00:37:20 2008 The remote PPTP access concentrator is slow to respond. There may be connectivity problems.
[INFO] Mon Jul 21 00:37:01 2008 Blocked outgoing TCP packet from 192.168.10.199:52227 to 213.234.18.14:12750 as ACK received but there is no active connection
[INFO] Mon Jul 21 00:37:01 2008 Starting WAN Services
[INFO] Mon Jul 21 00:37:01 2008 WAN interface is up. Connection to Internet established with IP Address 92.50.167.117 and default gateway 10.8.0.8
[INFO] Mon Jul 21 00:37:01 2008 PPP network up with IP Address 92.50.167.117
[INFO] Mon Jul 21 00:37:01 2008 WAN interface is down
[INFO] Mon Jul 21 00:37:00 2008 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Jul 21 00:37:00 2008 LCP sets remote auth: C223
[INFO] Mon Jul 21 00:37:00 2008 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1460
[INFO] Mon Jul 21 00:37:00 2008 PPTP connected to server "drs20.ufanet.ru" with ID 0x36E4
[INFO] Mon Jul 21 00:37:00 2008 The PPTP transmit window is 16
[INFO] Mon Jul 21 00:37:00 2008 Attempting to establish a PPTP connection.
[INFO] Mon Jul 21 00:36:30 2008 PPP network down
[INFO] Mon Jul 21 00:36:30 2008 WAN interface is down
[INFO] Mon Jul 21 00:36:30 2008 PPTP tunnel ID 0x13CB has been closed
[INFO] Mon Jul 21 00:36:30 2008 Stopping WAN Services
[INFO] Mon Jul 21 00:35:48 2008 Blocked incoming UDP packet from 221.206.121.10:49446 to 77.79.152.135:1027
[INFO] Mon Jul 21 00:35:48 2008 Blocked incoming UDP packet from 221.206.121.10:49445 to 77.79.152.135:1026
[INFO] Mon Jul 21 00:34:58 2008 Log viewed by IP address 192.168.10.199
[INFO] Mon Jul 21 00:34:52 2008 Blocked incoming TCP connection request from 141.13.16.201:45628 to 77.79.152.135:25
[WARN] Mon Jul 21 00:34:48 2008 The remote PPTP access concentrator is slow to respond. There may be connectivity problems.
[INFO] Mon Jul 21 00:34:37 2008 Blocked outgoing TCP packet from 192.168.10.199:52037 to 93.81.253.138:43220 as RST:ACK received but there is no active connection
[INFO] Mon Jul 21 00:34:06 2008 Starting WAN Services
[INFO] Mon Jul 21 00:34:06 2008 WAN interface is up. Connection to Internet established with IP Address 77.79.152.135 and default gateway 10.8.0.8
[INFO] Mon Jul 21 00:34:06 2008 PPP network up with IP Address 77.79.152.135
[INFO] Mon Jul 21 00:34:05 2008 WAN interface is down
[INFO] Mon Jul 21 00:34:05 2008 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Jul 21 00:34:05 2008 LCP sets remote auth: C223
[INFO] Mon Jul 21 00:34:05 2008 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1460
[INFO] Mon Jul 21 00:34:05 2008 PPTP connected to server "drs20.ufanet.ru" with ID 0x13CB
[INFO] Mon Jul 21 00:34:05 2008 The PPTP transmit window is 16
[INFO] Mon Jul 21 00:34:05 2008 Attempting to establish a PPTP connection.
[INFO] Mon Jul 21 00:33:35 2008 WAN interface is down
[INFO] Mon Jul 21 00:33:35 2008 PPTP tunnel ID 0x11A5 has been closed
[INFO] Mon Jul 21 00:33:35 2008 PPTP received a tunnel clear down request from the application, the tunnel will now be closed.
[INFO] Mon Jul 21 00:33:35 2008 PPP network down
[INFO] Mon Jul 21 00:33:35 2008 LCP sets remote auth: 00000000
[INFO] Mon Jul 21 00:33:35 2008 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Jul 21 00:33:35 2008 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Jul 21 00:33:34 2008 Stopping WAN Services
[INFO] Mon Jul 21 00:33:34 2008 WAN interface is down
[INFO] Mon Jul 21 00:33:34 2008 PPP network down
[INFO] Mon Jul 21 00:33:29 2008 Blocked incoming TCP connection request from 77.79.178.137:1453 to 77.79.168.88:26847
[INFO] Mon Jul 21 00:33:20 2008 Above message repeated 2 times
[INFO] Mon Jul 21 00:32:47 2008 Blocked incoming TCP connection request from 77.79.178.137:1414 to 77.79.168.88:26847
[INFO] Mon Jul 21 00:32:38 2008 Above message repeated 2 times
[INFO] Mon Jul 21 00:31:54 2008 Blocked incoming TCP packet from 61.191.56.123:80 to 77.79.168.88:40968 as SYN:ACK received but there is no active connection
[INFO] Mon Jul 21 00:31:52 2008 Above message repeated 1 times
[INFO] Mon Jul 21 00:31:48 2008 Blocked incoming TCP connection request from 189.42.177.129:63249 to 77.79.168.88:26847
[INFO] Mon Jul 21 00:31:45 2008 Above message repeated 1 times
[INFO] Mon Jul 21 00:30:55 2008 Blocked incoming TCP connection request from 189.42.177.129:59950 to 77.79.168.88:26847
[INFO] Mon Jul 21 00:30:52 2008 Above message repeated 1 times
[WARN] Mon Jul 21 00:30:32 2008 The remote PPTP access concentrator is slow to respond. There may be connectivity problems.
[INFO] Mon Jul 21 00:30:31 2008 Blocked incoming ICMP error message (ICMP type 3) from 59.149.207.73 to 77.79.168.88 as there is no UDP session active between 77.79.168.88:5010 and 192.168.0.100:44675
[INFO] Mon Jul 21 00:30:18 2008 Blocked incoming ICMP error message (ICMP type 3) from 125.24.154.156 to 77.79.168.88 as there is no UDP session active between 77.79.168.88:5010 and 192.168.1.6:59766
[INFO] Mon Jul 21 00:28:38 2008 Blocked incoming UDP packet from 122.141.76.3:52250 to 77.79.168.88:1027
[INFO] Mon Jul 21 00:28:38 2008 Blocked incoming UDP packet from 122.141.76.3:52249 to 77.79.168.88:1026
[INFO] Mon Jul 21 00:28:24 2008 Blocked incoming UDP packet from 125.211.198.18:47774 to 77.79.168.88:1027
[INFO] Mon Jul 21 00:28:24 2008 Blocked incoming UDP packet from 125.211.198.18:47774 to 77.79.168.88:1026
[INFO] Mon Jul 21 00:28:00 2008 UPnP added entry 255.255.255.255 <-> 77.79.168.88:5010 <-> 192.168.10.199:5010 TCP timeout:-1 'utorrent'
[INFO] Mon Jul 21 00:27:02 2008 Blocked incoming UDP packet from 221.130.195.124:54398 to 77.79.168.88:1027
[INFO] Mon Jul 21 00:26:15 2008 Blocked incoming TCP connection request from 189.42.177.129:63427 to 77.79.168.88:26847
[INFO] Mon Jul 21 00:26:07 2008 Above message repeated 2 times
[INFO] Mon Jul 21 00:23:14 2008 Blocked incoming TCP connection request from 189.42.177.129:55236 to 77.79.168.88:26847
[INFO] Mon Jul 21 00:23:08 2008 Above message repeated 1 times
[INFO] Mon Jul 21 00:23:04 2008 Starting WAN Services
[INFO] Mon Jul 21 00:23:04 2008 WAN interface is up. Connection to Internet established with IP Address 77.79.168.88 and default gateway 10.8.0.8
[INFO] Mon Jul 21 00:23:04 2008 PPP network up with IP Address 77.79.168.88
[INFO] Mon Jul 21 00:23:04 2008 WAN interface is down
[INFO] Mon Jul 21 00:23:04 2008 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Jul 21 00:23:04 2008 LCP sets remote auth: C223
[INFO] Mon Jul 21 00:23:04 2008 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1460
[INFO] Mon Jul 21 00:23:04 2008 PPTP connected to server "drs20.ufanet.ru" with ID 0x11A5
[INFO] Mon Jul 21 00:23:04 2008 The PPTP transmit window is 16
[INFO] Mon Jul 21 00:23:04 2008 Attempting to establish a PPTP connection.
[INFO] Mon Jul 21 00:22:57 2008 Wireless system with MAC address 001CF01041ED disconnected for reason: Timeout, station left.
[INFO] Mon Jul 21 00:22:34 2008 WAN interface is down
[INFO] Mon Jul 21 00:22:34 2008 PPTP tunnel ID 0x301F has been closed
[INFO] Mon Jul 21 00:22:34 2008 PPTP received a tunnel clear down request from the application, the tunnel will now be closed.
[INFO] Mon Jul 21 00:22:34 2008 PPP network down
[INFO] Mon Jul 21 00:22:34 2008 LCP sets remote auth: 00000000
[INFO] Mon Jul 21 00:22:34 2008 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Jul 21 00:22:34 2008 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Jul 21 00:22:33 2008 Stopping WAN Services
[INFO] Mon Jul 21 00:22:33 2008 WAN interface is down
[INFO] Mon Jul 21 00:22:33 2008 PPP network down
[INFO] Mon Jul 21 00:20:20 2008 Log viewed by IP address 192.168.10.199
[INFO] Mon Jul 21 00:20:17 2008 Allowed configuration authentication by IP address 192.168.10.199
[WARN] Mon Jul 21 00:19:15 2008 The remote PPTP access concentrator is slow to respond. There may be connectivity problems.
[INFO] Mon Jul 21 00:16:32 2008 Blocked outgoing TCP packet from 192.168.10.199:51890 to 93.172.102.149:20800 as RST:ACK received but there is no active connection
[INFO] Mon Jul 21 00:16:23 2008 Blocked incoming ICMP error message (ICMP type 3) from 76.175.122.231 to 89.189.135.222 as there is no UDP session active between 89.189.135.222:5010 and 76.175.122.231:46202
[INFO] Mon Jul 21 00:16:05 2008 Blocked incoming ICMP error message (ICMP type 3) from 219.79.3.46 to 89.189.135.222 as there is no UDP session active between 89.189.135.222:5010 and 192.168.11.2:61555
[INFO] Mon Jul 21 00:15:42 2008 Blocked incoming TCP connection request from 193.138.232.17:45716 to 89.189.135.222:1080
[INFO] Mon Jul 21 00:15:34 2008 Starting WAN Services
[INFO] Mon Jul 21 00:15:34 2008 WAN interface is up. Connection to Internet established with IP Address 89.189.135.222 and default gateway 10.8.0.8
[INFO] Mon Jul 21 00:15:34 2008 PPP network up with IP Address 89.189.135.222
[INFO] Mon Jul 21 00:15:33 2008 WAN interface is down
[INFO] Mon Jul 21 00:15:33 2008 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Jul 21 00:15:33 2008 LCP sets remote auth: C223
[INFO] Mon Jul 21 00:15:33 2008 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1460
[INFO] Mon Jul 21 00:15:33 2008 PPTP connected to server "drs20.ufanet.ru" with ID 0x301F
[INFO] Mon Jul 21 00:15:33 2008 The PPTP transmit window is 16
[INFO] Mon Jul 21 00:15:33 2008 Attempting to establish a PPTP connection.
[INFO] Mon Jul 21 00:15:03 2008 WAN interface is down
[INFO] Mon Jul 21 00:15:03 2008 PPTP tunnel ID 0x1BDD has been closed
[INFO] Mon Jul 21 00:15:03 2008 PPTP received a tunnel clear down request from the application, the tunnel will now be closed.
[INFO] Mon Jul 21 00:15:03 2008 PPP network down
[INFO] Mon Jul 21 00:15:03 2008 LCP sets remote auth: 00000000
[INFO] Mon Jul 21 00:15:03 2008 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Jul 21 00:15:03 2008 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Jul 21 00:15:02 2008 Stopping WAN Services
[INFO] Mon Jul 21 00:15:02 2008 WAN interface is down
[INFO] Mon Jul 21 00:15:02 2008 PPP network down
[INFO] Mon Jul 21 00:12:11 2008 Blocked incoming UDP packet from 125.211.198.10:46528 to 81.30.177.26:1026
[WARN] Mon Jul 21 00:11:53 2008 The remote PPTP access concentrator is slow to respond. There may be connectivity problems.
[INFO] Mon Jul 21 00:08:32 2008 Starting WAN Services
[INFO] Mon Jul 21 00:08:32 2008 WAN interface is up. Connection to Internet established with IP Address 81.30.177.26 and default gateway 10.8.0.8
[INFO] Mon Jul 21 00:08:32 2008 PPP network up with IP Address 81.30.177.26
[INFO] Mon Jul 21 00:08:32 2008 WAN interface is down
[INFO] Mon Jul 21 00:08:31 2008 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Jul 21 00:08:31 2008 LCP sets remote auth: C223
[INFO] Mon Jul 21 00:08:31 2008 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1460
[INFO] Mon Jul 21 00:08:31 2008 PPTP connected to server "drs20.ufanet.ru" with ID 0x1BDD
[INFO] Mon Jul 21 00:08:31 2008 The PPTP transmit window is 16
[INFO] Mon Jul 21 00:08:31 2008 Attempting to establish a PPTP connection.
[INFO] Mon Jul 21 00:08:01 2008 WAN interface is down
[INFO] Mon Jul 21 00:08:01 2008 PPTP tunnel ID 0xA333 has been closed
[INFO] Mon Jul 21 00:08:01 2008 PPTP received a tunnel clear down request from the application, the tunnel will now be closed.
[INFO] Mon Jul 21 00:08:01 2008 PPP network down
[INFO] Mon Jul 21 00:08:01 2008 LCP sets remote auth: 00000000
[INFO] Mon Jul 21 00:08:01 2008 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Jul 21 00:08:01 2008 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Jul 21 00:08:00 2008 Stopping WAN Services
[INFO] Mon Jul 21 00:08:00 2008 WAN interface is down
[INFO] Mon Jul 21 00:08:00 2008 PPP network down
[INFO] Mon Jul 21 00:07:59 2008 Dropped packet from 192.168.10.199 to 255.255.255.255 (IP protocol 6) as unable to create new session
[INFO] Mon Jul 21 00:07:59 2008 UPnP added entry 255.255.255.255 <-> 81.30.189.21:5010 <-> 192.168.10.199:5010 TCP timeout:-1 'utorrent'
[INFO] Mon Jul 21 00:07:52 2008 Blocked incoming UDP packet from 85.96.194.89:3693 to 81.30.189.21:5619
[INFO] Mon Jul 21 00:07:38 2008 Blocked incoming TCP packet from 125.65.76.179:25511 to 81.30.189.21:3700 as RST:ACK received but there is no active connection
[INFO] Mon Jul 21 00:06:38 2008 Blocked incoming UDP packet from 202.152.238.113:18454 to 81.30.189.21:5619
[INFO] Mon Jul 21 00:06:01 2008 Blocked incoming UDP packet from 62.139.87.46:3147 to 81.30.189.21:5619
[INFO] Mon Jul 21 00:05:00 2008 Blocked incoming UDP packet from 202.99.172.146:48762 to 81.30.189.21:1027
[INFO] Mon Jul 21 00:04:44 2008 Blocked outgoing TCP packet from 192.168.10.199:51727 to 77.79.161.68:2371 as FIN:ACK received but there is no active connection
[INFO] Mon Jul 21 00:04:42 2008 Blocked incoming UDP packet from 172.27.29.69:2427 to 81.30.189.21:27015
[WARN] Mon Jul 21 00:04:39 2008 The remote PPTP access concentrator is slow to respond. There may be connectivity problems.
[INFO] Mon Jul 21 00:04:24 2008 Blocked incoming UDP packet from 41.196.178.33:2914 to 81.30.189.21:5619
[INFO] Mon Jul 21 00:04:11 2008 Blocked incoming UDP packet from 221.208.127.142:59742 to 81.30.189.21:1026
[INFO] Mon Jul 21 00:04:11 2008 Blocked incoming UDP packet from 221.208.127.142:59743 to 81.30.189.21:1027
[INFO] Mon Jul 21 00:04:11 2008 Blocked outgoing TCP packet from 192.168.10.199:51699 to 80.236.57.23:51413 as PSH:ACK received but there is no active connection
[INFO] Mon Jul 21 00:04:10 2008 Blocked outgoing TCP packet from 192.168.10.199:51719 to 93.81.253.138:43220 as PSH:ACK received but there is no active connection
[INFO] Mon Jul 21 00:03:58 2008 Blocked incoming UDP packet from 201.30.242.213:61862 to 81.30.189.21:5619
[INFO] Mon Jul 21 00:03:51 2008 Blocked outgoing TCP packet from 192.168.10.199:51724 to 213.234.18.14:12750 as ACK received but there is no active connection
[INFO] Mon Jul 21 00:03:50 2008 Blocked outgoing TCP packet from 192.168.10.199:51730 to 217.10.33.5:5001 as PSH:ACK received but there is no active connection
[INFO] Mon Jul 21 00:03:46 2008 Blocked outgoing TCP packet from 192.168.10.199:51706 to 93.81.253.138:43220 as PSH:ACK received but there is no active connection
[INFO] Mon Jul 21 00:03:46 2008 Blocked outgoing TCP packet from 192.168.10.199:51723 to 213.234.18.14:12750 as ACK received but there is no active connection
[INFO] Mon Jul 21 00:03:42 2008 Blocked outgoing TCP packet from 192.168.10.199:51705 to 93.172.102.149:20800 as ACK received but there is no active connection
[INFO] Mon Jul 21 00:03:31 2008 Starting WAN Services
[INFO] Mon Jul 21 00:03:31 2008 WAN interface is up. Connection to Internet established with IP Address 81.30.189.21 and default gateway 10.8.0.8
[INFO] Mon Jul 21 00:03:31 2008 PPP network up with IP Address 81.30.189.21
[INFO] Mon Jul 21 00:03:30 2008 WAN interface is down
[INFO] Mon Jul 21 00:03:30 2008 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Jul 21 00:03:30 2008 LCP sets remote auth: C223
[INFO] Mon Jul 21 00:03:30 2008 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1460
[INFO] Mon Jul 21 00:03:30 2008 PPTP connected to server "drs20.ufanet.ru" with ID 0xA333
[INFO] Mon Jul 21 00:03:30 2008 The PPTP transmit window is 16
[INFO] Mon Jul 21 00:03:30 2008 Attempting to establish a PPTP connection.
[INFO] Mon Jul 21 00:03:18 2008 Wireless system with MAC address 001CF01041ED associated
[INFO] Mon Jul 21 00:03:17 2008 Wireless system with MAC address 001DE07E1CCF associated
[INFO] Mon Jul 21 00:03:07 2008 Starting DHCP server
[INFO] Mon Jul 21 00:03:01 2008 PPP network down
[INFO] Mon Jul 21 00:03:01 2008 WAN interface is down
[INFO] Mon Jul 21 00:03:01 2008 PPTP tunnel ID 0x5559 has been closed
[INFO] Mon Jul 21 00:03:01 2008 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Jul 21 00:03:01 2008 LCP sets remote auth: C223
[INFO] Mon Jul 21 00:03:01 2008 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1460
[INFO] Mon Jul 21 00:03:01 2008 PPTP connected to server "drs20.ufanet.ru" with ID 0x5559
[INFO] Mon Jul 21 00:03:01 2008 The PPTP transmit window is 16
[INFO] Mon Jul 21 00:03:01 2008 Attempting to establish a PPTP connection.
[INFO] Mon Jul 21 00:03:00 2008 Attempting to start always-on WAN connection
[INFO] Mon Jul 21 00:03:00 2008 Obtained IP Address using DHCP. IP address is 10.64.207.8
[INFO] Mon Jul 21 00:02:58 2008 Bringing up WAN using PPTP
[INFO] Mon Jul 21 00:02:58 2008 WAN interface cable has been connected
[INFO] Mon Jul 21 00:02:58 2008 LAN interface is up
[INFO] Mon Jul 21 00:02:58 2008 LAN Ethernet Carrier Detected
[INFO] Mon Jul 21 00:02:58 2008 Device initialized
[WARN] Mon Jul 21 00:02:58 2008 gw_wireless_schedule init
[INFO] Mon Jul 21 00:02:58 2008 Wireless Link is up
[INFO] Mon Jul 21 00:02:57 2008 Unlock AP setup
[INFO] Mon Jul 21 00:02:57 2008 No Internet access policy is in effect. Unrestricted Internet access allowed to everyone
[INFO] Thu Jan 01 05:00:00 1970 Loaded configuration from non-volatile memory
p.s. пока писал пост чуть не повесился несколько раз заново набирать((((
СообщениеДобавлено: Ср июл 23, 2008 10:25
уважаемая тех.поддержка когда ответите на мои посты???
просто уже терпения нет на ваш девайс(((
СообщениеДобавлено: Ср июл 23, 2008 15:44
up
СообщениеДобавлено: Чт июл 24, 2008 10:02
Подскажите, какие нюансы при настройке на DIR-615 (2.24RU) Wi-Fi. Не могу настроить на подключение к этой точке доступа коммуникатора GSmart MW-700. Уже отключил все расширенные фичи вай-фая - WMM, Short Gl, Extra Wireless Protection, Wi-Fi protected, 802.11n. Длину ключа WPA уменьшил до 8 символов. Не подключается gsmart к dir-615 и все тут! Что еще попробовать?
P.S. Ноут нормально работает по Wi-Fi с 615-ым. Сейчас в инете через него.
СообщениеДобавлено: Чт июл 24, 2008 11:40
UseArt
Ограничьте количество подключений в торренте
СообщениеДобавлено: Чт июл 24, 2008 11:42
Пришлите мне на почту настройки Wi-Fi части роутера и версию ОС в коммуникаторе
СообщениеДобавлено: Чт июл 24, 2008 12:06
Alexandr Zaitsev писал(а):
UseArt
до какого значения рекомендуете?
СообщениеДобавлено: Чт июл 24, 2008 14:41
до какого значения то ограничить ????? :evil: :?: :?: :?: :?:
СообщениеДобавлено: Чт июл 24, 2008 17:07
Например до 50-ти
СообщениеДобавлено: Чт июл 24, 2008 17:18
до 50 я уменьшил пару дней назад, стало соединение разрываться реже, но все же римерно раз в пару часов реконектилось
сегодня уменьшил до 40 - полет нормальный уже 6 часов, посмотрим как дальше будет...
СообщениеДобавлено: Пт июл 25, 2008 05:05
у меня значение стоит 20 соединений и толку ночью нормально по 6-8 часов, а как день или вечер то бывает и в минуту по 2-3 раза обрывы((((
причем ночью соединение стабильно даже если у меня значение 100 и более
СообщениеДобавлено: Сб июл 26, 2008 22:23
up
СообщениеДобавлено: Пн июл 28, 2008 11:06
ну что нить ответит тех поддержка???
СообщениеДобавлено: Вт июл 29, 2008 08:01
Ещё один нюанс забавный - вероятно это ещё как-то завязано на оборудовании провайдера или его настройках, т.к. с теми же ноутами (соответственно и софтом) в сети другого провайдера (Olympus NSP) с доступом по PPTP работает стабильно на любом количестве коннектов торрента. На текущий момент там аптайм соединения уже несколько суток.
Дома настроил доступ через ad-hoc, пока перебиваюсь так - но неудобно :-) Ждём решений
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 55
