Текущее время: Сб мар 28, 2026 14:22
СообщениеДобавлено: Пн июн 30, 2008 09:15
Новые 3627 пришли уже с новой прошивкой, и хотелось бы получить информацию о принципиальных и не очень отличиях прошивки 2.40.B19 от 2.20B35.
СообщениеДобавлено: Пн июн 30, 2008 23:38
DGS-3600 Series Firmware Version 2.40 Build 19.
Problems Resolved:
1. Fixed the problem of all traffic being mirrored when using ACL mirror function to mirror a specific IP at port 1.
2. Fixed the problem of Slave switch from going into ‘exception mode’ when the Master switch is being executed with a ‘reset’ command under Stacking topology.
3. Fixed the issue of this switch does not check the subnet mask (only check network address) when creating static routing table.
4. Fixed the problem of SNMP OID for TFTP services, whereby the TFTP Server IP Address does not set successfully to the switch, although the switch will response fine to SNMP agent.
5. Fixed the issue of telnet session being terminated when creating and session coming from trusted networks.
6. Fixed the issue when both DGS-3600 and DSA-3100 are connected to each other and DGS-3600 will enter ‘burn-in mode’ when both devices are restarted at the same time.
7. Fixed the trace route problem faced on firmware R2.20B50.
8. Fixed the issue under PIM-SM technology; for e.g., 3 switches are inter-connected, when switch 1 is suddenly rebooted, it will cause CPU high utilization on one of the switches.
9. Fixed the problem of OSPF AS external link not correctly registered in the OSPF LSDB table when using OSPF ECMP.
10. Fixed the issue of user access-level privilege rights being able to issue administrator command.
11. Re-instated a web URL link under admin > IP address. This was removed on firmware R2.20B49.
12. Fixed the problem when configuring a new ipif and set its state as enabled. The ipif will be in the disabled state after the switch configuration was saved and rebooted.
13. Fixed the display issue in Web UI for Routing table, which only showed the 1st page when actually there are more pages as seen on CLI.
Enhancements:
1. Show memory utilization in MIB.
2. Port link up/down trap.
3. Null interface for CLI.
4. Added pseudo CLI for PIM Sparse-Dense Mode.
5. LLDP.
6. Gratuitous ARP trap/log.
7. Three-Level User Account.
8. MS NAP - If 802.1X re-authentication triggered by PC, switch should re-assign attribute according to the policies in RADIUS server.
9. Enter not only VLAN name but also VID in "show fdb vlan" command0
10. Error message to describe the naming rule of flash file system if user input the illegal file name.
11. VLAN PVID auto assign.
12. Show VLAN by VID.
13. DIF change to unicast in traffic control.
14. Added PIM Sparse-Dense Mode.
15. SNMP state can be enable and disable.
16. Open CPU ACL feature.
17. Support DGS-3612 product.
СообщениеДобавлено: Ср июл 02, 2008 00:06
Но лучше использовать прошивку которую я вам выслал.
СообщениеДобавлено: Ср июл 02, 2008 06:16
спасибо, поймал:)
а можно changelog уже к ней?:)
СообщениеДобавлено: Ср июл 02, 2008 12:18
Будьте добры и мне прошивочку, которую лучше использовать для 3627G .
СообщениеДобавлено: Ср июл 02, 2008 21:51
Я Вам прошивку выслал. Chngelog будет с релизом.
СообщениеДобавлено: Пт июл 04, 2008 09:39
еще вопрос не в тему - если на порту стоит
config traffic control 5 broadcast enable action drop
будет ли DGS-3627 слать о шторме snmp трапы?
или он их шлет только в случае action shutdown?
СообщениеДобавлено: Пт июл 04, 2008 11:52
В режиме drop пока trap-ов нет.
СообщениеДобавлено: Пн июл 21, 2008 17:04
Вышлите мне новую прошивку для 3627. У меня Build 2.40-B19. Свитч стал каждый час перезагружаться, в логе пишет System cold start.
Хочу обновить прошивку, м.б поможет.
СообщениеДобавлено: Пн июл 21, 2008 17:14
Я вам прошивку выслал
СообщениеДобавлено: Пн июл 21, 2008 21:51
To Kos9k:
Перезвоните пожалуйста завтра во второй половине дня в офис по телефону 744-00-99 доб.390 или укажите в личку ваш телефон.
СообщениеДобавлено: Ср июл 23, 2008 14:01
Добрый день!
Вышлите пожалуйста последнюю версию прошивки для 3627G.
СообщениеДобавлено: Ср июл 23, 2008 14:43
Добрый день! Пришлите тоже новую прошивку для DGS-3612G
СообщениеДобавлено: Ср июл 23, 2008 14:54
Всем прошивки выслал
СообщениеДобавлено: Пт окт 03, 2008 12:00
А можно узнать почему прошивки под DGS3612 на сайте ftp.dlink.com и на сайте ftp.dlink.ru отчитается версиями? (2.40 против 2.20)?
И можно ли получить на email последнюю стабильную прошивку от Вас?
