Текущее время: Чт сен 24, 2026 01:03
СообщениеДобавлено: Пн июл 07, 2008 11:41
DIR-655 Russian PPPoE (Dual Access) Hardware Version: A2, Firmware Version: 1.12WW
Провайдер Акадо.
Настройки WAN автоматические (сеть провайдера по DHCP, соединение с интернетом по PPPoE, настройка - только логин и пароль)
Суть проблемы: периодический роутер не может подключится к сети.
Логи DIR-655.
Когда соединяюсь по PPPoE во время проблемы:
Priority Time Message
[INFO] Mon Jul 07 10:21:54 2008 Trying to establish a PPPoE connection
[INFO] Mon Jul 07 10:21:54 2008 WAN interface is down
[INFO] Mon Jul 07 10:21:24 2008 Trying to establish a PPPoE connection
[INFO] Mon Jul 07 10:21:24 2008 WAN interface is down
[INFO] Mon Jul 07 10:21:04 2008 Log viewed by IP address x.x.x.x
[INFO] Mon Jul 07 10:20:55 2008 Allowed configuration authentication by IP address x.x.x.x
[INFO] Mon Jul 07 10:20:54 2008 Trying to establish a PPPoE connection
[INFO] Mon Jul 07 10:20:54 2008 WAN interface is down
[WARN] Mon Jul 07 10:20:28 2008 A network computer (pc-book) was assigned the IP address of x.x.x.x.
[INFO] Mon Jul 07 10:20:28 2008 Wireless system with MAC address 112233445566 associated
[INFO] Mon Jul 07 10:20:24 2008 Trying to establish a PPPoE connection
[INFO] Mon Jul 07 10:20:24 2008 WAN interface is down
[INFO] Mon Jul 07 10:19:54 2008 Trying to establish a PPPoE connection
[INFO] Mon Jul 07 10:19:54 2008 WAN interface is down
[INFO] Mon Jul 07 10:19:36 2008 Wireless system with MAC address 112233445566 disconnected for reason: Received Deauthentication.
[INFO] Mon Jul 07 10:19:32 2008 Starting DHCP server
[INFO] Mon Jul 07 10:19:24 2008 Trying to establish a PPPoE connection
[INFO] Mon Jul 07 10:19:24 2008 Attempting to start always-on WAN connection
[INFO] Mon Jul 07 10:19:24 2008 Bringing up WAN using PPPoE
[INFO] Mon Jul 07 10:19:24 2008 WAN interface cable has been connected
[INFO] Mon Jul 07 10:19:24 2008 LAN interface is up
[INFO] Mon Jul 07 10:19:24 2008 LAN Ethernet Carrier Detected
[INFO] Mon Jul 07 10:19:23 2008 Device initialized
[WARN] Mon Jul 07 10:19:23 2008 gw_wireless_schedule init
[INFO] Mon Jul 07 10:19:23 2008 Wireless Link is up
[INFO] Mon Jul 07 10:19:22 2008 Unlock AP setup
[INFO] Mon Jul 07 10:19:22 2008 No Internet access policy is in effect. Unrestricted Internet access allowed to everyone
[INFO] Thu Jan 01 03:00:00 1970 Loaded configuration from non-volatile memory
Когда соединяюсь по Dinamic IP (DHCP) во время проблемы:
[WARN] Mon Jul 07 10:23:16 2008 Blocked packet from 0.0.0.0 to 0.0.0.0 (LAND Attack)
[INFO] Mon Jul 07 10:23:09 2008 Above message repeated 4 times
[INFO] Mon Jul 07 10:23:06 2008 Log viewed by IP address x.x.x.x
[WARN] Mon Jul 07 10:23:06 2008 Blocked packet from 0.0.0.0 to 0.0.0.0 (LAND Attack)
[INFO] Mon Jul 07 10:23:02 2008 Above message repeated 4 times
[INFO] Mon Jul 07 10:23:00 2008 Allowed configuration authentication by IP address x.x.x.x
[WARN] Mon Jul 07 10:23:00 2008 Blocked packet from 0.0.0.0 to 0.0.0.0 (LAND Attack)
[INFO] Mon Jul 07 10:22:07 2008 Above message repeated 42 times
[WARN] Mon Jul 07 10:22:06 2008 A network computer (pc-book) was assigned the IP address of x.x.x.x.
[INFO] Mon Jul 07 10:22:06 2008 Wireless system with MAC address 112233445566 associated
[WARN] Mon Jul 07 10:22:05 2008 Blocked packet from 0.0.0.0 to 0.0.0.0 (LAND Attack)
[INFO] Mon Jul 07 10:21:17 2008 Above message repeated 42 times
[INFO] Mon Jul 07 10:21:10 2008 Starting DHCP server
[WARN] Mon Jul 07 10:21:08 2008 Blocked packet from 0.0.0.0 to 0.0.0.0 (LAND Attack)
[INFO] Mon Jul 07 10:21:05 2008 Above message repeated 3 times
[INFO] Mon Jul 07 10:21:02 2008 Bringing up WAN using DHCP
[INFO] Mon Jul 07 10:21:02 2008 WAN interface cable has been connected
[INFO] Mon Jul 07 10:21:02 2008 LAN interface is up
[INFO] Mon Jul 07 10:21:02 2008 LAN Ethernet Carrier Detected
[INFO] Mon Jul 07 10:21:01 2008 Device initialized
[WARN] Mon Jul 07 10:21:01 2008 gw_wireless_schedule init
[INFO] Mon Jul 07 10:21:01 2008 Wireless Link is up
[INFO] Mon Jul 07 10:21:00 2008 Unlock AP setup
[INFO] Mon Jul 07 10:21:00 2008 No Internet access policy is in effect. Unrestricted Internet access allowed to everyone
Решается только звонком в тех. поддержку провайдера, отвечают, что проводятся тех. работы и в течении дня восстановят, но через 2 - 4 минуты связь восстанавливается. Повторялось уже несколько раз.
Кажется проблема в этом - [WARN] Mon Jul 07 10:21:08 2008 Blocked packet from 0.0.0.0 to 0.0.0.0 (LAND Attack)
Просвятите, с чем связана эта проблема.
СообщениеДобавлено: Пн июл 07, 2008 11:56
PS.
Есть так же еще одна проблема. При соединение с провайдером в режиме DualAccess если в "WAN Physical setting :" стоит Dynamic IP (у провайдера в сети выдаются все данные по DHCP) то роутер в своей статистике пишет, что он подключен, но вот ни в локальную сеть провайдера ни в интернет попасть невозможно.
Решается только тогда, когда ручками прописываешь в "WAN Physical setting :" уже при Static IP все параметры.
Вопрос вот в чем, почему при Dynamic IP роутер не работает и как влияет прописанный вручную ип адресс на сеть провайедера в тот момент когда мне назначают новые параметры (IP адресс)?
СообщениеДобавлено: Вт июл 29, 2008 14:03
все еще интересует тема.
dir-655 виноват?
СообщениеДобавлено: Ср июл 30, 2008 14:20
Это недопустимый пакет, роутер его блокирует. У вас есть возможность снять сниф?
СообщениеДобавлено: Пн авг 18, 2008 20:05
Уже нет такой возможности, так как довольно долго не возникает такой проблеммы, 11 дней подряд держит сеть.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 50
