Текущее время: Сб авг 08, 2026 20:46
 Заголовок сообщения: dsl 2540u разрывы связи
СообщениеДобавлено: Чт июн 19, 2008 16:33
здрайствуйте. у меня такая проблема несколько раз в сутки происходят дисконекты. в техподдержке провайдера говорят что с их стороны проблем нет. настроен в режиме роутера. провайдер ДОМОЛИНК Тула.
лог устрйства: Jan 1 00:00:12 user warn kernel: ip_conntrack version 2.1 (61 buckets, 0 max) - 368 bytes per conntrack
Jan 1 00:00:12 user warn kernel: ip_conntrack_pptp version 2.1 loaded
Jan 1 00:00:12 user warn kernel: ip_nat_pptp version 2.0 loaded
Jan 1 00:00:12 user warn kernel: ip_conntrack_h323: init
Jan 1 00:00:12 user warn kernel: ip_nat_h323: initialize the module!
Jan 1 00:00:12 user crit kernel: eth0 Link UP.
Jan 1 00:00:12 user crit kernel: ADSL G.994 training
Jan 1 00:00:12 user info kernel: device eth0 entered promiscuous mode
Jan 1 00:00:12 user info kernel: br0: port 1(eth0) entering learning state
Jan 1 00:00:12 user info kernel: br0: topology change detected, propagating
Jan 1 00:00:12 user info kernel: br0: port 1(eth0) entering forwarding state
Jan 1 00:00:12 user info kernel: device nas_0_35 entered promiscuous mode
Jan 1 00:00:12 user info kernel: br0: port 2(nas_0_35) entering learning state
Jan 1 00:00:12 user info kernel: br0: port 2(nas_0_35) entering forwarding state
Jan 1 00:00:12 user info kernel: device eth0 left promiscuous mode
Jan 1 00:00:12 user info kernel: br0: port 1(eth0) entering disabled state
Jan 1 00:00:12 user debug syslog: tftpd
Jan 1 00:00:12 user debug syslog: kill -16 221
Jan 1 00:00:13 user debug syslog: pppd
Jan 1 00:00:13 user debug syslog: ifconfig nas_0_35 mtu 1492
Jan 1 00:00:14 daemon notice pppd[307]: pppd 2.4.1 started by admin, uid 0
Jan 1 00:00:22 user crit kernel: ADSL G.992 started
Jan 1 00:00:27 user crit kernel: ADSL link down
Jan 1 00:00:33 user crit kernel: ADSL G.994 training
Jan 1 00:00:38 user crit kernel: ADSL G.992 started
Jan 1 00:00:43 user crit kernel: ADSL link down
Jan 1 00:00:44 user crit kernel: ADSL G.994 training
Jan 1 00:00:49 user crit kernel: ADSL G.992 started
Jan 1 00:00:54 user crit kernel: ADSL link down
Jan 1 00:00:55 user crit kernel: ADSL G.994 training
Jan 1 00:01:00 user crit kernel: ADSL G.992 started
Jan 1 00:01:05 user crit kernel: ADSL link down
Jan 1 00:01:06 user crit kernel: ADSL G.994 training
Jan 1 00:01:21 user crit kernel: ADSL G.992 started
Jan 1 00:01:24 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:01:28 user crit kernel: ADSL G.992 message exchange
Jan 1 00:01:29 user crit kernel: ADSL link up, interleaved, us=928, ds=4096
Jan 1 00:01:29 user warn kernel: ATM Soft SAR: ATM link connected.
Jan 1 00:01:30 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jan 1 00:01:31 daemon notice pppd[307]: PPP: Start to connect ...
Jan 1 00:01:32 daemon crit pppd[307]: PPP server detected.
Jan 1 00:01:32 daemon crit pppd[307]: PPP session established.
Jan 1 00:01:32 daemon crit pppd[307]: PPP LCP UP.
Jan 1 00:01:32 daemon crit pppd[307]: Received valid IP address from server. Connection UP.
Jan 1 00:01:34 user debug syslog: route add default gw 10.250.2.74 2>/dev/null
Jan 1 00:01:34 user debug syslog: iptables -A FORWARD -o ppp_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:01:35 user debug syslog: iptables -A FORWARD -i ppp_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:01:35 user debug syslog: echo > /proc/net/ip_conntrack
Jan 1 00:01:35 user debug syslog: echo "512" > /proc/sys/net/ipv4/ip_conntrack_max
Jan 1 00:01:35 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Jan 1 00:01:35 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Jan 1 00:01:35 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Jan 1 00:01:35 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 212.12.0.2 2>/dev/null
Jan 1 00:01:35 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 212.12.0.2
Jan 1 00:01:35 user debug syslog: /bin/dnsprobe &
Jan 1 00:01:35 user debug syslog: upnp -L br0 -W ppp_0_35_1 -D
Jan 1 00:01:35 user notice dnsprobe[1109]: dnsprobe started!
Jan 1 00:01:36 user debug syslog: iptables -t filter -I OUTPUT -o ppp_0_35_1 -d 239.255.255.250 -j DROP 2>/dev/null
Jan 1 00:01:37 user debug syslog: iptables -D INPUT -i ppp_0_35_1 -j DROP
Jan 1 00:01:37 user debug syslog: iptables -A INPUT -i ppp_0_35_1 -j DROP
Jan 1 00:02:07 user warn dnsprobe[1109]: dns query failed
Jan 1 00:02:09 user warn dnsprobe[1109]: dns query failed
Jan 1 00:02:11 user warn dnsprobe[1109]: dns query failed
Jan 1 00:02:11 user notice dnsprobe[1109]: Primary DNS server Is Down... Switching To Secondary DNS server
Jun 19 17:10:51 user notice dnsprobe[1109]: Switching Back To Primary DNS server
Jun 19 17:12:02 user debug syslog: sntp -s ntp1.dlink.com -s ntp.dlink.com.tw -t "Moscow, St. Petersburg, Volgograd" &
Jun 19 17:12:51 user alert kernel: Intrusion -> IN=ppp_0_35_1 OUT= MAC= SRC=10.250.116.180 DST=10.250.118.145 LEN=40 TOS=0x08 PREC=0x00 TTL=251 ID=24234 PROTO=TCP SPT=22479 DPT=139 WINDOW=16384 RES=0x00 SYN URGP=0
Jun 19 17:12:57 user debug igmp[1670]: iptables -t filter -I FORWARD 1 -i br0 -d 224.0.0.22 -j DROP 2>/dev/null
Jun 19 17:12:57 user debug igmp[1672]: iptables -t filter -D FORWARD -i br0 -d 224.0.0.22 -j ACCEPT 2>/dev/null
Jun 19 17:14:07 user alert kernel: Intrusion -> IN=ppp_0_35_1 OUT= MAC= SRC=10.250.77.198 DST=10.250.118.145 LEN=48 TOS=0x08 PREC=0x00 TTL=251 ID=19219 DF PROTO=TCP SPT=4207 DPT=445 WINDOW=65535 RES=0x00 SYN URGP=0
Jun 19 17:14:10 user alert kernel: Intrusion -> IN=ppp_0_35_1 OUT= MAC= SRC=10.250.77.198 DST=10.250.118.145 LEN=48 TOS=0x08 PREC=0x00 TTL=251 ID=19323 DF PROTO=TCP SPT=4207 DPT=445 WINDOW=65535 RES=0x00 SYN URGP=0
Jun 19 17:21:01 user alert kernel: Intrusion -> IN=ppp_0_35_1 OUT= MAC= SRC=10.250.79.125 DST=10.250.118.145 LEN=48 TOS=0x08 PREC=0x00 TTL=252 ID=8664 DF PROTO=TCP SPT=3142 DPT=445 WINDOW=65535 RES=0x00 SYN URGP=0
Jun 19 17:21:19 user alert kernel: Intrusion -> IN=ppp_0_35_1 OUT= MAC= SRC=10.250.107.35 DST=10.250.118.145 LEN=48 TOS=0x08 PREC=0x00 TTL=252 ID=56856 DF PROTO=TCP SPT=2089 DPT=445 WINDOW=64800 RES=0x00 SYN URGP=0
Jun 19 17:21:22 user alert kernel: Intrusion -> IN=ppp_0_35_1 OUT= MAC= SRC=10.250.107.35 DST=10.250.118.145 LEN=48 TOS=0x08 PREC=0x00 TTL=252 ID=57280 DF PROTO=TCP SPT=2089 DPT=445 WINDOW=64800 RES=0x00 SYN URGP=0
Jun 19 17:26:34 user alert kernel: Intrusion -> IN=ppp_0_35_1 OUT= MAC= SRC=10.250.79.125 DST=10.250.118.145 LEN=48 TOS=0x08 PREC=0x00 TTL=252 ID=46716 DF PROTO=TCP SPT=2443 DPT=135 WINDOW=65535 RES=0x00 SYN URGP=0
ADSL Statistics
Mode: G.DMT
Type: Interleave
Line Coding: Trellis On
Status: No Defect
Link Power State: L0
Downstream Upstream
SNR Margin (dB): 32.0 10.0
Attenuation (dB): 35.0 21.0
Output Power (dBm): 12.5 19.6
Attainable Rate (Kbps): 10592 1024
Rate (Kbps): 4096 928
K (number of bytes in DMT frame): 129 30
R (number of check bytes in RS code word): 16 4
S (RS code word size in DMT frame): 1 4
D (interleaver depth): 64 8
Delay (msec): 16 8
Super Frames: 72273 72271
Super Frame Errors: 0 0
RS Words: 4914630 1228607
RS Correctable Errors: 10 0
RS Uncorrectable Errors: 0 N/A
HEC Errors: 0 0
OCD Errors: 0 0
LCD Errors: 0 0
Total Cells: 11869624 0
Data Cells: 78045 0
Bit Errors: 0 0
Total ES: 0 0
Total SES: 0 0
Total UAS: 61 0
также как советовалось в какойто теме попробовал отрубить режим adsl2+ не помогло. сейчас отключил и adsl2.
заранее спасибо :(
 Заголовок сообщения: Re: dsl 2540u разрывы связи
СообщениеДобавлено: Чт июн 19, 2008 17:08
ADSL Statistics
Mode: G.DMT
Type: Interleave
Status: No Defect
Downstream Upstream
Delay (msec): 16 8
HEC Errors: 0 0
OCD Errors: 0 0
LCD Errors: 0 0
Data Cells: 78045 0
Bit Errors: 0 0
Total ES: 0 0
Total SES: 0 0
Total UAS: 61 0
заранее спасибо :(
Мигает ли индикатор DSL в момент разрыва? Укажите версию прошивки Вашего модема.
СообщениеДобавлено: Чт июн 19, 2008 17:11
Проблема заключается в "разрывах" ADSL соединения.
1. Назовите версию прошивки Вашего устройства.
2. Попросите провайдера продиагностировать Вашу линию.
3. Также попросите провайдера увеличить значение параметра Interleave в профиле Вашего порта на DSLAM.
4. Проверьте физические соединения: модема с телефонной розеткой, качества монтажа кабеля в телефонной розетке, целостность телефонного кабеля от розетки до распаечной коробки.
С уважением, Давыдов Денис.
СообщениеДобавлено: Чт июн 19, 2008 17:18
индикатор dsl при разрывах не мигает.
версия прошивки RU_DSL-2540U_3-06-04-3B00.A2pB023g2.d19b
провод до щитка прокладывал сам. до этого была обычная лапша. щас с проводом порядок.
некоторое время индикатор dsl гаc при разрывах, потом это устранили усилив какой то сигнал как они сказали.
СообщениеДобавлено: Чт июн 19, 2008 17:22
Обновите версию прошивки устройства до этой: ftp://ftp.dlink.ru/pub/ADSL/DSL-2540U/F ... 043H00.zip
После чего перенастройте устройство.
Если проблема также будет иметь место - воспользуйтесь советами из моего предыдущего сообщения.
СообщениеДобавлено: Чт июн 19, 2008 20:47
1. после обновления прошивки на вышеуказанную при обрывах, сессия не восстанавливается. приходится поднимать вручную :( .
2. какой провод лучше использовать от раздаточной коробки до разетки?
СообщениеДобавлено: Пн июн 23, 2008 13:29
1. Убедитесь что механизм Keep Alive включен.
2. Лучше использовать витую пару.
