Текущее время: Вс июн 14, 2026 17:47
 Заголовок сообщения: DI-804HV проблема с DHCP
СообщениеДобавлено: Ср май 21, 2008 12:48
Здравствуйте.
DI-804HV + DWL-2100AP (wireless client на WAN), подключение к Corbina-WiFi (через ТД Golden).
Прошивка DI-804HV -1.50b02, Russian PPTP, Dynamic WAN IP
Проблема - периодически замирает трафик LAN -> Internet, при этом роутер доступен по веб-интерфейсу и пингуется через LAN, в статусе PPTP connected.
Лог:
Wednesday May 21, 2008 12:09:23 DHCP:renew
Wednesday May 21, 2008 12:09:27 DHCP:renew
Wednesday May 21, 2008 12:09:28 Blocked access attempt from 159.148.193.131:20107 to UDP port 9746
Wednesday May 21, 2008 12:09:30 Blocked access attempt from 159.148.193.131:20107 to UDP port 9746
Wednesday May 21, 2008 12:09:34 Blocked access attempt from 159.148.193.131:20107 to UDP port 9746
Wednesday May 21, 2008 12:09:35 DHCP:renew
Wednesday May 21, 2008 12:09:51 DHCP:renew
Wednesday May 21, 2008 12:10:09 Blocked access attempt from 84.22.140.225:62544 to UDP port 9746
Wednesday May 21, 2008 12:10:11 Blocked access attempt from 84.22.140.225:62544 to UDP port 9746
Wednesday May 21, 2008 12:10:15 Blocked access attempt from 84.22.140.225:62544 to UDP port 9746
Wednesday May 21, 2008 12:10:19 Blocked access attempt from 89.235.161.170:47184 to UDP port 53980
Wednesday May 21, 2008 12:10:21 Blocked access attempt from 89.235.161.170:47184 to UDP port 53980
Wednesday May 21, 2008 12:10:25 Blocked access attempt from 89.235.161.170:47184 to UDP port 53980
Wednesday May 21, 2008 12:10:28 Blocked access attempt from 58.244.37.191:6290 to UDP port 55157
Wednesday May 21, 2008 12:12:27 Blocked access attempt from 88.205.159.245:4750 to UDP port 9746
Wednesday May 21, 2008 12:12:31 Blocked access attempt from 88.205.159.245:4750 to UDP port 9746
Wednesday May 21, 2008 12:12:49 Blocked access attempt from 82.83.158.85:61324 to TCP port 36356
Wednesday May 21, 2008 12:12:52 Blocked access attempt from 82.83.158.85:61324 to TCP port 36356
Wednesday May 21, 2008 12:12:58 Blocked access attempt from 82.83.158.85:61324 to TCP port 36356
Wednesday May 21, 2008 12:13:09 Blocked access attempt from 79.120.69.235:3907 to TCP port 55157
Wednesday May 21, 2008 12:13:12 Blocked access attempt from 79.120.69.235:3907 to TCP port 55157
Wednesday May 21, 2008 12:13:17 Blocked access attempt from 89.223.71.197:60312 to UDP port 9746
Wednesday May 21, 2008 12:13:18 Blocked access attempt from 79.120.69.235:3907 to TCP port 55157
Wednesday May 21, 2008 12:13:19 Blocked access attempt from 89.223.71.197:60312 to UDP port 9746
Wednesday May 21, 2008 12:13:21 Blocked access attempt from 202.97.238.203:42638 to UDP port 1026
Wednesday May 21, 2008 12:13:23 Blocked access attempt from 89.223.71.197:60312 to UDP port 9746
Wednesday May 21, 2008 12:13:30 Blocked access attempt from 89.235.161.170:47184 to UDP port 53980
Wednesday May 21, 2008 12:13:32 Blocked access attempt from 89.235.161.170:47184 to UDP port 53980
Wednesday May 21, 2008 12:13:36 Blocked access attempt from 89.235.161.170:47184 to UDP port 53980
Wednesday May 21, 2008 12:14:23 DHCP:renew
Wednesday May 21, 2008 12:14:23 DHCP:ack(DOL=1800,T1=900,T2=1575)
Связи не было с 12:09 до 12.14
Похоже, что при поднятом PPTP соединении роутер не корректно обновляет DHCP.
Пробовал вручную прописывать маршрут до DHCP сервера:
10.40.0.103   255.255.255.255   172.16.0.1
Не помогло
При подключении DWL-2100AP к компьютеру проблем нет.
Network Connection Details;
Physical Address: 52-54-AB-16-A9-33
IP Address: 172.17.203.92
Subnet Mask: 255.254.0.0
Default Gateway: 172.16.0.1
DHCP Server: 10.40.0.103
Lease Obtained: 21.05.2008 12:24:40
Lease Expires: 21.05.2008 12:54:40
DNS Servers: 194.67.1.150, 194.67.2.114
WINS Server:
Route print:
IPv4 Route Table
Interface List
0x1 ........................... MS TCP Loopback interface
0x70003 ...52 54 ab 16 a9 33 ...... Realtek RTL8029 PCI Ethernet NIC
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0       172.16.0.1    172.17.203.92     30
        127.0.0.0        255.0.0.0        127.0.0.1        127.0.0.1      1
       172.16.0.0      255.254.0.0    172.17.203.92    172.17.203.92     30
    172.17.203.92  255.255.255.255        127.0.0.1        127.0.0.1     30
   172.17.255.255  255.255.255.255    172.17.203.92    172.17.203.92     30
        224.0.0.0        240.0.0.0    172.17.203.92    172.17.203.92     30
  255.255.255.255  255.255.255.255    172.17.203.92    172.17.203.92      1
Persistent Routes:
  None
СообщениеДобавлено: Пт май 23, 2008 09:39
Up!
СообщениеДобавлено: Пт май 23, 2008 13:09
Пропишите маршрут на роутере до вашего DHCP сервера, это решит проблему.
СообщениеДобавлено: Пт май 23, 2008 15:23
Выше я писал, что маршрут
где 10.40.0.103 - DHCP сервер, 172.16.0.1 - Default Gateway
проблему не решил
Может, я не то прописываю?
СообщениеДобавлено: Вт май 27, 2008 00:24
Up!
СообщениеДобавлено: Вт май 27, 2008 15:54
Какая прошивка на точке?
СообщениеДобавлено: Вт май 27, 2008 16:20
DWL2100AP-firmware-v240eup02-rc253(1205164933).tfp
СообщениеДобавлено: Сб май 31, 2008 11:03
Прошил DWL2100 последней прошивкой - проблема осталась
Поставил вместо DI-804HV Asus WL-500g - проблем нет
Похоже, дело все-таки в 804, конкретно - в несовместимости прошивки 1.50b2 "Russian PPTP" с Golden Wifi
Вопрос: какая версия прошивки без "Russian PPTP"?
СообщениеДобавлено: Пн июн 02, 2008 10:17
ftp://ftp.dlink.ru/pub/Router/DI-804HV/ ... 144b11.zip не думаю что это решит проблему, если у вас есть возможность предоставьте сниф.
СообщениеДобавлено: Ср июн 04, 2008 15:42
После прошивки 1.44b11 - повис наглухо, не реагируя на reset. Веб-интерфейс недоступен. В сервис его или как?
СообщениеДобавлено: Ср июн 04, 2008 16:59
Попробуйте оживить утилитой из того же архива.
СообщениеДобавлено: Пн июн 23, 2008 14:56
Прошил 1.50b08 - полет нормальный
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 65
