Текущее время: Пт сен 25, 2026 04:20
 Заголовок сообщения: des 3526 + DHCP Relay
СообщениеДобавлено: Сб май 03, 2008 05:32
Люди, прошу помощи, ибоуже начал сходить сума!!!
Есть дес 3526.
На нём включен дхцп релей
DES-3526:admin#show dhcp_relay
Command: show dhcp_relay
DHCP/BOOTP Relay Status         : Enabled
DHCP/BOOTP Hops Count Limit     : 4
DHCP/BOOTP Relay Time Threshold : 0
DHCP Relay Agent Information Option 82 State  : Enabled
DHCP Relay Agent Information Option 82 Check  : Enabled
DHCP Relay Agent Information Option 82 Policy : Replace
Interface     Server 1         Server 2         Server 3         Server 4
System        10.45.100.1
Есть серверпод генту_2008_бета2
На нём собран dhcpd
Atlas ~ # dhcpd --version
isc-dhcpd-V3.1.0-Gentoo
есть конфиг dhcpd.conf
local-address 10.45.100.1;
ddns-update-style none;
option domain-name "kopeika.uah";
option domain-name-servers 10.45.100.1, 91.202.128.100, 91.202.129.100;
default-lease-time 600;
max-lease-time 7200;
authoritative;
log-facility local7;
if exists agent.circuit-id
 log ( info, concat( " Lease for ",
                     binary-to-ascii (10, 8, ".", leased-address),
                     " Swith port: ",
                     binary-to-ascii (10, 8, "", suffix( option agent.circuit-id, 1)),
                     " Switch MAC: ",
                     binary-to-ascii(16, 8, ".", option agent.remote-id)));
class "test"
 match if binary-to-ascii (10, 8, "", suffix( option agent.circuit-id, 1)) = "14" ;
shared-network KOPEIKA {
subnet 10.45.100.0 netmask 255.255.255.0 {
subnet 10.45.101.0 netmask 255.255.255.0 {
      option routers 10.45.100.1;
      option broadcast-address 10.45.111.255;
pool {
   allow members of "test" ;
   range 10.45.101.2 10.45.101.217 ;
   deny unknown-clients;
subnet 10.45.102.0 netmask 255.255.255.0 {
pool {
    allow unknown-clients;
    deny members of "test";
    range 10.45.102.2 10.45.102.217 ;
Перезапускаю дхцпд
Atlas ~ # rm -rf /var/lib/dhcp/*
Atlas ~ # /etc/init.d/dhcpd restart
 * Stopping dhcpd ...        [ ok ]
 * Creating //var/lib/dhcp/dhcpd.leases ...        [ ok ]
 * Starting dhcpd ...        [ ok ]
Atlas ~ # tail -f /var/log/messages
May  3 05:14:10 Atlas dhcpd: All rights reserved.
May  3 05:14:10 Atlas dhcpd: For info, please visit http://www.isc.org/sw/dhcp/
May  3 05:14:10 Atlas dhcpd: Wrote 0 class decls to leases file.
May  3 05:14:10 Atlas dhcpd: Wrote 0 leases to leases file.
May  3 05:15:35 Atlas dhcpd: Internet Systems Consortium DHCP Server V3.1.0-Gentoo
May  3 05:15:35 Atlas dhcpd: Copyright 2004-2007 Internet Systems Consortium.
May  3 05:15:35 Atlas dhcpd: All rights reserved.
May  3 05:15:35 Atlas dhcpd: For info, please visit http://www.isc.org/sw/dhcp/
May  3 05:15:35 Atlas dhcpd: Wrote 0 class decls to leases file.
May  3 05:15:35 Atlas dhcpd: Wrote 0 leases to leases file.
Пытаюсь получить адрес! Я сам сижу на 14 порту! Что будет видно из лога!
Ну теперь сообственно лог, когда я пытаюсь получить айпишник!
May  3 05:18:25 Atlas dhcpd: DHCPDISCOVER from 00:e0:91:10:e5:f2 (Synapse) via eth0
May  3 05:18:25 Atlas dhcpd: DHCPOFFER on 10.45.102.2 to 00:e0:91:10:e5:f2 (Synapse) via eth0
May  3 05:18:25 Atlas dhcpd: DHCPDISCOVER from 00:e0:91:10:e5:f2 via 10.45.101.1: network KOPEIKA: no free leases
May  3 05:18:25 Atlas dhcpd: DHCPREQUEST for 10.45.102.2 (10.45.100.1) from 00:e0:91:10:e5:f2 via eth0
May  3 05:18:25 Atlas dhcpd: DHCPACK on 10.45.102.2 to 00:e0:91:10:e5:f2 (Synapse) via eth0
May  3 05:18:25 Atlas dhcpd: DHCPREQUEST for 10.45.102.2 (10.45.100.1) from 00:e0:91:10:e5:f2 via 10.45.101.1: lease 10.45.102.2 unavailable.
May  3 05:18:25 Atlas dhcpd: DHCPNAK on 10.45.102.2 to 00:e0:91:10:e5:f2 via 10.45.101.1
Почему я получаю айпишник из другого пула! А не из того, что положено, согласно класу!
По логу же ясно видно, что я сижу на 14 порту! Люди! Помогите плиз! Сам понимаю что проблемы в конфиге, но не могу понять где именно..
Если кто может, посдкажите пожалуста, а ещё лутше прямо в конфиге ткните носом где не так...
А то уже 2 дня мучаюсь... Прям аж руки опускатся начали... :(
СообщениеДобавлено: Сб май 03, 2008 22:48
Какая у вас версия прошивки?
СообщениеДобавлено: Вс май 04, 2008 02:18
DES-3526:admin#show firmware information
Command: show firmware information
ID Version Size(B) Update Time From User
*1 5.01-B09 2953571 00000 days 20:38:26 10.45.104.63(T) synapse
'*' means boot up section
(T) means firmware update through TELNET
(S) means firmware update through SNMP
(W) means firmware update through WEB
(SIM) means firmware update through Single IP Management
Free space: 5242880 bytes
СообщениеДобавлено: Вс май 04, 2008 02:41
сменил конфиг dhcpd.conf
option netbios-name-servers     10.45.100.1;
option netbios-node-type        8;
option netbios-scope            "100mf";
default-lease-time 3600;
authoritative;
ddns-update-style ad-hoc;
#ddns-update-style interim;
#ddns-domainname "kopeika.uah.";
class "1" {match if substring(option agent.circuit-id,2,2) = 0:2;}
class "2" {match if substring(option agent.circuit-id,2,2) = 0:3;}
class "3" {match if substring(option agent.circuit-id,2,2) = 0:4;}
class "4" {match if substring(option agent.circuit-id,2,2) = 0:5;}
class "5" {match if substring(option agent.circuit-id,2,2) = 0:6;}
class "6" {match if substring(option agent.circuit-id,2,2) = 0:7;}
class "7" {match if substring(option agent.circuit-id,2,2) = 0:8;}
class "8" {match if substring(option agent.circuit-id,2,2) = 0:9;}
class "9" {match if substring(option agent.circuit-id,2,2) = 0:0A;}
class "10" {match if substring(option agent.circuit-id,2,2) = 0:0B;}
class "11" {match if substring(option agent.circuit-id,2,2) = 0:0C;}
class "12" {match if substring(option agent.circuit-id,2,2) = 0:0D;}
class "13" {match if substring(option agent.circuit-id,2,2) = 0:0E;}
class "14" {match if substring(option agent.circuit-id,2,2) = 0:0F;}
class "15" {match if substring(option agent.circuit-id,2,2) = 0:10;}
subnet 10.45.96.0 netmask 255.255.240.0 { option routers 10.45.100.1; option broadcast-address 10.45.111.255;
pool {  allow unknown-clients; range 10.45.101.241 10.45.101.247;}
pool {  allow members of "1"; range 10.45.101.11 10.45.101.17;}
pool {  allow members of "2"; range 10.45.101.21 10.45.101.27;}
pool {  allow members of "3"; range 10.45.101.31 10.45.101.37;}
pool {  allow members of "4"; range 10.45.101.41 10.45.101.47;}
pool {  allow members of "5"; range 10.45.101.51 10.45.101.57;}
pool {  allow members of "6"; range 10.45.101.61 10.45.101.67;}
pool {  allow members of "7"; range 10.45.101.71 10.45.101.77;}
pool {  allow members of "8"; range 10.45.101.81 10.45.101.87;}
pool {  allow members of "9"; range 10.45.101.91 10.45.101.97;}
pool {  allow members of "10"; range 10.45.101.101 10.45.101.107;}
pool {  allow members of "11"; range 10.45.101.111 10.45.101.117;}
pool {  allow members of "12"; range 10.45.101.121 10.45.101.127;}
pool {  allow members of "13"; range 10.45.101.131 10.45.101.137;}
pool {  allow members of "14"; range 10.45.101.141 10.45.101.147;}
pool {  allow members of "15"; range 10.45.101.151 10.45.101.157;}
        log ( info, concat( "Lease for ", binary-to-ascii (10, 8, ".",  leased-address), " is connected to interface ", binary-to-ascii (10, 8, "/", suffix ( option agent.circuit-id, 2)), " (add 1 to port number!), VLAN ", binary-to-ascii (10, 16, "", substring( option agent.circuit-id, 2, 2)), " on switch ", binary-to-ascii(16, 8, ":", substring( option agent.remote-id, 2, 6))));
        log ( info, concat( "Lease for ", binary-to-ascii (10, 8, ".",  leased-address), " raw option-82 info is CID: ", binary-to-ascii (10, 8, ".", option agent.circuit-id), " AID: ", binary-to-ascii(16, 8, ".", option agent.remote-id)));
Всёравно ничего не работает... Уже хочу убитб себя об стену...
При попчытке получит адрес, в логах появляетс такое:
May  4 02:43:43 Atlas dhcpd: Lease for 10.45.101.241 is connected to interface 0/14 (add 1 to port number!), VLAN 1 on switch 0:1b:11:21:7c:51
May  4 02:43:43 Atlas dhcpd: Lease for 10.45.101.241 raw option-82 info is CID: 0.4.0.1.0.14 AID: 0.6.0.1b.11.21.7c.51
May  4 02:43:43 Atlas named[8476]: client 10.45.100.1#32773: update 'kopeika.uah/IN' denied
May  4 02:43:43 Atlas dhcpd: Unable to add forward map from Synapse.kopeika.uah. to 10.45.101.241: timed out
May  4 02:43:43 Atlas dhcpd: DHCPREQUEST for 10.45.101.241 from 00:e0:91:10:e5:f2 (Synapse) via eth0
May  4 02:43:43 Atlas dhcpd: DHCPACK on 10.45.101.241 to 00:e0:91:10:e5:f2 (Synapse) via eth0
May  4 02:43:43 Atlas dhcpd: DHCPREQUEST for 10.45.101.241 from 00:e0:91:10:e5:f2 (Synapse) via 10.45.101.1
May  4 02:43:43 Atlas dhcpd: DHCPACK on 10.45.101.241 to 00:e0:91:10:e5:f2 (Synapse) via 10.45.101.1
И ещё == то логирует CID&AID то нет, такое ощущение, что свитч вообще их иногда не добавляет...
Ну ясно же видно, что я сижу на 14 порту! Почему же тогда не получаю адрес их нужного пула? Точнее даже не так, а "почему не віполняется правило в классе для 14 порта"???
СообщениеДобавлено: Вс май 04, 2008 07:23
понял почему логирует через раз!
!!! приходят два запроса от клиента на получения адреса !!!
Один через eth0 (10.45.100.1), другой как и должен через свитч 10.45.101.1 (в файл с лизам заносятся две записи!)
lease 10.45.101.241 {
  starts 0 2008/05/04 04:22:49;
  ends 0 2008/05/04 05:22:49;
  cltt 0 2008/05/04 04:22:49;
  binding state active;
  next binding state free;
  hardware ethernet 00:e0:91:10:e5:f2;
  uid "\001\000\340\221\020\345\362";
  client-hostname "Synapse";
  option agent.circuit-id 0:4:0:1:0:e;
  option agent.remote-id 0:6:0:1b:11:21:7c:51;
Как видно, одна с оптион_82, вторая без...
Может в этом всё дело?
СообщениеДобавлено: Вс май 04, 2008 14:23
А у Вас клиентские VLAN-ы проброшены до DHCP-сервера? Попробуйте прошивку которую я вам выслал.
СообщениеДобавлено: Вс май 04, 2008 15:24
Большое спасибо, но через попу заставил работать...
проблема была в том, что поскольку пока вся сеть один бродкаст домен, к дхцп серваку доходило два запроса. Один как бродкастовый, второй, уже маркированый от свича с опциеё 82.
Собственно сделал следующее, зарубил все пакеты с маком ff:ff:ff:ff:ff:ff
create access_profile ethernet destination_mac FF-FF-FF-FF-FF-FF profile_id 1
config access_profile profile_id 1 add access_id 2 ethernet destination_mac FF-FF-FF-FF-FF-FF port 14 deny
Теперь всё работает...
Теперь второй вопрос, как мне умно сделать правила, что бы на аплинк (25 порт) со всех портов приходили запросы на 67 и 68 порты только от свичей (10.45.101.1 10.45.102.1 10.45.103.1 01.45.104.1 10.45.105.1). А бродкаст со всех остальных портов на 67 порт от клиентов рубался свичём...
Ибо так как я сделал, это грех - ибо зарубил бродкаст на корне...
Соббственно пршу помощи!!!
Или ткните носом, как это сделать на самом сервере (но всё таки лутше помогите составить правило, ибо так надёжнее!)
Заранее благодарен
СообщениеДобавлено: Вс май 04, 2008 15:54
Или даже так!
Что бы бродкаст запросы наполучения айпишника клиентов рубались прямо на порту к которому подключены юзера.
Ибо как я дхйп_релей срабатывает до правил.
Короче проблема в том, что я не особо представляю, как зарубать запрос от клиента для мака ff:ff:ff:ff:ff:ff только для дхцп запросов, не потревожив весь другой бродкаст.
СообщениеДобавлено: Вс май 04, 2008 16:03
Мы готовим прошивку в которой при включении Relay будут отсекаться DHCP Broadcast пакеты в клиентских VLAN-ах.
СообщениеДобавлено: Вс май 04, 2008 16:14
Ну это супер!!!
Только вот может подскажите как в этот момент выкрутится, когда ещё прошивочки нету..:(
Буду очень признателен!!!
СообщениеДобавлено: Вс май 04, 2008 16:18
Или хотя бы скажите, как применить эти правила относительно длинка
ip access-list extended Deny_DHCP
deny udp any any eq bootpc
deny udp any any eq bootps
add permit ip any any
interface FastEthernet1/0/23
ip access-group Deny_DHCP in
вроде бы то что нужно...
СообщениеДобавлено: Вс май 04, 2008 17:09
Поскольку Relay срабатывает быстрее чем стандартные ACL то Вы стандартными ACL эти пакеты на свитче где включён Relay не отсечёте. Это можно сделать на ближайшем вышестоящем свитче, на котором Relay выключён. А по синтаксису просто рубите DHCP Broadcast по адресу и порту.
СообщениеДобавлено: Вс май 04, 2008 17:26
ну сделал вот так!
create access_profile ip udp src_port_mask 0xFFFF profile_id 1
config access_profile profile_id 1 add access_id 1 ip udp src_port 67 port 1 deny
config access_profile profile_id 1 add access_id 2 ip udp src_port 68 port 1 deny
config access_profile profile_id 1 add access_id 3 ip udp src_port 67 port 2 deny
config access_profile profile_id 1 add access_id 4 ip udp src_port 68 port 2 deny
config access_profile profile_id 1 add access_id 5 ip udp src_port 67 port 3 deny
config access_profile profile_id 1 add access_id 6 ip udp src_port 68 port 3 deny
config access_profile profile_id 1 add access_id 7 ip udp src_port 67 port 4 deny
config access_profile profile_id 1 add access_id 8 ip udp src_port 68 port 4 deny
config access_profile profile_id 1 add access_id 9 ip udp src_port 67 port 5 deny
config access_profile profile_id 1 add access_id 10 ip udp src_port 68 port 5 deny
config access_profile profile_id 1 add access_id 11 ip udp src_port 67 port 6 deny
config access_profile profile_id 1 add access_id 12 ip udp src_port 68 port 6 deny
config access_profile profile_id 1 add access_id 13 ip udp src_port 67 port 7 deny
config access_profile profile_id 1 add access_id 14 ip udp src_port 68 port 7 deny
config access_profile profile_id 1 add access_id 15 ip udp src_port 67 port 8 deny
config access_profile profile_id 1 add access_id 16 ip udp src_port 68 port 8 deny
config access_profile profile_id 1 add access_id 17 ip udp src_port 67 port 9 deny
config access_profile profile_id 1 add access_id 18 ip udp src_port 68 port 9 deny
config access_profile profile_id 1 add access_id 19 ip udp src_port 67 port 10 deny
config access_profile profile_id 1 add access_id 20 ip udp src_port 68 port 10 deny
config access_profile profile_id 1 add access_id 21 ip udp src_port 67 port 11 deny
config access_profile profile_id 1 add access_id 22 ip udp src_port 68 port 11 deny
config access_profile profile_id 1 add access_id 23 ip udp src_port 67 port 12 deny
config access_profile profile_id 1 add access_id 24 ip udp src_port 68 port 12 deny
config access_profile profile_id 1 add access_id 25 ip udp src_port 67 port 13 deny
config access_profile profile_id 1 add access_id 26 ip udp src_port 68 port 13 deny
config access_profile profile_id 1 add access_id 27 ip udp src_port 67 port 14 deny
config access_profile profile_id 1 add access_id 28 ip udp src_port 68 port 14 deny
config access_profile profile_id 1 add access_id 29 ip udp src_port 67 port 15 deny
config access_profile profile_id 1 add access_id 30 ip udp src_port 68 port 15 deny
config access_profile profile_id 1 add access_id 31 ip udp src_port 67 port 16 deny
config access_profile profile_id 1 add access_id 32 ip udp src_port 68 port 16 deny
config access_profile profile_id 1 add access_id 33 ip udp src_port 67 port 17 deny
config access_profile profile_id 1 add access_id 34 ip udp src_port 68 port 17 deny
config access_profile profile_id 1 add access_id 35 ip udp src_port 67 port 18 deny
config access_profile profile_id 1 add access_id 36 ip udp src_port 68 port 18 deny
config access_profile profile_id 1 add access_id 37 ip udp src_port 67 port 19 deny
config access_profile profile_id 1 add access_id 38 ip udp src_port 68 port 19 deny
config access_profile profile_id 1 add access_id 39 ip udp src_port 67 port 20 deny
config access_profile profile_id 1 add access_id 40 ip udp src_port 68 port 20 deny
config access_profile profile_id 1 add access_id 41 ip udp src_port 67 port 21 deny
config access_profile profile_id 1 add access_id 42 ip udp src_port 68 port 21 deny
Всё работает суперово!
