Текущее время: Вс авг 09, 2026 04:01
 Заголовок сообщения: DES-3226S и CISCO глюки
СообщениеДобавлено: Ср окт 20, 2004 11:32
Имеется DES-3226S в связке catalyst 2924-(DES-3226S)-7507rsp16
и получаю такие вот грабли:
на свитче DES-3226S порт в циску говорит port11 Connection 100M/Half/None
циско говорит
brabus#sh int fa 1/0/0
FastEthernet1/0/0 is up, line protocol is up
Hardware is cyBus FastEthernet Interface, address is 00b0.4a22.f020 (bia 00b0.4a22.f020)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 19:16:59
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 310000 bits/sec, 98 packets/sec
5 minute output rate 181000 bits/sec, 94 packets/sec
5929485 packets input, 2435409279 bytes, 0 no buffer
Received 132 broadcasts, 0 runts, 0 giants, 0 throttles
44 input errors, 44 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog
0 input packets with dribble condition detected
5575709 packets output, 1665686400 bytes, 0 underruns
0 output errors, 6546 collisions, 1 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier
0 output buffer failures, 0 output buffers swapped out
конфигурация порта на циско
interface FastEthernet1/0/0
description -=TRUNK UA=-
no ip address
ip route-cache flow
full-duplex
no cdp enable
end
вот что за DES-3226S
Device Type DES-3226S Fast-Ethernet Switch
Module Type DES-132T 2-port 1000BASE-T Gigabit Ethernet Module
MAC Address 00-0D-88-F4-B8-09
Get IP From Manual
IP Address 195.140.176.12
VLAN Name SERVERS
Subnet Mask 255.255.255.240
Default Gateway 195.140.176.1
Boot PROM Version Build 2.00.001
Firmware Version Build 4.02-B05
Hardware Version 2C1
когда пытаюсь поставить 100мб фулл дуплекс на делинке порт вообще не поднимается! в авто всё нормально только пишет что это халф хотя на циско пишет что фулл. При работе с каталистами история повторяется!
Что делать в данной ситуации?
СообщениеДобавлено: Ср окт 20, 2004 15:29
Выключить на циске принудительную установку full-duplex. На автомате должно всё подниматься.
СообщениеДобавлено: Ср окт 20, 2004 15:33
На маршрутизаторах такого понятия НЕТ! только 100мбит халф или фулл 8-)
СообщениеДобавлено: Ср окт 20, 2004 15:50
config t
no full-duplex
end
СообщениеДобавлено: Ср окт 20, 2004 16:30
Lexx писал(а):
config t
no full-duplex
end
и сразу становимся half! только что проверил!
СообщениеДобавлено: Ср окт 20, 2004 17:16
peace писал(а):
Lexx писал(а):
config t
no full-duplex
end
Т.е. в конфиге появляется half? Или ведёт себя как half?
А если указать в конфиге роутера speed 100 ?
 Заголовок сообщения: Re: DES-3226S и CISCO глюки
СообщениеДобавлено: Пт дек 14, 2007 01:54
циско говорит
0 watchdog
no ip address
ip route-cache flow
full-duplex
no cdp enable
end
Get IP From Manual
VLAN Name SERVERS
Таже самая проблема, а как себя ведет 3526 в подобной ситуации ?
также будет выставлять в Half Duplex ?
СообщениеДобавлено: Пт дек 14, 2007 10:46
стоят и 3226s и 3526 в связке с цисками 2821, 2801, 7201, 7301, со свичами 3550,3750
взде полный дуплекс и скорость или 100 и 1000, какой порт.
и не помню проблем
а вот мой 3526 подключен к ленсвязевской 5350 - никак не хочет скорость устаканиваться. если авто на портах - то у меня показывается 100/халф у него 100/фулл и тикают ошибки на портах много.
и побороть не удалось. меняли прошивки у меня, у него - один хрен
выставили 10/полудуплекс и успокоились.
более двух лет такая фигня.
