Текущее время: Вт сен 29, 2026 00:03
СообщениеДобавлено: Вт мар 25, 2008 10:16
Доброго времени суток. Столкнулся с такой проблемой, загружаю коммутатор DES-3010F, наблюдаю следующие.
Моргает индикатор Console
Подрубившись компортом выжу (причем такое чувство что это бесконечно)
[code]DES-3010F Fast Ethernet Switch Command Line Interface
Firmware: Build 4.01.020
Copyright(C) 2004-2007 D-Link Corporation. All rights reserved.
UserName:080000080001000080081000080002000080082000080003000080083000080004000080084000080005000080085000080006000080086
00008000700008008700008000800008008800008000900008008900008000A00008008A00008000B00008008B00008000C00008008C00008000D000
08008D00008000E00008008E00008000F00008008F000080000100080080100080001100080081100080002100080082100080003100080083100080
00410008008410008000510008008510008000610008008610008000710008008710008000810008008810008000910008008910008000A10008008A
10008000B10008008B10008000C10008008C10008000D10008008D10008000E10008008E10008000F10008008F100080000200080080200080001200
080081200080002200080082200080003200080083200080004200080084200080005200080085200080006200080086200080007200080087200080
00820008008820008000920008008920008000A20008008A20008000B20008008B20008000C20008008C20008000D20008008D20008000E20008008E
20008000F20008008F200080000300080080300080001300080081300080002300080082300080003300080083300080004300080084300080005300
08008530008000630008008630008000730008008730008000830008008830008000930008008930008000A30008008A30008000B30008008B300080
00C30008008C30008000D30008008D30008000E30008008E30008000F30008008F300080000400080080400080001400080081400080002400080082
400080003400080083400080004400080084400080005400080085400080006400080086400080007400080087400080008400080088400080009400
08008940008000A40008008A40008000B40008008B40008000C40008008C40008000D40008008D40008000E40008008E40008000F40008008F400080
000500080080500080001500080081500080002500080082500080003500080083500080004500080084500080005500080085500080006500080086
50008000750008008750008000850008008850008000950008008950008000A50008008A50008000B50008008B50008000C50008008C50008000D500
08008D50008000E50008008E50008000F50008008F500080000600080080600080001600080081600080002600080082600080003600080083600080
00460008008460008000560008008560008000660008008660008000760008008760008000860008008860008000960008008960008000A60008008A
60008000B60008008B60008000C60008008C60008000D60008008D60008000E60008008E60008000F60008008F600080000700080080700080001700
080081700080002700080082700080003700080083700080004700080084700080005700080085700080006700080086700080007700080087700080
00870008008870008000970008008970008000A70008008A70008000B70008008B70008000C70008008C70008000D70008008D70008000E70008008E
70008000F70008008F700080000800080080800080001800080081800080002800080082800080003800080083800080004800080084800080005800
08008580008000680008008680008000780008008780008000880008008880008000980008008980008000A80008008A80008000B80008008B800080
00C80008008C80008000D80008008D80008000E80008008E80008000F80008008F800080000900080080900080001900080081900080002900080082
900080003900080083900080004900080084900080005900080085900080006900080086900080007900080087900080008900080088900080009900[/code]
В сервисный центр отправлять или можно как то решить самому.
best regards
kuznetsov timofey
СообщениеДобавлено: Ср мар 26, 2008 08:53
А настройки ком-порта менять пробовали?
СообщениеДобавлено: Ср мар 26, 2008 10:33
Сам коммутатор работает нормально? WEB открывается?
СообщениеДобавлено: Чт мар 27, 2008 12:36
Позвоните, пожалуйста, мне в офис по телефону (495)744-0099 доб.392
Бигаров Руслан.
СообщениеДобавлено: Вт апр 22, 2008 08:20
Да конечно пробовал менять настройки все равно так же.
best regards
kuznetsov timofey
СообщениеДобавлено: Вт апр 22, 2008 08:22
Хорошо сегодня позвоню.
best regards
kuznetsov timofey
Сейчас этот форум просматривают: Google [Bot] и гости: 23
