Текущее время: Вт сен 29, 2026 08:31
 Заголовок сообщения: address_binding dhcp_snoop
СообщениеДобавлено: Пт апр 11, 2008 13:39
Доброго времени суток, где можно описание этих функций взять.
firmware 5.01.B19
# IPBIND
disable address_binding acl_mode
disable address_binding trap_log
disable address_binding dhcp_snoop
config address_binding dhcp_snoop max_entry ports 1 limit 5
config address_binding dhcp_snoop max_entry ports 2 limit 5
config address_binding dhcp_snoop max_entry ports 3 limit 5
config address_binding dhcp_snoop max_entry ports 4 limit 5
config address_binding dhcp_snoop max_entry ports 5 limit 5
config address_binding dhcp_snoop max_entry ports 6 limit 5
config address_binding dhcp_snoop max_entry ports 7 limit 5
config address_binding dhcp_snoop max_entry ports 8 limit 5
config address_binding dhcp_snoop max_entry ports 9 limit 5
config address_binding dhcp_snoop max_entry ports 10 limit 5
config address_binding dhcp_snoop max_entry ports 11 limit 5
config address_binding dhcp_snoop max_entry ports 12 limit 5
config address_binding dhcp_snoop max_entry ports 13 limit 5
config address_binding dhcp_snoop max_entry ports 14 limit 5
config address_binding dhcp_snoop max_entry ports 15 limit 5
config address_binding dhcp_snoop max_entry ports 16 limit 5
config address_binding dhcp_snoop max_entry ports 17 limit 5
config address_binding dhcp_snoop max_entry ports 18 limit 5
config address_binding dhcp_snoop max_entry ports 19 limit 5
config address_binding dhcp_snoop max_entry ports 20 limit 5
config address_binding dhcp_snoop max_entry ports 21 limit 5
config address_binding dhcp_snoop max_entry ports 22 limit 5
config address_binding dhcp_snoop max_entry ports 23 limit 5
config address_binding dhcp_snoop max_entry ports 24 limit 5
config address_binding dhcp_snoop max_entry ports 25 limit 5
config address_binding dhcp_snoop max_entry ports 26 limit 5
best regards
kuznetsov timofey
СообщениеДобавлено: Пт апр 11, 2008 22:05
Я вам описание настройки функции выслал.
СообщениеДобавлено: Пн апр 14, 2008 02:51
Можно и мне эту документацию.
СообщениеДобавлено: Пн апр 14, 2008 06:46
Можно попросить выслать на этот адрес Kuznetsov_t@mail.ru , если не трудно. А то что то не дошло письмо наверное.
best regards
kuznetsov timofey
СообщениеДобавлено: Пн апр 14, 2008 19:08
Я Вам описание настройки функции выслал.
СообщениеДобавлено: Вт апр 15, 2008 07:16
Спасибо получил. Как у себя опробую отпишу на почту.
best regards
kuznetsov timofey
СообщениеДобавлено: Вс апр 20, 2008 00:02
Иван, а можно и мне выслать описание?
СообщениеДобавлено: Вт апр 22, 2008 13:27
Я Вам описания параметров выслал.
