Текущее время: Пт авг 07, 2026 23:02
СообщениеДобавлено: Вт апр 01, 2008 20:08
проблема, не синхронизируется, просто мигает индикатор STATUS
прилагаю отчеты, прошивки менял, ПОМОГИТЕ
ADSL Status
ADSL status shows the ADSL physical layer status.
ADSL Firmware Version: 7.03.01.00 - 7.03.01.00 - 7.03.01.00 Annex B - 01.07.2c - 0.54
ADSL Software Version: V3.02B01T01.RU-A.20071226
Line State Disconnected
Modulation Multi-mode
Annex Mode ANNEX_B
Max Tx Power -38 dBm/Hz
Item Downstream Upstream Unit
SNR Margin 0 0 dB
Line Attenuation 0 0 dB
Data Rate 0 0 kbps
Display Receive and Transmit packages through ADSL
Transmit
Tx PDU's 0
Tx Total Bytes 0
Tx Total Error Counts 0
Receive
Rx PDU's 0
Rx Total Bytes 0
Rx Total Error Counts 0
Jan 1 12:00:12> NTP Polling Timer for DHCP Started succesfully.
Jan 1 12:00:12> DSL Polling Timer Started succesfully.
Jan 1 12:00:12> Firewall NAT service started
Jan 1 12:00:16> starting on port 80
Jan 1 12:00:16> (c)2000 Netfilter core team
Jan 1 12:00:16> netfilter PSD loaded - (c) astaro AG
Jan 1 12:00:16> Initializing the WAN Bridge.
Jan 1 12:00:16> Please set the MAC Address for the WAN Bridge.
Jan 1 12:00:16> Set the Environment variable 'wan_br_mac'.
Jan 1 12:00:16> xx.xx.xx.xx.xx.xx
Jan 1 12:00:16> Mounted root (squashfs filesystem) readonly.
Jan 1 12:00:16> Mounted devfs on /dev
Jan 1 12:00:16> 64k freed
Jan 1 12:00:16> Algorithmics/MIPS FPU Emulator v1.5
Jan 1 12:00:16> registered device TI Avalanche SAR
Jan 1 12:00:16> Sangam detected
Jan 1 12:00:16> DSP binary filesize = 376866 bytes
Jan 1 12:00:16> Setting mode to 0xffff
Jan 1 12:00:16> version:[7.03.01.00]
Jan 1 12:00:16> Disable_igmp_snooping_register!!!Jan 1 12:00:16> Setting mode to 0xffff
Jan 1 12:00:16> Default Asymmetric MTU for nas0 1500
Jan 1 12:00:16> Registering protocol inspector: 0x94162838 for VCC:0x94008a00
Jan 1 12:00:16> Default Asymmetric MTU for br0 1500
Jan 1 12:00:16> Bridge Created: br0
Jan 1 12:00:17> Bridge Created: br1
Jan 1 12:00:17> Bridge Interface Added: eth0
Jan 1 12:00:18> 2
Jan 1 12:00:18> Default Asymmetric MTU for br1 1500
Jan 1 12:00:18> 2
Jan 1 12:00:22> DSL Carrier is down
Jan 1 12:00:43> modulation(1)
СПАСИБО ЧТО ДОЧИТАЛИ ДО ЭТОГО МЕСТА :)
СообщениеДобавлено: Ср апр 02, 2008 16:01
1. А какая модель модема?
2. У Вас ADSL-линия стандарта Annex A или Annex B?
