Текущее время: Вс авг 23, 2026 02:17
 Заголовок сообщения: DES 1228 и 1252 - DUP!
СообщениеДобавлено: Вт мар 25, 2008 14:38
стоит сервер, интернет приходит по wi-fi, по оптике подключён к серверу свитч 1252(через конвертеры соответственно), на нем настроены VLAN, в него воткут такой же свитч с VLAN.
Device Type DES-1252
Firmware Version 1.10.07
первый пингуется нормально, второй вот так
64 bytes from 10.XX.XX.31: icmp_seq=1 ttl=255 time=510 ms
64 bytes from 10.XX.XX.31: icmp_seq=1 ttl=255 time=510 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=1 ttl=255 time=511 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=1 ttl=255 time=512 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=1 ttl=255 time=513 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=1 ttl=255 time=515 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=1 ttl=255 time=516 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=1 ttl=255 time=517 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=9.76 ms
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=9.80 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=9.84 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=9.87 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=10.1 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=10.3 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=10.4 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=10.5 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=10.7 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=10.8 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=11.0 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=11.2 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=11.3 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=11.5 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=11.6 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=11.8 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=11.9 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=12.1 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=12.2 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=12.3 ms (DUP!)
64 bytes from 10.XX.XX.31: icmp_seq=2 ttl=255 time=12.5 ms (DUP!)
в чем может быть загвоздка.
по такой же схеме подключены свитчи другого производителя, всё в порядке.
СообщениеДобавлено: Чт мар 27, 2008 17:42
UP
проблема так и не решена
СообщениеДобавлено: Чт мар 27, 2008 18:31
(DUP!) - означает, что вам пришло два ответа.
Бигаров Руслан.
СообщениеДобавлено: Сб мар 29, 2008 02:15
Тут не два а целых двадцать два. Скорее всего кольцо.
WBR. Sp!ZER
СообщениеДобавлено: Пн мар 31, 2008 01:02
Попробуйте поставить в System Settings параметр Group Interval в 0.
