Текущее время: Ср ноя 11, 2026 09:47
 Заголовок сообщения: проблема с pptp на DI-704UP
СообщениеДобавлено: Пн янв 14, 2008 20:42
роутер DI-704UP Firmware Version: V1.03b03, Wed, Feb 14 2007
постоянно обрывается vpn
как заметил каждые 7 миинут
перегрева нет раньше с этим провайдером работал без проблем
СообщениеДобавлено: Вт янв 15, 2008 09:39
Wed Feb 14 05:09:25 2007 DHCP:renew
Wed Feb 14 05:09:30 2007 DHCP:renew
Wed Feb 14 05:09:39 2007 DHCP:renew
Wed Feb 14 05:09:55 2007 DHCP:renew
Wed Feb 14 05:14:24 2007 DHCP:release
Wed Feb 14 05:14:26 2007 Connection is broken
Wed Feb 14 05:14:26 2007 PPTP start to dial-down
Wed Feb 14 05:14:42 2007 Blocked access attempt from 66.249.73.147:64118 to TCP port 80
Wed Feb 14 05:14:45 2007 Blocked access attempt from 66.249.73.147:64118 to TCP port 80
Wed Feb 14 05:14:51 2007 Blocked access attempt from 66.249.73.147:64118 to TCP port 80
Wed Feb 14 05:15:38 2007 PPTP:error=-299
Wed Feb 14 05:17:07 2007 DOD:triggered internally
Wed Feb 14 05:17:07 2007 PPTP start to dial-up
Wed Feb 14 05:17:07 2007 DHCP:discover(destine)
Wed Feb 14 05:17:07 2007 DHCP:offer(172.17.78.1)
Wed Feb 14 05:17:07 2007 DHCP:request(172.17.78.75)
Wed Feb 14 05:17:07 2007 DHCP:ack(DOL=600,T1=300,T2=525)
Wed Feb 14 05:17:10 2007 PPTP server=192.168.1.11 briz
Wed Feb 14 05:17:11 2007 PAP1: Greetings!!
Wed Feb 14 05:17:11 2007 IPCP1: IP is 194.143.137.49
Wed Feb 14 05:17:11 2007 IPCP1: DNS0 is 194.143.137.2
Wed Feb 14 05:17:11 2007 IPCP1: DNS1 is 194.143.136.1
Wed Feb 14 05:17:11 2007 IPCP terminate recv
Wed Feb 14 05:17:14 2007 IPCP terminate recv
Wed Feb 14 05:17:17 2007 IPCP terminate recv
Wed Feb 14 05:17:20 2007 IPCP terminate recv
Wed Feb 14 05:17:23 2007 IPCP terminate recv
Wed Feb 14 05:17:26 2007 LCP terminate recv
Wed Feb 14 05:17:27 2007 Connection is broken
Wed Feb 14 05:17:27 2007 PPTP start to dial-down
Wed Feb 14 05:17:29 2007 LCP terminate recv
Wed Feb 14 05:17:31 2007 PPTP:error=-200
Wed Feb 14 05:17:31 2007 DHCP:release
Wed Feb 14 05:17:37 2007 DOD:triggered internally
Wed Feb 14 05:17:37 2007 PPTP start to dial-up
Wed Feb 14 05:17:37 2007 DHCP:discover(destine)
Wed Feb 14 05:17:37 2007 DHCP:offer(172.17.78.1)
Wed Feb 14 05:17:37 2007 DHCP:request(172.17.78.75)
Wed Feb 14 05:17:37 2007 DHCP:ack(DOL=600,T1=300,T2=525)
Wed Feb 14 05:17:39 2007 PPTP server=192.168.1.114 briz
Wed Feb 14 05:17:40 2007 PAP1: Greetings!!
Wed Feb 14 05:17:40 2007 IPCP1: IP is 194.143.137.49
Wed Feb 14 05:17:40 2007 IPCP1: DNS0 is 194.143.137.6
Wed Feb 14 05:17:40 2007 IPCP1: DNS1 is 194.143.136.1
Wed Feb 14 05:18:39 2007 Blocked access attempt from 13.251.85.12:30311 to UDP port 1026
Wed Feb 14 05:19:20 2007 Blocked access attempt from 66.249.73.147:32776 to TCP port 80
Wed Feb 14 05:19:23 2007 Blocked access attempt from 66.249.73.147:32776 to TCP port 80
Wed Feb 14 05:19:29 2007 Blocked access attempt from 66.249.73.147:32776 to TCP port 80
Wed Feb 14 05:19:41 2007 Blocked access attempt from 66.249.73.147:32776 to TCP port 80
Wed Feb 14 05:20:05 2007 Blocked access attempt from 66.249.73.147:32776 to TCP port 80
Wed Feb 14 05:22:38 2007 DHCP:renew
Wed Feb 14 05:22:43 2007 DHCP:renew
Wed Feb 14 05:22:52 2007 DHCP:renew
Wed Feb 14 05:23:08 2007 DHCP:renew
Wed Feb 14 05:23:29 2007 Connection is broken
Wed Feb 14 05:23:29 2007 PPTP start to dial-down
Wed Feb 14 05:23:32 2007 PPTP:error=-200
Wed Feb 14 05:23:32 2007 DHCP:release
Wed Feb 14 05:23:33 2007 DOD:TCP trigger from 192.168.0.101:411 to 172.17.137.19:3459
Wed Feb 14 05:23:33 2007 PPTP start to dial-up
Wed Feb 14 05:23:33 2007 DHCP:discover(destine)
Wed Feb 14 05:23:33 2007 DHCP:offer(172.17.78.1)
Wed Feb 14 05:23:33 2007 DHCP:request(172.17.78.75)
Wed Feb 14 05:23:33 2007 DHCP:ack(DOL=600,T1=300,T2=525)
Wed Feb 14 05:23:33 2007 PPTP server=192.168.1.115 briz
Wed Feb 14 05:23:34 2007 PAP1: Greetings!!
Wed Feb 14 05:23:34 2007 IPCP1: IP is 194.143.137.49
Wed Feb 14 05:23:34 2007 IPCP1: DNS0 is 194.143.137.4
Wed Feb 14 05:23:34 2007 IPCP1: DNS1 is 194.143.136.1
Wed Feb 14 05:28:34 2007 DHCP:renew
Wed Feb 14 05:28:39 2007 DHCP:renew
Wed Feb 14 05:28:48 2007 DHCP:renew
СообщениеДобавлено: Вт янв 15, 2008 11:36
Это происходит только при простое или при передаче трафика тоже?
СообщениеДобавлено: Вт янв 15, 2008 18:20
это происходит каждые 7 минут иногда роутер сам переподключается а иногда время подключения продолжает тикать показывает ип но интернета нет помогает перезагрузка из веб интерфейса
СообщениеДобавлено: Ср янв 16, 2008 13:56
что означают ошибки
Saturday March 01, 2008 11:41:57 PPTP:error=-112
и иногда выпадает 200
Сейчас этот форум просматривают: Google [Bot] и гости: 17
