Текущее время: Чт авг 13, 2026 00:04
 Заголовок сообщения: 7090 групповой вызов!!!
СообщениеДобавлено: Пт ноя 09, 2007 11:29
Помогите, не работает групповой вызов, в логе ошибки ERR.
Вот лог:2007/11/09 11:59:56.649 INF 115a2cd78daf11dcb00994123debb211 Call: OnRegisterCall(): *******************************************************
2007/11/09 11:59:56.649 INF 115a2cd78daf11dcb00994123debb211 Call: OnRegisterCall(): Incoming call src=79043586519 address=195.206.45.14 dst=73952706261
2007/11/09 11:59:56.693 INF a866edd820944feb819d5c7e716d072e Conference: OnCapabilitiesCall(): incoming >>> Caps (DB): PCMA/20, G.729A/2, G.729/2, PCMU/20, G.723.1/1
2007/11/09 11:59:56.695 INF a866edd820944feb819d5c7e716d072e Conference: OnCapabilitiesCall(): incoming >>> Caps (device): PCMA/20, PCMU/20, G.729/2, G.729B/3, G.723.1/3, G.723.1/3
2007/11/09 11:59:56.695 INF a866edd820944feb819d5c7e716d072e Conference: OnCapabilitiesCall(): Caps1: PCMA/20, G.729/2, PCMU/20, G.723.1/3, G.723.1/3
2007/11/09 11:59:56.733 INF 115a2cd78daf11dcb00994123debb211 Rule: GetRoute(): Rule description: In Call
2007/11/09 11:59:56.734 INF 115a2cd78daf11dcb00994123debb211 DisaService: .ctor(): --->>> Follow to DISA service src=79043586519, dst=73952706261, disa=a8430849-31b5-4b11-a202-747c993aa5f5
2007/11/09 11:59:56.792 INF 115a2cd78daf11dcb00994123debb211 Conference: OnMediaStart(): incoming >>> Call src=79043586519 dst=73952706261 caps_start: PCMA/20,
2007/11/09 11:59:56.794 INF 115a2cd78daf11dcb00994123debb211 Conference: OnConnectedCall(): incoming >>> call=115a2cd78d-af11-dcb0-0994-123debb211.
2007/11/09 11:59:57.111 INF e31efba4015b423c9e763a36adb96168 Conference: OnPayloadTypeChangedCall(): incoming >>> callId=115a2cd78d-af11-dcb0-0994-123debb211
2007/11/09 12:00:11.762 INF 115a2cd78daf11dcb00994123debb211 DisaService: ProcessForward(): Forward on attendant to 0007
2007/11/09 12:00:13.129 INF 115a2cd78daf11dcb00994123debb211 Rule: GetRoute(): Rule description: Call group
2007/11/09 12:00:13.137 INF 115a2cd78daf11dcb00994123debb211 GroupCallService: .ctor(): --->>> Follow to GroupCall service src=79043586519, dst=0007, guid=3cf72004-cd30-4eb4-aa94-a04cacd3f1a0
2007/11/09 12:00:14.208 ERR 7f5926a8b2d84d87bdb365b379964a60 Exception:
2007/11/09 12:00:14.209 ERR 7f5926a8b2d84d87bdb365b379964a60 Exception message: Object reference not set to an instance of an object
2007/11/09 12:00:14.210 ERR 7f5926a8b2d84d87bdb365b379964a60 Exception stack: at MeraSystems.VoIP.Phoenix.MediaProcessor.PepareCodecForOutCall (MeraSystems.VoIP.Phoenix.Call inCall, MeraSystems.VoIP.Phoenix.Call outCall) [0x00000]
at MeraSystems.VoIP.Phoenix.Conference.CreateOutgoingLeg (MeraSystems.VoIP.Phoenix.EndPoint endPoint, MeraSystems.VoIP.Phoenix.Terminal outTerminal, MeraSystems.VoIP.Phoenix.Call inCall, System.String source, System.String destination, System.String state) [0x00000]
at MeraSystems.VoIP.Phoenix.GroupCallService.CreateOutgoingCallInGroup (System.String destination, MeraSystems.VoIP.Phoenix.Terminal outTerminal) [0x00000]
at MeraSystems.VoIP.Phoenix.GroupCallService.Redial (System.Object obj, System.EventArgs args) [0x00000]
2007/11/09 12:00:24.205 ERR 7f5926a8b2d84d87bdb365b379964a60 Exception:
2007/11/09 12:00:24.206 ERR 7f5926a8b2d84d87bdb365b379964a60 Exception message: Object reference not set to an instance of an object
2007/11/09 12:00:24.207 ERR 7f5926a8b2d84d87bdb365b379964a60 Exception stack: at MeraSystems.VoIP.Phoenix.MediaProcessor.PepareCodecForOutCall (MeraSystems.VoIP.Phoenix.Call inCall, MeraSystems.VoIP.Phoenix.Call outCall) [0x00000]
2007/11/09 12:00:34.233 ERR 7f5926a8b2d84d87bdb365b379964a60 Exception:
2007/11/09 12:00:34.234 ERR 7f5926a8b2d84d87bdb365b379964a60 Exception message: Object reference not set to an instance of an object
2007/11/09 12:00:34.235 ERR 7f5926a8b2d84d87bdb365b379964a60 Exception stack: at MeraSystems.VoIP.Phoenix.MediaProcessor.PepareCodecForOutCall (MeraSystems.VoIP.Phoenix.Call inCall, MeraSystems.VoIP.Phoenix.Call outCall) [0x00000]
2007/11/09 12:00:44.205 ERR 7f5926a8b2d84d87bdb365b379964a60 Exception:
2007/11/09 12:00:44.206 ERR 7f5926a8b2d84d87bdb365b379964a60 Exception message: Object reference not set to an instance of an object
2007/11/09 12:00:44.207 ERR 7f5926a8b2d84d87bdb365b379964a60 Exception stack: at MeraSystems.VoIP.Phoenix.MediaProcessor.PepareCodecForOutCall (MeraSystems.VoIP.Phoenix.Call inCall, MeraSystems.VoIP.Phoenix.Call outCall) [0x00000]
2007/11/09 12:00:44.411 INF 115a2cd78daf11dcb00994123debb211 GroupCallService: OnUnregisterCall() Call src=79043586519 dst=73952706261 was unregistered, code=NormalCallClearing, reason=Normal call termination
СообщениеДобавлено: Пт ноя 09, 2007 11:47
IP-PBX member
Настройки расскажите для начала, лучше базу сразу слить и сказать кто на кого звонит
MERA
СообщениеДобавлено: Ср ноя 14, 2007 07:13
Я бы прислал базу, но куда это присобачить. А звонят извне, отвечает ДИЗА, по концу таймаута ДИЗЫ идет на нмр 0007, а в 0007 занесен групповой вызов, вот и все. Да, вызывающему идут гудки будто вызов идет, но не один телефон из группы не звонит.
СообщениеДобавлено: Ср ноя 14, 2007 07:14
Телефоны на гетвее 2032
СообщениеДобавлено: Ср ноя 14, 2007 12:41
IP-PBX member
А можете сделать тот же тест без гейта- чисто воип телефонами и 7090?
MERA
СообщениеДобавлено: Ср ноя 14, 2007 13:08
VoIP у нас всего один телефон.
Могу дать веэб доступ к GW и к 7090, надо ?
СообщениеДобавлено: Ср ноя 14, 2007 14:02
Модератор
Модератор
Да, давайте на почту
Виктор Колосов
СообщениеДобавлено: Чт ноя 15, 2007 17:52
отправил в Личку
СообщениеДобавлено: Пт ноя 23, 2007 06:54
После обновления вопрос с ERR снялся. Да и наконец разобрались с "автооператором". Обединение юзеров и правил идет через сервисы, т.е. должны быть созданы группы типа pickup, надо создать сервисы Group Call и привязывать к определенной группе. Потом эти группы прописывать у юзеров и создаются правила с этими сервизами. Теперь звонки можно распределять по разным группам и с ДИЗЫ и внутренние звонки.
СообщениеДобавлено: Пт ноя 23, 2007 07:04
Большое спасибо, Иркутским представителям Длинк за помощь в настройке подключения к SIPnet (поддержка SipNet сказал что 7090 с МЕРой вообще к ним не подключается из-за ошибки в протоколе), разработчика которые столь своевременно выпустили прошивку, поддержке на форуме за живое участие в решении проблем.
СообщениеДобавлено: Пт ноя 23, 2007 10:46
IP-PBX member
Не правду они говорят- я с ихней же поддержкой коннект налаживал еще пару лет назад. 7090 к сипнет очень даже подключается. надо просто знать как.
MERA
СообщениеДобавлено: Пт ноя 23, 2007 19:24
Ага, представитель Делинка мне и помог минут за пять (у меня в логин на 7090 был написан мой логин в Sipnet, а нужно было 3109901@sipnet.ru т.е. номер телефона@sipnet.ru), а вот товарищи из тех поддержки Сипнета 4 (ЧЕТЫРЕ) дня думали я им удаленный доступ к устройству дал, в конеце товарищь, который со мной общался сказал, что они всё попробовали и он вызвонил человека который "плотно" занимался 7090 и мерой и он сказал "ошибка в протаколе и они* ее искать не хотят, говорят что к Тел-ми нормально конектится "
* Они он имел ввиду вас поддержку Делинк и Мера.
А вообще у Делинка хорошая вещь есть инструкции по подключению к провайдеру в картинках http://dlink.ru/technical/expl_.php только там для 7090 ничего нет и в доке этот адрес не указа.
И есть еще один + в других утройствах Делинка это кнопочка HELP на каждой страничке настроек оборудования, а там куски из манула относящиеся к настройкам, конечно иногда скудновато, но очень удобно.
СообщениеДобавлено: Пт ноя 23, 2007 19:26
P.S.
т.е. я как клиент сделал все что мог для тех поддержки Sipnet.
СообщениеДобавлено: Пт ноя 23, 2007 19:30
IP-PBX member
Я где то как то писал. Вроде до сих пор актуально
Мануал по дружбе с SIPNET
1. Регистрируемся на SIPNET. Как результат получаем SIPID и пароль.
2. Прописываем SIPNET в Gateways следующим образом
2.1 Gateway name- sipnet.ru
2.2 IP Address 212.53.35.219 (ну или чего выдаст nslookup на sipnet.ru)
2.3 порт 5060
2.4 Выставляем исходящую регистрацию (Register with GK/registrar )
2.4.1 User- SIPID@sipnet.ru
2.4.2 Password - Пароль на СИПНЕТЕ
2.4.3 Port - 5060
2.4.3 TTL - 120 (не меньше 60)
3. Открываем файрволл (если PBX стоит за файрволлом), для входящих и исходящих UDP с портов старше 1024 и ходящих с хоста sipnet.ru
4. Перегружаемся и убеждаемся что в колонке статуса появилось External. Если не появилось смотрим логи и сниффим.
5. Прописываем роутинг для исходящих звонков на sipnet.
Note: sipnet разрешает все звонки с любых зарегистрированных на PBX телефонов.
6. Прописываем роутинг для входящих звонков. Тонкость: с SIPNET получится звонить только на сипнетный SIPID бесплатно. Посему возможны 2 опции- адресовать этот звонок конкретному телефону за PBX или выйти на DISA.
6.1 Например у нас есть локальный телефон 5972. Тогда правило выглядит как:
Match Destination: ^SIPID$
Result Destination: 5972
Command: Dial User
6.2 В случае DISA:
Command: DISA
MERA
СообщениеДобавлено: Пт ноя 23, 2007 19:45
Осталось это довести до клиентов Длинка http://dlink.ru/technical/expl_.php
и до клиентов Sipnet-a http://www.sipnet.ru/orderandpay/hardware.html#phones в виде http://www.sipnet.ru/files/agatux.pdf и его тех поддержки. :D
И ссылки в доку и веб интерфейс для полного счастья.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 1
