Текущее время: Вс сен 13, 2026 08:38
 Заголовок сообщения: непонятки с vlan das3224
СообщениеДобавлено: Пт ноя 16, 2007 11:59
делаю всё по инструкции!
create vlan static vlanname M vlanid 112
create vlan static vlanname A vlanid 118
create vlan static vlanname E vlanid 127
modify vlan static vlanid 1 untaggedports none egressports none
modify vlan static vlanname M egressports 1 2 4 5 6 7 8 9 10 11 13 14 15 16 17 18 19 20 21 22 23 24 385 untaggedports 1 2 4 5 6 7 8 9 10 11 13 14 15 16 17 18 19 20 21 22 23 24 floodSupport enable bcastsupport enable
modify vlan static vlanname Agrotech egressports 3 385 untaggedports 3 floodSupport enable bcastsupport enable
modify vlan static vlanname Ekspert egressports 12 385 untaggedports 12 floodSupport enable bcastsupport enable
modify gvrp port info portid 1 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 2 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 4 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 5 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 6 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 7 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 8 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 9 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 10 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 11 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 13 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 14 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 15 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 16 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 17 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 18 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 19 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 20 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 21 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 22 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 23 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 24 portvlanid 112 acceptframetypes all ingressfiltering true
modify gvrp port info portid 3 portvlanid 118 acceptframetypes all ingressfiltering true
modify gvrp port info portid 12 portvlanid 127 acceptframetypes all ingressfiltering true
Пакеты с 3 порта проходят только в сторону dslam! а обратно нет
СообщениеДобавлено: Пт ноя 16, 2007 12:36
вместо Agrotech и Ekspert А и Е! ошибся просто
 Заголовок сообщения: Re: непонятки с vlan das3224
СообщениеДобавлено: Пт ноя 16, 2007 15:20
В данной реализации все должно работать.
Что стоит за DSLAM? Коммутатор? На нем создан VLAN с VID 118? Порт на коммутаторе (к которому подключен DSLAM) сконфигурирован как tagged в нужных VLAN?
Какое устройство подключено к 3-му порту DSLAM? Как настроено данное устройство?
С уважением, Давыдов Денис.
СообщениеДобавлено: Пт ноя 16, 2007 16:19
das 3224 ! des 3018 ! влан создан tagget ! dslam пингуется на ура! а вот пакеты идут на cpe идут только в сторону абонента
СообщениеДобавлено: Пт ноя 16, 2007 16:26
Так, давайте все по порядку:
1. DAS-3224 подключен к DES-3018.
2. IP адрес DSLAM пингуется с компьютера, подключенного к DES-3018? Если это так, к какому порту DES-3018 подключен компьютер?
3. С компьютера, подключенного к DES-3018 абонентское устройство/компьютер не пингуется?
4. Какое абонентское устройство используется и как настроено?
5. Приведите вывод команды (DES-3018): show vlan
6. Опишите схему Вашей сети и настройки устройств максимально подробно, от этого зависит продуктивность дальнейшего разговора.
СообщениеДобавлено: Пт ноя 16, 2007 17:49
1.Das 3224 подключен к таггет порту des 3018
2. Компьютер подключен к антаггет порту 3018 тоже влан что и 3224!
3. с компьютера подключенного к 3018 дслам пингуется а пользовательский компьтер нет!
4. абонентское устроёство dsl-500t и настроено правильно на 100%(штук 300 уже перенастроил)
5.
VID : 118 VLAN Name : test
VLAN TYPE : static
Member ports : 9-11
Static ports : 9-11
Untagged ports : 9,11
6. схема проста , чисто пробная! Дслам подключен к коммутатору, к дслам подключен модем и за ним комп! Тестовый компьютер подключен к порту коммутатора!
СообщениеДобавлено: Пт ноя 16, 2007 18:05
Вот теперь все понятно.
385 bridge интерфейс на DSLAM сконфигурирован как tagged в VLAN c VID 118, поэтому все нетегированные кадры, приходящие с Untagged интерфейса коммутатора будут отброшены. Это нормальная ситуация. Для нормальной передачи трафика к абоненту и обратно порт на коммутаторе должен быть сконфигурирован как tagged в VLAN с VID 118. У вас же все порты, входящие в VLAN с VID 118 на коммутаторе сконфигурированы как untagged.
Почитайте описание стандарта 802.1Q и сразу все станет ясно.
СообщениеДобавлено: Пт ноя 16, 2007 18:20
Да нет! Причина в другом была! както странно получилось что порт к которому тестовый комп был подключен на 3018 он антаггет 118 и ещё антаггет влан 120 был!
СообщениеДобавлено: Пт ноя 16, 2007 18:22
Это невозможно. Порт (по стандарту) может быть Untagged лишь в одном VLAN...
СообщениеДобавлено: Ср ноя 28, 2007 23:48
а вот и может быть! совсем недавно столкнулся с такой ситуацией на 3010g! И ещё вопрос : возможно ли сделать на das 3224 также как и на 3216 чтобы все приходящие на uplink 3224 пакеты антаггет ассоциировались с default вланом , и сделать несколько портов таггет в других вланах и mgmt влан?
СообщениеДобавлено: Чт ноя 29, 2007 10:58
По поводу коммутатора:
Описанная вами схема возможна только в случае поддержки Assymetric VLAN на коммутаторе.
По поводу DSLAM:
Что бы все Untagged кадры ассоциировались с Default VLAN - они должны из него и приходить.
Сделать один и тот же порт Untagged в нескольких VLAN невозможно, так как DAS-3224/3248 не поддерживает Assymetric VLAN и поддерживать не будет.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 54
