Текущее время: Чт окт 01, 2026 23:17
 Заголовок сообщения: DI-634M и PPtP
СообщениеДобавлено: Вт окт 30, 2007 21:27
Вопрос звучит банально - не работает. Провайдер несколько экзотический- Сигмаком. Все настройки прописываюся, но роутер не коннектится и в логах пишут WAN Interface down. Может кто может поделится опытом настройки в доморощенных сетях...
СообщениеДобавлено: Вт окт 30, 2007 21:49
[INFO] Tue Oct 30 21:40:20 2007 Log viewed by IP address 192.168.0.130
[INFO] Tue Oct 30 21:39:57 2007 WAN interface is down
[INFO] Tue Oct 30 21:39:57 2007 PPTP tunnel ID 0x5077 has been closed
[INFO] Tue Oct 30 21:39:56 2007 WAN interface is down
[INFO] Tue Oct 30 21:39:56 2007 LCP sets remote auth: 0000
[INFO] Tue Oct 30 21:39:56 2007 LCP sets remote options: ACCM: 0, ACFC: 1, PFC: 1, MRU: 1462
[INFO] Tue Oct 30 21:39:56 2007 LCP sets local options: ACCM: 0, ACFC: 1, PFC: 1, MRU: 1462
[INFO] Tue Oct 30 21:39:56 2007 PPTP connected to server "local" with ID 0x5077
[INFO] Tue Oct 30 21:39:56 2007 The PPTP transmit window is 10
[INFO] Tue Oct 30 21:39:56 2007 Attempting to establish a PPTP connection.
[INFO] Tue Oct 30 21:39:06 2007 Initialization complete, starting DHCP server
[INFO] Tue Oct 30 21:39:04 2007 Allowed configuration authentication by IP address 192.168.0.130
[INFO] Tue Oct 30 21:39:03 2007 Obtained IP Address using DHCP. IP address is 10.202.108.208
[INFO] Tue Oct 30 21:39:03 2007 DHCP Server Parameter 47 was removed from the parameter database
[INFO] Tue Oct 30 21:39:03 2007 DHCP Server Parameter 46 was removed from the parameter database
[INFO] Tue Oct 30 21:39:03 2007 DHCP Server Parameter 44 was removed from the parameter database
[INFO] Tue Oct 30 21:39:03 2007 DHCP Server Parameter 19 was added to the parameter database
[INFO] Tue Oct 30 21:39:03 2007 DHCP Server Parameter 15 was added to the parameter database
[INFO] Tue Oct 30 21:39:03 2007 DHCP Server Parameter 3 was added to the parameter database
[INFO] Tue Oct 30 21:39:03 2007 DHCP Server Parameter 1 was added to the parameter database
[INFO] Tue Oct 30 21:39:00 2007 Bringing up WAN using PPTP
[INFO] Tue Oct 30 21:39:00 2007 WAN interface cable has been connected
[INFO] Tue Oct 30 21:38:58 2007 DHCP Server Parameter 6 was added to the parameter database
[INFO] Tue Oct 30 21:38:58 2007 LAN interface is up
[INFO] Tue Oct 30 21:38:58 2007 LAN Ethernet Carrier Detected
[INFO] Tue Oct 30 21:38:58 2007 Device initialized
[INFO] Tue Oct 30 21:38:58 2007 No Internet access policy is in effect. Unrestricted Internet access allowed to everyone
[INFO] Thu Jan 01 00:00:00 1970 Loaded configuration from non-volatile memory
У провайдера VPN через PPtP без шифрования, проверка подлинности MS Chap V2
СообщениеДобавлено: Ср окт 31, 2007 01:14
Вопрос наверное снимается... MS CHAP V2 роутером не поддерживается и проблема видимо в этом. Теперь продается за 2500 р. практически новый :oops:
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 137
