Текущее время: Сб окт 03, 2026 13:12
 Заголовок сообщения: DI-624S: [UDP Flood]
СообщениеДобавлено: Чт окт 25, 2007 23:06
Здравствуйте! Видел аналогичную тему но с другим уклоном, у меня же такая байда.
В логах постоянно появляются записи такого рода:
Oct 25 22:55:33 DOS [UDP]: Attack Incoming 192.168.101.6->235.10.10.34 [UDP Flood]
Oct 25 22:55:31 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.8 [UDP Flood]
Oct 25 22:55:31 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.24 [UDP Flood]
Oct 25 22:55:29 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.8 [UDP Flood]
Oct 25 22:55:28 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.24 [UDP Flood]
Oct 25 22:55:27 DOS [UDP]: Attack Incoming 192.168.101.6->235.10.10.34 [UDP Flood]
Oct 25 22:55:26 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.24 [UDP Flood]
Oct 25 22:55:25 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.8 [UDP Flood]
Oct 25 22:55:24 DOS [UDP]: Attack Incoming 192.168.101.6->235.10.10.34 [UDP Flood]
Oct 25 22:55:23 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.24 [UDP Flood]
Oct 25 22:55:21 DOS [UDP]: Attack Incoming 192.168.101.6->235.10.10.34 [UDP Flood]
Oct 25 22:55:21 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.24 [UDP Flood]
Oct 25 22:55:19 DOS [UDP]: Attack Incoming 192.168.101.6->235.10.10.34 [UDP Flood]
Oct 25 22:55:17 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.8 [UDP Flood]
Oct 25 22:55:16 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.8 [UDP Flood]
Oct 25 22:55:15 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.24 [UDP Flood]
Oct 25 22:55:14 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.8 [UDP Flood]
Oct 25 22:55:14 DOS [UDP]: Attack Incoming 192.168.101.6->235.10.10.34 [UDP Flood]
Oct 25 22:55:12 DOS [UDP]: Attack Incoming 192.168.101.6->235.10.10.34 [UDP Flood]
Oct 25 22:55:12 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.8 [UDP Flood]
Oct 25 22:55:10 DOS [UDP]: Attack Incoming 192.168.101.6->235.10.10.34 [UDP Flood]
Oct 25 22:55:09 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.24 [UDP Flood]
Oct 25 22:55:08 DOS [UDP]: Attack Incoming 192.168.101.6->235.10.10.34 [UDP Flood]
Oct 25 22:55:07 DOS [UDP]: Attack Incoming 192.168.101.6->235.10.10.34 [UDP Flood]
Oct 25 22:55:06 DOS [UDP]: Attack Incoming 192.168.101.6->235.10.10.34 [UDP Flood]
Oct 25 22:55:05 DOS [UDP]: Attack Incoming 192.168.101.6->235.10.10.34 [UDP Flood]
Oct 25 22:55:04 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.24 [UDP Flood]
Oct 25 22:55:03 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.24 [UDP Flood]
Oct 25 22:55:02 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.24 [UDP Flood]
Oct 25 22:55:01 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.8 [UDP Flood]
Oct 25 22:55:00 DOS [UDP]: Attack Incoming 192.168.101.6->235.10.10.34 [UDP Flood]
Oct 25 22:54:59 DOS [UDP]: Attack Incoming 192.168.101.6->235.10.10.34 [UDP Flood]
Oct 25 22:54:58 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.24 [UDP Flood]
Oct 25 22:54:57 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.24 [UDP Flood]
Oct 25 22:54:56 DOS [UDP]: Attack Incoming 192.168.204.13->239.192.152.143 [UDP Flood]
Oct 25 22:54:55 DOS [UDP]: Attack Incoming 192.168.101.6->235.10.10.34 [UDP Flood]
Oct 25 22:54:54 DOS [UDP]: Attack Incoming 192.168.101.6->235.10.10.34 [UDP Flood]
Oct 25 22:54:53 DOS [UDP]: Attack Incoming 192.168.101.2->235.10.10.8 [UDP Flood]
Это чего меня бомбят постоянно?
IP не мои, первый видимо сетевой, второй внешний.
kumar
СообщениеДобавлено: Вс окт 28, 2007 11:33
Да, вот интересно, выше приведенный лог есть следствие наличия iptv и выдаёт его при включённом Multicast. Когда Multicast выключаю соответственно лог очищается. Провайдер говорит, что типа на качество инета это не влияет, так как канал сильно широкий! Однако наблюдаю тормоза при серфинге инета. Так вопрос: может ли эта байда исчисляемая в миллисекундах мешать другим процессам и вообще тормозить роутер?
kumar
Сейчас этот форум просматривают: Google [Bot] и гости: 196
