Текущее время: Сб авг 22, 2026 11:50
 Заголовок сообщения: Проблема с Dlink [DI 524]
СообщениеДобавлено: Чт сен 27, 2007 21:29
Есть провайдер который раздаёт свой интернет через локальную сеть по ВПН соединению, поставил точку доступа DI 524 (обновил последней прошивкой, сделал сброс в дефолт), настроил чтобы точка сама подымала впн, вбил все настройки, пишет PPTP connected. Захожу в интернет через вайфай, но кроме яндекса не одна страница не открывается, в логах проходит вот что:
Thursday September 27, 2007 20:51:41 Unrecognized attempt blocked from 77.235.113.27:50016 to 217.25.225.122 TCP:55727
Thursday September 27, 2007 20:51:44 Unrecognized attempt blocked from 77.235.113.27:50016 to 217.25.225.122 TCP:55727
Thursday September 27, 2007 20:52:12 Unrecognized attempt blocked from 87.236.29.217:2592 to 217.25.225.122 TCP:55727
Thursday September 27, 2007 20:52:15 Unrecognized attempt blocked from 87.236.29.217:2592 to 217.25.225.122 TCP:55727
Thursday September 27, 2007 20:52:26 Associated: 00-1B-9E-15-8F-67 st=0
Thursday September 27, 2007 20:52:49 Unrecognized attempt blocked from 10.104.3.27:2923 to 217.25.225.122 TCP:55727
Thursday September 27, 2007 20:52:52 Unrecognized attempt blocked from 10.104.3.27:2923 to 217.25.225.122 TCP:55727
Thursday September 27, 2007 20:53:25 Unrecognized attempt blocked from 78.106.230.60:4171 to 217.25.225.122 TCP:55727
Thursday September 27, 2007 20:53:28 Unrecognized attempt blocked from 78.106.230.60:4171 to 217.25.225.122 TCP:55727
Thursday September 27, 2007 20:53:36 Unrecognized attempt blocked from 87.126.0.198:12386 to 217.25.225.122 UDP:57218
Thursday September 27, 2007 20:53:47 Associated: 00-13-02-AA-CD-86 st=0
Thursday September 27, 2007 20:54:14 Unrecognized attempt blocked from 77.235.113.27:50309 to 217.25.225.122 TCP:55727
Thursday September 27, 2007 20:54:17 Unrecognized attempt blocked from 77.235.113.27:50309 to 217.25.225.122 TCP:55727
Thursday September 27, 2007 20:54:30 Unrecognized attempt blocked from 78.106.230.60:4291 to 217.25.225.122 TCP:55727
Thursday September 27, 2007 20:54:33 Unrecognized attempt blocked from 78.106.230.60:4291 to 217.25.225.122 TCP:55727
Как это поправить и иметь нормальный интернет?
СообщениеДобавлено: Пт сен 28, 2007 16:38
Приведенные логи не имеют отношения к отсутствию интернета.
Попробуйте пропинговать тотже yandex по IP и по имени сначала с компьютера, потом с роутера. Какой результат?
СообщениеДобавлено: Сб сен 29, 2007 22:07
Учавствовал в настройке этого девайса. Пинги с компьютера проходят до всех сайтов. Рамблер, яндекс, длинк ру, мэйл ру, все работает. Проблема при работе по хттп протоколу, фантастика, но работает только яндекс, но даже он не полностью, например, новости открывает, поиск работает, а вот Мой круг уже не открывается, все другие сайты тоже не работают :(.
По настройкам лазили, все фильтры отключены.
PS: аська нормально работает.
СообщениеДобавлено: Вс сен 30, 2007 01:41
Попробуте поставить другой браузер,у меня такое было когда винда в автоматическом режиме обновилась...
СообщениеДобавлено: Вс сен 30, 2007 10:52
Пробывали и Explorer'ом и Firefox'ом :(
Какие могут быть ещё варианты?
СообщениеДобавлено: Вт окт 02, 2007 15:12
Попробуйте уменьшить MTU в настройках до 1400,или,если не поможет,с шагом в 100 до 1000
СообщениеДобавлено: Вт окт 02, 2007 22:47
Сменили аппарат на Zyxel P330, работает все на ура. Настроилось все за 10-15 минут.
