Текущее время: Вт ноя 10, 2026 05:10
СообщениеДобавлено: Пт сен 14, 2007 17:34
У меня модем DSL-300T. Время от времени он теряет несущую при этом индикатор ADSL начинает редко мигать по идеи он должен через некоторое время самостоятельно подключиться но до тех пор пока не вынешь и в сунешь обратно кабель телефонной линии или полностью не перезагрузишь модем индикатор ADSL продолжает редко мигать. это так и должно быть или тут чтото не то?
Jan 5 00:09:58> pppd 2.4.1 started by root, uid 0
Jan 5 00:11:38> System Call Error
Jan 5 00:11:38> Couldn't get channel number: Transport endpoint is not connected
Jan 5 00:11:38> Doing disconnect
Jan 5 00:11:38> pppd 2.4.1 started by root, uid 0
Jan 5 00:13:18> System Call Error
Jan 5 00:13:18> Couldn't get channel number: Transport endpoint is not connected
Jan 5 00:13:18> Doing disconnect
Jan 5 00:13:19> pppd 2.4.1 started by root, uid 0
Jan 5 00:14:59> System Call Error
Jan 5 00:14:59> Couldn't get channel number: Transport endpoint is not connected
Jan 5 00:14:59> Doing disconnect
Jan 5 00:14:59> pppd 2.4.1 started by root, uid 0
Jan 5 00:16:39> System Call Error
Jan 5 00:16:39> Couldn't get channel number: Transport endpoint is not connected
Jan 5 00:16:39> Doing disconnect
Jan 5 00:16:39> pppd 2.4.1 started by root, uid 0
Jan 5 00:18:19> System Call Error
Jan 5 00:18:19> Couldn't get channel number: Transport endpoint is not connected
Jan 5 00:18:19> Doing disconnect
Jan 5 00:18:19> pppd 2.4.1 started by root, uid 0
Jan 5 00:19:59> System Call Error
Jan 5 00:19:59> Couldn't get channel number: Transport endpoint is not connected
Jan 5 00:19:59> Doing disconnect
Jan 5 00:20:00> pppd 2.4.1 started by root, uid 0
Jan 5 00:21:40> System Call Error
Jan 5 00:21:40> Couldn't get channel number: Transport endpoint is not connected
Jan 5 00:21:40> Doing disconnect
Jan 5 00:21:40> pppd 2.4.1 started by root, uid 0
Jan 5 00:23:20> System Call Error
Jan 5 00:23:20> Couldn't get channel number: Transport endpoint is not connected
Jan 5 00:23:20> Doing disconnect
Jan 5 00:23:20> pppd 2.4.1 started by root, uid 0
Jan 5 00:25:00> System Call Error
Jan 5 00:25:00> Couldn't get channel number: Transport endpoint is not connected
Jan 5 00:25:00> Doing disconnect
Jan 5 00:25:01> pppd 2.4.1 started by root, uid 0
Jan 5 00:26:41> Couldn't get channel number: Transport endpoint is not connected
Jan 5 00:26:41> System Call Error
Jan 5 00:26:41> Doing disconnect
Jan 5 00:26:41> pppd 2.4.1 started by root, uid 0
Jan 5 00:28:21> System Call Error
Jan 5 00:28:21> Couldn't get channel number: Transport endpoint is not connected
Jan 5 00:28:21> Doing disconnect
Jan 5 00:28:21> pppd 2.4.1 started by root, uid 0
Jan 5 00:29:53> DSL Carrier is down
Jan 5 00:30:01> System Call Error
Jan 5 00:30:01> Couldn't get channel number: Transport endpoint is not connected
Jan 5 00:30:01> Doing disconnect
Jan 5 00:30:01> pppd 2.4.1 started by root, uid 0
Jan 5 00:30:23> DSL Carrier is up
Jan 5 00:30:42> Connect: ppp0 {--} nas0
Jan 5 00:30:49> default route ioctl(SIOCADDRT): Network is unreachable(128)
Jan 5 00:30:49> WAN IP address 85.141.105.145
Jan 5 00:30:49> PPPoE Connect with IP Address 85.141.105.145
Jan 5 00:30:49> WAN gateway 85.141.104.1
Jan 5 00:30:49> PPPoE Connection Successfully Established
Jan 5 00:30:49> PPPoE Connect with Gateway IP Address: 85.141.104.1
Jan 5 00:30:49> primary DNS address 212.188.4.10
Jan 5 00:30:49> secondary DNS address 195.34.32.116
Jan 5 00:34:03> DSL Carrier is down
Jan 5 00:34:23> DSL Carrier is training
Jan 5 00:34:29> Connection terminated.
Jan 5 00:34:29> Doing disconnect
Jan 5 00:34:29> PPPD Successfully Launched
Jan 5 00:34:33> DSL Carrier is up
Jan 5 00:34:33> pppd 2.4.1 started by root, uid 0
Jan 5 00:34:34> Connect: ppp0 {--} nas0
Jan 5 00:34:35> default route ioctl(SIOCADDRT): Network is unreachable(128)
Jan 5 00:34:35> WAN IP address 85.141.105.215
Jan 5 00:34:35> PPPoE Connect with IP Address 85.141.105.215
Jan 5 00:34:35> WAN gateway 85.141.104.1
Jan 5 00:34:35> PPPoE Connection Successfully Established
Jan 5 00:34:35> PPPoE Connect with Gateway IP Address: 85.141.104.1
Jan 5 00:34:35> primary DNS address 212.188.4.10
Jan 5 00:34:35> secondary DNS address 195.34.32.116
Jan 5 00:35:13> DSL Carrier is down
Jan 5 00:35:33> DSL Carrier is training
Jan 5 00:35:40> Terminated: Modem Hang-Up
Jan 5 00:35:40> Modem hangup
Jan 5 00:35:40> Connection terminated.
Jan 5 00:35:40> Doing disconnect
Jan 5 00:35:40> pppd 2.4.1 started by root, uid 0
Jan 5 00:35:41> Connect: ppp0 {--} nas0
Jan 5 00:35:41> default route ioctl(SIOCADDRT): Network is unreachable(128)
Jan 5 00:35:41> WAN IP address 85.141.105.253
Jan 5 00:35:41> PPPoE Connect with IP Address 85.141.105.253
Jan 5 00:35:41> WAN gateway 85.141.104.1
Jan 5 00:35:41> PPPoE Connection Successfully Established
Jan 5 00:35:41> PPPoE Connect with Gateway IP Address: 85.141.104.1
Jan 5 00:35:41> primary DNS address 212.188.4.10
Jan 5 00:35:41> secondary DNS address 195.34.32.116
Jan 5 00:35:43> DSL Carrier is up
Jan 5 00:36:23> DSL Carrier is training
Jan 5 00:36:33> DSL Carrier is down
Jan 5 00:36:43> DSL Carrier is training
Jan 5 00:36:44> Modem hangup
Jan 5 00:36:44> Connection terminated.
Jan 5 00:36:44> Doing disconnect
Jan 5 00:36:44> Terminated: Modem Hang-Up
Jan 5 00:36:49> pppd 2.4.1 started by root, uid 0
Jan 5 00:36:50> Connect: ppp0 {--} nas0
Jan 5 00:36:50> default route ioctl(SIOCADDRT): Network is unreachable(128)
Jan 5 00:36:50> WAN IP address 85.141.104.15
Jan 5 00:36:50> PPPoE Connect with IP Address 85.141.104.15
Jan 5 00:36:50> WAN gateway 85.141.104.1
Jan 5 00:36:50> PPPoE Connection Successfully Established
Jan 5 00:36:50> PPPoE Connect with Gateway IP Address: 85.141.104.1
Jan 5 00:36:50> primary DNS address 212.188.4.10
Jan 5 00:36:50> secondary DNS address 195.34.32.116
Jan 5 00:36:53> DSL Carrier is up
Jan 5 00:58:03> DSL Carrier is training
Jan 5 00:58:13> DSL Carrier is down
Jan 5 00:58:23> DSL Carrier is training
Jan 5 00:58:29> PPPD Successfully Launched
Jan 5 00:58:29> Connection terminated.
Jan 5 00:58:29> Doing disconnect
Jan 5 00:58:29> pppd 2.4.1 started by root, uid 0
Jan 5 00:58:29> Connect: ppp0 {--} nas0
Jan 5 00:58:30> default route ioctl(SIOCADDRT): Network is unreachable(128)
Jan 5 00:58:30> WAN IP address 85.141.105.79
Jan 5 00:58:30> PPPoE Connect with IP Address 85.141.105.79
Jan 5 00:58:30> WAN gateway 85.141.104.1
Jan 5 00:58:30> PPPoE Connection Successfully Established
Jan 5 00:58:30> PPPoE Connect with Gateway IP Address: 85.141.104.1
Jan 5 00:58:30> primary DNS address 212.188.4.10
Jan 5 00:58:30> secondary DNS address 195.34.32.116
Jan 5 00:58:33> DSL Carrier is up
СообщениеДобавлено: Пн сен 17, 2007 11:02
Приведите вывод страницы Status -> ADSL, укажите версию прошивки модема.
СообщениеДобавлено: Пн сен 17, 2007 17:33
Product Information
Model Number
DSL-300T
Ethernet MAC 00:11:95:B8:47:25
Software Versions
Gateway V1.00B02T02.EU.20040618
ATM Driver 4.01.00.00
DSL HAL 1.01.00.00
DSL Datapumps 1.01.00.00 Annex A
SAR HAL 01.06.06 s
PDSP Firmware 0.49
Boot Loader 0.22.02
Modem Status
Connection Status Connected
Upstream Rate (Kbps) 704
Downstream Rate (Kbps) 6144
US Margin 7
DS Margin 7
Modulation MMODE
LOS Errors 5
DS Line Attenuation 39
US Line Attenuation 22
Path Mode Interleaved
DSL Statistics
Near End F4 Loop Back Count 0
Near End F5 Loop Back Count
СообщениеДобавлено: Ср сен 19, 2007 01:14
Поставьте на модеме G.DMT-модуляцию ADSL-соединения. Если не поможет - звоните в Стрим, пусть понижают Вам канальную скорость до тарифной.
