Текущее время: Сб авг 08, 2026 02:13
 Заголовок сообщения: Качество линии
СообщениеДобавлено: Пт сен 14, 2007 17:14
Mode: ADSL2+
Line Coding: Trellis On
Status: No Defect
Link Power State: L0
SNR Margin (dB): 34.6 40.5
Attenuation (dB): 48.0 25.5
Output Power (dBm): 8.5 40.5
Attainable Rate (Kbps): 6960 136
Rate (Kbps): 260 68
Канал по тарифу заявлен как 256/64. Хотел узнать. Эти параметры показывают хорошо или плохо
СообщениеДобавлено: Сб сен 15, 2007 08:39
Из-за чего может быть вот такое:
Sep 15 04:16:59 daemon crit pppd[280]: Clear IP addresses. Connection DOWN.
Sep 15 04:16:59 daemon crit pppd[280]: Clear IP addresses. PPP connection DOWN.
Sep 15 04:17:08 daemon notice pppd[280]: PPP: Start to connect ...
Sep 15 04:17:11 daemon crit pppd[280]: PPP server detected.
Sep 15 04:17:11 daemon crit pppd[280]: PPP session established.
Sep 15 04:17:13 daemon crit pppd[280]: PPP LCP UP.
Sep 15 04:17:13 daemon err pppd[280]: User name and password authentication failed.
Sep 15 04:17:16 daemon notice pppd[280]: PPP: Start to connect ...
Sep 15 04:17:16 daemon crit pppd[280]: PPP server detected.
Sep 15 04:17:16 daemon crit pppd[280]: PPP session established.
Sep 15 04:17:18 daemon crit pppd[280]: PPP LCP UP.
Sep 15 04:17:18 daemon err pppd[280]: User name and password authentication failed.
Sep 15 04:17:21 daemon notice pppd[280]: PPP: Start to connect ...
Sep 15 04:17:21 daemon crit pppd[280]: PPP server detected.
Sep 15 04:17:21 daemon crit pppd[280]: PPP session established.
Sep 15 04:17:23 daemon crit pppd[280]: PPP LCP UP.
Sep 15 04:17:24 daemon err pppd[280]: User name and password authentication failed.
Sep 15 04:17:27 daemon notice pppd[280]: PPP: Start to connect ...
Sep 15 04:17:27 daemon crit pppd[280]: PPP server detected.
Sep 15 04:17:27 daemon crit pppd[280]: PPP session established.
Sep 15 04:17:29 daemon crit pppd[280]: PPP LCP UP.
Sep 15 04:17:29 daemon err pppd[280]: User name and password authentication failed.
Sep 15 04:17:32 daemon notice pppd[280]: PPP: Start to connect ...
Sep 15 04:17:32 daemon crit pppd[280]: PPP server detected.
Sep 15 04:17:32 daemon crit pppd[280]: PPP session established.
Sep 15 04:17:34 daemon crit pppd[280]: PPP LCP UP.
Sep 15 04:17:34 daemon err pppd[280]: User name and password authentication failed.
Sep 15 04:17:37 daemon notice pppd[280]: PPP: Start to connect ...
Sep 15 04:17:38 daemon crit pppd[280]: PPP server detected.
Sep 15 04:17:38 daemon crit pppd[280]: PPP session established.
Sep 15 04:17:40 daemon crit pppd[280]: PPP LCP UP.
Sep 15 04:17:40 daemon err pppd[280]: User name and password authentication failed.
Sep 15 04:17:43 daemon notice pppd[280]: PPP: Start to connect ...
Sep 15 04:17:43 daemon crit pppd[280]: PPP server detected.
Sep 15 04:17:43 daemon crit pppd[280]: PPP session established.
Sep 15 04:17:45 daemon crit pppd[280]: PPP LCP UP.
Sep 15 04:17:45 daemon err pppd[280]: User name and password authentication failed.
Sep 15 04:17:48 daemon notice pppd[280]: PPP: Start to connect ...
Sep 15 04:17:48 daemon crit pppd[280]: PPP server detected.
Sep 15 04:17:48 daemon crit pppd[280]: PPP session established.
Sep 15 04:17:50 daemon crit pppd[280]: PPP LCP UP.
Sep 15 04:17:51 daemon err pppd[280]: User name and password authentication failed.
Sep 15 04:17:54 daemon notice pppd[280]: PPP: Start to connect ...
Sep 15 04:17:54 daemon crit pppd[280]: PPP server detected.
Sep 15 04:17:54 daemon crit pppd[280]: PPP session established.
Sep 15 04:17:56 daemon crit pppd[280]: PPP LCP UP.
Sep 15 04:17:56 daemon err pppd[280]: User name and password authentication failed.
Sep 15 04:17:59 daemon notice pppd[280]: PPP: Start to connect ...
Sep 15 04:17:59 daemon crit pppd[280]: PPP server detected.
Sep 15 04:17:59 daemon crit pppd[280]: PPP session established.
Sep 15 04:18:01 daemon crit pppd[280]: PPP LCP UP.
Sep 15 04:18:01 daemon err pppd[280]: User name and password authentication failed.
Sep 15 04:18:04 daemon notice pppd[280]: PPP: Start to connect ...
Sep 15 04:18:05 daemon crit pppd[280]: PPP server detected.
Sep 15 04:18:05 daemon crit pppd[280]: PPP session established.
Sep 15 04:18:07 daemon crit pppd[280]: PPP LCP UP.
Sep 15 04:18:07 daemon err pppd[280]: User name and password authentication failed.
Sep 15 04:18:10 daemon notice pppd[280]: PPP: Start to connect ...
Sep 15 04:18:10 daemon crit pppd[280]: PPP server detected.
Sep 15 04:18:10 daemon crit pppd[280]: PPP session established.
Sep 15 04:18:12 daemon crit pppd[280]: PPP LCP UP.
Sep 15 04:18:12 daemon err pppd[280]: User name and password authentication failed.
Sep 15 04:18:15 daemon notice pppd[280]: PPP: Start to connect ...
Sep 15 04:18:15 daemon crit pppd[280]: PPP server detected.
Sep 15 04:18:15 daemon crit pppd[280]: PPP session established.
Sep 15 04:18:17 daemon crit pppd[280]: PPP LCP UP.
Sep 15 04:18:18 daemon err pppd[280]: User name and password authentication failed.
Sep 15 04:18:21 daemon notice pppd[280]: PPP: Start to connect ...
Sep 15 04:18:21 daemon crit pppd[280]: PPP server detected.
Sep 15 04:18:21 daemon crit pppd[280]: PPP session established.
Sep 15 04:18:23 daemon crit pppd[280]: PPP LCP UP.
Sep 15 04:18:23 daemon err pppd[280]: User name and password authentication failed.
Sep 15 04:18:26 daemon notice pppd[280]: PPP: Start to connect ...
Sep 15 04:18:26 daemon crit pppd[280]: PPP server detected.
Sep 15 04:18:26 daemon crit pppd[280]: PPP session established.
Sep 15 04:18:28 daemon crit pppd[280]: PPP LCP UP.
Sep 15 04:18:29 daemon crit pppd[280]: Received valid IP address from server. Connection UP.
Девай настроен как роутер. В режиме моста - влетает с первого раза в инет
СообщениеДобавлено: Сб сен 15, 2007 18:00
1. Attenuation (dB) слишком высокое.
2. Неверное имя пользователя и/или пароль.
СообщениеДобавлено: Сб сен 15, 2007 18:20
Чем это грозит, как лечить?
Правильное. Просто разобрался потом. Суть. Модем DSL-2540U работает в режиме роутера. Если дисконнект делать руками а потом коннект то проверку пароля/имени проходит мгновенно. А если произошол разрыв, то модем пытается автоматом поднять линк, но не получается т.к. DSLAM думает что сессия с клиентом ещё не завершена. По этому не даёт авторизироваться. И буквально минут через 5, разрывается линк со стороны прова. И авторизация проходит на ура. Просто у прова стоит большой тайм-аут при развыве связи. Всё это проверил сегодня опытным путём. Как лечить не знаю. Надо звонить прову и говорить пусть уменьшат тайм-аут. Поправьте если я не прав
СообщениеДобавлено: Сб сен 15, 2007 18:26
Ещё одна тема. По поводу, данная функция в модеме не работает: Dial on demand (with idle timeout timer). Проверял сегодня. Не отрубает инет по тайм-ауту. За-то поднимать по запросу - поднимает. Да-же если установить 1 минуту. Комп на время проверки был отключен из сети и кабелем от модема. Странно но модем регулярно что-то куда-то посылает. Что и куда - непонятно. Синхронизация времени и Keep Alive отключены. Может кто нибудь объяснит.
СообщениеДобавлено: Пн сен 17, 2007 10:47
Затухание сигнала нисходящего потока.
Это грозит "разрывами связи". Попросите провайдера немного понизить скорость Downstream потока (при этом SNR должен возрасти, а Attenuation - понизиться), cоответственно связь станет стабильней. Пусть также включат режим Interleave и задержку в передаче данных сделают побольше.
По поводу Dial on demand (with idle timeout timer) - проверим.
СообщениеДобавлено: Пн сен 17, 2007 11:04
Дело в том что при таком большом затухании связь держиться всё равно на убой. за 4 дня (работает 24 часа в сутки) небыло ни одного разрыва.
СообщениеДобавлено: Пн сен 17, 2007 11:06
Только что позвонил сказали что включен. У меня просто очень много модуляций стоит включенных. Оставил только нужную DMT. Они сказали могут включить режим FAST.
СообщениеДобавлено: Чт сен 20, 2007 23:05
У меня тоже такое, что именно требовать от провайдера для стабильности? :(
СообщениеДобавлено: Пт сен 21, 2007 10:34
см. выше
Сейчас этот форум просматривают: Google [Bot] и гости: 14
