Текущее время: Вс окт 04, 2026 06:38
 Заголовок сообщения: System Logs DI-604
СообщениеДобавлено: Ср авг 29, 2007 11:37
Прошу совет по настройке лога в роутере
у меня не отображается информация по внутренним
адресам - кто куда заходил, вот пример лога с другого
роутера той же модели с такой прошивкой 3.20:
Wed Aug 29 09:51:51 2007 10.0.0.8 query DNS for www.russianamerica.com
Wed Aug 29 09:51:52 2007 10.0.0.8 query DNS for www.google-analytics.com
Wed Aug 29 09:51:52 2007 10.0.0.8 query DNS for c.mystat-in.net
Wed Aug 29 09:53:32 2007 10.0.0.8 query DNS for ad.adriver.ru
Wed Aug 29 09:54:02 2007 10.0.0.8 query DNS for video.oboz.ua
Wed Aug 29 09:54:06 2007 10.0.0.8 query DNS for mad.tmgu.net
Wed Aug 29 09:54:07 2007 10.0.0.8 query DNS for bb.clickad.com.ua
Wed Aug 29 09:54:57 2007 10.0.0.61 query DNS for swonline.ru
а вот часть лога с которым не получается:
System Logs
Tue Aug 28 14:32:07 2007 Unrecognized attempt blocked from 58.211.136.210:80 to 216.21.25.12 TCP:1042
Tue Aug 28 14:32:16 2007 Unrecognized attempt blocked from 212.40.33.180:2155 to 216.21.25.12 TCP:445
Tue Aug 28 14:32:19 2007 Unrecognized attempt blocked from 212.40.33.180:2155 to 216.21.25.12 TCP:445
Tue Aug 28 14:33:27 2007 Unrecognized attempt blocked from 212.40.48.234:3987 to 216.21.25.12 TCP:445
Tue Aug 28 14:33:29 2007 Unrecognized attempt blocked from 90.230.110.171:30590 to 216.21.25.12 UDP:1026
Tue Aug 28 14:33:30 2007 Unrecognized attempt blocked from 212.40.48.234:3987 to 216.21.25.12 TCP:445
Tue Aug 28 14:36:59 2007 Unrecognized attempt blocked from 212.40.37.146:4359 to 216.21.25.12 TCP:445
Tue Aug 28 14:37:02 2007 Unrecognized attempt blocked from 212.40.37.146:4359 to 216.21.25.12 TCP:445
Tue Aug 28 14:40:08 2007 Unrecognized attempt blocked from 212.40.37.146:3490 to 216.21.25.12 TCP:445
Tue Aug 28 14:40:11 2007 Unrecognized attempt blocked from 212.40.37.146:3490 to 216.21.25.12 TCP:445
Tue Aug 28 14:40:56 2007 Unrecognized attempt blocked from 69.41.164.186:36538 to 216.21.25.12 TCP:20941
Tue Aug 28 14:40:59 2007 Unrecognized attempt blocked from 69.41.164.186:36538 to 216.21.25.12 TCP:20941
Tue Aug 28 14:43:28 2007 Unrecognized attempt blocked from 212.40.37.198:4928 to 216.21.25.12 TCP:445
Tue Aug 28 14
СообщениеДобавлено: Чт авг 30, 2007 10:11
неужели никто не использует логи?
СообщениеДобавлено: Чт авг 30, 2007 11:28
DNSом во втором случе роутер прописан?
СообщениеДобавлено: Чт авг 30, 2007 11:32
в смысле на компьютерах которые ходят через роутер?
да на них прописан
 Заголовок сообщения: попробовал я
СообщениеДобавлено: Чт авг 30, 2007 13:14
DI-604 H/W: F3 F/W: 3.21
пробовал nslookup-ить через DNS провайдера (по умолчанию), затем с прямым указанием DNSа провайдера, затем с указанием IP роутера в качестве DNS, затем использовал сторонний DNS - все запросы обработаны успешно, в логах - ничего кроме
Unrecognized attempt blocked from ...
СообщениеДобавлено: Чт авг 30, 2007 13:26
вот лог:
System Logs
Thu Aug 30 11:55:02 2007 Unrecognized attempt blocked from 212.39.99.210:1989 to 11.11.11.11 TCP:135
Thu Aug 30 11:55:16 2007 Unrecognized attempt blocked from 212.39.99.210:2431 to 11.11.11.11 TCP:139
Thu Aug 30 11:55:25 2007 Unrecognized attempt blocked from 61.139.33.98:6000 to 11.11.11.11 TCP:5168
Thu Aug 30 11:55:35 2007 Unrecognized attempt blocked from 212.39.99.210:3014 to 11.11.11.11 TCP:139
Thu Aug 30 11:55:56 2007 Unrecognized attempt blocked from 61.139.33.98:6000 to 11.11.11.11 TCP:5168
Thu Aug 30 11:58:08 2007 10.0.0.7 query DNS for www.i.ua
Thu Aug 30 11:58:09 2007 10.0.0.7 query DNS for i.i.ua
Thu Aug 30 11:58:10 2007 10.0.0.7 query DNS for r.i.ua
Thu Aug 30 11:58:10 2007 10.0.0.7 query DNS for c.bigmir.net
Thu Aug 30 11:58:10 2007 10.0.0.7 query DNS for s.holder.com.ua
Thu Aug 30 11:58:11 2007 10.0.0.7 query DNS for i.holder.com.ua
Thu Aug 30 11:58:11 2007 10.0.0.7 query DNS for m1.i.ua
Thu Aug 30 11:58:13 2007 10.0.0.7 query DNS for www.reklamer.com.ua
Thu Aug 30 11:58:25 2007 10.0.0.7 query DNS for www.bigmir.net
Thu Aug 30 11:58:27 2007 10.0.0.7 query DNS for ad.adriver.ru
Thu Aug 30 11:58:28 2007 10.0.0.7 query DNS for i.bigmir.net
Thu Aug 30 11:58:28 2007 10.0.0.7 query DNS for ab.adpro.com.ua
Thu Aug 30 11:58:29 2007 10.0.0.7 query DNS for news.img.com.ua
Thu Aug 30 11:58:31 2007 10.0.0.7 query DNS for mail.bigmir.net
Thu Aug 30 11:58:32 2007 10.0.0.7 query DNS for ad7.bigmir.net
Thu Aug 30 11:58:33 2007 10.0.0.7 query DNS for ad0.bigmir.net
Thu Aug 30 11:58:33 2007 10.0.0.7 query DNS for bbn.img.com.ua
Thu Aug 30 11:58:49 2007 10.0.0.7 query DNS for passport.bigmir.net
Thu Aug 30 11:58:49 2007 10.0.0.7 query DNS for mbox.bigmir.net
Thu Aug 30 12:01:50 2007 10.0.0.7 query DNS for ad.adriver.ru
Thu Aug 30 12:01:51 2007 10.0.0.7 query DNS for ad0.bigmir.net
Thu Aug 30 12:02:48 2007 10.0.0.61 query DNS for i.ua
Thu Aug 30 12:04:03 2007 Unrecognized attempt blocked from 203.44.203.229:3622 to 11.11.11.11 TCP:139
Thu Aug 30 12:04:06 2007 Unrecognized attempt blocked from 203.44.203.229:3622 to 11.11.11.11 TCP:139
Thu Aug 30 12:04:09 2007 Unrecognized attempt blocked from 203.44.203.229:3843 to 11.11.11.11 TCP:445
Thu Aug 30 12:04:12 2007 Unrecognized attempt blocked from 203.44.203.229:3843 to 11.11.11.11 TCP:445
Thu Aug 30 12:06:12 2007 10.0.0.7 query DNS for newsu.img.com.ua
Thu Aug 30 12:06:12 2007 10.0.0.7 query DNS for c.bigmir.net
Thu Aug 30 12:06:33 2007 10.0.0.101 query DNS for ya.ru
Thu Aug 30 12:06:33 2007 10.0.0.101 query DNS for www.tns-counter.ru
Thu Aug 30 12:06:34 2007 10.0.0.101 query DNS for export.yandex.ru
Thu Aug 30 12:06:57 2007 Unrecognized attempt blocked from 80.85.58.105:3286 to 11.11.11.11 TCP:445
Thu Aug 30 12:07:45 2007 Unrecognized attempt blocked from 212.40.99.147:2179 to 11.11.11.11 TCP:135
Thu Aug 30 12:07:56 2007 10.0.0.61 query DNS for i.ua
Thu Aug 30 12:08:21 2007 10.0.0.101 query DNS for www.gorodok.com.ua
Thu Aug 30 12:12:20 2007 Unrecognized attempt blocked from 212.15.10.209:4034 to 11.11.11.11 TCP:135
Thu Aug 30 12:12:52 2007 Unrecognized attempt blocked from 212.39.107.118:3800 to 11.11.11.11 TCP:135
Thu Aug 30 12:13:28 2007 Restarted by 195.234.213.234
Thu Aug 30 12:14:14 2007 Unrecognized attempt blocked from 222.39.224.136:6000 to 11.11.11.11 TCP:42
Thu Aug 30 12:15:31 2007 Unallowed access from 10.0.0.8: to 212.40.34.13: protocol=6 rule=0 (by firewall)
Thu Aug 30 12:15:34 2007 Unallowed access from 10.0.0.8: to 212.40.34.13: protocol=6 rule=0 (by firewall)
Thu Aug 30 12:15:40 2007 Unallowed access from 10.0.0.8: to 212.40.34.13: protocol=6 rule=0 (by firewall)
Thu Aug 30 12:16:37 2007 Restarted by 195.234.213.234
Thu Aug 30 12:16:53 2007 10.0.0.221 query DNS for www.zelpo.sk
Thu Aug 30 12:24:16 2007 Unrecognized attempt blocked from 212.15.10.209:3931 to 11.11.11.11 TCP:135
Thu Aug 30 12:24:19 2007 Unrecognized attempt blocked from 212.15.10.209:3931 to 11.11.11.11 TCP:135
Thu Aug 30 12:28:08 2007 10.0.0.7 query DNS for ad.adriver.ru
Thu Aug 30 12:28:08 2007 10.0.0.7 query DNS for ad0.bigmir.net
Thu Aug 30 12:28:08 2007 10.0.0.7 query DNS for c.bigmir.net
Thu Aug 30 12:28:08 2007 10.0.0.7 query DNS for bbn.img.com.ua
Thu Aug 30 12:28:17 2007 10.0.0.7 query DNS for mbox.bigmir.net
Thu Aug 30 12:29:23 2007 Unrecognized attempt blocked from 58.51.99.81:6000 to 11.11.11.11 TCP:2967
Thu Aug 30 12:29:40 2007 10.0.0.7 query DNS for google.com.ua
Thu Aug 30 12:29:41 2007 10.0.0.7 query DNS for www.google.com.ua
Thu Aug 30 12:30:02 2007 10.0.0.7 query DNS for baptist.org.ua
Thu Aug 30 12:30:20 2007 10.0.0.7 query DNS for u414.57.spylog.com
Thu Aug 30 12:30:20 2007 10.0.0.7 query DNS for counter.rambler.ru
Thu Aug 30 12:30:20 2007 10.0.0.7 query DNS for www.logoslovo.ru
Thu Aug 30 12:30:20 2007 10.0.0.7 query DNS for www.baptisttop1000.com
Thu Aug 30 12:30:20 2007 10.0.0.7 query DNS for top.list.ru
Thu Aug 30 12:30:20 2007 10.0.0.7 query DNS for uucyc.net
Thu Aug 30 12:30:20 2007 10.0.0.7 query DNS for www.maranatha.org.ua
Thu Aug 30 12:30:20 2007 10.0.0.7 query DNS for uucyc.pp.ru
Thu Aug 30 12:30:20 2007 10.0.0.7 query DNS for www.evangelie.ru
Thu Aug 30 12:30:20 2007 10.0.0.7 query DNS for foryou.kherson.ua
Thu Aug 30 12:30:21 2007 10.0.0.7 query DNS for christ4you.org
Thu Aug 30 12:30:21 2007 10.0.0.7 query DNS for www2.a-counter.kiev.ua
Thu Aug 30 12:30:21 2007 10.0.0.7 query DNS for www.bigmir.net
Thu Aug 30 12:30:21 2007 10.0.0.7 query DNS for supertop.ru
все отражается а на другом DI-604 у того же провайдера только:
Unrecognized attempt blocked from ...[/img]
СообщениеДобавлено: Чт авг 30, 2007 16:09
нуждаюсь в помощи помогите разобраться или у кого логи выводятся
хотя покажите что вас?
и какие настройки стоят
Сейчас этот форум просматривают: Baidu [Spider] и гости: 203
