Текущее время: Вс авг 09, 2026 10:56
 Заголовок сообщения: DES3026: Port Security
СообщениеДобавлено: Вт июл 31, 2007 15:28
Имем:
Port_security Trap/Log : Enabled
Port   Admin State   Max. Learning Addr.  Lock Address Mode
1      Enabled       0                    Permanent
2      Enabled       0                    Permanent
3      Enabled       0                    Permanent
4      Enabled       0                    Permanent
5      Enabled       0                    Permanent
6      Enabled       0                    Permanent
7      Enabled       0                    Permanent
8      Enabled       0                    Permanent
9      Enabled       0                    Permanent
10     Enabled       0                    Permanent
11     Enabled       0                    Permanent
12     Enabled       0                    Permanent
13     Enabled       0                    Permanent
14     Enabled       0                    Permanent
15     Enabled       0                    Permanent
16     Enabled       0                    Permanent
17     Enabled       0                    Permanent
18     Enabled       0                    Permanent
19     Enabled       0                    Permanent
Command: show fdb
Unicast MAC Address Aging Time  = 300
VID   VLAN Name         MAC Address        Port    Type
1     default           00-02-B3-4C-9C-57   24    Dynamic
1     default           00-0E-0C-A2-35-A1   24    Dynamic
1     default           00-19-5B-73-58-06   CPU   Self
1     default           00-30-48-86-FC-E7   24    Dynamic
1     default           00-30-84-4F-EF-80   24    Dynamic
1     default           00-30-94-33-D6-E5   24    Dynamic
1     default           00-60-5C-F4-C5-F3   24    Dynamic
1     default           00-60-94-25-85-62   24    Dynamic
1     default           00-90-27-43-50-B6   24    Dynamic
667   667               00-0F-3D-31-98-EE    6    Permanent
667   667               00-16-E6-6B-CA-68    3    Permanent
667   667               00-18-F3-05-9D-6D    1    Permanent
667   667               00-19-21-4C-86-9B    2    Permanent
667   667               00-19-5B-B1-BF-4E    4    Permanent
667   667               00-1A-92-32-E4-48    7    Permanent
667   667               00-1A-92-9E-78-D1    5    Permanent
667   667               00-E0-1E-62-D7-B0   24    Dynamic
4005  4005              00-13-80-83-74-C8   24    Dynamic
4005  4005              00-30-4F-51-DE-0F   17    Permanent
Total Entries  : 19
Проблема вот в этом:
69     2007/07/31  14:26:05  Port Security Violation (MAC 00-0F-3D-31-98-EE, Po
                             rt 6)
68     2007/07/31  14:26:00  Port Security Violation (MAC 00-18-F3-05-9D-6D, Po
                             rt 1)
67     2007/07/31  14:25:35  Port Security Violation (MAC 00-0F-3D-31-98-EE, Po
                             rt 6)
66     2007/07/31  14:25:05  Port Security Violation (MAC 00-0F-3D-31-98-EE, Po
                             rt 6)
65     2007/07/31  14:24:35  Port Security Violation (MAC 00-0F-3D-31-98-EE, Po
                             rt 6)
64     2007/07/31  14:24:10  Port Security Violation (MAC 00-0F-3D-31-98-EE, Po
                             rt 6)
63     2007/07/31  14:23:35  Port Security Violation (MAC 00-0F-3D-31-98-EE, Po
                             rt 6)
Почему (к примеру) мак 00-0F-3D-31-98-EE нарушает секюрити???
Ведь этот мак статически прописан в FDB!
Версия прошивки: 4.01.012
СообщениеДобавлено: Вт июл 31, 2007 16:04
Вы его руками прописывали? Укажите команду пожалуйста.
СообщениеДобавлено: Вт июл 31, 2007 16:28
Прописывал через WEB-интерфейс
СообщениеДобавлено: Вт июл 31, 2007 20:41
Проверим. По результатам сообщим.
СообщениеДобавлено: Ср авг 01, 2007 10:20
Проблема подтвердилась. Мы занимаемся ей. Как только будут результаты сообщу.
СообщениеДобавлено: Ср авг 01, 2007 10:22
Спасибо!
Поскольку я сейчас это использую (вроде как работает) но чем черевато? Может отключить на пока?
СообщениеДобавлено: Ср авг 01, 2007 10:35
Нет похоже проблема только с логированием.
