Текущее время: Чт сен 24, 2026 05:11
СообщениеДобавлено: Пн июл 23, 2007 13:17
DSG-3324
<134>Jul 23 09:08:22 192.168.0.16 INFO: Port 1:18 link down
<134>Jul 23 09:08:25 192.168.0.16 INFO: Port 1:18 link up, 1000Mbps FULL duplex
<134>Jul 23 09:09:01 192.168.0.16 INFO: Port 1:15 link up, 1000Mbps FULL duplex
<134>Jul 23 09:09:03 192.168.0.16 INFO: Port 1:15 link down
<134>Jul 23 09:09:07 192.168.0.16 INFO: Port 1:15 link up, 1000Mbps FULL duplex
<134>Jul 23 09:09:36 192.168.0.16 INFO: Port 1:15 link down
<134>Jul 23 09:09:40 192.168.0.16 INFO: Port 1:15 link up, 1000Mbps FULL duplex
<134>Jul 23 09:12:07 192.168.0.16 INFO: Port 1:16 link down
<134>Jul 23 09:12:10 192.168.0.16 INFO: Port 1:16 link up, 100Mbps FULL duplex
<134>Jul 23 09:47:22 192.168.0.16 INFO: Port 1:6 link down
<134>Jul 23 09:47:57 192.168.0.16 INFO: Port 1:6 link up, 1000Mbps FULL duplex
<134>Jul 23 09:48:17 192.168.0.16 INFO: Port 1:6 link down
<134>Jul 23 09:48:20 192.168.0.16 INFO: Port 1:6 link up, 1000Mbps FULL duplex
DES-3550
<134>Jul 23 07:44:55 192.168.0.14 INFO: Port 7 link down
<134>Jul 23 07:44:58 192.168.0.14 INFO: Port 7 link up, 100Mbps FULL duplex
<134>Jul 23 07:45:10 192.168.0.14 INFO: Port 7 link down
<134>Jul 23 07:45:15 192.168.0.14 INFO: Port 7 link up, 100Mbps FULL duplex
<134>Jul 23 08:07:04 192.168.0.14 INFO: Port 25 link up, 100Mbps FULL duplex
<134>Jul 23 08:07:06 192.168.0.14 INFO: Port 25 link down
<134>Jul 23 08:07:09 192.168.0.14 INFO: Port 25 link up, 100Mbps FULL duplex
<134>Jul 23 08:07:10 192.168.0.14 INFO: Port 25 link down
<134>Jul 23 08:07:13 192.168.0.14 INFO: Port 25 link up, 100Mbps FULL duplex
<134>Jul 23 08:07:31 192.168.0.14 INFO: Port 25 link down
<134>Jul 23 08:07:34 192.168.0.14 INFO: Port 25 link up, 100Mbps FULL duplex
<134>Jul 23 08:12:25 192.168.0.14 INFO: Port 19 link down
<134>Jul 23 08:12:27 192.168.0.14 INFO: Port 19 link up, 100Mbps FULL duplex
<134>Jul 23 08:12:29 192.168.0.14 INFO: Port 19 link down
<134>Jul 23 08:12:31 192.168.0.14 INFO: Port 19 link up, 100Mbps FULL duplex
<134>Jul 23 08:12:44 192.168.0.14 INFO: Port 19 link down
<134>Jul 23 08:12:48 192.168.0.14 INFO: Port 19 link up, 100Mbps FULL duplex
<134>Jul 23 08:13:17 192.168.0.14 INFO: Port 13 link down
<134>Jul 23 08:13:19 192.168.0.14 INFO: Port 13 link up, 100Mbps FULL duplex
<134>Jul 23 08:13:56 192.168.0.14 INFO: Port 13 link down
<134>Jul 23 08:13:58 192.168.0.14 INFO: Port 13 link up, 100Mbps FULL duplex
3312 в стеке с 3226
<134>Jul 23 12:28:13 192.168.0.15 INFO: Port 11:20 link down
<134>Jul 23 12:28:14 192.168.0.15 INFO: Port 11:20 link up, 100Mbps FULL duplex
<134>Jul 23 12:28:17 192.168.0.15 INFO: Port 11:20 link down
<134>Jul 23 12:28:18 192.168.0.15 INFO: Port 11:20 link up, 100Mbps FULL duplex
<134>Jul 23 12:28:41 192.168.0.15 INFO: Port 11:20 link down
<134>Jul 23 12:28:42 192.168.0.15 INFO: Port 11:20 link up, 100Mbps FULL duplex
<134>Jul 23 12:28:49 192.168.0.15 INFO: Port 11:9 link up, 100Mbps FULL duplex
<134>Jul 23 12:34:56 192.168.0.15 INFO: Port 9:6 link down
<134>Jul 23 12:34:57 192.168.0.15 INFO: Port 9:6 link up, 100Mbps FULL duplex
<134>Jul 23 12:36:11 192.168.0.15 INFO: Port 11:9 link down
<134>Jul 23 12:40:58 192.168.0.15 INFO: Port 9:9 link down
<134>Jul 23 12:40:59 192.168.0.15 INFO: Port 9:9 link up, 100Mbps FULL duplex
<134>Jul 23 12:41:03 192.168.0.15 INFO: Port 9:9 link down
<134>Jul 23 12:41:04 192.168.0.15 INFO: Port 9:9 link up, 100Mbps FULL duplex
<134>Jul 23 12:45:39 192.168.0.15 INFO: Port 11:9 link up, 100Mbps FULL duplex
<134>Jul 23 13:17:33 192.168.0.15 INFO: Port 9:8 link down
<134>Jul 23 13:17:34 192.168.0.15 INFO: Port 9:8 link up, 100Mbps FULL duplex
<134>Jul 23 13:17:35 192.168.0.15 INFO: Port 9:8 link down
<134>Jul 23 13:17:36 192.168.0.15 INFO: Port 9:8 link up, 100Mbps FULL duplex
<134>Jul 23 13:22:54 192.168.0.15 INFO: Port 11:9 link down
<134>Jul 23 13:44:33 192.168.0.15 INFO: Port 11:9 link up, 100Mbps FULL duplex
<134>Jul 23 13:54:55 192.168.0.15 INFO: Port 11:3 link down
<134>Jul 23 13:54:56 192.168.0.15 INFO: Port 11:3 link up, 100Mbps FULL duplex
<134>Jul 23 14:05:06 192.168.0.15 INFO: Port 11:10 link down
<134>Jul 23 14:06:48 192.168.0.15 INFO: Port 11:10 link up, 100Mbps FULL duplex
Порты и свичей и клиентов выставлены в автосогласование...
Вот и думаю, это к чему?
СообщениеДобавлено: Пн июл 23, 2007 14:49
Может линки действительно так скачут? И версии прошивок на текущий момент укажите пожалуйста.
СообщениеДобавлено: Пн июл 23, 2007 15:24
Да вот думаю, с чего бы им скакать....
А прошивки все самые последние....
DES-3550:admin#show switch
Command: show switch
Device Type : DES-3550 Fast-Ethernet Switch
Combo Port Type : 1000Base-T + 1000Base-T
MAC Address : 00-0F-3D-85-C9-9B
IP Address : 192.168.0.14 (Manual)
VLAN Name : default
Subnet Mask : 255.255.255.0
Default Gateway : 192.168.0.10
Boot PROM Version : Build 3.00.003
Firmware Version : Build 5.00-B12
Hardware Version : 1A1
DGS-3312SR:4#show stacking
Command: show stacking
ID MAC Address Port Range Mode Version RPS Status Model Name
*15 00-0D-88-DB-EB-E0 1 - 12 MASTER 3.60-S10 Not Present DGS-3312SR
9 00-0D-88-D2-06-80 451 - 476 AUTO 4.02-B47 Not Support DES-3226S
10 00-0D-88-D2-60-00 501 - 526 AUTO 4.02-B47 Not Support DES-3226S
11 00-0D-88-F4-B3-59 551 - 576 AUTO 4.02-B47 Not Support DES-3226S
Total Entries :4
DGS-3324SR:4#show switch
Device Type : DGS-3324SR Stackable Ethernet Switch
Unit ID : 1
MAC Address : 00-15-E9-91-F3-00
IP Address : 192.168.0.16 (Manual)
VLAN Name : default
Boot PROM Version : Build 2.01-B01
Firmware Version : Build 4.40-B04
Hardware Version : 3A1
СообщениеДобавлено: Пн июл 23, 2007 15:39
Перезвоните пожалуйста в офис по телефону 744-00-99 доб.390.
СообщениеДобавлено: Вт июл 24, 2007 08:03
По Вашей рекомендации включил trusted_host, обновил прошивку на 3226, однако странности продолжаются...
Сидел, тупо смотрел лог.. Как только увидел
<134>Jul 24 08:41:48 192.168.0.15 INFO: Port 10:13 link down
<134>Jul 24 08:41:52 192.168.0.15 INFO: Port 10:13 link up, 100Mbps FULL duplex
сразу набрал
DGS-3312SR:4#show fdb port 10:13
Command: show fdb port 10:13
VID VLAN Name MAC Address Port Type
Total Entries : 0
И еще такой вопросик - что это может быть:
DGS-3312SR:4#show fdb port 10:25
Command: show fdb port 10:25
1 default 00-30-48-54-57-33 10:25 Dynamic
1 default 02-01-00-00-00-00 10:25 Dynamic
Total Entries : 2
02-01-00-00-00-00 - странный мак...
clear fdb помогло на 2 минуты - снова появился...
В этот порт воткнут сервер с встроенным интеловским адаптером Intel(R) PRO/1000 CT Desktop Connection....
СообщениеДобавлено: Вт июл 24, 2007 09:58
Какие настройки на сетевой карте?
СообщениеДобавлено: Вт июл 24, 2007 10:07
Все по дефолту... Может, что-то конкретное интересует?
А что по поводу отключающихся портов?
СообщениеДобавлено: Вт июл 24, 2007 11:54
Я Вам сказал возможные причины для проверки. Больше ничего сказать нельзя.
