Текущее время: Чт окт 01, 2026 19:49
СообщениеДобавлено: Вт июл 10, 2007 07:06
Простроил 2003 сервер и 824 роутер согласно инструкциям ( основывался на _http://www.dlink.ru/technical/faq_vpn_21.php и _http://www.dlink.ru/technical/faq_vpn_8.php родственных примерах) соединение начинает устанавливаться (начинается обмен ключами) но потом соединение рвется лог вот.
Monday December 11, 2006 03:42:44 Send IKE M1(INIT) : 20.10.156.20 --> 20.10.109.187
Monday December 11, 2006 03:42:44 Receive IKE M2(RESP) : 20.10.109.187 --> 20.10.156.20
Monday December 11, 2006 03:42:44 Try to match with ENC:3DES AUTH:PSK HASH:MD5 Group:Group2
Monday December 11, 2006 03:42:44 Send IKE M3(KEYINIT) : 20.10.156.20 --> 20.10.109.187
Monday December 11, 2006 03:42:44 Receive IKE M4(KEYRESP) : 20.10.109.187 --> 20.10.156.20
Monday December 11, 2006 03:42:45 Send IKE M5(IDINIT) : 20.10.156.20 --> 20.10.109.187
Monday December 11, 2006 03:42:45 Receive IKE M6(IDRESP) : 20.10.109.187 --> 20.10.156.20
Monday December 11, 2006 03:42:45 IKE Phase1 (ISAKMP SA) established : 20.10.109.187 <-> 20.10.156.20
Monday December 11, 2006 03:42:45 Send IKE Q1(QINIT) : 192.168.0.0 --> 192.168.69.0
Monday December 11, 2006 03:42:45 Receive IKE INFO : 20.10.109.187 --> 20.10.156.20
Monday December 11, 2006 03:42:50 IKED re-TX : QINIT to 20.10.109.187
Monday December 11, 2006 03:42:55 IKED re-TX : QINIT to 20.10.109.187
Monday December 11, 2006 03:43:05 IKED re-TX : QINIT to 20.10.109.187
Monday December 11, 2006 03:43:15 IKED re-TX : QINIT to 20.10.109.187
Monday December 11, 2006 03:43:35 IKED re-TX : QINIT to 20.10.109.187
Monday December 11, 2006 03:43:36 Send IKE (INFO) : delete [192.168.0.0|20.10.156.20]-->[20.10.109.187|192.168.69.0] phase 2
Monday December 11, 2006 03:43:36 IKE phase2 (IPSec SA) remove : 192.168.0.0 <-> 192.168.69.0
Monday December 11, 2006 03:43:37 inbound SPI = 0x3000010, outbound SPI = 0x0
помогите разобраться в чем дело.
Оба конца и 2003 и 824 на реальных IP (в логе заменены другими адресами) Тестовые соединения IPSEC между сервером и клиентами на базе виндовс и PSK устанавливаются.
СообщениеДобавлено: Вт июл 10, 2007 17:12
Прошивка самая последняя Firmware Version: v1.06b07, Mon, Dec 11 2006
Грешил сперва на Керио Аннет. Не тутто было.
Смоделировал систему впрямую без роутеров Комп - Длинк - сервер - комп
Таже фигня. Не работает!
Только первая фаза.
СообщениеДобавлено: Чт июл 12, 2007 12:14
Настроил я всеже IPSec пришлось во второй фазе (IPSec Proposal index) выставить DH Group в NONE теперь возникли вопросы в уровне секьюрности соединения.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 162
