Текущее время: Чт авг 20, 2026 13:49
Начать новую тему Ответить на тему  [ Сообщений: 606 ]  На страницу Пред.  1 ... 31, 32, 33, 34, 35, 36, 37 ... 41  След.
СообщениеДобавлено: Вс май 06, 2007 14:49
Проблемка с 500ым. Постоянно рвется связь, хотя с другим модемом (zyxel) все в порядке
Jan 1 12:00:11> NTP Polling Timer for DHCP Started succesfully.
Jan 1 12:00:11> DSL Polling Timer Started succesfully.
Jan 1 12:00:12> Firewall NAT service started
Jan 1 12:00:12> The firmware build date/time:20061228055253
Jan 1 12:00:13> starting on port 80
Jan 1 12:00:14> Bridge Created: br0
Jan 1 12:00:14> Bridge Created: br1
Jan 1 12:00:15> Bridge Interface Added: eth0
Jan 1 12:00:21> DSL Carrier is down
Jan 1 12:00:51> DSL Carrier is up
Jan 1 12:00:51> sar read trained mode (5)(ADSL_2plus)
Jan 1 12:00:52> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:52> Connect: ppp0 {--} nas0
Jan 1 12:00:55> PAP authentication failed
Jan 1 12:00:55> Connection terminated.
Jan 1 12:00:55> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:55> Connect: ppp0 {--} nas0
Jan 1 12:00:58> PAP authentication failed
Jan 1 12:00:58> Connection terminated.
Jan 1 12:01:41> pppd 2.4.3 started by root, uid 0
Jan 1 12:01:42> Firewall rules flushed
Jan 1 12:02:03> Connect: ppp0 {--} nas0
Jan 1 12:02:06> PAP authentication succeeded
Jan 1 12:02:06> peer from calling number 00:E0:FC:2B:4C:63 authorized
Jan 1 12:02:06> WAN IP address 10.92.1.125
Jan 1 12:02:06> WAN gateway 10.92.0.1
Jan 1 12:02:06> primary DNS address 80.254.111.254
Jan 1 12:02:06> secondary DNS address 195.161.172.254
Jan 1 12:02:06> PPPoE Connect with IP Address 10.92.1.125
Jan 1 12:02:06> PPPoE Connection Successfully Established
Jan 1 12:02:06> PPPoE Connect with Gateway IP Address: 10.92.0.1
Jan 1 12:02:18> Firewall rules flushed
Jan 1 12:02:20> Firewall rules flushed
Jan 1 12:03:38> Firewall rules flushed
Jan 1 12:03:41> Firewall rules flushed
Jan 1 12:04:31> DSL Carrier is training
Jan 1 12:04:41> DSL Carrier is down
Jan 1 12:04:51> DSL Carrier is up
Jan 1 12:04:52> sar read trained mode (5)(ADSL_2plus)
Jan 1 12:04:53> PPPD Terminated Through Signal
Jan 1 12:04:53> Connection terminated.
Jan 1 12:04:53> pppd 2.4.3 started by root, uid 0
Jan 1 12:05:00> Connect: ppp0 {--} nas0
Jan 1 12:05:03> PAP authentication succeeded
Jan 1 12:05:03> peer from calling number 00:E0:FC:2B:4C:63 authorized
Jan 1 12:05:03> PPPoE Connect with IP Address 10.92.1.16
Jan 1 12:05:03> PPPoE Connection Successfully Established
Jan 1 12:05:03> PPPoE Connect with Gateway IP Address: 10.92.0.1
Jan 1 12:05:03> WAN IP address 10.92.1.16
Jan 1 12:05:03> WAN gateway 10.92.0.1
Jan 1 12:05:03> primary DNS address 80.254.111.254
Jan 1 12:05:03> secondary DNS address 195.161.172.254
Jan 1 12:07:31> DSL Carrier is down
Jan 1 12:07:41> DSL Carrier is up
Jan 1 12:07:42> sar read trained mode (5)(ADSL_2plus)
Jan 1 12:07:43> PPPD Terminated Through Signal
Jan 1 12:07:43> Connection terminated.
Jan 1 12:07:43> pppd 2.4.3 started by root, uid 0
Jan 1 12:07:50> Connect: ppp0 {--} nas0
Jan 1 12:07:53> PAP authentication succeeded
Jan 1 12:07:53> peer from calling number 00:E0:FC:2B:4C:63 authorized
Jan 1 12:07:53> PPPoE Connect with IP Address 10.92.0.44
Jan 1 12:07:53> PPPoE Connection Successfully Established
Jan 1 12:07:53> PPPoE Connect with Gateway IP Address: 10.92.0.1
Jan 1 12:07:53> WAN IP address 10.92.0.44
Jan 1 12:07:53> WAN gateway 10.92.0.1
Jan 1 12:07:53> primary DNS address 80.254.111.254
Jan 1 12:07:53> secondary DNS address 195.161.172.254
Jan 1 12:09:01> DSL Carrier is down
Jan 1 12:09:21> DSL Carrier is up
Прошу прощения за большое сообщение. Не знал, что конкретно вставить
СообщениеДобавлено: Пн май 07, 2007 11:13
To anderson_vdonsk
Судя по Вашему логу, происходит разрыв ADSL соединения.
Попросите провайдера посмотреть статистику ошибок на порту DSLAM.
С уважением, Давыдов Денис.
СообщениеДобавлено: Пн май 07, 2007 21:30
To anderson_vdonsk
Просьба доложить о результате. Кстати, вы часом не на Укртелекоме? Проблема моя на вашу похожа.
З.Ы. Попробуйте поставить режим модуляции ADSL_G.dmt, он же G.992.1
СообщениеДобавлено: Вт май 08, 2007 09:56
Прошу ещё раз обратить внимание, что в последних двух прошивках (V3.02B01T01.RU.20061228, V3.02B01T01.RU.20070402) наблюдается бага после изменения порта. В одной теме я уже писал об этом. Придётся снова откатываться до V3.02B01T01.RU.20060818. :wink:
В познании сила!
СообщениеДобавлено: Вт май 08, 2007 18:56
To severnet:
Что значит изменение порта? Какого порта? И да у меня ситуация один в один как у вас.
СообщениеДобавлено: Вс май 13, 2007 10:36
Подскажите как прошиться V3.02B01T01.RU.20070402 на данный момент стоит V3.02B01T01.RU.20060818
СообщениеДобавлено: Вс май 13, 2007 11:37
Я сначала запустил утилиту DLinkEU_DSL-504T_V2.00B01T01.EU.20050630_upgradeB05.exe.
Затем только смог прошить DLinkRU_DSL-504T_V3.02B01T01.RU.20070402
СообщениеДобавлено: Пт май 18, 2007 19:04
Люди, подскажите, у меня ща стоит прошивка:DLinkRU_DSL-500T_V3.02B01T01.RU.20070402
А надо поменять на: DSL-500T.V1.00B02T02.RU.20050223.
Можите подсказать, как это сделать, заранее спасибо.
СообщениеДобавлено: Пн май 21, 2007 11:42
Откат до версии 1.xx возможен только в сервисных центрах компании D-Link.
СообщениеДобавлено: Вт май 22, 2007 15:14
Кстати, да. После изменения порта в Tools -> Admin c 80 на другой порт, web-интерфейс модема уже не работает на другом порте и вообще ни на каком. Приходится обнулять модем и настраивать заново. А в прошивке от 18.08.2006 такой недоработки нет. А последняя апрельская прошивка вообще чуть не сделала мой модем неработоспособным.
Вопрос к специалистам. В комплекте к прошивкам идет файл config.DLinkEU_DSL-500T.img.
Я перепрошиваю модем без него и модем работает. Скажите, зачем этот файл нужен и если он нужен, то куда его заливать: туда, куда и прошивку (Tools -> Firmware) или туда, где загружаются настройки с жесткого диска (Tools -> System).
Последний раз редактировалось PolAnd Вс май 27, 2007 18:48, всего редактировалось 1 раз.
СообщениеДобавлено: Вс июн 03, 2007 14:58
Конфигурационный файл заливать нужно, так как он производит factory reset с учетом изменений в новой прошивке.
СообщениеДобавлено: Вс июн 03, 2007 15:55
Понятно. Спасибо.
А куда заливать этот config....img, вот еще вопрос! Туда, куда и прошивку (кнопка Firmware) или в загрузку настроек (кнопка System)?
Подскажите, а то боюсь ошибиться.
СообщениеДобавлено: Пн июн 04, 2007 17:27
Заливать config.*.img нужно через Tools/System --> "Load Settings From Local Hard Drive" ;)
СообщениеДобавлено: Сб июн 23, 2007 20:59
Поскажите, сменил прошивку на V2.01B01T01.RU.20060620, и никак не могу найти в ней статус path mode, как его можно посомтреть, в старой было в статусе adsl , а в этой нету. Модем 500T
пока смог выцепить вот это сам из /proc/avalanche/avsar_modem_stats
[Upstream (TX) Interleave path]
CRC: 0 FEC: 0 NCD: 1
LCD: 0 HEC: 0
[Downstream (RX) Interleave path]
CRC: 0 FEC: 0 NCD: 0
LCD: 0 HEC: 0
[Upstream (TX) Fast path]
CRC: 1 FEC: 0 NCD: 0
LCD: 0 HEC: 0
[Downstream (RX) Fast path]
LCD: 0 HEC: 0
но как по этому определить какой режим fast или interleave ?
СообщениеДобавлено: Пн июн 25, 2007 09:33
LCD: 0 HEC: 0
LCD: 0 HEC: 0
LCD: 0 HEC: 0
LCD: 0 HEC: 0
Возможность просмотра режима соединения есть только в последних прошивках. В каком режиме работает порт на DSLAM - можно узнать у Вашего оператора.
