Текущее время: Ср сен 09, 2026 23:37
СообщениеДобавлено: Чт июл 29, 2004 19:28
debug isdn q931
1) DG-104SH---AS5350---Meridian81:
Jul 29 19:25:55.953: ISDN Se3/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0011
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Display i = 'DG-104SH'
Calling Party Number i = 0x2182, '3079'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '4786'
Jul 29 19:25:56.045: ISDN Se3/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8011
Jul 29 19:25:56.045: ISDN Se3/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8011
Progress Ind i = 0x8182 - Destination address is non-ISDN
Jul 29 19:26:15.853: ISDN Se3/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x8011
Jul 29 19:26:15.857: ISDN Se3/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0011
2) DG-104SH---3640---Meridian81:
Jul 29 19:29:39.618 MSK: ISDN Se1/0:15: TX -> SETUP pd = 8 callref = 0x50AE
Jul 29 19:29:39.618 MSK: Bearer Capability i = 0x8090A3
Jul 29 19:29:39.618 MSK: Channel ID i = 0xA98381
Jul 29 19:29:39.622 MSK: Calling Party Number i = 0xA1, '3079', Plan:ISDN, Type:National
Jul 29 19:29:39.622 MSK: Called Party Number i = 0xA1, '4786', Plan:ISDN, Type:National
Jul 29 19:29:39.726 MSK: ISDN Se1/0:15: RX <- CALL_PROC pd = 8 callref = 0xD0AE
Jul 29 19:29:39.726 MSK: Channel ID i = 0xA98381
Jul 29 19:29:39.730 MSK: ISDN Se1/0:15: RX <- ALERTING pd = 8 callref = 0xD0AE
Jul 29 19:29:39.730 MSK: Progress Ind i = 0x8182 - Destination address is non-ISDN
Jul 29 19:29:56.462 MSK: ISDN Se1/0:15: RX <- CONNECT pd = 8 callref = 0xD0AE
Jul 29 19:29:56.462 MSK: Progress Ind i = 0x8182 - Destination address is non-ISDN
все вроде бы одинаково.
на обеих цисках софт 12.2.16...
Единственное отличие - на 5350 необходимо
voice class h323 1
call start slow
h245 caps mode restricted
dial-peer voice XXX voip
description D-link
voice-class h323 1
в случае DG-104SH---AS5350---Meridian81 станция не получает АОН.
в случае DG-104SH---3640---Meridian81 станция получает АОН.
Если очень нужен АОН - (ну в принципе нормальное желание) , то извратиться то можно и префикс ставить на D-link'е и снимать его (префикс) на Циске на pots dial-peer'е как это делаю я:
dial-peer voice 1 pots
destination-pattern 0677....
progress_ind setup enable 3
clid network-number 3079
Но мне думается что есть другие способы получить на Меридиане законный АОН, да и вообще, это не дело - плодить для каждого fxs длинка по pots-дайл-пиру на 5350!
Если кто может помочь, очень прошу, подскажите что я делаю неправильно, как быть.
СообщениеДобавлено: Чт авг 05, 2004 10:41
Сравниваем:
5350:
Calling Party Number i = 0x2182, '3079', Plan:ISDN, Type:National
3640:
Наводящий: А не numbering-type ли это (а не в амперах ли)?
Предложение: на Dial-peer-е кошки в сторону станции забивать numbering-plan/numbering-type по необходимости. И это можно делать для всех.
Может это не вся проблема, но с подобным уже сталкивались.
У себя лечу своим же свичем: http://smartgate.wtelecom.net.
Там к тому же для D-link-а много чего в логике учтено. С него факсы даже на VocalTec бегают как часы.
_,,,_|\_/|_,,,_ WBR, Roman Nikitchenko.
СообщениеДобавлено: Пт авг 06, 2004 13:34
Насколько я понял, Вы рекомендуете правилами трансляции
перебить numbering-plan/numbering-type ?
Я сделал это:
translation-rule 1
Rule 0 ^3079 3079 national unknown
destination-pattern [12456789]...
translate-outgoing calling 1
direct-inward-dial
port 3/0:D
Вот Вам дебаг:
Aug 6 14:26:03.943: ISDN Se3/0:15 Q931: TX -> SETUP pd = 8 callref = 0x009C
Standard = CCITT
Calling Party Number i = 0x0182, '3079'
Plan:ISDN, Type:Unknown
Aug 6 14:26:04.019: ISDN Se3/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x809C
Aug 6 14:26:04.023: ISDN Se3/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x809C
Результат прежний, на станции setup без АОНа!
Скажу больше: "Calling Party Number i = 0x0182, '3079'"
Здесь "01" == Type:Unknown + имеется следующий байт;
"82" == ошибка
Уважаемые, это похоже тот случай где без софтсвича просто не обойтись. Я прав?
СообщениеДобавлено: Пт авг 06, 2004 15:05
Пояснения насчет rule и numbering-type ушли мылом.
Кому интересно -
http://www.cisco.com/en/US/products/sw/ ... 7fe55.html
