Текущее время: Ср июн 24, 2026 19:16
 Заголовок сообщения: stp/mstp interoperability trouble w/cisco
СообщениеДобавлено: Вт май 15, 2007 09:20
Hi there!
Возникла проблема в выборе root bridge при совместной работе dgs-3024 в качестве distribution layer-коммутаторов и catalyst me6524 в качестве core. На стенде схема выродилась в back-to-back следующего вида:
dgs-3024--port24<----dot1q---->fe0/5--catalyst3560-24pe
(Proposed root bridge)
dgs3024:
Firmware Version : Build 4.00-B04
Hardware Version : 0A1
catalyst3560:
s/w ver. 12.2(35)SE1 / ADVIPSERV
При попытках поднятия mstp:
[dgs]%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
Command: show stp mst_config_id
Current MST Configuration Identification
Configuration Name : FOOBAR Revision Level :555
MSTI ID Vid list
CIST 1-499,700-4094
1 500-599
2 600-699
Command: show stp instance_id 1
STP Instance Settings
Instance Type : MSTI(1)
Instance Status : Enabled
Instance Priority : 40961(bridge priority : 40960, sys ID ext : 1 )
STP Instance Operational Status
Regional Root Bridge : 40961/00-17-9A-7F-57-AA
Internal Root Cost : 0
Designated Bridge : 40961/00-17-9A-7F-57-AA
Root Port : None
Remaining Hops : 20
Last Topology Change : 1439
Topology Changes Count : 2
Command: show stp ports 24
MSTP Port Information
Port Index : 24 , Hello Time: 2 /2 , Port STP enabled LBD : No
External PathCost : Auto/2000000 , Edge Port : No /No , P2P : Auto /No
Port Forward BPDU : enabled
Msti Designated Bridge Internal PathCost Prio Status Role
0 A000/00179A7F57AA 2000000 128 Forwarding Designated
1 A001/00179A7F57AA 2000000 128 Forwarding Designated
2 A002/00179A7F57AA 2000000 128 Forwarding Designated
[catalyst]%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
#sh spanning-tree mst configuration
Name [FOOBAR]
Revision 555 Instances configured 3
Instance Vlans mapped
0 1-499,700-4094
1 500-599
2 600-699
#sh spanning-tree mst 1
##### MST1 vlans mapped: 500-599
Bridge address 0017.5937.e900 priority 4097 (4096 sysid 1)
Root this switch for MST1
Interface Role Sts Cost Prio.Nbr Type
Fa0/5 Desg BLK 2000000 128.7 Dispute Shr
... dgs игнорирует stp bpdu от catalyst с меньшим приоритетом (4096), продолжая передавать свои config. bpdu (40960). Соответственно, catalyst переводит свой порт в BLK. Данная ситуация продолжается до тех пор, пока dgs имеет бОльший priority, Однако, если выставить бОльший приоритет catalyst'у, то dgs спокойно становится root bridge:
dut-3560#sh spanning-tree mst 1
Bridge address 0017.5937.e900 priority 61441 (61440 sysid 1)
Root address 0017.9a7f.57aa priority 40961 (40960 sysid 1)
port Fa0/5 cost 2000000 rem hops 19
Fa0/5 Root FWD 2000000 128.7 Shr
TIA!
P.S. Аналогичная ситуация возникает и в случае использования pvst+ со стороны catalyst и plain dot1d для vlanid=1 со стороны dgs -- до тех пор, пока catalyst's priority ниже, чем сконфигурированное значение на dgs, последний игнорирует bpdu от catalyst (two-way bpdu flow). При выкручивании priority на catalyst, dgs спокойно становится root bridge.
СообщениеДобавлено: Вт май 15, 2007 09:36
А у Вас ни симптомы вот этой ситуации не похоже? http://www.dlink.ru/technical/faq_hub_switch_111.php
СообщениеДобавлено: Вт май 15, 2007 10:21
Нет, я видел эту ссылку, поэтому и привел информацию по поводу версии IOS -- 12.2(35)SE, что на данный момент является одним из последних имиджей. Btw, аналогичные результаты были получены и для ME6524/12.2(18)ZU2, где, если мне не изменят склероз, MST *НЕ* является pre-standard ieee с момента FCS для этой коробки.
СообщениеДобавлено: Вт май 15, 2007 10:24
Пришлите схему в графической форме с указанием на ней портов соединения, конфиг файл DGS-3024 и настройки касаемо MSTP Cisco.
СообщениеДобавлено: Вт май 15, 2007 12:15
Ушло почтой.
СообщениеДобавлено: Вт май 15, 2007 14:16
Мы занимаемся этой проблемой. Как только будут новости сообщу.
СообщениеДобавлено: Пн май 21, 2007 10:15
Сколько у Вас VLAN-ов используется в реальности?
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 43
