Текущее время: Сб авг 08, 2026 04:35
 Заголовок сообщения: 500-T: Modem Hang-Up
СообщениеДобавлено: Чт май 03, 2007 16:32
500T подключен по PPPoE, скорость у провайдера ограничена 64 Kb/s. При
серфинге проблем нет, при попытке скачать файл размером 3-7М все равно
браузером или менеджером загрузок некоторое время качается нормально,
затем происходит остановка закачки. При этом и пинги и серфинг - без проблем.
Качать пробовал разные файлы в частности с rapidshare.de
Пробовал уменьшить MTU до 1000.
Лог:
Jan 1 12:00:10> Valid Configuration Tree
Jan 1 12:00:10> NTP Polling Timer for DHCP Started succesfully.
Jan 1 12:00:10> DSL Polling Timer Started succesfully.
Jan 1 12:00:10> doing modulation_set.
Jan 1 12:00:11> Firewall NAT service started
Jan 1 12:00:12> starting on port 80
Jan 1 12:00:13> Bridge Created: br0
Jan 1 12:00:13> Bridge Created: br1
Jan 1 12:00:14> Bridge Interface Added: eth0
Jan 1 12:00:20> DSL Carrier is down
Jan 1 12:00:30> DSL Carrier is up
Jan 1 12:00:31> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:32> Connect: ppp0 {--} nas0
Jan 1 12:00:34> PAP authentication succeeded
Jan 1 12:00:34> peer from calling number 00:17:DF:6E:90:1B authorized
Jan 1 12:00:34> WAN IP address 10.154.128.243
Jan 1 12:00:34> WAN gateway 10.212.54.6
Jan 1 12:00:34> primary DNS address 212.57.145.253
Jan 1 12:00:34> secondary DNS address 195.54.2.1
Jan 1 12:00:34> PPPoE Connect with IP Address 10.154.128.243
Jan 1 12:00:34> PPPoE Connection Successfully Established
Jan 1 12:00:34> PPPoE Connect with Gateway IP Address: 10.212.54.6
Jan 1 12:02:34> Terminated: Modem Hang-Up
Jan 1 12:02:34> Modem hangup
Jan 1 12:02:34> Connection terminated.
Jan 1 12:02:34> pppd 2.4.3 started by root, uid 0
Jan 1 12:02:34> Connect: ppp0 {--} nas0
Jan 1 12:02:34> PAP authentication succeeded
Jan 1 12:02:34> peer from calling number 00:17:DF:6E:90:1B authorized
Jan 1 12:02:34> WAN IP address 10.154.128.243
Jan 1 12:02:34> PPPoE Connect with IP Address 10.154.128.243
Jan 1 12:02:34> PPPoE Connection Successfully Established
Jan 1 12:02:34> PPPoE Connect with Gateway IP Address: 10.212.54.6
Jan 1 12:02:34> WAN gateway 10.212.54.6
Jan 1 12:02:34> primary DNS address 212.57.145.253
Jan 1 12:02:34> secondary DNS address 195.54.2.1
Jan 1 12:06:28> Terminated: Modem Hang-Up
Jan 1 12:06:28> Modem hangup
Jan 1 12:06:28> Connection terminated.
Jan 1 12:06:28> pppd 2.4.3 started by root, uid 0
Jan 1 12:06:28> Connect: ppp0 {--} nas0
Jan 1 12:06:28> PAP authentication succeeded
Jan 1 12:06:28> peer from calling number 00:17:DF:6E:90:1B authorized
Jan 1 12:06:28> WAN IP address 10.154.128.243
Jan 1 12:06:28> PPPoE Connect with IP Address 10.154.128.243
Jan 1 12:06:29> PPPoE Connection Successfully Established
Jan 1 12:06:29> PPPoE Connect with Gateway IP Address: 10.212.54.6
Jan 1 12:06:29> WAN gateway 10.212.54.6
Jan 1 12:06:29> primary DNS address 212.57.145.253
Jan 1 12:06:29> secondary DNS address 195.54.2.1
ADSL Status:
ADSL status shows the ADSL physical layer status.
ADSL Firmware Version: 4.03.03.00 - 3.02.00.03 - 3.02.06.00 Annex A - 01.07.02 - 0.49
ADSL Software Version: V2.01B01T01.RU.20060620
Line State Connected
Modulation Multi-mode
Annex Mode ANNEX_A
Max Tx Power -38 dBm/Hz
Item Downstream Upstream Unit
SNR Margin 31 25 dB
Line Attenuation 23 15 dB
Data Rate 512 512 kbps
Я так понимаю, проблема в Jan 1 12:06:28> Terminated: Modem Hang-Up?
СообщениеДобавлено: Чт май 03, 2007 16:35
Попробуйте вернуть устройство к заводским установкам и перенастроить.
С уважением, Давыдов Денис.
СообщениеДобавлено: Чт май 03, 2007 18:49
Сделал. Один файл вроде скачал. Дальше опять то же самое...
12:00:36> PPPoE Connect with IP Address 10.154.128.243
Jan 1 12:00:36> PPPoE Connection Successfully Established
Jan 1 12:00:36> PPPoE Connect with Gateway IP Address: 10.212.54.6
Jan 1 12:49:11> Modem hangup
Jan 1 12:49:11> Connection terminated.
Jan 1 12:49:11> Terminated: Modem Hang-Up
Jan 1 12:49:14> pppd 2.4.3 started by root, uid 0
Jan 1 12:49:14> Connect: ppp0 {--} nas0
Jan 1 12:49:15> PAP authentication succeeded
Jan 1 12:49:15> peer from calling number 00:17:DF:6E:90:1B authorized
Jan 1 12:49:15> WAN IP address 10.154.128.243
Jan 1 12:49:15> PPPoE Connect with IP Address 10.154.128.243
Jan 1 12:49:15> PPPoE Connection Successfully Established
Jan 1 12:49:15> PPPoE Connect with Gateway IP Address: 10.212.54.6
Jan 1 12:49:15> WAN gateway 10.212.54.6
Jan 1 12:49:15> primary DNS address 212.57.145.253
Jan 1 12:49:15> secondary DNS address 195.54.2.1
Jan 1 12:59:11> Modem hangup
Jan 1 12:59:11> Connection terminated.
Jan 1 12:59:11> Terminated: Modem Hang-Up
Jan 1 12:59:14> pppd 2.4.3 started by root, uid 0
Ну и далее hagup через случайные (?) промежутки...
СообщениеДобавлено: Сб май 05, 2007 00:15
Была такая-же проблема. Поставил прогу CfosSpeed (альтернативный ADSL драйвер) и все стало докачиваться. Попробуй.
СообщениеДобавлено: Сб май 05, 2007 12:40
Не помогло. Модем разрывает связь с периодичностью в 5 минут (чаще всего), даже если ничего не качаешь.
Home->WAN->Connection Settings установлено в Always On.
Ничего не понимаю...
СообщениеДобавлено: Пн май 07, 2007 13:00
Попробуйте обновить прошивку до последней: ftp://ftp.dlink.ru/pub/ADSL/DSL-500T/Fi ... 070402.zip
Если это не поможет и проблема все также будет иметь место - привозите устройство в ближайший сервисный центр на тестирование.
СообщениеДобавлено: Пн май 07, 2007 17:40
Не помогло. Провайдер дал другой модем - Star-Net. Линию проверили, говорят все в порядке. Ситуация не изменилась...
Да, у провайдера мой модем работает без проблем... Да, а сервисный центр от нас далеко :)
Из-за чего вообще такое может быть? Спасибо за помощь.
СообщениеДобавлено: Вт май 08, 2007 11:15
Это может происходить по следующим причинам: происходит потеря сигнала без разрыва ADSL несущей. Из за этого происходит разрыв PPPoE соединения. Подробную статистику можно посмотреть в статистике DSL порта на DSLAM, к которому Вы подключены. Все это должен проверить провайдер.
СообщениеДобавлено: Пт май 18, 2007 19:14
Провайдер согласился, что проблема в DSLAM, потому что они пробовали втыкать модем напрямую в мой порт, и происходит разрыв соединения, точно так же, как и у меня. Произвели переключение на другой порт, но ситуация не изменилась :(
Провайдер говорит - не знаем что делать, больше ни у кого таких проблем не возникало...
Со своей стороны нашел выход - если 1 раз в 10 секунд пинговать роутер (или кто он там) или DNS провайдера, обрывов PPPoE не происходит. Пока вроде работает, но как-то это некузяво :) В чем же все-таки может быть проблема?
СообщениеДобавлено: Пн май 21, 2007 14:16
Попросите оператора посмотреть статистику ошибок в свойствах того DSL порта на DSLAM, к которому Вы подключены. Возможно, данную проблему можно решить тонкой настройкой профиля DSL порта.
