Текущее время: Вс окт 04, 2026 09:47
СообщениеДобавлено: Чт май 03, 2007 13:32
Thursday March 25, 2004 00:12:42 PPPoE start to dial-up
Thursday March 25, 2004 00:12:42 PADT sent
Thursday March 25, 2004 00:12:44 PADI sent @telsi-cs1
Thursday March 25, 2004 00:12:44 PADO recv 0016 telsi-cs1
Thursday March 25, 2004 00:12:44 PADR sent
Thursday March 25, 2004 00:12:44 PADS recv 8002 5CE6
Thursday March 25, 2004 00:12:49 CHAP3: OK
Thursday March 25, 2004 00:13:12 LCP terminate recv
Thursday March 25, 2004 00:13:12 PPP3: closed
Thursday March 25, 2004 00:15:18 Restarted by 192.168.0.143
Thursday March 25, 2004 00:15:28 DOD:triggered internally
Thursday March 25, 2004 00:15:28 PPPoE start to dial-up
Thursday March 25, 2004 00:15:28 PADT sent
Thursday March 25, 2004 00:15:30 PADI sent @telsi-cs1
Thursday March 25, 2004 00:15:30 PADO recv 0016 telsi-cs1
Thursday March 25, 2004 00:15:30 PADR sent
Thursday March 25, 2004 00:15:30 PADS recv 8002 5EE6
Thursday March 25, 2004 00:15:50 LCP terminate recv
Thursday March 25, 2004 00:15:50 PPP3: closed
Thursday March 25, 2004 00:18:13 PPPoE start to dial-up
Thursday March 25, 2004 00:18:13 PADT sent
Thursday March 25, 2004 00:18:15 PADI sent @telsi-cs1
Thursday March 25, 2004 00:18:15 PADO recv 0016 telsi-cs1
Thursday March 25, 2004 00:18:15 PADR sent
Thursday March 25, 2004 00:18:15 PADS recv 8002 60E6
Thursday March 25, 2004 00:18:19 CHAP3: OK
Thursday March 25, 2004 00:18:22 CHAP3: OK
Thursday March 25, 2004 00:18:42 LCP terminate recv
Thursday March 25, 2004 00:18:42 PPP3: closed
Current Firmware Version: V1.03b01
Firmware Date: Thu, Oct 05 2006
И так по кругу. Он не успевает поднять первое соединение, как ломиться второй раз и сервер его скидывает. Как это исправить?
СообщениеДобавлено: Чт май 03, 2007 13:46
А У Вас случаем не Static PPPoE? Потому как устройство не может получить от сервера IP адреса.
Что У Вас за провайдер?
СообщениеДобавлено: Чт май 03, 2007 13:59
Нет. ip адрес выдается провайдером после авторизации. по логам радиуса авторизации она проходит успешно. просто с компьютера рррое устанавливается на ура, а вот длинк не может.
Со стороны провайдера это выглядит так:
Thu May 3 15:56:47 2007 : Error: rlm_sql: Stop packet with zero session length.
Thu May 3 15:56:47 2007 : Auth: Login OK: [nik/] (from client cs1 port 0)
Thu May 3 15:56:44 2007 : Auth: Login OK: [nik/] (from client cs1 port 0)
Thu May 3 15:56:14 2007 : Error: rlm_sql: Stop packet with zero session length.
Thu May 3 15:56:14 2007 : Auth: Login OK: [nik/] (from client cs1 port 0)
Thu May 3 15:56:11 2007 : Auth: Login OK: [nik/] (from client cs1 port 0)
Thu May 3 15:52:08 2007 : Error: rlm_sql: Stop packet with zero session length.
Thu May 3 15:52:07 2007 : Auth: Login OK: [nik/] (from client cs1 port 0)
Thu May 3 15:52:04 2007 : Auth: Login OK: [nik/] (from client cs1 port 0)
Thu May 3 15:47:34 2007 : Error: rlm_sql: Stop packet with zero session length.
Thu May 3 15:47:34 2007 : Auth: Login OK: [nik/] (from client cs1 port 0)
Thu May 3 15:47:31 2007 : Auth: Login OK: [nik/] (from client cs1 port 0)
Thu May 3 15:46:28 2007 : Error: rlm_sql: Stop packet with zero session length.
Thu May 3 15:46:28 2007 : Auth: Login OK: [nik/] (from client cs1 port 0)
Thu May 3 15:46:25 2007 : Auth: Login OK: [nik/] (from client cs1 port 0)
Thu May 3 15:39:01 2007 : Error: rlm_sql: Stop packet with zero session length.
Thu May 3 15:39:01 2007 : Auth: Login OK: [nik/] (from client cs1 port 0)
Thu May 3 15:38:58 2007 : Auth: Login OK: [nik/] (from client cs1 port 0)
Когда же цепляешь рррое напрямую картинка ограничивается одной записью:
СообщениеДобавлено: Чт май 03, 2007 14:16
радиус использует только для авторизации, но и выдаёт Framed-IP-xxx?
Давай посмотрим логи радиуса, если есть возможность. Суть одна -- девайс не получает IP, по какой причине -- непонятно.
Если можете предоставить sniff будет вообще замечательно.
Как я понимаю Вы представитель www.tele-set.ru ?
СообщениеДобавлено: Чт май 03, 2007 14:28
У меня тут один логичный вопрос возник: можно ли длинку как-то сказать, чтобы он совершал попытки соединиться хотябы через 3-4 секунды, а не 2 раза в 1 секунду?
PS: я в спешке немного модель попутал :( 704UP прошу прощение за оплошность.
СообщениеДобавлено: Чт май 03, 2007 14:33
Вопрос логичный, но это делается на уровне прошивки и пользователем этот параметр не задётся. Разве что использовать не always-on, а manual/connect-on-demand
СообщениеДобавлено: Чт май 03, 2007 14:41
Использовал - то же самое. У него как у матрешки - 3 в 1. Даже при единовременной попытке установить соединение в логах образуется 3 записи:
Thu May 3 16:45:03 2007 : Error: rlm_sql: Stop packet with zero session length.
Thu May 3 16:45:03 2007 : Auth: Login OK: [nik/] (from client cs1 port 0)
Thu May 3 16:45:00 2007 : Auth: Login OK: [nik/] (from client cs1 port 0)
А что сложного или же строшного в том, чтобы данный параметр был доступен пользователям? В окнах же он доступен.
СообщениеДобавлено: Чт май 03, 2007 15:00
Так, давайте более объективно.
1
Вы можете предоставить снифф или полный вывод freeradius? Обсуждать "а хорошо было бы" можно бескрайне долго.
2
Вы нашли в чём проблема?
СообщениеДобавлено: Чт май 03, 2007 15:27
В каком формате сохранить лог сниффера ethereal?
СообщениеДобавлено: Чт май 03, 2007 15:30
libpcap, желательно перед сохранением натравить фильтр по mac(роутера)
СообщениеДобавлено: Чт май 03, 2007 15:37
файл ушел по почте.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 184
