Текущее время: Вс ноя 08, 2026 23:08
СообщениеДобавлено: Сб мар 03, 2007 15:00
Роутер Dlink DI-804HV
провайдер Corbina
Раньше все работало нормально. Сессия устанавливалась интернет работал все в норме.
Настраивал по этой статье
http://dlink.ru/technical/faq_internet_22.php
Потом были проблеммы со скоростью интернета и по заявке в тех поддержку поменяли порт подключения на коммутаторе ( ну так сказали в карбине)
Теперь есть такая ситуация.
Роутер подключается интернет есть пиблизительно 5-7 минут потом отключается и все больше не подключается.
в логах следующее
WAN Type: PPTP (V1.43)
Display time: Thursday January 26, 2006 00:45:48
Thursday January 26, 2006 00:41:59 PPTP:error=-112
Thursday January 26, 2006 00:42:01 DOD:TCP trigger from 192.168.0.101:4932 to 213.66.15.165:39365
Thursday January 26, 2006 00:42:01 PPTP start to dial-up
Thursday January 26, 2006 00:42:05 PPTP server=10.176.0.17
Thursday January 26, 2006 00:42:18 PPTP:error=-112
Thursday January 26, 2006 00:42:18 DOD:UDP trigger from 195.14.50.1:53 to 10.176.91.164:65507
Thursday January 26, 2006 00:42:18 PPTP start to dial-up
Thursday January 26, 2006 00:42:18 PPTP server=195.14.38.15
Thursday January 26, 2006 00:42:18 CHAP1: OK
Thursday January 26, 2006 00:42:18 IPCP1: IP is 85.21.236.52
Thursday January 26, 2006 00:42:18 IPCP1: DNS0 is 213.234.192.7
Thursday January 26, 2006 00:42:19 Blocked access attempt from 83.108.171.151:49104 to TCP port 57275
Thursday January 26, 2006 00:42:20 Blocked access attempt from 83.108.171.151:49104 to TCP port 57289
Thursday January 26, 2006 00:42:34 Blocked access attempt from 85.21.178.20:4526 to TCP port 5800
Thursday January 26, 2006 00:42:36 Blocked access attempt from 85.21.178.20:4719 to TCP port 139
Thursday January 26, 2006 00:42:38 Blocked access attempt from 85.21.178.20:1149 to TCP port 1433
Thursday January 26, 2006 00:44:32 PPTP start to dial-down
hursday January 26, 2006 00:41:58 PPTP:error=-112
Thursday January 26, 2006 00:42:00 DOD:TCP trigger from 192.168.0.101:4932 to 213.66.15.165:39365
Thursday January 26, 2006 00:42:00 PPTP start to dial-up
Thursday January 26, 2006 00:42:04 PPTP server=10.176.0.17
Thursday January 26, 2006 00:42:33 Blocked access attempt from 85.21.178.20:4526 to TCP port 5800
Thursday January 26, 2006 00:42:35 Blocked access attempt from 85.21.178.20:4719 to TCP port 139
Thursday January 26, 2006 00:42:37 Blocked access attempt from 85.21.178.20:1149 to TCP port 1433
Thursday January 26, 2006 00:46:35 PPTP:error=-200
Thursday January 26, 2006 00:46:37 DOD:TCP trigger from 192.168.0.101:4962 to 85.225.220.132:10314
Thursday January 26, 2006 00:46:37 PPTP start to dial-up
Если подключаем кабель напрямую в компьютер то все работает нормально.
Вопрос это проблемы с роутером или с настройками у првайдера?
Firmware Version: V1.43, Thu, Jan 26 2006
СообщениеДобавлено: Пн мар 05, 2007 11:54
Перепрошейтесь вот на эту прошивку: ftp://ftp.dlink.ru/pub/Router/DI-804HV/ ... 1207155433).zip
После этого сбросьте роутер в заводские установки и настройте его заново.
СообщениеДобавлено: Пт мар 09, 2007 11:17
Проблема решена
Оказывается подключили не тот блок питания
использоватли блок питания от точки доступа DWL 2000AP+
а у нее ток 2.4 А когда требуется 2.0 A
В результате обнаружились интересные глюки.
Роутер работает примерно 20-30 мин потом нагревается и сетевой интерфейс WAN теряет DHCP ( не может получить адрес)
потом процент доставки пакетов достигает 50%
При этом PPTP соединение с корбиной падает и больше не поднимается.
Так же отваливается статическая маршрутиризация :)
Как только роутер охлаждается все снова работает.
При этом в режиме коммутатора работает н6ормально все это время. :)
