Текущее время: Чт окт 29, 2026 00:11
 Заголовок сообщения: Роутинг
СообщениеДобавлено: Пн фев 26, 2007 14:17
Dl-824vup+ Настраиваю роутинг (сеть корбина) нажимаю апли и роутер больше не видеться. Вай фай пропадает локальное соединение пишет что ограниченно. Если я сбрасываю настройки, настраиваю все кроме роутинга то все работает нормально. Но роутинг мне очень нужен, так как неудобно по ресурсам сети лазить, собсно для этой цели и бралась эта модель.
Device Information
Firmware Version: v1.05, Mon, Apr 25 2005
WAN Type: PPTP (v1.05)
Display time: Thursday April 12, 2007 15:32:19
logs
Thursday April 12, 2007 15:03:29 DOD:UDP trigger from 192.168.0.180:1369 to 64.12.161.153:5150
Thursday April 12, 2007 15:03:29 PPTP start to dial-up
Thursday April 12, 2007 15:03:29 DHCP:discover(My Host)
Thursday April 12, 2007 15:03:31 DOD:TCP trigger from 192.168.0.180:1352 to 69.136.33.138:42354
Thursday April 12, 2007 15:03:33 DHCP:discover(My Host)
Thursday April 12, 2007 15:03:35 DHCP:offer(10.197.0.17)
Thursday April 12, 2007 15:03:35 DHCP:request(10.197.98.225)
Thursday April 12, 2007 15:03:35 DHCP:ack(DOL=604800,T1=302400,T2=529200)
Thursday April 12, 2007 15:03:35 PPTP server=195.14.38.15
Thursday April 12, 2007 15:03:36 CHAP1: OK
Thursday April 12, 2007 15:03:36 IPCP1: DNS0 is 213.234.192.7
Thursday April 12, 2007 15:03:36 IPCP1: DNS1 is 195.14.50.21
Thursday April 12, 2007 15:03:36 PPTP start to dial-up
Thursday April 12, 2007 15:03:41 Syn Time: Thu Apr 12 15:03:41 2007
Thursday April 12, 2007 15:03:54 Blocked access attempt from 83.37.9.22:13933 to UDP port 137
Thursday April 12, 2007 15:09:23 Blocked access attempt from 10.197.68.206:1243 to TCP port 445
Thursday April 12, 2007 15:09:26 Blocked access attempt from 10.197.68.206:1243 to TCP port 445
Thursday April 12, 2007 15:09:29 Blocked access attempt from 10.197.68.206:2083 to TCP port 139
Thursday April 12, 2007 15:09:30 Blocked access attempt from 10.197.68.206:2254 to TCP port 445
Thursday April 12, 2007 15:09:32 Blocked access attempt from 10.197.68.206:2083 to TCP port 139
Thursday April 12, 2007 15:09:33 Blocked access attempt from 10.197.68.206:2254 to TCP port 445
Thursday April 12, 2007 15:14:34 Blocked access attempt from 77.11.198.180:30362 to UDP port 1026
Thursday April 12, 2007 15:15:48 Blocked access attempt from 10.197.68.206:1674 to TCP port 445
Thursday April 12, 2007 15:15:51 Blocked access attempt from 10.197.68.206:1674 to TCP port 445
Thursday April 12, 2007 15:18:59 Blocked access attempt from 55.129.212.244:30362 to UDP port 1026
Thursday April 12, 2007 15:20:42 Blocked access attempt from 202.109.114.168:1402 to UDP port 1434
Thursday April 12, 2007 15:21:27 Blocked access attempt from 10.197.68.206:1778 to TCP port 445
Thursday April 12, 2007 15:21:30 Blocked access attempt from 10.197.68.206:1778 to TCP port 445
Thursday April 12, 2007 15:24:47 Blocked access attempt from 62.195.227.76:3389 to UDP port 1434
Thursday April 12, 2007 15:28:10 Blocked access attempt from 10.197.46.82:1125 to TCP port 445
Thursday April 12, 2007 15:28:13 Blocked access attempt from 10.197.46.82:1125 to TCP port 445
Thursday April 12, 2007 15:28:16 Blocked access attempt from 10.197.46.82:1999 to TCP port 139
Thursday April 12, 2007 15:28:19 Blocked access attempt from 10.197.46.82:1999 to TCP port 139
Thursday April 12, 2007 15:29:32 Blocked access attempt from 204.16.210.193:58980 to UDP port 1027
Thursday April 12, 2007 15:32:19 Blocked access attempt from 10.197.68.206:4951 to TCP port 445
Thursday April 12, 2007 15:32:22 Blocked access attempt from 10.197.68.206:4951 to TCP port 445
СообщениеДобавлено: Пн фев 26, 2007 15:14
Попробуйте прошить последнюю прошивку.
СообщениеДобавлено: Пн фев 26, 2007 15:42
Поставьте последнюю и прошивку и приведтите таблицу маршрутизации, что Вы прописываете.
СообщениеДобавлено: Вт фев 27, 2007 15:29
А где можно найти инструкцию по перепрошивке? И желательно ссылку на последнюю прошивку.
СообщениеДобавлено: Вт фев 27, 2007 16:25
http://www.dlink.ru/technical/faq_internet_46.php
http://ftp.dlink.ru/pub/Router/DI-824VUP+/Firmware/20061211_824VUP_v106b07(1211)(1211120535).zip
СообщениеДобавлено: Чт мар 01, 2007 20:04
прошивка новая а таблице роутинга так и не добавили строки
