Текущее время: Сб ноя 07, 2026 22:30
СообщениеДобавлено: Вт фев 20, 2007 19:24
Здраствуйте. Наблюдается падение скорости интернета на роутере DI-704P.
:!: В этот понедельник навещал вас, вы протестили его и сказали что "тест ок" (номер заказа 55628) :D :!:
Ну так вот... приехав и подключив роутер у себя наблюдается все таже ситуация :(
Прошивка 3,15 (последняя с вашего сайта).
У меня статический адрес (выделенный,постоянный 85.30.228.104).
В лог файле пишет вот что:
WAN Type: Static IP Address (V3.15)
Display time: Monday February 19, 2007 21:07:57
Monday February 19, 2007 20:11:53 Unrecognized attempt blocked from 117.11.171.64:30787 to 85.30.228.104 UDP:1026
Monday February 19, 2007 20:12:28 Unrecognized attempt blocked from 85.30.89.15:63100 to 85.30.228.104 TCP:135
Monday February 19, 2007 20:13:30 Unrecognized attempt blocked from 85.30.89.189:4501 to 85.30.228.104 TCP:135
Monday February 19, 2007 20:13:33 Unrecognized attempt blocked from 85.30.89.189:4501 to 85.30.228.104 TCP:135
Monday February 19, 2007 20:14:36 Unrecognized attempt blocked from 85.30.82.232:2876 to 85.30.228.104 TCP:445
Monday February 19, 2007 20:15:20 Unrecognized attempt blocked from 85.30.81.62:3429 to 85.30.228.104 TCP:135
Monday February 19, 2007 20:15:23 Unrecognized attempt blocked from 85.30.81.62:3429 to 85.30.228.104 TCP:135
Monday February 19, 2007 20:16:18 Unrecognized attempt blocked from 85.30.122.163:3064 to 85.30.228.104 TCP:135
Monday February 19, 2007 20:16:19 Unrecognized attempt blocked from 72.165.220.56:40739 to 85.30.228.104 TCP:22
Monday February 19, 2007 20:16:21 Unrecognized attempt blocked from 85.30.122.163:3064 to 85.30.228.104 TCP:135
Display time: Monday February 19, 2007 21:08:28
Monday February 19, 2007 20:16:20 Unrecognized attempt blocked from 85.30.122.163:3064 to 85.30.228.104 TCP:135
Monday February 19, 2007 20:16:36 Unrecognized attempt blocked from 85.30.81.62:2214 to 85.30.228.104 TCP:135
Monday February 19, 2007 20:18:18 Unrecognized attempt blocked from 64.72.116.55:58593 to 85.30.228.104 UDP:10481
Monday February 19, 2007 20:18:59 Unrecognized attempt blocked from 85.30.83.83:3510 to 85.30.228.104 TCP:445
Monday February 19, 2007 20:19:02 Unrecognized attempt blocked from 85.30.83.83:3510 to 85.30.228.104 TCP:445
Monday February 19, 2007 20:21:15 Unrecognized attempt blocked from 15.76.177.148:30787 to 85.30.228.104 UDP:1026
Monday February 19, 2007 20:22:43 Unrecognized attempt blocked from 85.30.80.20:4772 to 85.30.228.104 TCP:135
Monday February 19, 2007 20:22:45 Unrecognized attempt blocked from 85.30.80.20:4761 to 85.30.228.104 TCP:135
Monday February 19, 2007 20:24:42 Unrecognized attempt blocked from 85.30.81.62:2015 to 85.30.228.104 TCP:135
Monday February 19, 2007 20:24:45 Unrecognized attempt blocked from 85.30.81.62:2015 to 85.30.228.104 TCP:135
Display time: Monday February 19, 2007 21:08:39
Monday February 19, 2007 20:25:29 Unrecognized attempt blocked from 85.30.89.51:64300 to 85.30.228.104 TCP:135
Monday February 19, 2007 20:26:58 Restarted by 192.168.0.146
Monday February 19, 2007 20:27:15 Unrecognized attempt blocked from 85.30.79.186:3271 to 85.30.228.104 TCP:445
Monday February 19, 2007 20:27:18 Unrecognized attempt blocked from 85.30.79.186:3271 to 85.30.228.104 TCP:445
Monday February 19, 2007 20:27:34 Unrecognized attempt blocked from 85.30.81.62:3625 to 85.30.228.104 TCP:135
Monday February 19, 2007 20:27:36 Unrecognized attempt blocked from 85.30.89.242:4728 to 85.30.228.104 TCP:445
Monday February 19, 2007 20:27:39 Unrecognized attempt blocked from 85.30.89.242:4728 to 85.30.228.104 TCP:445
Monday February 19, 2007 20:28:12 Unrecognized attempt blocked from 85.30.88.235:4717 to 85.30.228.104 TCP:445
Monday February 19, 2007 20:28:15 Unrecognized attempt blocked from 85.30.88.235:4717 to 85.30.228.104 TCP:445
Очень надеюсь что вы мне не откажете в помощи снова. :roll: Заранее извиняюсь если эта тема уже повторялась! Жду и надеюсь на вас :idea:
СообщениеДобавлено: Ср фев 21, 2007 11:23
Падение скорости наблюдается сразу после включения или через какое-то время? До какого уровня падает скорость?
СообщениеДобавлено: Ср фев 21, 2007 19:11
Скорость скачки сразу парадет в 1.5 раза. Через минут 20 работа в браузере становиться практически не возможна. Загрузки страницы приходиться ждать по 10 секунд и более. Иногда происходит чудо и роутер начинает шустро работать, но продолжается это не долго(1 минута максимум). Сразу после включения скорость в браузере нормальная!
При работе без роутера данной проблемы с тормозами нет.
СообщениеДобавлено: Чт фев 22, 2007 13:42
В заявке Вы написали "Не выпускает в Интернет". Именно на эту неисправность устройство и тестировали. В Интернет оно пускает.
Привозите еще раз, только в заявке укажите именно падение скорости через 20 минут работы.
