Текущее время: Чт июл 02, 2026 02:20
 Заголовок сообщения: DI-604 PPTP на Linux и FreeBSD (6.0)
СообщениеДобавлено: Вс янв 28, 2007 18:52
В локальной сети есть два VPN-сервера ( Linux-FC3 и Unix (FreeBSD-6.0), а также DI-604 H/W:ver: F3 FW: V3.14 Firmware Date: Thu, Dec 15 2005
PPPoE на Unix - без проблем.
PPTP на Linux - без проблем.
PPTP на Unix - не проходит.... (PPTPd v-1.2.3)
(Везде PAP-авторизация)
Пробовал на 2 экземплярах DI-604..... :evil:
Настройкa WAN PPTP одна и та же кроме, конечно, IP сервера :)
HOME WAN
Others PPTP (for Europe use only)
PPTP Static IP
My IP Address 192.168.16.242
My Subnet Mask 255.255.255.0
My Gateway 192.168.16.1 (192.168.16.10 )
Server IP/Name 192.168.16.1 ( 192.168.16.10 )
PPTP Account test
PPTP Password ***********
Retype Password ***********
Connection ID (optional)
Maximum Idle Time 5 Minutes
MTU 1460
Connect mode select Always-on
Change the TTL value Enabled
В СТАТУС ЛОГ -
start to hang-up
Restarted by 192.168.0.200
DOD:triggered internally
start to dial-up
PPTP:PNS=192.168.16.10
PPP1: RX LCP Request
PPP1: TX LCP Reject
PPP1: TX LCP ACK
PPP1: TX LCP Request
PPP1: RX LCP ACK
PPP1: TX PAP
PPP1: TX PAP
PPP1: TX PAP
PPP1: TX PAP
PPP1: TX LCP Reject
PPP1: RX LCP ACK
PPP1: TX LCP ACK
PPP1: TX PAP
PPP1: TX PAP
PPP1: TX LCP Reject
PPP1: RX LCP ACK
PPP1: TX LCP ACK
PPP1: TX PAP
PPP1: TX PAP
PPP1: retry fail
PPP1: TX LCP Request2
PPP1: Error - 102/112...
В логе FreeBSD (ppp.log) в этот момент
ppp[49024]: tun34: Phase: PPP Started (direct mode).
ppp[49024]: tun34: Phase: bundle: Establish
ppp[49024]: tun34: Phase: deflink: closed -> opening
ppp[49024]: tun34: Phase: deflink: Connected!
ppp[49024]: tun34: Phase: deflink: opening -> carrier
ppp[49024]: tun34: Phase: deflink: carrier -> lcp
ppp[49024]: tun34: Phase: bundle: Authenticate
ppp[49024]: tun34: Phase: deflink: his = none, mine = PAP
ppp[49024]: tun34: Phase: deflink: HDLC errors -> FCS: 0, ADDR: 6, COMD: 0, PROTO: 0
ppp[49024]: tun34 Phase: deflink: HDLC errors -> FCS: 0, ADDR: 7, COMD: 0, PROTO: 0
(Напоминаю, что PPPoE с тем же логином/паролем проходит без проблем, как и VPN (PPTP/PPPoE) from Windows) :evil:
На форуме нашел утверждение о том, что DI-604 тестировался с PPTPd for Linux.
Вопрос - Проверялся ли DI-604 на работу с PPTPd for Unix?
И что самое неприятное - это то, что после первой настройки PPTP DI-604 отработал с Unix-ом около 5 суток и после первого дисконнекта с сервера все как отрезало.... Бьюсь с ним уже неделю....
(Рестарт PPTPd и перезагрузка FreeBSD были, сброс настроек DI-604 до фабричных тоже).....
Сидел бы на PPPoE, да не во всех сегментах сети он проходит - есть радио-линки.......
Может кто-нить сталкивался с такой проблемой ? Или может тех-поддержка что посоветует?
После длительного изучения форума по проблемам "ошибка 112" решил добавить информации для техподдержки -
между DI-604 и VPN-сервером только 16 портовый свитч, кстати тоже D-Link, и два шнурка, каждый по 1,5 м. длиной. Так что о недоступности VPN-сервера говорить просто смешно.
А вот с ошибкой протокола - это уже серьезнее... :cry:
Последний раз редактировалось Гога Ср янв 31, 2007 18:32, всего редактировалось 1 раз.
СообщениеДобавлено: Вт янв 30, 2007 11:27
Ну так что, ни одной мысли у техподдержки по этой проблеме нет ?
СообщениеДобавлено: Ср янв 31, 2007 14:06
Похоже техподдержка слила.....
Придется искать маршрутизатор другого производителя ... :?
Народ, что посоветуете? (Для одновременной работы в Инете 10-30 пользователей.)
СообщениеДобавлено: Чт фев 01, 2007 22:57
АААУУУУ!!! Техподдержка !!! Вы что, прячетесь???
Хоть бы что-то сказали.... :evil:
СообщениеДобавлено: Чт фев 01, 2007 23:16
мы не занимаемся поддержкой ОС Unix
PS: с mpd/poptopd устройство без проблем работает
PS2: Не советую его использовать для 20-30 пользователей.
СообщениеДобавлено: Пт фев 02, 2007 12:32
Ну наконец-то отозвались... :D
Спасибо за ответ, хотя чем тогда отличается POPTOPd Unixa от POPTOPd Linuxa?
Почему DI-604 работает с Linux и отказывается работать с Unix?
Интересно, это только мне так повезло, или есть еще счастливчики? :lol:
Если я не один такой, то на коробке надо бы дописать - PPTP client only for Linux. Так наверное было бы правильнее...
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 49
