Текущее время: Ср сен 30, 2026 11:24
 Заголовок сообщения: Не могу установить VPN через DI-704P
СообщениеДобавлено: Ср янв 17, 2007 20:31
Почему некий IP пингуется из LAN, но с ним не могу установить VPN?
Примерная схема такая:
DI-704P подключается на 10.8.0.1 через VPN и получает белый IP
Из сети LAN компьютер пытается на IP 10.8.0.1 тоже установить VPN, но после проверки имени и пароля пишет: Ошибка 619. не удается подключиться к удаленному компьютеру, поэтому порт подключения закрыт.
В логах:
Wednesday January 17, 2007 09:27:30 PPP1: TX IPCP Reguest
Wednesday January 17, 2007 09:27:30 PPP1: RX IPCP Request
Wednesday January 17, 2007 09:27:30 PPP1: RX IPCP ACK
Wednesday January 17, 2007 09:27:32 PPP1: RX LCP Request
Wednesday January 17, 2007 09:27:32 PPP1: TX LCP ACK
Wednesday January 17, 2007 09:27:32 PPP1: TX LCP Request2
Wednesday January 17, 2007 09:27:32 PPP1: RX LCP ACK
Wednesday January 17, 2007 09:27:32 PPP1: RX LCP NAK/REJECT
Wednesday January 17, 2007 09:27:32 CHAP1: Welcome
Wednesday January 17, 2007 09:27:32 PPP1: TX IPCP Reguest
Wednesday January 17, 2007 09:27:32 PPP1: RX IPCP Request
Wednesday January 17, 2007 09:27:32 PPP1: RX IPCP ACK
Wednesday January 17, 2007 09:27:34 PPP1: RX LCP Request
Wednesday January 17, 2007 09:27:34 PPP1: TX LCP ACK
Wednesday January 17, 2007 09:27:34 PPP1: TX LCP Request2
Wednesday January 17, 2007 09:27:33 PPP1: RX LCP Request
Wednesday January 17, 2007 09:27:33 PPP1: TX LCP ACK
Wednesday January 17, 2007 09:27:33 PPP1: RX LCP ACK
Wednesday January 17, 2007 09:27:33 CHAP1: Welcome
Wednesday January 17, 2007 09:27:33 PPP1: TX IPCP Reguest
Wednesday January 17, 2007 09:27:33 PPP1: RX IPCP Request
Wednesday January 17, 2007 09:27:33 PPP1: RX IPCP ACK
Wednesday January 17, 2007 09:27:34 PPP1: RX LCP NAK/REJECT
Wednesday January 17, 2007 09:27:35 PPP1: RX LCP Request
Wednesday January 17, 2007 09:27:36 PPP1: TX LCP ACK
Wednesday January 17, 2007 09:27:36 PPP1: TX LCP Request2
Wednesday January 17, 2007 09:27:36 PPP1: RX LCP Request
Wednesday January 17, 2007 09:27:36 PPP1: RX LCP ACK
Wednesday January 17, 2007 09:27:36 CHAP1: Welcome
и т.д....
 Заголовок сообщения: Re: Не могу установить VPN через DI-704P
СообщениеДобавлено: Ср янв 17, 2007 22:31
А что значит "некий IP"?
на мой дителантский взгяд могут быть две вещи, мешающих установить VPN-соединение
1) несовпадающие настройки (клиента и сервера)
2) невключена VPN Pass-Through (или частично невключена)
Проверьте... ;-) Вдруг это эно? ;-)
Илья.
C уважением,
Илья.
СообщениеДобавлено: Чт янв 18, 2007 07:46
это как раз 10.8.0.1
СообщениеДобавлено: Чт янв 18, 2007 10:05
Узнайте у провайдера не используется ли шифрование. С шифрованием работать не будет.
СообщениеДобавлено: Пт янв 19, 2007 12:25
Не используется..
СообщениеДобавлено: Пн янв 22, 2007 14:29
По логам роутера причину несоединения назвать трудно. Не можете ли Вы привести логи сервера провайдера?
Сейчас этот форум просматривают: Google [Bot] и гости: 179
