Текущее время: Вс ноя 08, 2026 22:28
 Заголовок сообщения: DI-LB604 и Корбина VPN
СообщениеДобавлено: Чт дек 21, 2006 15:48
Удалось кому-нибудь настроить?
Инструкции Корбины и тему про настройку DI-XXX читал, делаю все аналогично (насколько это возможно, т.к. настройка немного отличается от описанных), но соединения нет.
Firmware Version: v.1.01 .03 Built Date: Oct 24 2006
СообщениеДобавлено: Чт дек 21, 2006 17:33
Приведите логи со страницы Status->Log
СообщениеДобавлено: Чт дек 21, 2006 18:04
Message Status: 0 messages send, 28 messages unsent, Page 1
Index Time Priority Module Messages
1 2006/12/21 18:02:33 Info. sntp SNTP request Sent.
2 2006/12/21 18:01:38 Warning pptp/l2tp Cannot connect to a PPTP server on WAN1.
3 2006/12/21 18:00:24 Info. pptp/l2tp Start to connect to a PPTP server on WAN1 now.
4 2006/12/21 18:00:24 Info. pptp/l2tp Close a PPTP session on WAN1 now.
5 2006/12/21 17:59:34 Warning pptp/l2tp Cannot connect to a PPTP server on WAN1.
6 2006/12/21 17:58:19 Info. pptp/l2tp Start to connect to a PPTP server on WAN1 now.
7 2006/12/21 17:58:07 Info. dhcp Receive DHCP ACK : WAN1.
8 2006/12/21 17:58:07 Info. dhcp Send DHCP Request : WAN1.
9 2006/12/21 17:58:07 Info. dhcp Receive DHCP Offer : WAN1.
10 2006/12/21 17:58:07 Info. dhcp Send DHCP Discover : WAN1.
11 2006/12/21 17:57:35 Info. dhcp Send DHCP Discover : WAN1.
12 2006/12/21 17:57:32 Info. sntp Get GMT time from SNTP server.
13 0 00:00:28 Info. sntp SNTP request Sent.
14 0 00:00:24 Warning pptp/l2tp Cable isn't connected or no IP address on WAN1.
15 0 00:00:24 Info. pptp/l2tp Start to connect to a PPTP server on WAN1 now.
16 0 00:00:15 Info. dhcp Send DHCP Discover : WAN1.
17 0 00:00:08 Info. dhcp WAN2 is available via Static IP.(IP:192.168.19.33)
18 0 00:00:07 Info. dhcp Send DHCP Discover : WAN1.
19 0 00:00:03 Info. dhcp Send DHCP Discover : WAN1.
20 0 00:00:02 Info. snmp SNMP agent is active.
21 0 00:00:02 Info. mail SMTP is active.
22 0 00:00:02 Info. mail Send Email Alert (Head Office: System Startup !).
23 0 00:00:02 Info. kernel System is starting. (2101 .03)
24 0 00:00:02 Info. dhcp TFTP server is active.
25 0 00:00:02 Info. snmp SNMP AuthenTraps have been enabled.
26 0 00:00:02 Info. http Web server is active.
27 0 00:00:01 Info. syslog Syslog is active.
28 0 00:00:00 Info. kernel System is starting. (2101 .03)
В поле PPTP Server IP Address : нельзя занести символьное имя vpn.corbina.net, только числа 0-255. Я занес 195.14.38.3, а сейчас обнаружил, что от сессии к сессии этот адрес у Корбины меняется 195.14.38.12 195.14.38.19 195.14.38.20 ....
СообщениеДобавлено: Сб дек 23, 2006 23:19
Методом перебора доступных PPTP Server IP Address и увеличив Echo Time :до 90 сек удалось таки подключить маршрутизатор к VPN Корбины. Подключается крайне не стабильно - где-то раз из пяти. Но на подключенном к нему компьютере доступа в инет нет! Пингуется только маршрутизатор. Вот лог подключения (к WAN2 ничего не подключено)
1 2006/12/23 21:06:26 Info. ppp Send PPP LCP Echo-Reply to WAN1.
2 2006/12/23 21:06:26 Info. ppp Receive PPP LCP Echo-Request from WAN1.
3 2006/12/23 21:06:26 Info. sntp Get GMT time from SNTP server.
4 0 00:01:04 Info. sntp SNTP request Sent.
5 0 00:01:04 Info. ppp WAN1 is available via PPTP.(IP:89.178.125.207)
6 0 00:01:04 Info. ppp Receive PPP IPCP Configure-Ack from WAN1.
7 0 00:01:04 Info. ppp Send PPP IPCP Configure-Request to WAN1.
8 0 00:01:04 Info. ppp Receive PPP IPCP Configure-Nak from WAN1.
9 0 00:01:04 Info. ppp Send PPP IPCP Configure-Ack to WAN1.
10 0 00:01:04 Info. ppp Receive PPP IPCP Configure-Request from WAN1.
11 0 00:01:04 Info. ppp Authentication Successfully on WAN1 !
12 0 00:01:04 Info. ppp Send PPP IPCP Configure-Request to WAN1.
13 0 00:01:04 Info. ppp IPCP is up on WAN1.
14 0 00:01:04 Info. ppp Send PPP PAP/CHAP to WAN1.
15 0 00:01:04 Info. ppp PAP/CHAP is up on WAN1.
16 0 00:01:04 Info. ppp Receive PPP LCP Configure-Ack from WAN1.
17 0 00:01:04 Info. ppp Send PPP LCP Configure-Request to WAN1.
18 0 00:01:04 Info. ppp Receive PPP LCP Configure-Nak from WAN1.
19 0 00:01:04 Info. ppp Send PPP LCP Configure-Ack to WAN1.
20 0 00:01:04 Info. ppp Receive PPP LCP Configure-Request from WAN1.
21 0 00:01:04 Info. ppp Send PPP LCP Configure-Request to WAN1.
22 0 00:01:03 Info. ppp Send PPP LCP Configure-Request to WAN1.
23 0 00:01:03 Info. ppp LCP is up on WAN1.
24 0 00:01:03 Info. pptp/l2tp A PPTP session is established on WAN1.
25 0 00:01:03 Info. pptp/l2tp Receive PPTP Outgoing-Call-Reply to WAN1.
26 0 00:01:03 Info. ppp Send PPP LCP Configure-Request to WAN1.
27 0 00:01:03 Info. ppp LCP is up on WAN1.
28 0 00:01:03 Info. pptp/l2tp A PPTP session is established on WAN1.
29 0 00:01:03 Info. pptp/l2tp Receive PPTP Outgoing-Call-Reply to WAN1.
30 0 00:01:03 Info. pptp/l2tp Send PPTP Outgoing-Call-Request to WAN1.
31 0 00:01:03 Info. pptp/l2tp Receive PPTP Start-Control-Connection-Reply to WAN1.
32 0 00:01:03 Info. pptp/l2tp Send PPTP Start-Control-Connection-Request to WAN1.
33 0 00:01:03 Info. pptp/l2tp Start to connect to a PPTP server on WAN1 now.
34 0 00:01:03 Info. dhcp Receive DHCP ACK : WAN1.
35 0 00:01:03 Info. dhcp Send DHCP Request : WAN1.
36 0 00:01:03 Info. dhcp Receive DHCP Offer : WAN1.
37 0 00:01:03 Info. dhcp Send DHCP Discover : WAN1.
38 0 00:00:31 Info. dhcp Send DHCP Discover : WAN1.
39 0 00:00:15 Info. dhcp Send DHCP Discover : WAN1.
40 0 00:00:07 Info. dhcp Send DHCP Discover : WAN1.
41 0 00:00:03 Info. dhcp Send DHCP Discover : WAN1.
42 0 00:00:02 Info. snmp SNMP agent is active.
43 0 00:00:02 Info. mail SMTP is active.
44 0 00:00:02 Info. mail Send Email Alert (Head Office: System Startup !).
45 0 00:00:02 Info. kernel System is starting. (2101 .03)
46 0 00:00:02 Info. dhcp TFTP server is active.
47 0 00:00:02 Info. snmp SNMP AuthenTraps have been enabled.
48 0 00:00:02 Info. http Web server is active.
49 0 00:00:01 Info. syslog Syslog is active.
50 0 00:00:00 Info. kernel System is starting. (2101 .03)
Маршрутизатор реальный доступ к инету получил (сторока 3).
В какую сторону копать, чтобы его получил и подключенный к нему комп?
Настройки сейчас все дефолтные, ну за исключением WAN, LAN и DHCP(отключен)
СообщениеДобавлено: Пн дек 25, 2006 12:37
Уважаемый Alexandr Zaitsev,
прокомментируйте хоть как-нибудь мою проблему. Есть надежда, что будет работать?
СообщениеДобавлено: Пн дек 25, 2006 13:50
на компах шлюз д.б. = адресу роутера и проверь настройки ДНС
СообщениеДобавлено: Пн дек 25, 2006 15:00
mikhe
Совершенно верно, приведите настройки на сетевых интерфейсах компьютеров.
СообщениеДобавлено: Пн дек 25, 2006 15:38
У маршрутизатора LAN IP 172.16.19.51, этот же адрес прописан в Default gateway и Preferred DNS server на сетевом интерфейсе компьютера (IP 172.16.19.52).
Если убрать PPTP, то в локальную сеть Корбины доступ есть. При подключенном в WAN2 другом провайдере и с хитро-мудро прописанной маршрутизацией все работает: и доступ к обеим локалкам 10.ХХХ, 192.168.ХХХ, инет через WAN2 и VPN с компа через WAN1. Для полного счастья осталось совсем чуть-чуть.
Вопрос к спецам: может галка PPTP Passthrough на доступ влияет?
Приду домой проверю.
СообщениеДобавлено: Вт дек 26, 2006 00:13
Продолжаю пляски с бубном. Галка PPTP Passthrough на доступ не влияет. Но обнаружил, что DNS c компа все-таки рабтает.
ping www.бла-бла-куда-ни-разу-не-ходил. выдает реальный IP и таймаут.
Единственный адрес, который пингуется - это динамический, который мне присваевается 89.178.ХХХ.
СообщениеДобавлено: Вт дек 26, 2006 08:09
Может быть я отстал от жизни, но вроде бы прошивка LB-604 не позволяет работать с Корбина VPN. У меня для этих целей к одному из WAN-ов LB-604 прицеплен DI-604, который с Корбиной работает.
СообщениеДобавлено: Вт дек 26, 2006 10:32
Уважаемые представители техподдержки D-Link могут прокомментировать это сообщение?
Андрей писал(а):
... но вроде бы прошивка LB-604 не позволяет работать с Корбина VPN.
И если это верно, то будет ли в ближайшем будущем работающая прошивка?
СообщениеДобавлено: Чт янв 11, 2007 11:08
Уважаемые представители техподдержки, маршрутизатор по прежнему не работает. Что делать?
СообщениеДобавлено: Чт янв 11, 2007 14:45
Уважаемые представители техподдержки упорно игнорируют ...
Может хотя бы подскажете как доступ по TELNET разрешить?
Подозреваю, что нужно добавить волшебные слова в конфигурационный файл и перезалить?
Или может бета-прошивку какую-нибудь дадите на тестирование?
СообщениеДобавлено: Пт янв 12, 2007 11:22
На этом устройстве есть проблемы с подключением к pptp серверу.
После настройки на странице Home->WAN нужно нажать кнопку Port options и снять там галочку On Demand. После перезагрузки зайти на Status и нажать Connect.
СообщениеДобавлено: Пт янв 12, 2007 14:46
Насколько я помню в LB604 есть еще одна проблема - в качестве адреса pptp-сервера нельзя указать имя (vpn.corbina.net), только ip. Для соединения с Корбиной это вксьма актуально.
Сейчас этот форум просматривают: Baidu [Spider] и гости: 33
