Текущее время: Вс авг 09, 2026 06:32
 Заголовок сообщения: Из внешки не виден виртуал сервер
СообщениеДобавлено: Чт дек 14, 2006 12:39
стоит di 804 , выделенный IP подключен на wan маршрутизатора , на lan подключены 2 компа и сервер , интернет есть только на компах , на сервере нет , сайт на сервере недоступен , виртуал серверы настроили но безтолку .
Вот лог:
WAN Type: Static IP Address (V1.43)
Display time: Thursday December 14, 2006 15:33:51
Thursday December 14, 2006 15:25:17 Blocked access attempt from 82.200.245.235:4394 to TCP port 445
Thursday December 14, 2006 15:25:18 Syn Time: Thu Dec 14 15:25:18 2006
Thursday December 14, 2006 15:25:19 Restarted by 192.168.0.141
Thursday December 14, 2006 15:26:18 Blocked access attempt from 16.150.9.5:31223 to UDP port 1026
Thursday December 14, 2006 15:26:24 Blocked access attempt from 82.200.30.66:2548 to TCP port 445
Thursday December 14, 2006 15:26:27 Blocked access attempt from 82.200.30.66:2548 to TCP port 445
Thursday December 14, 2006 15:27:25 Blocked access attempt from 82.200.152.141:2837 to TCP port 445
Thursday December 14, 2006 15:27:27 Blocked access attempt from 82.200.152.141:2837 to TCP port 445
Thursday December 14, 2006 15:27:49 Blocked access attempt from 82.200.5.125:3264 to TCP port 135
Thursday December 14, 2006 15:27:52 Blocked access attempt from 82.200.5.125:3264 to TCP port 135
Thursday December 14, 2006 15:28:23 Blocked access attempt from 82.200.6.15:4747 to TCP port 139
Thursday December 14, 2006 15:28:24 Blocked access attempt from 82.200.6.15:4747 to TCP port 139
Thursday December 14, 2006 15:28:26 Blocked access attempt from 82.200.6.15:4940 to TCP port 139
Thursday December 14, 2006 15:28:29 Blocked access attempt from 82.200.6.15:4940 to TCP port 139
Thursday December 14, 2006 15:29:08 Blocked access attempt from 82.200.141.58:3530 to TCP port 135
Thursday December 14, 2006 15:29:11 Restarted by 192.168.0.141
ко всему этому сервер интернет не видит
Virtual Server HTTP 192.168.0.100 TCP 80 / 80 always
Virtual Server HTTPS 192.168.0.100 TCP 443 / 443 always
Virtual Server DNS 192.168.0.100 UDP 53 / 53 always
Virtual Server SMTP 192.168.0.100 TCP 25 / 25 always
Virtual Server POP3 192.168.0.100 TCP 110 / 110 always
Firmware Version: V1.43, Thu, Jan 26 2006
LAN
MAC Address 00-0F-3D-21-73-BF
IP Address 192.168.0.1
Subnet Mask 255.255.255.0
DHCP Server Enabled
WAN
MAC Address 00-0F-3D-21-73-BE
Connection Static IP
IP Address 82.200.17.53
Subnet Mask 255.255.255.128
Gateway 82.200.17.1
Domain Name Server 82.200.17.1
Allow Virtual Server SMTP WAN,* LAN,192.168.0.100 TCP,25
Allow Virtual Server HTTP WAN,* LAN,192.168.0.100 TCP,80
Allow Virtual Server HTTPS WAN,* LAN,192.168.0.100 TCP,443
Allow Virtual Server DNS WAN,* LAN,192.168.0.100 UDP,53
Allow Virtual Server POP3 WAN,* LAN,192.168.0.100 TCP,110
Allow Virtual Server FTP WAN,* LAN,192.168.0.100 TCP,21
СообщениеДобавлено: Чт дек 14, 2006 16:03
Виртуальные серверы тут ни при чем. У Вас видимо что-то не так с настройками "сервера"
Шлюз на "сервере" прописан?
СообщениеДобавлено: Пт дек 15, 2006 07:47
Это тот IP, который на wan маршрутизатора, если да, то прописан -результат тотже
СообщениеДобавлено: Пт дек 15, 2006 10:42
Никак не WAN, а LAN
СообщениеДобавлено: Пт дек 15, 2006 17:20
Спасибо за советы ,
500 рублей и нет проблем :lol: :lol: :lol:
Сейчас этот форум просматривают: Google [Bot] и гости: 16
