Текущее время: Сб окт 31, 2026 04:59
 Заголовок сообщения: DI-604 интернет стал медленнее
СообщениеДобавлено: Вт окт 17, 2006 13:47
Настройки по дефолту
при закачки файлов на фтп лог выглядит так:
WAN Type: Dynamic IP Address (V3.14)
Display time: Tuesday October 17, 2006 02:45:49
Monday October 16, 2006 23:44:47 Unrecognized attempt blocked from 212.122.94.225:50865 to 84.32.49.45 TCP:113
Monday October 16, 2006 23:44:54 Unrecognized attempt blocked from 212.122.94.225:50865 to 84.32.49.45 TCP:113
Monday October 16, 2006 23:45:06 Unrecognized attempt blocked from 212.122.94.225:50865 to 84.32.49.45 TCP:113
Monday October 16, 2006 23:45:22 Unrecognized attempt blocked from 84.32.48.138:3060 to 84.32.49.45 TCP:445
Monday October 16, 2006 23:45:24 Unrecognized attempt blocked from 84.32.48.138:3207 to 84.32.49.45 TCP:135
Monday October 16, 2006 23:45:33 Unrecognized attempt blocked from 202.97.238.203:53398 to 84.32.49.45 UDP:1026
Monday October 16, 2006 23:48:36 Unrecognized attempt blocked from 221.208.208.98:39414 to 84.32.49.45 UDP:1026
Monday October 16, 2006 23:48:36 Unrecognized attempt blocked from 221.208.208.98:39414 to 84.32.49.45 UDP:1027
Monday October 16, 2006 23:55:50 Unrecognized attempt blocked from 221.208.208.89:53588 to 84.32.49.45 UDP:1027
Monday October 16, 2006 23:55:59 Unrecognized attempt blocked from 60.11.125.55:45466 to 84.32.49.45 UDP:1026
в чём может быть проблема?
СообщениеДобавлено: Вт окт 17, 2006 15:34
Как то условия непонятны, где находится ФТП сервер, откуда на него льют поток, какие адреса у внутреннего и внешнего интерфейсов и соотв подсети ... :roll:
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 39
