Текущее время: Ср окт 28, 2026 06:49
СообщениеДобавлено: Пн май 17, 2004 15:10
Доброго времени суток, дорогие друзья,
есть проблема: В рамках сети -
fax1--fxs--DG-104SH---eth---cisco5350---e1---PBX---fax2
Прошивки D-link - 20, 53
CiscoIOS 12.3(6)
Настройка D-link
>show h323
h323 display_name = 'DG-104SH'
h323 h323_ID = 'DEFAULT_H323_ID'
h323 h245_term_type = 60
h323 endpoint_reg_type = gw
h323 rtp_port_base = 30000
h323 rtp_tos = 8
h323 ras_tos = 4
h323 h225h245_tos = 4
h323 fast_start = on
h323 t38 = on
h323 t38_req_initiater = callee
h323 gk_mode = auto
h323 gk_addr = auto
h323 gk_identifier = ''
h323 keepalive_to_gk = off
h323 keepalive_interval = 120
h323 gk_max_fails = 3
h323 gk_rsp_timeout = 5
h323 no_ans_callfwd_time = 10
h323 h235_token = off
h323 h235_token_password =
h323 aliases (E.164) =
3076
факсы по протоколу t38 ходят в одну сторону :
fax1-->fax2 успешно
fax2-->fax1 неуспешно
Соединение заваливается с такими логами:
ggdbg>
ggdbg>000222299 HSMU 3: CallingPartyId = "TA:10.1.42.31:11619,NAME:Sev-GW53,5014984045"
000222299 HSMU 3: Remote caller ID number = 5014984045
000222299 HSMU 3: UserUserInfo = "5014984045"
000222299 HSMU 3: remote CID number:"5014984045", name:"O"
000222299 HSMU 3: received H323 call, processing ...
000222302 HSMU: Enter call_profile->capabilities
000222302 HSMU: t.38 codec found at profile 6
000222302 HSMU: Exit call_profile->capabilities.
000222302 HSMU 3: set timer for 30000 in state hsmup_state_h245_wait_complete
000222322 HSMU 3: Starting Capabilities Exchange, capabilities_send=0
000222322 HSMU 3: Sending local capabilities.
000222322 HSMU: h323_get_static_cap_name capability name "t38fax"
000222322 HSMU: h323_get_static_cap_name capability name "nonStandard"
000222322 HSMU: h323_get_static_cap_name NOT FOUND!
000222322 HSMU: Invalid capability name "hookflash"
000222322 HSMU: Invalid capability name "dtmf"
000222322 HSMU: Invalid capability name "basicString"
000222322 HSMU: h323_get_static_cap_name capability name "g729AnnexA"
000222322 HSMU: h323_get_static_cap_name capability name "g729"
000222322
000222322 Capability Set
000222322 Local capability codec "g711Ulaw64k".
000222322 Remote capability codec "t38fax".
000222322 Remote capability codec "nonStandard".
000222322 Remote capability codec "UnknownCapability".
000222322 Remote capability codec "g729AnnexA".
000222322 Remote capability codec "g729".
000222322 Local capability codec "g711Alaw64k".
000222323 Remote capability codec "UnknownCapability".
000222323 Remote capability codec "g729AnnexA".
000222348 HSMU 3: cmEvCallMasterSlaveStatus_msg: Local station is Slave
000222348 HSMU 3: cmControlStateConnected, p_call->fast_start_on=0
000222349 HSMU 3: Slave mode, waiting for Logical Channel opening.
000222349 HSMU 3: abort timer in state hsmup_state_h245_wait_complete
000222349 HSMU 3: set timer for 10000 in state hsmup_state_slave_wait_open_in_lc
000222349 HSMU 3: Chan 0i cmEvChannelSetRTCPAddress_msg IP = 10.1.42.31, Port = 16453
000222349 HSMU 3: Chan 0i - slave offering channel "g729"
000222349 Match found with element 4
000222349 hsmup_slave_incoming_lc: nw_open(RTP1), call_num=3 , port=30006, chan_num(i/o)=0i
000222349 HSMU 3: Chan 0i: Opened RTP socket = 1, cmChannel = 30006
000222349 hsmup_slave_incoming_lc: nw_open(RTCP2), call_num=3 , port=30007, chan_num(i/o)=0i
000222349 HSMU 3: Chan 0i: Opened RTCP socket = 2, port 30007
000222349 HSMU 3: selected codec name=g729AnnexA, selected profile=5, slave
000222349 HSMU 3: Chan 0i - cmChannelStateConnected "g729AnnexA"
local RTCP = 30007, remote RTCP =16453, RTP = 10.1.41.211:30006
000222349 HSMU 3: Chan 0o - hsmup_open_channel() codec = "g729AnnexA", p_assoc_chan=0x424a1b,chanal name =" "
000222349 HSMU 3: abort timer in state hsmup_state_slave_wait_open_in_lc
000222368 HSMU 3: Chan 0o cmEvChannelSetRTCPAddress_msg IP = 10.1.42.31, Port = 16453
000222369 HSMU 3: Chan 0o cmEvChannelSetAddress_msg IP = 10.1.42.31, Port = 16452
000222369 HSMU 3: Chan 0o - cmChannelStateConnected "g729AnnexA"
local RTCP = 30007, remote RTCP =16453, RTP = 10.1.42.31:16452
000222369 HSMU 3: VOICE CONNECTED, coding=g729AnnexA, mode=Slave
000222369 HSMU 3: set timer for 30000 in state hsmup_state_voice_connected
000224507 HSMU 3: abort timer in state hsmup_state_voice_connected
000224507 HSMU 3: set timer for 30000 in state hsmup_state_voice_connected
000224508 HSMU 3: abort timer in state hsmup_state_voice_connected
000224508 HSMU 3: set timer for 30000 in state hsmup_state_voice_connected
000224566 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=7f
000224791 HSMU 3: abort timer in state hsmup_state_voice_connected
000224791 HSMU 3: hsmup_codec_on_calling_by_pcall, codec_name="t38fax"
000224791 NWIF: send_datagram() - could not send a UDP packet: no listening connection.
000224791 HSMU 3: request mode "accept"
000224791 HSMU 3: recv cmReqModeAccept Chan 1213486160i old name="g729AnnexA", new name="t38fax"
000224791 HSMU 3: set timer for 10000 in state hsmup_state_fax_channel
000224791 HSMU: h323_get_static_cap_name capability name "t38fax"
000224791 HSMU 3: Chan 1i cmEvChannelSetRTCPAddress_msg IP = 10.1.42.31, Port = 16453
000224791 HSMU 3: Chan 1i - slave offering channel "t38fax"
000224791 Match found with element 5
000224791 hsmup_slave_incoming_lc: nw_open(RTP4), call_num=3 , port=30006, chan_num(i/o)=1i
000224792 HSMU 3: Chan 1i: Opened RTP socket = 4, cmChannel = 30006
000224792 hsmup_slave_incoming_lc: nw_open(RTCP3), call_num=3 , port=30007, chan_num(i/o)=1i
000224792 HSMU 3: Chan 1i: Opened RTCP socket = 3, port 30007
000224792 HSMU 3: selected codec name=t38fax, selected profile=6, slave
000224792 HSMU 3: Chan 1i - cmChannelStateConnected "t38fax"
000224792 HSMU 3: Chan 1o - hsmup_open_channel() codec = "t38fax", p_assoc_chan=0x424a83,chanal name =" "
000224792 HSMU: h323_get_static_cap_name capability name "t38fax"
000224792 HSMU 3: Chan 1o cmEvChannelSetRTCPAddress_msg IP = 10.1.42.31, Port = 16453
000224792 HSMU 3: Chan 1o cmEvChannelSetAddress_msg IP = 10.1.42.31, Port = 16452
000224792 HSMU 3: Chan 1o - cmChannelStateConnected "t38fax"
000224792 HSMU 3: abort timer in state hsmup_state_fax_channel
000224792 HSMU 3: VOICE CONNECTED, coding=t38fax, mode=Slave
000224792 HSMU 3: set timer for 30000 in state hsmup_state_voice_connected
000227791 HSMU 3: timer triggered in state hsmup_state_voice_connected
000227791 HSMU 3: abort timer in state hsmup_state_voice_connected
000227791 HSMU 3: set timer for 30000 in state hsmup_state_voice_connected
000229785 HSMU 3: abort timer in state hsmup_state_voice_connected
000229785 HSMU 3: cmCallDropParam(p_call=0x42421e, h323_release_reason=11)
000229785 HSMU: h323_get_static_cap_name capability name "t38fax"
000229837 HSMU 3: voice rtp open=0, rtcp open=0, nw_close(voice socked RTP0, RTCP0)
000229837 HSMU 3: nw_close(inchan local RTCP2, RTP1)
000229837 HSMU 3: nw_close(inchan local RTCP3, RTP4)
000229837 HSMU 3: nw_close(inchan local RTCP65535, RTP65535)
000229837 HSMU 3: nw_close(outchan local RTCP65535)
000229838 HSMU 3: nw_close(outchan local RTCP65535)
Вот что известно об этом звонке Циске:
Sev-GW53-1#SH CALL ACT VOI
Telephony call-legs: 0
SIP call-legs: 0
H323 call-legs: 1
MGCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 1
GENERIC:
SetupTime=1568119730 ms
Index=2
PeerAddress=3076
PeerSubAddress=
PeerId=3076
PeerIfIndex=137
LogicalIfIndex=0
ConnectTime=156814193
CallDuration=00:00:34 sec
CallState=4
CallOrigin=1
ChargedUnits=0
InfoType=fax
TransmitPackets=456
TransmitBytes=6064
ReceivePackets=953
ReceiveBytes=23890
VOIP:
ConnectionId[0x3E48B313 0xA72C11D8 0x86378681 0x89ADF8AF]
IncomingConnectionId[0x3E48B313 0xA72C11D8 0x86378681 0x89ADF8AF]
RemoteIPAddress=10.1.41.211
RemoteUDPPort=30006
RemoteSignallingIPAddress=10.1.41.211
RemoteSignallingPort=1720
RemoteMediaIPAddress=10.1.41.211
RemoteMediaPort=30006
RoundTripDelay=0 ms
SelectedQoS=best-effort
tx_DtmfRelay=inband-voice
FastConnect=FALSE
AnnexE=FALSE
Separate H245 Connection=TRUE
H245 Tunneling=FALSE
SessionProtocol=cisco
ProtocolCallId=
SessionTarget=ipv4:10.1.41.211
OnTimeRvPlayout=6000
GapFillWithSilence=0 ms
GapFillWithPrediction=0 ms
GapFillWithInterpolation=0 ms
GapFillWithRedundancy=0 ms
HiWaterPlayoutDelay=80 ms
LoWaterPlayoutDelay=80 ms
TxPakNumber=441
TxSignalPak=0
TxComfortNoisePak=0
TxDuration=11028
TxVoiceDuration=0
RxPakNumber=2
RxSignalPak=0
RxDuration=10
TxVoiceDuration=22260
VoiceRxDuration=6000
RxOutOfSeq=0
RxLatePak=0
RxEarlyPak=0
PlayDelayCurrent=80
PlayDelayMin=80
PlayDelayMax=80
PlayDelayClockOffset=177243621
PlayDelayJitter=0
PlayErrPredictive=0
PlayErrInterpolative=0
PlayErrSilence=0
PlayErrBufferOverFlow=0
PlayErrRetroactive=0
PlayErrTalkspurt=0
OutSignalLevel=0
InSignalLevel=0
LevelTxPowerMean=0
LevelRxPowerMean=0
LevelBgNoise=0
ERLLevel=0
ACOMLevel=0
ErrRxDrop=0
ErrTxDrop=0
ErrTxControl=0
ErrRxControl=0
ReceiveDelay=80 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = enabled
CoderTypeRate=t38
CodecBytes=40
Media Setting=flow-through
AlertTimepoint=1568119980 ms
CallerName=
CallerIDBlocked=False
OriginalCallingNumber=5014984045
OriginalCallingOctet=0x21
OriginalCalledNumber=3076
OriginalCalledOctet=0x81
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0xFF
TranslatedCallingNumber=5014984045
TranslatedCallingOctet=0x21
TranslatedCalledNumber=3076
TranslatedCalledOctet=0x81
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0xFF
GwReceivedCalledNumber=3076
GwReceivedCalledOctet3=0x81
GwOutpulsedCalledNumber=3076
GwOutpulsedCalledOctet3=0x81
GwReceivedCallingNumber=5014984045
GwReceivedCallingOctet3=0x21
GwReceivedCallingOctet3a=0x80
GwOutpulsedCallingNumber=5014984045
GwOutpulsedCallingOctet3=0x21
GwOutpulsedCallingOctet3a=0x80
Username=
FaxRelayMaxJitterBufDepth = 0 ms
FaxRelayJitterBufOverFlow = 0
FaxRelayHSmodulation = 0
FaxRelayNumberOfPages = 0
SIP call-legs: 0
H323 call-legs: 1
MGCP call-legs: 0
Total call-legs: 1
Прошу дать разъяснение, какие настройки сделаны неверно, чего не хватает D-Link у
Соединение рвется
Cause i = 0x8190 - Normal call clearing
Заранее благодарен всем ответившим.
Петр Акимов
СообщениеДобавлено: Пн май 17, 2004 19:20
Вопрос снимается , я поторопился.
Как оказалось, кривенький аппарат (W2K+Xircom faxmodem) умеет отправлять, а принимает плохо. Заменив его заведомо исправным , все заработало.
Настройки D-link:
Country code: Sweden
Term. type 40
Fast start on
set h323 t38 on
set h323 t38_req_initiater callee
set coding 6 fax_tcf_method 2
set coding 6 fax_t30_features ecmon
set coding 6 vad off
commit
Конфигурация Cisco5350:
voice service pots
fax prot t38 ls-red 5 hs-red 2
voice service voip
voice class h323 1
h245 caps mode restricted
dialpeer voice 666 voip
desc DLINK
voice-class h323 1
no vad
session target ??
destination-pattern ??
СообщениеДобавлено: Вт май 18, 2004 12:20
Настройки D-link:
Term. type 40
Fast start on
set h323 t38 on
commit
voice service pots
voice service voip
voice class h323 1
desc DLINK
voice-class h323 1
no vad
session target ??
За что??? :)
С уважением, Дмитрий Письменов
СообщениеДобавлено: Вт май 18, 2004 12:57
Вы верите в мистику, Дмитрий? Правильно делаете. Раньше я думал, что машины не могут лгать, не умеют: они либо работают либо нет. Теперь же, познакомившись с D-link, я все больше убеждаюсь в обратном. :wink:
СообщениеДобавлено: Вт май 18, 2004 14:27
Ну при чем же тут Д-Линк? Если у Вас проблема решишась сменой факсового аппарата? :)
СообщениеДобавлено: Вт май 18, 2004 17:56
не тот ли Вы Аким, которого я знавал по известному зданию на ул. Волгина?
СообщениеДобавлено: Вт май 18, 2004 20:47
2 skantere: Если Вы про Гурьянова и Каширку, то да, это мы, на Волгина - это пока только проект. Кстати откуда Вам известны эти данные?
[/quote]
СообщениеДобавлено: Вт май 18, 2004 21:00
Вот подходящий ответ из нашего форума:
Виктор Колосов писал(а):
Как я уже говорил выше, проблема не в NAT ... Установить два одинаковых случая зависания не возможно, в этом и состоит проблема.
У нас в оффисе повесить устройство не удается.
Пока разбираемся.
Виктор Колосов
СообщениеДобавлено: Ср май 19, 2004 09:09
Модератор
Модератор
Пока разбираемся.
Виктор Колосов
Это абсолютно не относиться к факсам ...
Виктор Колосов
