Текущее время: Чт июн 18, 2026 14:52
 Заголовок сообщения: и опять мультикаст
СообщениеДобавлено: Вс сен 24, 2006 11:27
config limited multicast address 1 from 230.10.10.10 to 230.10.10.10 access permit state enable
config limited multicast address 2 from 230.10.10.10 to 230.10.10.10 access permit state enable
config limited multicast address 3 from 230.10.10.10 to 230.10.10.10 access permit state enable
config limited multicast address 4 from 230.10.10.10 to 230.10.10.10 access permit state enable
config limited multicast address 5 from 230.10.10.10 to 230.10.10.10 access deny state enable
config limited multicast address 6 from 230.10.10.10 to 230.10.10.10 access permit state enable
config limited multicast address 7 from 230.10.10.10 to 230.10.10.10 access permit state enable
config limited multicast address 8 from 230.10.10.10 to 230.10.10.10 access permit state enable
config limited multicast address 9 from 230.10.10.10 to 230.10.10.10 access permit state enable
config limited multicast address 10 from 230.10.10.10 to 230.10.10.10 access permit state enable
config limited multicast address 11 from 230.10.10.10 to 230.10.10.10 access permit state enable
config limited multicast address 12 from 230.10.10.10 to 230.10.10.10 access permit state enable
config limited multicast address 13 from 230.10.10.10 to 230.10.10.10 access permit state enable
config limited multicast address 14 from 230.10.10.10 to 230.10.10.10 access permit state enable
config limited multicast address 15 from 230.10.10.10 to 230.10.10.10 access permit state enable
config limited multicast address 16 from 230.10.10.10 to 230.10.10.10 access permit state enable
config limited multicast address 17 from 230.10.10.10 to 230.10.10.10 access permit state enable
config limited multicast address 18 from 230.10.10.10 to 230.10.10.10 access deny state enable
config limited multicast address 19 from 230.10.10.10 to 230.10.10.10 access permit state enable
config limited multicast address 20 from 230.10.10.10 to 230.10.10.10 access deny state enable
config limited multicast address 21 from 230.10.10.10 to 230.10.10.10 access deny state enable
config limited multicast address 22 from 230.10.10.10 to 230.10.10.10 access deny state enable
config limited multicast address 23 from 230.10.10.10 to 230.10.10.10 access deny state enable
config limited multicast address 24 from 230.10.10.10 to 230.10.10.10 access deny state enable
config limited multicast address 25 from 230.10.10.10 to 230.10.10.10 access permit state enable
config limited multicast address 26 from 230.10.10.10 to 230.10.10.10 access permit state enable
enable igmp_snooping
config igmp_snooping default host_timeout 260 router_timeout 260 leave_timer 2 state enable
config igmp_snooping querier default query_interval 125 max_response_time 10 robustness_variable 2
config igmp_snooping querier default last_member_query_interval 1 state enable
вот такие настройки
порты 18 20 22 24 включены в транк с 1226G
поидее на них запрещен поток мультикаста
но как только любой клиент с разрешенных портов запрашивает поток, то этот поток заодно прет на 1226G и соответсвенно с него на все компы.
Что я не так сделал?
СообщениеДобавлено: Пн сен 25, 2006 10:05
Настройки Router Ports посмотрите.
СообщениеДобавлено: Пн сен 25, 2006 13:56
я Вам на почту письмо со скрином и полным конфигом отправил.
Тема - 3526 мультикаст
возможно я простот что-то намудрил...
Буду очень признателен за помощь
СообщениеДобавлено: Пн сен 25, 2006 14:10
Я Вам по почте ответил.
СообщениеДобавлено: Пн сен 25, 2006 14:35
ОГРОМНОЕ СПАСИБО - помогло!
СообщениеДобавлено: Пн сен 25, 2006 22:15
еще один вопросик
после того как клиент перестал запрашивать мультикаст проходит не меньше 3 минут и только тогда поток прекращается, хотелось бы что бы сразу прекращался поток, в старых версиях прошивок было намного меньше это время.
дело в том что у меня несколько мультикаст групп ( IPTV )
в каждой группе идет несколько каналов, и например клиент запросил первую группу, посмотрел, выключил и сразу включил вторую, то к нему уже идут два потока, а это уже около 40 мегабит. Не всякая сетевая или комп справляется с такой нагрузкой, видео начинает тормозить, а если дождаться тех 3 минут, когда первый отвалится, то все ок.
СообщениеДобавлено: Вт сен 26, 2006 11:00
А как же нам, читающим форум, увидеть это решение!? Опять Вам писать?
СообщениеДобавлено: Вт сен 26, 2006 13:24
там в транке 4 порта было и в Router Ports надо было включить мастер-порт транка, в моем случае это был 18 порт.
плиз на второй вопрос о времени отключения ответьте....
СообщениеДобавлено: Вт сен 26, 2006 15:27
kazakru писал(а):
еще один вопросик
Там вроде таймауты есть и в новой прошивке обещали, что будут работать.
СообщениеДобавлено: Вт сен 26, 2006 16:02
У Вас IGMP Snooping параметр Leave Timer какое значение стоит?
СообщениеДобавлено: Вт сен 26, 2006 19:14
по умолчанию 2 стояло, поставил 1 все равно через 3,5 минуты только отвалилось
вот если побаловаться с Host Timeout ( по умолчанию 260 ) то при 50 отрубается через 30 сек, но если меньше ставить то поток срывается или вообще не идет.
СообщениеДобавлено: Ср сен 27, 2006 09:30
У Вас IGMP Snooping настроена в соответствии с FAQ? http://www.dlink.ru/technical/faq_hub_switch_54.php
СообщениеДобавлено: Ср сен 27, 2006 13:28
ну в начале поста конфиг приведен, можно только добавить еще
к нему
# FDB
config fdb aging_time 300
config multicast port_filtering_mode 1-26 filter_unregistered_groups
Сейчас этот форум просматривают: Google [Bot] и гости: 13
