Текущее время: Ср ноя 04, 2026 22:01
СообщениеДобавлено: Сб сен 09, 2006 15:47
Здравствуйте, у меня такая проблема. Роутер DI-604, прошивка 3.14, подключен к сети Корбина Телеком. После месяца работы роутер перестал подключаться по PPTP. При попытке подключения в окне Status при подключении к сети выводятся следующие:
IP Address: 10.65.17.28
Connection Time: -
Subnet Mask: 255.255.0.0
Gateway: 10.65.0.17
Domain Net Server: 195.14.50.1, 195.14.50.21
Лог подключения слудющий:
Thursday December 15, 2005 00:09:34 DOD:triggered internally
Thursday December 15, 2005 00:09:34 start to dial-up
Thursday December 15, 2005 00:09:34 DHCP:discover()
Thursday December 15, 2005 00:09:34 DHCP:offer(10.65.0.17)
Thursday December 15, 2005 00:09:34 DHCP:request(10.65.17.28)
Thursday December 15, 2005 00:09:34 DHCP:decline?
Thursday December 15, 2005 00:09:34 DHCP:ack(DOL=604800,T1=302400,T2=529200)
Thursday December 15, 2005 00:09:50 Unrecognized attempt blocked from 195.14.40.6:1723 to 10.65.17.28 TCP:1856
Thursday December 15, 2005 00:09:58 Unrecognized attempt blocked from 10.65.17.10:3800 to 10.65.17.28 TCP:135
Thursday December 15, 2005 00:10:01 Unrecognized attempt blocked from 10.65.17.10:3800 to 10.65.17.28 TCP:135
Thursday December 15, 2005 00:10:04 Unrecognized attempt blocked from 10.65.17.10:3885 to 10.65.17.28 TCP:445
Thursday December 15, 2005 00:10:07 Unrecognized attempt blocked from 10.65.17.10:3885 to 10.65.17.28 TCP:445
Thursday December 15, 2005 00:10:13 Unrecognized attempt blocked from 195.14.40.6:1723 to 10.65.17.28 TCP:1756
Thursday December 15, 2005 00:10:13 Unrecognized attempt blocked from 10.65.17.10:3885 to 10.65.17.28 TCP:445
Thursday December 15, 2005 00:10:54 Unrecognized attempt blocked from 195.14.40.6:1723 to 10.65.17.28 TCP:1856
Thursday December 15, 2005 00:10:56 PPTP:PNS=10.65.0.17
Thursday December 15, 2005 00:11:17 Unrecognized attempt blocked from 195.14.40.6:1723 to 10.65.17.28 TCP:1756
Thursday December 15, 2005 00:11:16 Unrecognized attempt blocked from 195.14.40.6:1723 to 10.65.17.28 TCP:1756
Thursday December 15, 2005 00:11:59 PPTP:error=-112
После минутных попыток подключения все оканчивается неудачей.
Если после этого сбросить роутер к заводским настройкам кнопкой Reset to Defaults, то роутер нормально подключается.
В окне Status при подключении к сети выводятся следующие:
IP Address: 89.178.78.1
Connection Time: 00:02:42
Subnet Mask: 255.255.255.255
Gateway: 89.178.78.1
Domain Name Server: 213.234.192.7, 195.14.50.1
Saturday September 09, 2006 04:31:11 start to dial-up
Saturday September 09, 2006 04:31:11 DHCP:discover()
Saturday September 09, 2006 04:31:11 DHCP:offer(10.65.0.17)
Saturday September 09, 2006 04:31:11 DHCP:request(10.65.17.28)
Saturday September 09, 2006 04:31:11 DHCP:decline?
Saturday September 09, 2006 04:31:11 DHCP:ack(DOL=604800,T1=302400,T2=529200)
Saturday September 09, 2006 04:31:11 PPTP:PNS=195.14.40.7
Saturday September 09, 2006 04:31:14 PPP1: TX LCP Request
Saturday September 09, 2006 04:31:14 PPP1: RX LCP Request
Saturday September 09, 2006 04:31:14 PPP1: TX LCP ACK
Saturday September 09, 2006 04:31:14 PPP1: RX LCP NAK/REJECT
Saturday September 09, 2006 04:31:14 PPP1: TX LCP Request2
Saturday September 09, 2006 04:31:14 PPP1: RX LCP ACK
Saturday September 09, 2006 04:31:14 MSCHAP1: OK
Saturday September 09, 2006 04:31:14 PPP1: RX IPCP Request
Saturday September 09, 2006 04:31:14 PPP1: TX IPCP Reguest
Saturday September 09, 2006 04:31:14 PPP1: RX IPCP NACK/REJECT
Saturday September 09, 2006 04:31:14 IPCP1: IP is 89.178.78.1
Saturday September 09, 2006 04:31:14 IPCP1: DNS0 is 213.234.192.7
Saturday September 09, 2006 04:31:14 IPCP1: DNS1 is 195.14.50.1
Saturday September 09, 2006 04:31:14 PPP1: RX IPCP ACK
Saturday September 09, 2006 04:31:17 Syn time: Sat Sep 09 04:31:17 2006
Saturday September 09, 2006 04:31:28 Unrecognized attempt blocked from 195.14.40.6:1723 to 10.65.17.28 TCP:1856
Saturday September 09, 2006 04:31:40 Unrecognized attempt blocked from 210.146.187.97:1027 to 89.178.78.1 UDP:137
Saturday September 09, 2006 04:31:51 Unrecognized attempt blocked from 195.14.40.6:1723 to 10.65.17.28 TCP:1756
Saturday September 09, 2006 04:32:32 Unrecognized attempt blocked from 10.65.17.10:1041 to 10.65.17.28 TCP:135
Saturday September 09, 2006 04:32:32 Unrecognized attempt blocked from 195.14.40.6:1723 to 10.65.17.28 TCP:1856
Если после этого поковыряться в настройках роутера то при последующих попытках подключения подключаться он отказывается!
Параметры ipconfig /all:
Microsoft Windows XP [Версия 5.1.2600]
(С) Корпорация Майкрософт, 1985-2001.
C:\Documents and Settings\Алексей.ABYSMO>ipconfig /all
Настройка протокола IP для Windows
Имя компьютера . . . . . . . . . : Abysmo
Основной DNS-суффикс . . . . . . :
Тип узла. . . . . . . . . . . . . : широковещательный
IP-маршрутизация включена . . . . : нет
WINS-прокси включен . . . . . . . : нет
Порядок просмотра суффиксов DNS . : corbina.net
Подключение по локальной сети - Ethernet адаптер:
DNS-суффикс этого подключения . . : corbina.net
Описание . . . . . . . . . . . . : VIA PCI 10/100Mb Fast Ethernet адап
тер
Физический адрес. . . . . . . . . : 00-04-61-5F-C7-6B
Dhcp включен. . . . . . . . . . . : да
Автонастройка включена . . . . . : да
IP-адрес . . . . . . . . . . . . : 192.168.0.100
Маска подсети . . . . . . . . . . : 255.255.255.0
Основной шлюз . . . . . . . . . . : 192.168.0.1
DHCP-сервер . . . . . . . . . . . : 192.168.0.1
DNS-серверы . . . . . . . . . . . : 213.234.192.7
195.14.50.1
Аренда получена . . . . . . . . . : 9 сентября 2006 г. 16:32:10
Аренда истекает . . . . . . . . . : 16 сентября 2006 г. 16:32:10
ПОМОГИТЕ РАЗОБРАТЬСЯ В ПРОБЛЕМЕ!
СообщениеДобавлено: Вс сен 10, 2006 19:07
Up
СообщениеДобавлено: Пн сен 11, 2006 10:20
Сервер не отвечает по какой-то причине, именно так определяется ошибка -112
СообщениеДобавлено: Пн сен 11, 2006 19:56
Если интересно, после отключения вкладок в rtab глюк пропал.
СообщениеДобавлено: Вт сен 12, 2006 11:29
Интересно!
Спасибо за информацию.
Сейчас этот форум просматривают: Baidu [Spider] и гости: 116
